Вот что говорит роммон помогите!
Если кто знает tftp клиент вроде правильно настроен вот только фаил чуть не так называется как исправить тот какой по умолчанию не знаю!
Xmodem file system is available.
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 7739904
flashfs[0]: flashfs fsck took 11 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:16:c7:16:c4:53
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
button pressed for 20 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/c1200-k9w7
-tar.default
examining image...tftp://255.255.255.255/c1200-k9w7-tar.default: no such file or
directory
ERROR: Failed to open archive file tftp://255.255.255.255/c1200-k9w7-tar.default
The system is unable to boot automatically because there
are no bootable files to boot.
ap:
ap: version
C1200 Boot Loader (C1200-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Compiled Mon 13-Jun-05 15:39 by ssearch
Error opening flash:/update/info (no such file or directory)
ERROR: Image is not a valid IOS image archive.
Edited by Cezar1209
Reset done!
-tar.default
directory
ap:
ap: version
Нашел решение!! Если сому интересно команда xmodem!
copy xmodem flash:ios.bin
