indiana Опубликовано 3 октября, 2011 · Жалоба решил почистить все что мог, и фот что получилось: HP ProCurve Switch 2610-24 (J9085A) ROM Build Directory: /sw/rom/build/nemorom(ndx) ROM Version: R.10.06 ROM Build Date: 16:36:54 Nov 28 2007 ROM Build Number: 14201 Copyright (c) 1995-2001 Hewlett-Packard Company. All rights reserved. RESTRICTED RIGHTS LEGEND Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subdivision (b) (3) (ii) of the Rights in Technical Data and Computer Software clause at 52.227-7013. Hewlett-Packard Company, 3000 Hanover Street, Palo Alto, CA 94303 Enter h or ? for help. =>? LAN Monitor Commands do(wnload) - Download via Xmodem sp(eed) <baud> - Set a new baud rate h(elp) - Display help screen ? - Display help screen id(entify) - Print out identification string jp(jump) <1|2> - Jump to product code, optional 1-primary, 2-secondary q(uit) - Exit the monitor boot - Reboot the system reset - Reset the system v(ersion) - Display version information => есть способ как то залить прошивку? Здравствуйте! Была такая же тема, залил через HyperTerminal новую 11.72 прошивку, но она не запустилась. Пишет ProCurve J9085A Switch 2610-24 Software revision R.11.72 Copyright (C) 1991-2011 Hewlett-Packard Co. All Rights Reserved. RESTRICTED RIGHTS LEGEND Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subdivision (b) (3) (ii) of the Rights in Technical Data and Computer Software clause at 52.227-7013. HEWLETT-PACKARD COMPANY, 3000 Hanover St., Palo Alto, CA 94303 CONFIGURATION INITIALIZATION FAILED: Invalid Product Number in Config File Press any key to continue ROM information: Build directory: /sw/rom/build/nemorom(ndx) Build date: Nov 28 2007 Build time: 16:36:54 Build version: R.10.06 Build number: 14201 OS identifier found at @ 0xbc020000 Verifying Image validity ... CRC on OS image header Passed CRC on complete OS image file Passed Valid OS image @ 0xbc020000 Decompressing...done. CRC of image is 0x2e3a30b1 CRC @ 0x80001000 Len 10873888 is 0x2e3a30b1 initializing. Config Error - Initialization Stopped Waiting for Speed Sense. Press <Enter> twice to continue. и так по кругу... как восстановить заводские настройки? или хотябы сбросить эту прошивку и заного залить новую? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
NvAriec Опубликовано 14 марта, 2012 · Жалоба Здравствуйте! Интересует вопрос стекирования. Сделал стек из двух коммутаторов. Как обратится к интерфейсу из 2 коммутатора стека? Необходимо для агрегации двух и более каналов в один. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
