Есть очень старый узел. На нём стоит коммутатор:
Cisco Internetwork Operating System Software
IOS C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC16, RELEASE SOFTWARE (fc1)
Copyright © 1986-2006 by cisco Systems, Inc.
Compiled Thu 21-Sep-06 12:51 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
B0-1 uptime is 21 minutes
System returned to ROM by reload
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC16.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAA0420K0A5, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:02:16:E7:39:00
Motherboard assembly number: 73-3903-04
Power supply part number: 34-0971-01
Motherboard serial number: FAA04199NYE
Power supply serial number: PAC04140344
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAA0420K0A5
Configuration register is 0xF
Необходимо подключить к нему другой коммутатор по гигабиту по меди. Есть GBIC модуль AT G8T.
При установке модуля состояние порта следующее:
GigabitEthernet0/1 is down, line protocol is down
Hardware is Gigabit Ethernet, address is 0002.16e7.3931 (bia 0002.16e7.3931)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive not set
Auto-duplex , 1000Mb/s, media type is T
output flow-control is off, input flow-control is off
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output never, output hang never
Last clearing of "show interface" counters never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
7 packets input, 448 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
7 packets output, 448 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
Я так понимаю что коммутатор отказывается признавать инородного вендора. Причём глюк чисто софтварный. Возможно ли в конфигурации указать коммутатроу распознование инородных модулей? Есть слухи что такая команда есть, но она недокументирована. Может кто подскажет?
Попробуйте так:
service unsupported-transceiver (команда скрытая и пишется именно так)
no errdisable detect cause gbic-invalid
Спасибо, завтра попробую. "no errdisable detect cause gbic-invalid" - это вторая команда или ответ на первую?)
Просто по памяти строки имеют формат no errdisable cause {причина}
Edited by M-a-x-Z
Попробуйте так:
Вторая команда так же в глобальном режиме, что бы не засорять лог возможной руганью на gbic
  • 2 weeks later...
