kirush Posted March 10, 2011 Posted March 10, 2011 (edited) Вчера нечайно уронил mpd4, переподнял, с этого момента в логи начались сыпаться: Mar 10 11:43:28 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 110): option length exceeds option buffer length. Mar 10 11:44:32 accounter dhcpd: parse_option_buffer: malformed option dhcp.merit-dump (code 14): option length exceeds option buffer length. Mar 10 11:44:36 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 99): option length exceeds option buffer length. Mar 10 11:44:44 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 129): option length exceeds option buffer length. Mar 10 11:45:00 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 129): option length exceeds option buffer length. Mar 10 11:45:32 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 129): option length exceeds option buffer length. Mar 10 11:46:36 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 129): option length exceeds option buffer length. Mar 10 11:46:40 accounter dhcpd: parse_option_buffer: malformed option dhcp.merit-dump (code 14): option length exceeds option buffer length. Mar 10 11:46:48 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 129): option length exceeds option buffer length. Mar 10 11:47:04 accounter dhcpd: parse_option_buffer: malformed option dhcp.<unknown> (code 129): option length exceeds option buffer length. Mar 10 11:51:12 accounter dhcpd: parse_option_buffer: malformed option dhcp.client-last-transaction-time (code 91): option length exceeds option buffer length. С чем это может быть связано? В Гугле ничего понятного не нашел. tcpdump на этот пакет говорит: 14:17:28.836814 IP (tos 0xc0, ttl 30, id 43056, offset 0, flags [none], proto UDP (17), length 328) 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:05:5d:8d:8c:bb, length 300, xid 0x78b, secs 64463, Flags [none] (0x600a) Client-Ethernet-Address 00:05:5d:8d:8c:bb [|bootp] 14:17:28.987429 IP (tos 0x0, ttl 64, id 19287, offset 0, flags [none], proto UDP (17), length 330) 10.1.15.123.68 > 10.1.255.254.67: BOOTP/DHCP, Request from 6c:f0:49:91:55:b8, length 302, xid 0xdbb2f01d, Flags [none] (0x0000) Client-IP 10.1.15.123 Client-Ethernet-Address 6c:f0:49:91:55:b8 [|bootp] 14:17:28.987645 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 484) 10.1.255.254.67 > 255.255.255.255.68: BOOTP/DHCP, Reply, length 456, xid 0xdbb2f01d, Flags [Broadcast] (0x8000) Client-IP 10.1.15.123 Your-IP 10.1.15.123 Client-Ethernet-Address 6c:f0:49:91:55:b8 [|bootp] Edited March 10, 2011 by kirush Вставить ник Quote
