День добрый всем, имеею две циски
7505
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.0(9)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Cisco RSP4 (R5000) processor with 131072K/2072K bytes of memory.
R5000 CPU at 200MHz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
Chassis Interface.
1 AIP controller (1 ATM).
1 VIP2 R5K controller (2 FastEthernet).
2 FastEthernet interfaces
1 ATM interface
123K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
B 7507
Cisco RSP4 (R5000) processor with 262144K/2072K bytes of memory.
Chassis Interface.
125440K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
No slave installed in slot 3.
На обоих цисках есть BGP, OSPF, GRE, обе в инет смотрят, конфиги как бы довольно сильно похожи, но 7505 в РАЗЫ лучше трафик ест
Вот пример 7505
#show interfaces fastEthernet 3/0/0
FastEthernet3/0/0 is up, line protocol is up
 5 minute input rate 11561000 bits/sec, 9338 packets/sec
 5 minute output rate 8630000 bits/sec, 9867 packets/sec
Router-77pbx-kar#show interfaces fastEthernet 3/1/0
FastEthernet3/1/0 is up, line protocol is up
 5 minute input rate 3485000 bits/sec, 2492 packets/sec
 5 minute output rate 6463000 bits/sec, 1957 packets/sec
CPU utilization for five seconds: 44%/41%; one minute: 41%; five minutes: 41%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
 74    13242800  32033648        413  1.14%  0.56%  0.53%   0 IP Input
А 7507 в разы хуже
show interfaces fastEthernet 4/0/0
FastEthernet4/0/0 is up, line protocol is up
 5 minute input rate 5150000 bits/sec, 4464 packets/sec
 5 minute output rate 5121000 bits/sec, 4452 packets/sec
show interfaces fastEthernet 4/1/0
FastEthernet4/1/0 is up, line protocol is up
 5 minute input rate 2545000 bits/sec, 4019 packets/sec
 5 minute output rate 2220000 bits/sec, 3483 packets/sec
#show processes cpu sorted 1min
CPU utilization for five seconds: 99%/54%; one minute: 99%; five minutes: 98%
 73   104986024 105856149        991 43.92% 46.18% 45.81%   0 IP Input
IOS идентичные rsp-jk9sv-mz.124-3g.bin
IP CEF включенны на обоих, и есть маршруты если просмотреть CEF, кого винить, что искать?
Edited by E^X
плин!!! no ip cef был на интерфейсах отключенно, по умолчанию, а на другой по умолчанию включён... вот же подгадило.
