Extreme Networks BD 6800.
Укомплектован:
1 G8Ti 701028 10 0023F25470 Operational Configured as G8Ti Express
2 G16X3 701062 07 0344F70400 Operational Configured as G16X3 Express
3 G8Xi 701024 11 0021F19657 Operational Configured as G8Xi Express
4 G8Xi 701024 13 0027F39015 Operational Configured as G8Xi Express
A MSM 701021 16 0135F15963 MASTER
B MSM 701021 17 0220F71386 SLAVE
5 G8Xi 701024 26 0119f99343 Operational Configured as G8Xi Express
6 G16X3 701062 07 0346F70495 Operational Configured as G16X3 Express
7 G8Xi 701024 09 0006F03126 Operational Configured as G8Xi Express
8 Powerdown Configured as G16X3 Express
Проблема в 8 слоте. Не заводится, когда все слоты включены. Если вынимается любая другая планка , то после рестарта свитча все 7 планок работает и G16X3 в том числе.
SysName: BD6808
SysLocation:
SysContact: support@extremenetworks.com, +1 888 257 3000
System MAC: 68:08:68:08:68:08
Platform: BD6808
License: Full L3
System Mode: 802.1Q EtherType is 8100 (Hex).
Diag Mode: Fast Post
RED Probability: 0
DLCS: Disabled
Backplane Ls: port-based
SysHwRecLevel: none
SysHealth Check: Enabled. Alarm Level = Log
Recovery Mode: None
Transceiver Diag: Disabled. Failure action: log only
Fdb-Scan Diag: Enabled. Failure action: log only
MSM Failover: take-links-down
System Watchdog: Enabled
Reboot Loop Prot: Disabled
Backup-MSM
ESRP-Aware Mode: Enabled
Alter Queue Mgmt: Disabled Next Boot: Disabled
Bus-stats: Enabled
Card-scan: Disabled
Current Time: Sat Apr 2 12:01:51 2011
Timezone: [Auto DST Enabled] GMT Offset: 0 minutes, name is GMT.
DST of 60 minutes is currently in effect, name is not set.
DST begins every second Sunday March at 2:00
DST ends every first Sunday November at 2:00
Boot Time: Sat Apr 2 00:45:55 2011
Config Modified: Sat Apr 2 09:49:50 2011
Next Reboot: None scheduled
MSM-B RebootTime: None scheduled
Timed Upload: None scheduled
Timed Download: None scheduled
Temperature: Normal. All fans are operational.
Power Supply: PSU-A OK @ AC220V, PSU-B OK @ AC220V
MSM: MSM-A MSM-B
Module Type: MSM64i MSM64i
Current State: MASTER SLAVE
Default Cfg Mode: Standard
Image Selected: Primary Primary
Image Booted: Primary
Config Selected: Primary Primary
Config Booted: Primary
EW Versions:
MSM-A
Primary EW Ver: 7.8.2.1 [non-ssh] [wlan]
Secondary EW Ver: 7.8.2.1 [non-ssh] [wlan]
MSM-B
Primary Config: Created by EW Version:
7.8.2.1 [30]
15964 bytes saved on Sat Apr 2 01:18:43 2011
Secondary Config: Created by EW Version:
7.8.2.1 [30]
14848 bytes saved on Tue Jan 11 00:56:02 2011
Подскажите, какое решение этой проблемы может быть?
Спасибо
Edited by alexs200
Гипотезы (на правах бреда):
1) Шина переполнена по пропускной способности
2) Не хватает мощности БП
1. Сеть не превышает 2000 человек. Может не хватать шины при таком количестве абонентов? Да порты гиговые все, но графики на нагруженных портах не показывали выше 150-200мб передачи. Как можно посмотреть нагрузку шины?
2. Power Supply: PSU-A OK @ AC220V, PSU-B OK @ AC220V. Стоит 2 блока питания. Если верить Extreme то там все в порядке/ К сожалению у нас нет возможности взять на тест блок в два раза мощнее тех, которые стоят сейчас.
А может такое быть (я тоже побрежу с вашего позволения), что сей девайс понимает только 7 слотов, а 8й - резервируемый?
Я сталкивался с таким в Alvarion и на кое-каком оборудовании Huawei.
' timestamp='1301754236' post='603213']
Это железно не так! До того как поставить 3 планки на 16 SFP портов, стояли все модуля на 8 GBIC. Все 8 слотов работали.
Первые гипотезы ближе к истине.
В начале было подозрение, что не тянет один модуль управления А. Докупили второй В. Ничего не изменилось. Посоветовали синхронизировать оба. т.е. MSM А MASTER делает полностью копию себя на MSM В SLAVE, включая версию прлошивки, конфиг, загрузочный имидж.
Почему то была 100% уверенность что заработает.
есть еще вариант конфигурирования задней планки, куда входят все эти модули. Жаль , что машина боевая, нет возможности погонять и поэкспериментировать. Изменяем конфиги днем, перегружаем глубоко ночью.
А что в logging при загрузке пишет
ГДЕ ИМЕННО ЭТО СМОТРЕТЬ.
04/02/2011 01:19:10.23 <Info:KERN> NV:Completed configuration save (primary) operation
04/02/2011 01:08:19.43 <Info:SYST> Generating default port configuration for slot 8 module oper type Unknown config type G16X3
04/02/2011 01:08:19.43 <Info:SYST> 10.10.0.10 admin: configure slot 8 module g16x
04/02/2011 01:07:58.21 <Info:SYST> 10.10.0.10 admin: clear slot 8
04/02/2011 01:05:00.17 <Info:SYST> Generating default port configuration for slot 8 module oper type Unknown config type G16X3
04/02/2011 01:05:00.17 <Info:SYST> 10.10.0.10 admin: configure slot 8 module g16x
04/02/2011 01:04:50.00 <Info:SYST> 10.10.0.10 admin: enable slot 8
04/02/2011 01:04:13.59 <Info:SYST> 10.10.0.10 admin: unconfigure slot 8
04/02/2011 00:53:48.17 <Info:USER> admin logged in through http (10.10.0.10)
04/02/2011 00:51:14.81 <Info:SYST> 10.10.0.10 admin: enable slot 8
04/02/2011 00:51:04.19 <Info:KERN> Secondary Mgmt port enabled
04/02/2011 00:51:04.18 <Info:KERN> Secondary Mgmt port initialized
04/02/2011 00:51:00.02 <Info:SYST> 10.10.0.10 admin: configure slot 8 module g16x
04/02/2011 00:50:59.49 <Info:SYST> slave MSM communications pipe is open
04/02/2011 00:50:58.68 <Info:SYST> MSM-B is inserted.
БОЛЬШЕ ВРОДЕ НИЧЕГО НЕ РУГАЕТСЯ НА ПЛАНКУ!
Лучше посмотреть лог непосредственно после загрузки, где определяются модули, Slot ... power on , может там понятней будет почему powerdown
04/02/2011 00:46:02.11 System does not have enough power left to support card 8.
Спасибо! все-таки блок питания. Будем искать мощней.
