Протоколы - IEEE 802.11b/g
Частотный диапазон - 2.4-2.483 GHz
Модуляции - 802.11g - OFDM (64-QAM, 16-QAM,QPSK, BPSK) 802.11b - DSSS (DBPSK, DQPSK, CCK)
Выходная мощность - 36 dBm
Метод доступа - CSMA/CA with ACK
Чувствительность приемника:
-100dBm @ 1 Mbps -92dBm @ 12 Mbps
-95dBm @ 2 Mbps -89dBm @ 18 Mbps
-93dBm @ 5.5 Mbps -86dBm @ 24 Mbps
-91dBm @ 11 Mbps -83dBm @ 36 Mbps
-94dBm @ 6 Mbps -78dBm @ 48 Mbps
-93dBm @ 9 Mbps -76dBm @ 54 Mbps
Функционал
TCP and VPN session persistent roaming across subnets
Mobile tactical mesh operating mode
Full 802.11b/g client compatibility
802.1q VLAN support
Support for static and dynamic addressing for wireless and wired clients
Layer 2 and Layer 3 support
DHCP Server and Relay
NAT support
Plug & Play Wired client support
Two (2) 10/100 Base-T Ethernet ports (Management and CPE connection)
802.11e WMM QoS support
802.1p/q with 4 queues per VLAN and ESSID
Two (2) Type-A USB ports
Console port (for factory use) and Serial port
Аппаратная спецификация
Autosensing 10/100 BaseT Ethernet
Power input: 10.0 to 32.0VDC
Power consumption: 8W typical
Управление
RADIUS Accounting
Secure Local and Remote Management Tools via ,HTTPS externally accessible
Configuration Save and Restore
Software Upgrades with Rollback
Command Line Interface (CLI) via SSH
SNMP (standard MIBs and Tropos MIB)
Wireless, Network and Client Monitoring, Statistics and Wireless capture capabilities
Состояние на 4+. Лен.область, отправка почтой в любой регион.
Цена договорная....
