sva_zar Posted May 11, 2011 Posted May 11, 2011 Доброе время суток! Пожалуйста подскажите. связь Asterisk-AP200B-KX-TEM 824(в два порта СО) как сделать чтоб звонки распределялись по FXS т.е. если FXS0 занят то направить на FXS1 и на оборот. конфиг AP200# show ru ! version 8.23H ! hostname AP200 ! ! no bridge spanning-tree ! dhcp-list 0 type server dhcp-list 0 address server interface ether0.0 dhcp-list 0 option dhcp-lease-time 600 ! dhcp-list 1 type server dhcp-list 1 address server 10.1.1.2 10.1.1.126 255.255.255.128 ! ! ip-share enable ip-share interface net-side ether0.0 ip-share interface local-side ether1.0 ! interface ether0.0 ip address 192.168.200.75 255.255.255.0 ! interface ether1.0 no ip address ip dhcp-group 0 ! snmp name AP200B ! no arp reset ! ! ! ! ! ! VoIP configuration. ! ! ! Voice service voip configuration. ! voice service voip fax protocol t38 redundancy 0 fax rate 9600 h323 call start fast h323 call tunnel enable busyout monitor gatekeeper no busyout monitor callagent busyout monitor voip-interface ! ! ! Voice port configuration. ! ! FXS voice-port 0/0 ! ! ! FXS voice-port 0/1 ! ! ! ! ! Pots peer configuration. ! dial-peer voice 1 pots destination-pattern 400 port 0/0 user-password user400 ! dial-peer voice 2 pots destination-pattern 400 port 0/1 user-password user400 ! ! ! ! Voip peer configuration. ! dial-peer voice 100 voip destination-pattern T session target 192.168.200.233 session protocol sip codec g711alaw dtmf-relay rtp-2833 ! ! ! ! ! ! ! Gateway configuration. ! gateway h323-id voip.192.168.200.75 no ignore-msg-from-other-gk ! ! ! SIP UA configuration. ! sip-ua sip-username 400 sip-password user400 sip-server 192.168.200.233 register e164 ! ! ! MGCP configuration. ! mgcp codec g711ulaw ! ! ! Tones ! ! ! ! AP200# Вставить ник Quote
Deac Posted May 11, 2011 Posted May 11, 2011 Addpac - CISCO like, ну тогда: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml Читать до посинения просветления. Ну и прошивочку поновее, актуальная v8_30W Вставить ник Quote
udaffrzn Posted June 8, 2013 Posted June 8, 2013 Не стал создавать новой темы, подскажите пожалуйста. В АР200 имеется функция PSTN Backup. Чтобы позвонить в линию необходимо нажать сперва "#", а затем набрать номер абонента. Имеется ли возможность настроить аддпак так, чтобы по умолчанию все звонки уходили в PSTN, и только при нажатии "#" - в VoIP? Вставить ник Quote
