fox_m Posted April 13, 2011 Posted April 13, 2011 Всем привет. Поясните, что значит команда speed nonegotiate. Понятно что она отключает "переговоры". Ситуация такая, 2 cisco 3560 соединены между собой uplink портами. В порты установлены SFP модули. Физика поднялась только после того, как указал на интерфейсе данную команду. Что оно все таки делает? Вставить ник Quote
Stak Posted April 13, 2011 Posted April 13, 2011 Usage Guidelines You can configure the Fast Ethernet port speed as either 10 or 100 Mbps. You can configure the Gigabit Ethernet port speed as 10, 100, or 1000 Mbps. When a 1000BASE-T SFP module is in the SFP module slot, you can configure the speed as 10, 100, 1000, or auto but not to nonegotiate. Except for the 1000BASE-T SFP modules, if an SFP module port is connected to a device that does not support autonegotiation, you can configure the speed to not negotiate (nonegotiate). If the speed is set to auto, the switch negotiates with the device at the other end of the link for the speed setting and then forces the speed setting to the negotiated value. The duplex setting remains as configured on each end of the link, which could result in a duplex setting mismatch. <a name="wp1947360"> If both ends of the line support autonegotiation, we highly recommend the default autonegotiation settings. If one interface supports autonegotiation and the other end does not, do use the auto setting on the supported side, but set the duplex and speed on the other side. http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_sec/command/reference/cli3.html#wpmkr1947311 Вставить ник Quote
dm-- Posted April 13, 2011 Posted April 13, 2011 Физика поднялась только после того, как указал на интерфейсе данную команду. а теперь понаблюдайте счетчик ошибок на интерфейсе. Вставить ник Quote
fox_m Posted April 13, 2011 Author Posted April 13, 2011 Дык вот именно, что нет ошибок. Хотя трафик постоянно ~200Mbps GigabitEthernet0/27 is up, line protocol is up (connected) Hardware is Gigabit Ethernet, address is 001b.8f36.1d9b (bia 001b.8f36.1d9b) MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 54/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive not set Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLX SFP input flow-control is off, output flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input 1w0d, output 2w5d, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 30 second input rate 0 bits/sec, 0 packets/sec 30 second output rate 213823000 bits/sec, 19625 packets/sec 251148208 packets input, 41728551980 bytes, 0 no buffer Received 243238830 broadcasts (219462079 multicasts) 0 runts, 2 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 219462079 multicast, 0 pause input 0 input packets with dribble condition detected 4645273696 packets output, 6314945311387 bytes, 0 underruns 0 output errors, 0 collisions, 10 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out Вставить ник Quote
dm-- Posted April 13, 2011 Posted April 13, 2011 а оптический измеритель есть? уровень сигнала замерить есть возможность? такая ерунда с nonegotiate обычно бывает при недостатке оптического бюджета, ну или тупой конвертер с другой стороны. Вставить ник Quote
fox_m Posted April 14, 2011 Author Posted April 14, 2011 Блин, с другой стороны оказалась совсем не циска. А какое-то другое железо. Пока не выяснил какое. Возможно с этим все связаною Вставить ник Quote
Stak Posted April 14, 2011 Posted April 14, 2011 Повторюсь: if an SFP module port is connected to a device that does not support autonegotiation, you can configure the speed to not negotiate (nonegotiate). Вставить ник Quote
sirmax Posted April 14, 2011 Posted April 14, 2011 Сталкивался с аналогичной проблемой. с "той стороны" был Длинк 3627. Ошибок на интерфейсе не было. Вставить ник Quote
Andrei Posted April 14, 2011 Posted April 14, 2011 У меня как раз сейчас 100Мбитные sfp-шки от Нага, установленные в DGS-3100, не заводятся с Наговскими соточными конверторами. Бюджета хватает с запасом - все 20 километровое, а городок максимум километра 3-4. В DGS-3100 для гиговых оптических портов скорость не настраивается, только auto, на все остальное ругается: DGS-3100# conf ports 9 speed 100_full Port 1:9 is a 1G-Fiber port and its speed can be configured only as 1G Failed to set speed. Fail. DGS-3100# conf ports 9 speed auto Success. DGS-3100# sh ports 9 Port Port Settings Connection Address State Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl Learning --- ------- ------------------ ------------------ ------- 1:9 Enabled Auto/Disabled Link Down Enabled Хотя в соседнем порту соточная sfp-ка работает: DGS-3100# sh ports 24 Port Port Settings Connection Address State Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl Learning --- ------- ------------------ ------------------ ------- 1:24 Enabled 100M/Full/Disabled 100M/Full/Disabled Enabled Вставить ник Quote
Andrei Posted April 15, 2011 Posted April 15, 2011 Сегодня проводил эксперимент: с одной стороны DGS-3100-24TG с наговскими 100М-sfp, с другой - наговский 100М конвертор. На конверторе индикация такая, как будто все ОК, индикаторы линков горят, подмигивают, но пинги не идут :( Смотрю в лог DGS-3100-24TG: 80 15-Apr-2011 13:30:49 %LINK-W-Down: 1:9 81 15-Apr-2011 13:30:47 %LINK-I-Up: 1:9 82 15-Apr-2011 13:30:45 %LINK-W-Down: 1:9 83 15-Apr-2011 13:30:45 %LINK-I-Up: 1:9 84 15-Apr-2011 13:30:44 %LINK-W-Down: 1:9 85 15-Apr-2011 13:30:44 %LINK-I-Up: 1:9 86 15-Apr-2011 13:30:41 %LINK-W-Down: 1:9 87 15-Apr-2011 13:30:39 %LINK-I-Up: 1:9 88 15-Apr-2011 13:30:38 %LINK-W-Down: 1:9 89 15-Apr-2011 13:30:37 %LINK-I-Up: 1:9 90 15-Apr-2011 13:30:18 %LINK-W-Down: 1:9 91 15-Apr-2011 13:30:18 %LINK-I-Up: 1:9 92 15-Apr-2011 13:30:17 %LINK-W-Down: 1:9 93 15-Apr-2011 13:30:15 %LINK-I-Up: 1:9 94 15-Apr-2011 13:30:14 %LINK-W-Down: 1:9 95 15-Apr-2011 13:30:13 %LINK-I-Up: 1:9 96 15-Apr-2011 13:30:11 %LINK-W-Down: 1:9 97 15-Apr-2011 13:30:11 %LINK-I-Up: 1:9 98 15-Apr-2011 13:30:09 %LINK-W-Down: 1:9 Т.е. линк пляшет вприсядку каждые несколько секунд. Куда бежать, куда копать? Вставить ник Quote
shefys Posted April 16, 2011 Posted April 16, 2011 В коммутаторах Cisco autonegotiation сделан не самым стандартным образом. Вернее, у кого как получилось реализовать поддержку IEEE 802.3u - у того так и работает. Вообщем, если не уверены, то лучше настройте руками - проблема interoperability может вылезти в любом месте (и с SFP в том числе). Вставить ник Quote
Andrei Posted April 16, 2011 Posted April 16, 2011 Вообщем, если не уверены, то лучше настройте руками - проблема interoperability может вылезти в любом месте (и с SFP в том числе). В том-то и дело, что руками не дается: DGS-3100# conf ports 9 speed Command: config ports 9 speed auto auto 10_half 10_half 10_full 10_full 100_half 100_half 100_full 100_full 1000_full 1000_full DGS-3100# conf ports 9 speed 100_full Port 1:9 is a 1G-Fiber port and its speed can be configured only as 1G Failed to set speed. Fail. Однако поскольку sfp-ка все же соточная, то порту будет видно: DGS-3100# sh ports 11 Port Port Settings Connection Address State Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl Learning --- ------- ------------------ ------------------ ------- 1:11 Enabled 100M/Full/Disabled 100M/Full/Disabled Enabled Вопрос - из-за чего вот это: 80 15-Apr-2011 13:30:49 %LINK-W-Down: 1:9 81 15-Apr-2011 13:30:47 %LINK-I-Up: 1:9 82 15-Apr-2011 13:30:45 %LINK-W-Down: 1:9 83 15-Apr-2011 13:30:45 %LINK-I-Up: 1:9 84 15-Apr-2011 13:30:44 %LINK-W-Down: 1:9 85 15-Apr-2011 13:30:44 %LINK-I-Up: 1:9 86 15-Apr-2011 13:30:41 %LINK-W-Down: 1:9 87 15-Apr-2011 13:30:39 %LINK-I-Up: 1:9 88 15-Apr-2011 13:30:38 %LINK-W-Down: 1:9 89 15-Apr-2011 13:30:37 %LINK-I-Up: 1:9 :( Вставить ник Quote
DVM-Avgoor Posted April 16, 2011 Posted April 16, 2011 :( У длинка есть форум. Логичнее спрашивать там. Например вот. И вообще, емнип, в начале продаж 3100-24TG вроде как только 1G SFP поддерживал официально, хотя я могу и ошибаться. Вставить ник Quote
Andrei Posted April 16, 2011 Posted April 16, 2011 У длинка есть форум. Логичнее спрашивать там. Например вот. И вообще, емнип, в начале продаж 3100-24TG вроде как только 1G SFP поддерживал официально, хотя я могу и ошибаться. У длинка на форуме спрошу. Сотки sfp в нем работают - проверено. Трабла с одним линком :( Вставить ник Quote
biox Posted April 18, 2011 Posted April 18, 2011 возможно необходимо обновить прошивку на 3100-24 Вставить ник Quote
Andrei Posted April 19, 2011 Posted April 19, 2011 возможно необходимо обновить прошивку на 3100-24 ...после чего в нем могут перестать работать соточные sfp? :) Вставить ник Quote
Mallorn Posted April 22, 2011 Posted April 22, 2011 Замечали похожие вещи при работе некоторых медиаконвертеров именно с д-линк железом. Смысл такой, autononegotiate на линке медиаконвертер - д-линr коммутатор часто не работает корректно или вообще не работает. Помогает переключение порта в фиксированный 100M Full. Вставить ник Quote
dmber Posted April 22, 2011 Posted April 22, 2011 скорость на порту можно менять, если сначала выключить порт conf ports 1:9 st dis conf ports 1:9 speed 100_full conf ports 1:9 st en хотя, по моему опыту, все равно что стояло до вставки соточного модуля (1000_full или auto) он все равно переключится на 100_full Вставить ник Quote
Andrei Posted April 23, 2011 Posted April 23, 2011 скорость на порту можно менять, если сначала выключить порт conf ports 1:9 st dis conf ports 1:9 speed 100_full conf ports 1:9 st en DGS-3100# sh sw Device Type : DGS-3100-24TG Gigabit stackable L2 Managed Switch Boot PROM Version : 1.0.1.04 Firmware Version : 3.00.43 Hardware Version : 04 DGS-3100# conf ports 1:9 st dis Success. DGS-3100# conf ports 1:9 speed 100_full Port 1:9 is a 1G-Fiber port and its speed can be configured only as 1G Failed to set speed. Fail. DGS-3100# conf ports 1:9 st en Success. Так что ни фига. Вставить ник Quote
Butch3r Posted April 25, 2011 Posted April 25, 2011 У нас между нашей 7606 и ТТК 7606 не поднимается линк, если с обеих сторон стоит автоопределение. А вот если на нашей циске его выключить - то всё начинает работает Модули конечно голимый китай и начинают работать только после включения unsupported-transivers. Бюджета хватает на 100%. И всё работает нормально, вообще по возможности стараюсь ставить всем SFP принудительную скорость на порту Вставить ник Quote
