zntz Posted March 19, 2011 Posted March 19, 2011 (edited) Добрый вечер. Пожалуйста, помогите в настройке мультикаста... Есть сеть с двумя свичами L3 1) Huawei, к нему подключен хост вещающий мультикаст. На Huawei уже настроен и работает мультикаст (10.1.22.1), т.е. у всех 2) Edge-Core. Активировал мультикаст. Вот на нем уже не вижу мулькаста совершенно (10.1.22.2) соединены транком порт в порт 1/1 вланом 22 на Edge-Core есть еще влан 23 (10.1.23.1) На влане на обоих свичах включил ip pim dense-mode ------------------------------------ Edge-core#sh run int vlan 22 interface Vlan22 ip pim dense-mode ip address 10.1.22.2 255.255.255.252 Edge-core#sh ip pim neighbor Neighbor Interface Uptime/Expires Ver DR Address Prior 10.1.22.1 Vlan22 00:42:18/00:01:28 v2 Edge-core#sh ip igmp snooping vlan 22 Igmp snooping information for vlan 22 Igmp snooping L2 general querier :NO Igmp snooping query-interval :125(s) Igmp snooping max response time :10(s) Igmp snooping robustness :2 Igmp snooping mrouter port keep-alive time :255(s) IGMP Snooping Connect Group Membership Note:*-All Source, (S)- Include Source, -Exclude Source Groups Sources Ports Exptime System Igmp snooping vlan 22 mrouter port Note:"!"-static mrouter port Ethernet1/1 так же активировал ip igmp snooping ip igmp snooping vlan 22 ip igmp snooping vlan 23 ip pim multicast-routing --------------------------------------- [Huawei]disp igmp int vlan 22 Vlan-interface22 (10.200.22.1): IGMP is enabled Current IGMP version is 2 Value of query interval for IGMP(in seconds): 60 Value of other querier time out for IGMP(in seconds): 120 Value of maximum query response time for IGMP(in seconds): 10 Value of robust count for IGMP: 2 Value of startup query interval for IGMP(in seconds): 15 Value of last member query interval for IGMP(in seconds): 1 Value of query timeout for IGMP version 1(in seconds): 400 Policy to accept IGMP reports: none Querier for IGMP: 10.200.22.1 (this router) IGMP group limit is 256 No IGMP group reported что нужно настроить, чтобы на Edge-Core появился мультикаст и как его пробросить на vlan23? Edited March 22, 2011 by zntz Вставить ник Quote
