Joneg Posted April 5, 2011 Posted April 5, 2011 (edited) Помогите решить проблему. Высокая загрузка CPU в циске, до 80% в часпик. sh processes cpu detailed | ex 0.0 CPU utilization for five seconds: 74%; one minute: 65%; five minutes: 62% PID/TID 5Sec 1Min 5Min Process Prio STATE CPU 1 25.8% 35.0% 37.8% [idle thread] 0 Ready 12d13h PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU 16408 72.5% 61.6% 58.7% ios-base 2d07h 1 0.1% 0.2% 0.3% 10 Receive 45m33s 7 22.8% 21.6% 20.3% 21 Intr 16h40m 8 0.7% 0.6% 0.5% 22 Intr 2h00m 11 2.1% 3.2% 5.1% 10 Receive 1h07m 13 3.8% 6.2% 5.9% 10 Receive 30m50s 14 16.0% 6.8% 5.8% 10 Receive 55m59s 15 5.5% 6.9% 6.2% 10 Reply 29m38s 16 5.8% 6.8% 6.3% 10 Receive 41m06s 17 15.7% 8.8% 5.9% 10 Receive 31m10s Process sbin/ios-base, type IOS, PID = 16408 CPU utilization for five seconds: 47%/22%; one minute: 38%; five minutes: 36% Task Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Task Name 2 5668922 165666509 34 0.47% 0.50% 0.44% 0 Service Task 3 8047707 139812551 57 0.15% 0.16% 0.17% 0 Service Task 16 51868409 132477284 391 40.95% 32.25% 30.70% 0 ARP Input 90 686701 333994 2056 0.87% 0.86% 0.77% 0 Compute load avg 126 18351338 116378341 157 1.67% 1.43% 1.37% 0 IP Input 170 1870543 2306738 810 0.29% 0.24% 0.25% 0 CEF process 172 11651469 448629 25971 1.73% 1.34% 1.33% 0 Adj Manager Task Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Task Name PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU 16423 0.1% 0.1% 0.1% raw_ip.proc 1h43m 6 0.1% 0.1% 0.1% 10 Receive 50m14s PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU 16426 0.4% 0.7% 0.7% udp.proc 47m11s 5 0.4% 0.7% 0.7% 10 Receive 47m05s PID/TID 5Sec 1Min 5Min Process Prio STATE CPU PID/TID 5Sec 1Min 5Min Process Prio STATE CPU 16427 0.4% 0.3% 0.3% iprouting.iosproc 1h13m 1 0.3% 0.1% 0.1% 10 Receive 17m46s 3 0.1% 0.2% 0.2% 10 Receive 18m19s Process sbin/iprouting.iosproc, type IOS, PID = 16427 CPU utilization for five seconds: 0%/0%; one minute: 0%; five minutes: 0% Task Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Task Name PID/TID 5Sec 1Min 5Min Process Prio STATE CPU 16428 0.7% 0.2% 0.2% cdp2.iosproc 21m07s 3 0.7% 0.2% 0.2% 10 Receive 1m56s Process sbin/cdp2.iosproc, type IOS, PID = 16428 CPU utilization for five seconds: 0%/0%; one minute: 0%; five minutes: 0% Task Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Task Name 16 51868409 132477284 391 40.95% 32.25% 30.70% 0 ARP Input Вклчюение выключение arp proxy дел не меняет. sh ip arp summary 3405 IP ARP entries, with 379 of them incomplete В кратце о кнофигурации. Используются vrf и route leaking между ними. Для каждой группы vlan-ов(клиенских подсетей) выделен отдельный vrf. На каждом vrf статично прописан маршрут по умолчанию. В каждом vlan работает шейпер ubrl локального трафика между vlan. Так же есть vrf main и vrf inet. ip vrf forwarding ip vrf inet rd 65000:3333 route-target export 65000:3333 route-target import 65000:4444 route-target import 65000:100 route-target import 65000:200 route-target import 65000:300 ! ip vrf main rd 65000:4444 route-target export 65000:4444 route-target import 65000:3333 route-target import 65000:100 route-target import 65000:200 route-target import 65000:300 ! ip vrf s_100 rd 65000:100 route-target export 65000:100 route-target import 65000:200 route-target import 65000:300 route-target import 65000:4444 route-target import 65000:3333 ! ip vrf s_200 rd 65000:200 route-target export 65000:200 route-target import 65000:4444 route-target import 65000:3333 route-target import 65000:100 route-target import 65000:300 ! ip vrf s_300 rd 65000:300 route-target export 65000:300 route-target import 65000:200 route-target import 65000:100 route-target import 65000:4444 route-target import 65000:3333 ! mls qos no mls flow ip no mls rate-limit unicast acl vacl-log no mls acl tcam share-global mls ip multicast flow-stat-timer 9 mls cef error action freeze ! ! redundancy mode sso main-cpu auto-sync running-config ! spanning-tree mode pvst no spanning-tree vlan 1-820 ! vlan internal allocation policy ascending ! class-map match-all local_traff match access-group 100 ! ! policy-map local_traff_dest class local_traff police flow mask dest-only 5120000 960000 conform-action transmit exceed-action drop ! ! Клиенские вланы выгялдят так: interface Vlan100 ip vrf forwarding s_100 ip address 10.100.0.1 255.255.0.0 service-policy input local_traff_dest no ip proxy-arp ! interface Vlan200 ip vrf forwarding s_200 ip address 10.200.0.1 255.255.0.0 service-policy input local_traff_dest no ip proxy-arp ! interface Vlan300 ip vrf forwarding s_300 ip address 10.300.0.1 255.255.0.0 service-policy input local_traff_dest no ip proxy-arp ! ! !физ интерфейсы настреоны примерно так: interface GigabitEthernet1/18 switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 1,100,200,300 switchport mode trunk no ip address mls qos vlan-based ! Записей в arp таблицах вроде бы не много, arp proxy выключен, чем ещё заниматсья этому ARP Input. Какие команды ещё показать? И ещё, помогите определить корректно ли работает CEF у меня между vrf. И может ли она вообще работать в таких условиях? Почему то мне кажется, что загрузка прерываниями велика. sh inter stat показывет на всех vkan примерно следующую картину: Vlan1 Switching path Pkts In Chars In Pkts Out Chars Out Processor 5746090 474623717 13208895 2202676571 Route cache 35397990 2290769142 626803989 488527204857 Distributed cache 81809384033 56387428971765 104002506654 111270830879762 Total 81850528113 56390194364624 104642519538 111761560761190 Vlan100 Switching path Pkts In Chars In Pkts Out Chars Out Processor 10755 707620 44972 2914894 Route cache 1859 748815 32 1532 Distributed cache 9461815739 13764392782038 4252376719 273152020552 Total 9461828353 13764394238473 4252421723 273154936978 Vlan200 Switching path Pkts In Chars In Pkts Out Chars Out Processor 12860 1775016 85789 5528486 Route cache 58830 9928179 968 54510 Distributed cache 93073021633 129966337880688 46006406024 4489828282825 Total 93073093323 129966349583883 46006492781 4489833865821 Vlan300 Switching path Pkts In Chars In Pkts Out Chars Out Processor 6576169 610811865 4091582 292831340 Route cache 262566878 244917144610 2337 154631 Distributed cache 53311483961 32255344337646 50889545047 25423430357803 Железо: sh module Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL1133XWHX 3 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL1029W1SQ 5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1108HW4L Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ------ ------------ ------------ ------- 1 0007.0e3a.89c8 to 0007.0e3a.89df 2.6 12.2(14r)S5 12.2(18)SXF8 Ok 3 0018.b907.0ea0 to 0018.b907.0ecf 7.0 7.2(1) 8.5(0.46)RFW Ok 5 0016.c85e.80f8 to 0016.c85e.80fb 5.3 8.4(2) 12.2(18)SXF8 Ok Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 1 Centralized Forwarding Card WS-F6700-CFC SAL1126SFU6 3.1 Ok 5 Policy Feature Card 3 WS-F6K-PFC3B SAL1109J079 2.3 Ok 5 MSFC3 Daughterboard WS-SUP720 SAL1108HKXG 2.6 Ok Mod Online Diag Status ---- ------------------- 1 Pass 3 Pass 5 Pass Edited April 5, 2011 by Joneg Вставить ник Quote
Frau Posted April 5, 2011 Posted April 5, 2011 Записей в arp таблицах вроде бы не много, arp proxy выключен, чем ещё заниматсья этому ARP Input. как самый распространенный вариант - петля в одном из клиентских виланов Вставить ник Quote
Joneg Posted April 5, 2011 Author Posted April 5, 2011 А как это можно явно увидеть? Ведь какой то параметр в счетчиках интерфейсов должен быть завышен, или защита какая то сработать... Вставить ник Quote
Frau Posted April 5, 2011 Posted April 5, 2011 А как это можно явно увидеть? Ведь какой то параметр в счетчиках интерфейсов должен быть завышен, или защита какая то сработать... могут в логах маки флапать, это если между портами замкнуто. А можно включить storm-control на портах и там будет видно Вставить ник Quote
secandr Posted April 5, 2011 Posted April 5, 2011 (edited) Всегда интересовал тот же вопрос. Ищем петли административным путём: повысилась загрузка ЦПУ на кошке, тут же фиксируются положение всех сотрудников и подрядчиков. Определяется виновный и даём по шапке. Петля прекращается. Edited April 5, 2011 by secandr Вставить ник Quote
Дятел Posted April 5, 2011 Posted April 5, 2011 Joneg, скажите какой SUP и версию софта. Лечим аналогичные грабли. Не петля. Вставить ник Quote
slan Posted April 5, 2011 Posted April 5, 2011 Еще дело может быть в некорректной работе CEF. Может быть сменить версию прошивки. К сожалению, на 6500 в версиях прошивок, которые умеют все (типа adventerprisek9), не всегда этот CEF корректно работает и включение абсолютно на первый взгляд безобидных команд приводит к тому, что обработка пакетов производится процом - отсюда и загрузка. Посмотрите еще на предмет переполнение буфера TCAM (sh tcam counts). Есть ли какие ошибки в логах? В свое время удалось решить похожую проблему откатом к более простой версии иос (с более скромным набором поддерживаемых функций :-). Вставить ник Quote
Joneg Posted April 5, 2011 Author Posted April 5, 2011 sh ver Cisco Internetwork Operating System Software IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-VM), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2007 by cisco Systems, Inc. Compiled Sat 03-Mar-07 01:58 by tinhuang Image text-base: 0x01020150, data-base: 0x01021000 ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1) BOOTLDR: cisco_1 uptime is 2 weeks, 1 day, 3 hours, 59 minutes Time since cisco_1 switched to active is 2 weeks, 1 day, 3 hours, 59 minutes System returned to ROM by power cycle at 12:39:53 UTC Mon Feb 28 2011 (SP by power on) System image file is "sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF8.bin" cisco WS-C6509 (R7000) processor (revision 3.0) with 491520K/32768K bytes of memory. Processor board ID TBM06026541 SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache Last reset from s/w reset Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). TN3270 Emulation software. 32 Virtual Ethernet/IEEE 802.3 interfaces 74 Gigabit Ethernet/IEEE 802.3 interfaces 1917K bytes of non-volatile configuration memory. 65536K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102 Patching is not available since the system is not running from an installed image. To install please use the "install file" command Когда ставили циску один из вланов нехотел подниматься, в логах циски были записи что STP выключил этот влан. Нагуглив первое попавшееся решение no spanning-tree vlan 1-820 выключил это на всех vlan. Что я сделал этой командой? И почему STP блокировало порт? Вставить ник Quote
Дятел Posted April 5, 2011 Posted April 5, 2011 у нас замена софта на Version 12.2(33) вылечила проблему..... Вставить ник Quote
Joneg Posted April 5, 2011 Author Posted April 5, 2011 sh tcam counts Used Free Percent Used Reserved ---- ---- ------------ -------- Labels:(in) 6 4090 0 Labels:(eg) 3 4093 0 ACL_TCAM -------- Masks: 21 4075 0 72 Entries: 68 32700 0 576 QOS_TCAM -------- Masks: 6 4090 0 18 Entries: 24 32744 0 144 LOU: 0 128 0 ANDOR: 1 15 6 ORAND: 0 16 0 ADJ: 3 2045 0 у нас замена софта на Version 12.2(33) вылечила проблему..... Это вы за 20 минут проделали все? Вставить ник Quote
Дятел Posted April 5, 2011 Posted April 5, 2011 если бы..... 4 дня развлекались.... Вставить ник Quote
Joneg Posted April 5, 2011 Author Posted April 5, 2011 (edited) А как проблема появилась? У меня я полагаю она была изначально, но с заведением всех вланов в циску стала проявляться более явно Вы самую последнюю Release 12.2(33)SXI6 поставили? Edited April 5, 2011 by Joneg Вставить ник Quote
Дятел Posted April 6, 2011 Posted April 6, 2011 System:Cisco IOS Software, s3223_rp Software (s3223_rp-IPSERVICESK9_WAN-M),Version 12.2(33)SXH5 Вставить ник Quote
MagMike Posted April 7, 2011 Posted April 7, 2011 у меня подобная проблема - высокая загрузка - была, когда в одном из route-map-ов забыл указать "set". Вставить ник Quote
staryk Posted April 7, 2011 Posted April 7, 2011 Когда ставили циску один из вланов нехотел подниматься, в логах циски были записи что STP выключил этот влан. Нагуглив первое попавшееся решение no spanning-tree vlan 1-820 выключил это на всех vlan. Что я сделал этой командой? И почему STP блокировало порт? stp отработало потому что была петля, выключив stp на данном вилане вы себе создали проблему, я бы на вашем месте включил обратно и изучил нехитрую логику работы stp. по существу проблемы - если петля и прочее найдена не будет, попробуйте перейти на ветку софта 12.2(33), как уже рекомендовал Дятел. там могут быть чудеса с routed MAC'ами (у нас были), вылечилось увеличением age time. Мы в похожей ситуации ничего странного не нашли, просто стало много ARP трафика и простой переход с 18 ветки на 33 привел к сдутию процесса ARP input, видимо, алгоритм обработки очереди был серьезно переработан индусами Вставить ник Quote
Joneg Posted April 7, 2011 Author Posted April 7, 2011 Роут мапав не используем вовсе. STP уже прочитал, высстановил прежнее значение STP, блокировки vlan не последовало, видимо если чтото и было, уже ликвидировалось. На днях попробуем поставить 33 ветку. О результате обязательно отпишусь. Вставить ник Quote
darkagent Posted April 7, 2011 Posted April 7, 2011 40.95% 32.25% 30.70% 0 ARP Input - это не arp proxy, не то ковыряете, тут именно arp input (подсказка - rate, pps) Если железка позволяет, в control-plane на input вкатайте полиси лимитирующее arp input rate на 4900M с такой бедой тоже сталкивались, правда у нас на нем arp summary на порядок больше будет вылечилось как то так: class-map match-all system-cpp-arp match protocol arp policy-map system-cpp-policy ..блаблабла class system-cpp-arp police rate 8192 pps ..блаблабла control-plane service-policy input system-cpp-policy Вставить ник Quote
Дятел Posted April 7, 2011 Posted April 7, 2011 ага, подропать ARP и получить перезапросы от абонентов....Не лечит. Хотя механизм на сап32/720 немного другой.... Вставить ник Quote
darkagent Posted April 7, 2011 Posted April 7, 2011 подропать ARP и получить перезапросы tcpdump/wireshark'ом в разрыве как-нибудь посидеть рекомендую, и построить графики пактеной нагрузки по arp. такая политика позволяет размазать штормы. тем более что рейты можно подкрутить. у себя выставили 8192 как оптимальное - чтоб железку не нервировать и чтоб дискомфорта абонентам не доставлять. Вставить ник Quote
Дятел Posted April 7, 2011 Posted April 7, 2011 не было у нас шторма, не было! все запросы - валидные. просто их много, и неправильная организации очереди у 18 ветки софта приводит в убиванию проца вертикально от 60 до 100% (это такой мы для себя вывод сделали, а так - х.з., на циско-форуме никто никаких ответов не дал). Вставить ник Quote
staryk Posted April 7, 2011 Posted April 7, 2011 да, и если еще не переехали на 33, можно навесить SPAN на cpu немного извращенным способом, цитирую: 1.Set up port monitor as normal Router(config)# monitor session 1 source interface x/y (an unused interface) Router(config)# monitor session 1 destination interface x/y 2. Login to SP Router# remote login switch 3. Enable monitor on switch Router-sp# test monitor add 1 rp-inband both --- проверено на 18, работает. а резать arp на control-plane особого толка нет, на 65 это делается примерно так: mls qos protocol arp police бла-бла-бла, 32kb минимум Вставить ник Quote
darkagent Posted April 7, 2011 Posted April 7, 2011 это такой мы для себя вывод сделали без тщательного анализа поспешные выводы делать не всегда хорошо. а резать arp на control-plane особого толка нет да как бы arp всегда был и остается наибольшим убивцем cpu в ядрах сети. на 65 это делается примерно так да в принципе как на 7600. в таком случае стоит прибегнуть к вайтпапперу best practicies для кошек http://www.cisco.com/web/about/security/intelligence/coppwp_gs.html там как раз про arp атаки расписано. Вставить ник Quote
Дятел Posted April 7, 2011 Posted April 7, 2011 там как раз про arp атаки расписано. не было атаки. замена софта вылечила. Вставить ник Quote
C@T Posted April 7, 2011 Posted April 7, 2011 да, и если еще не переехали на 33, можно навесить SPAN на cpu немного извращенным способом, цитирую: Уважаемый staryk, а не знаете, как сделать тоже самое, то есть CPU SPAN, на 33 ? эти команды там не работают, а какими их заменили, информацию найти не удалось Вставить ник Quote
darkagent Posted April 7, 2011 Posted April 7, 2011 не было атаки. замена софта вылечила. дай бог... как показывает практика, иногда в сети появляются доморощенные хитрожопы, зачастую в лице начинающих монтажников крупных конкурирующих контор, желающие хоть как то поднасрать.. так что готовым надо быть ко всему. Вставить ник Quote
