Привет, кто нибудь из вас поднимал lacp между cisco 3750 и huawei 5328. Может кто сталкивался? Не работает в общем!
!Software Version V100R005C01SPC100
sysname PS526_3-AGG1
interface Eth-Trunk1
port link-type trunk
port trunk allow-pass vlan 305
mode lacp-static
jumboframe enable 9000
interface GigabitEthernet0/0/22
description *** Cisco 3750 port Gi 1/0/7 ***
eth-trunk 1
undo ntdp enable
undo ndp enable
port media type copper
undo negotiation auto
port media type fiber
combo-port auto
interface GigabitEthernet0/0/23
description *** Cisco 3750 port Gi 1/0/6 ***
eth-trunk 1
undo ntdp enable
undo ndp enable
combo-port auto
[PS526_3-AGG1]display lacp statistics eth-trunk 1
Eth-Trunk1's PDU statistic is:
Port LacpRevPdu LacpSentPdu MarkerRevPdu MarkerSentPdu
GigabitEthernet0/0/23 0 991 0 0
GigabitEthernet0/0/22 0 984 0 0
ATS-26/3#sh run int gi 1/0/6
Building configuration...
Current configuration : 264 bytes
interface GigabitEthernet1/0/6
description *** KZN-PS526_3-AGG1 port Gi 0/0/23 ***
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 305
switchport mode trunk
speed 1000
duplex full
channel-protocol lacp
channel-group 1 mode active
end
ATS-26/3#sh run int gi 1/0/7
interface GigabitEthernet1/0/7
description *** KZN-PS526_3-AGG1 port Gi 0/0/22 ***
speed 1000
duplex full
end
ATS-26/3#sh run int Po1
Current configuration : 152 bytes
interface Port-channel1
speed 1000
duplex full
end
ATS-26/3#sh lacp counters
LACPDUs Marker Marker Response LACPDUs
Port Sent Recv Sent Recv Sent Recv Pkts Err
Channel group: 1
Gi1/0/6 2429 958 0 0 0 0 0
Gi1/0/7 2044 951 0 0 0 0 0
ATS-26/3#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SD) LACP Gi1/0/6(w) Gi1/0/7(H)
d - default port
d - default port
Edited by bmp82
У нас поднят между между h3c и 7606. Не хотел работать, пока не прописали в настройках Bridge-Aggregation команду link-aggregation mode dynamic
Также не поднимался LACP между телесином 9424 и этим же h3c, из-за того, что на порту у телесина не был прописал native vlan.
Бред!...Поднялось!
Добавил bpdu enable. Получилось:
mode lacp-static
bpdu enable
Но ведь эта дура ругалась на этот bpdu, когда добавлял Gi 0/0/22-23 в эзерченел командой eth-trunk 1, посчитал этот параметр несущественным.
Edited by bmp82
