kot654 Posted May 16, 2011 Posted May 16, 2011 есть маршрутизатор cisco настроил все но почемуто впн на циске не подключается. вот конфиг что нитак сделал то? Using 2023 out of 29688 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption service internal ! hostname Router ! boot-start-marker boot-end-marker ! logging buffered 4096 debugging ! no aaa new-model no ip gratuitous-arps ip cef ! ! no ip dhcp use vrf connected ! ip dhcp pool lan network 10.1.1.0 255.255.255.0 default-router 10.1.1.1 dns-server 10.2.2.2 ! ! ip multicast-routing ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 vpdn enable ! vpdn-group 1 request-dialin protocol pptp rotary-group 0 initiate-to ip 10.100.100.3 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface FastEthernet0 ip address 192.168.62.21 255.255.255.0 ip nat outside ip virtual-reassembly ip tcp adjust-mss 1450 duplex auto speed auto ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface Vlan1 ip address 10.1.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1450 ! interface Dialer0 mtu 1450 ip address negotiated ip pim dense-mode encapsulation ppp ip tcp adjust-mss 1400 dialer in-band dialer idle-timeout 0 dialer string 123 dialer vpdn dialer-group 1 no cdp enable ppp pfc local request ppp pfc remote apply ppp encrypt mppe 40 ppp authentication chap callin ppp chap hostname xxxxxxx ppp chap password 0 xxxxxx ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.62.1 ip route 0.0.0.0 0.0.0.0 Dialer0 ip route 10.100.100.3 255.255.255.255 FastEthernet0 ! ! no ip http server no ip http secure-server ip nat translation timeout 600 ip nat translation tcp-timeout 600 ip nat translation max-entries 5000 ip nat inside source list 1 interface FastEthernet0 overload ! access-list 1 permit 10.1.1.0 0.0.0.255 dialer-list 1 protocol ip permit ! ! ! control-plane ! ! ! ! mgcp behavior g729-variants static-pt ! ! ! ! ! line con 0 line aux 0 line vty 0 4 login ! end Вставить ник Quote
kot654 Posted May 16, 2011 Author Posted May 16, 2011 какая информация нужна? есть cisco 1712 + провайдер который раздает инет через впн, нужно раздать инет на свит циски. что еще нужно спрашивайте Вставить ник Quote
Ivan Rostovikov Posted May 16, 2011 Posted May 16, 2011 Откройте для себя команду "debug" !!! Вставить ник Quote
kot654 Posted May 16, 2011 Author Posted May 16, 2011 я если чесно новичек в цисках. можно поподробнее Вставить ник Quote
Ivan Rostovikov Posted May 16, 2011 Posted May 16, 2011 Если новичек - попробуйте воспользоваться веб-интерфейсом. Объяснить подробно - нелегко. conf t logging monitor logging on exit Это настройка логирования в терминальную сессию. terminal monitor Это указывает, что именно в Вашу сессию надо логировать. debug ppp ? Это указывает, что нужно выводить отладочную информацию. И какую. Вставить ник Quote
kot654 Posted May 16, 2011 Author Posted May 16, 2011 веб интерфейса на моей циске, нет старенькая она, дебаг попробую. Вставить ник Quote
kot654 Posted May 16, 2011 Author Posted May 16, 2011 вообщем впн начал стартовать, проблема была тупо в обжимке провода пережал на перекрестную и впн поднялся, но сейчас он постоянно отваливается примерно раз в 1 минуту Вставить ник Quote
kot654 Posted May 25, 2011 Author Posted May 25, 2011 вообщем разобрался с впн он теперь работает стабильно, настроил нат, но он почему то не работает, непойму почему. Гляньте конфиг Using 1521 out of 29688 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption service internal ! hostname Router ! boot-start-marker boot-end-marker ! ! no aaa new-model ip cef ! ! ! ! ip name-server 10.2.2.2 ip multicast-routing ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 vpdn enable ! vpdn-group 1 request-dialin protocol pptp rotary-group 0 initiate-to ip 10.100.100.3 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface FastEthernet0 ip address 192.168.62.21 255.255.255.0 duplex auto speed auto ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface Vlan1 ip address 10.1.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Dialer0 ip address negotiated ip pim dense-mode ip nat outside ip virtual-reassembly encapsulation ppp dialer in-band dialer idle-timeout 0 dialer string 123 dialer vpdn dialer-group 1 no peer neighbor-route no keepalive no cdp enable ppp pfc local request ppp pfc remote apply ppp encrypt mppe auto ppp chap hostname xxxxxx ppp chap password 0 xxxxx ppp ipcp route default ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.62.1 ! ! no ip http server no ip http secure-server ! dialer-list 1 protocol ip permit ! ! ! control-plane ! ! ! ! mgcp behavior g729-variants static-pt ! ! ! ! ! line con 0 line aux 0 line vty 0 4 login ! end Вставить ник Quote
pliskinsad Posted May 25, 2011 Posted May 25, 2011 нет строчки для ната типа: ip nat inside source list LIST interface Dialer0 overload ну и в acl LIST нужно описать сеть которую хочешь натить. Вставить ник Quote
kot654 Posted May 26, 2011 Author Posted May 26, 2011 добавил строки ip nat inside source list 1 interface Dialer0 overload access-list 1 permit 10.1.1.0 0.0.0.255 инета нет Вставить ник Quote
kot654 Posted May 26, 2011 Author Posted May 26, 2011 вообщем всем спасибо все заработало. конечный конфиг будет ниже. только почему то через циску скорость максимум 9-10мб\с когда напрямую кабель к компу цепляеш 25-30 мб\с. как решить такой казус? Using 1662 out of 29688 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption service internal ! hostname Router ! boot-start-marker boot-end-marker ! ! no aaa new-model ip cef ! ! ! ! ip name-server 10.2.2.2 ip multicast-routing ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 vpdn enable ! vpdn-group 1 request-dialin protocol pptp rotary-group 0 initiate-to ip 10.100.100.3 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface FastEthernet0 ip address 192.168.62.21 255.255.255.0 duplex auto speed auto ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface Vlan1 ip address 10.1.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Dialer0 ip address negotiated ip pim dense-mode ip nat outside ip virtual-reassembly encapsulation ppp dialer in-band dialer idle-timeout 0 dialer string 123 dialer vpdn dialer-group 1 no peer neighbor-route no keepalive no cdp enable ppp pfc local request ppp pfc remote apply ppp encrypt mppe auto ppp chap hostname xxxxxxx ppp chap password 0 xxxxxx ppp ipcp route default ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 Dialer0 ip route 10.100.100.3 255.255.255.255 192.168.62.1 ! ! no ip http server no ip http secure-server ip nat inside source list 1 interface Dialer0 overload ! access-list 1 permit 10.1.1.0 0.0.0.255 dialer-list 1 protocol ip permit ! ! ! control-plane ! ! ! ! mgcp behavior g729-variants static-pt ! ! ! ! ! line con 0 line aux 0 line vty 0 4 login ! end Вставить ник Quote
sol Posted May 28, 2011 Posted May 28, 2011 Откройте для себя http://shop.nag.ru/uploads/docs/Doc/routerperformance.pdf Вставить ник Quote
