ntil Posted April 20, 2011 Posted April 20, 2011 собственно при входящем звонке с SIP циска отвечает 183 Session Progress вместо 180 Ringing а мой SIP провайдер не пропускает РТП с рингбеком - т.е. нада както заставить циску слать 180. rtr#sh ver Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-IPVOICE-M), Version 12.3(23), RELEASE SOFTWARE (fc5) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by cisco Systems, Inc. Compiled Tue 24-Jul-07 14:47 by stshen Image text-base: 0x8000816C, data-base: 0x81455D6C ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1) rtr uptime is 56 minutes System returned to ROM by reload at 13:24:34 UTC Fri Nov 7 2008 System restarted at 13:00:30 UTC Fri Nov 7 2008 System image file is "flash:c1700-ipvoice-mz.123-23.bin" cisco 1751-V (MPC860P) processor (revision 0x600) with 59025K/6511K bytes of memory. Processor board ID FOC10295J6R (815324709), with hardware revision 0000 MPC860P processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0. 1 FastEthernet/IEEE 802.3 interface(s) 1 ATM network interface(s) 2 Voice FXS interface(s) 32K bytes of non-volatile configuration memory. 32768K bytes of processor board System flash (Read/Write) Configuration register is 0x2102 rtr#sh run Building configuration... Current configuration : 1405 bytes ! ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname rtr ! boot-start-marker boot-end-marker ! enable secret 5 *** enable password *** ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 voice-card 2 ! no aaa new-model ip subnet-zero ip cef ! ! ! ! ! voice call send-alert ! voice service pots ! voice service voip sip ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface ATM0/0 no ip address shutdown no atm ilmi-keepalive dsl operating-mode auto ! interface FastEthernet0/0 ip address XX.XX.XX.210 255.255.255.252 speed auto full-duplex ! ip classless ip route XX.XX.XX.44 255.255.255.252 XX.XX.XX.209 no ip http server ! ! voice-port 2/0 no battery-reversal cptone RU station-id number *******697 ! voice-port 2/1 station-id number *******697 ! ! ! dial-peer voice 9 voip destination-pattern .T session protocol sipv2 session target sip-server session transport udp dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 5 pots destination-pattern *******697 port 2/0 forward-digits 0 ! sip-ua sip-server ipv4:XX.XX.XX.46:5060 ! ! line con 0 line aux 0 line vty 0 4 password *** login ! end Вставить ник Quote
Voicemaster Posted April 20, 2011 Posted April 20, 2011 Смените провайдера, бо идиотство. Хотя кошку вашу, вероятно, можно научить. . Вставить ник Quote
Aleck_K Posted April 22, 2011 Posted April 22, 2011 циска отвечает 183 Session Progress вместо 180 Ringing В циске настраивается, как будут обрабатываться провижн-респонсы. Точную команду не подскажу, но поищите по ключевым словам 100rel provision response disable Вставить ник Quote
Kondor Posted April 25, 2011 Posted April 25, 2011 (edited) Попробуйте посмотрите в сторону progress indication в dial-peer: progress_ind setup enable 3 И почитайте здесь - http://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/dt4t323.html#wp1045359 Edited April 25, 2011 by Kondor Вставить ник Quote
ntil Posted April 26, 2011 Author Posted April 26, 2011 Попробуйте посмотрите в сторону progress indication в dial-peer: progress_ind setup enable 3 И почитайте здесь - http://www.cisco.com....html#wp1045359 Да читал я этот документ (и даже понял его :) ) еще до того, как обратится за помощью к форумчанам. не помогает все это. выписал памяти, буду ставить последний наявный ИОС ... Смените провайдера, бо идиотство. ниразу даже не идиотство. просто политика такая. а менять немогу - номера привязаны. Вставить ник Quote
Deac Posted April 27, 2011 Posted April 27, 2011 Да не решается это средствами самой железки. Нужно внешнее средство, типа ring_insert_callid() у kamailio, ну и в CISCO-вском софте есть подобное. Вставить ник Quote
rover-lt Posted April 28, 2011 Posted April 28, 2011 собственно при входящем звонке с SIP циска отвечает 183 Session Progress вместо 180 Ringing а мой SIP провайдер не пропускает РТП с рингбеком - т.е. нада както заставить циску слать 180. Может просто ртп не пропускает, а не 183? Тады можно sip-ua disable-early-media session progress это далеко не ringing. Рингинга вообще может не быть, а session progress будет. Вставить ник Quote
ntil Posted April 28, 2011 Author Posted April 28, 2011 disable-early-media disable-early-media не полная ком*** disable-early-media 180 - делает совсем не то, отключает фмтп секцию в ответе 180 рингинг. может действительно нельзя отключить 183 ? Вставить ник Quote
All is not what it seems Posted April 29, 2012 Posted April 29, 2012 Router(conf-serv-sip)#block ? 180 Block 180 response to Invite 181 Block 181 response to Invite 183 Block 183 response to Invite Вставить ник Quote
