АТС - Cisco 1751 fxo (pppoe+adsl) - tunnel - cisco 1751 fxs
C1751 - ADSL-PPPOE FXO
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
no ftp-server write-enable
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback cisco
h323
sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
interface Tunnel0
description #tunnel2Srgt
ip address 10.10.0.2 255.255.255.252
ip tcp adjust-mss 1460
keepalive 3 3
tunnel source Dialer1
tunnel destination 195.114.ххх.ххх
tunnel path-mtu-discovery
interface FastEthernet0/0
description #General_UpLink#
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no keepalive
no cdp enable
interface FastEthernet0/0.201
description #Office#
encapsulation dot1Q 201
ip address 192.168.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1202
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname eleks
ppp chap password 7 073B0663542B21
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface Dialer1
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname ****
ppp chap password 7 *******
ip nat inside source list 102 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.10.0.1 255.255.255.255 Tunnel0
ip route 192.168.0.0 255.255.255.0 10.10.0.1
no ip http server
voice-port 2/0
supervisory disconnect anytone
ring number 2
no battery-reversal
disc_pi_off
no vad
no comfort-noise
cptone RU
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 210
voice-port 2/1
dial-peer voice 11 pots
destination-pattern 110
port 2/0
dial-peer voice 100 voip
incoming called-number .
destination-pattern .T
voice-class codec 1
session target ipv4:10.10.0.1
dtmf-relay cisco-rtp
no vad
это со стороны C1751 FXS без всяких там левых инкапсуляций
voice service voip
fax protocol t38 ls-redundancy 3 hs-redundancy 0 fallback cisco
h323
sip
voice class codec 1
interface Tunnel0
description #Tunnel2NJC#
ip address 10.10.0.1 255.255.255.252
keepalive 3 3
tunnel source FastEthernet0/0.100
tunnel destination 80.242.49.233
interface FastEthernet0/0.100
description #Uplink2Inet#
encapsulation dot1Q 100
ip address 195.114.xxx.xxx 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no cdp enable
interface FastEthernet0/0.202
encapsulation dot1Q 202
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
ip nat inside source list 102 interface FastEthernet0/0.100 overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0.100 254
ip route 10.10.0.2 255.255.255.255 Tunnel0
ip route 192.168.1.0 255.255.255.0 10.10.0.2
no ip http server
voice-port 2/0
no battery-reversal
disc_pi_off
cptone RU
timeouts call-disconnect 1
timeouts wait-release 1
connection plar 110
caller-id enable
voice-port 2/1
dial-peer voice 1 pots
destination-pattern 210
port 2/0
voice-class codec 1
session target ipv4:10.10.0.2
no vad
Дебаг на стороне FXO
с fxs звонки приходят на атс и можно разговаривать сколько тебе влезет, а вот если звонок с FXO -> fxs пару секунд и обрыв,
в дебаги FXO :
002505: .Feb 14 16:27:33: voip_rtp_update_xmit_info, dstvdbptr: 0, dstCallID -1, gccb: 82968034, xmitFunc 0,context 0
002506: .Feb 14 16:27:33: voip_rtp_update_xmit_info Context is NULL, exit
002507: .Feb 14 16:27:33: voip_rtcp_close_session
002508: .Feb 14 16:27:33: voip_rtcp_stop_session:
002509: .Feb 14 16:27:33: voip_rtcp_stop_session: stop session
002510: .Feb 14 16:27:33: voip_rtcp_stop_session: ERROR - Dest IP Addr=0, no RTCP pkt sent
002511: .Feb 14 16:27:33: Cleaning up sess=81E032E0, sp=17056, dp=0
002512: .Feb 14 16:27:33: voip_rtp_update_callinfo: RTCP disabled
002513: .Feb 14 16:27:33: voip_rtp_update_callinfo: RTP address/port changes A0A0001:4B4E->0:0
002514: .Feb 14 16:27:33: voip_rtp_update_callinfo: first_pak=TRUE, new_ssrc=0
002515: .Feb 14 16:27:33: voip_rtp_update_xmit_info
002516: .Feb 14 16:27:33: voip_rtp_update_xmit_info, dstvdbptr: 0, dstCallID -1, gccb: 82968034, xmitFunc 0,context 0
002517: .Feb 14 16:27:33: voip_rtp_update_xmit_info Context is NULL, exit
002518: .Feb 14 16:27:33: voip_rtp_stop_disc_timer
002519: .Feb 14 16:27:33: voip_rtcp_remove_ccb
002520: .Feb 14 16:27:33: regxrule_stack_pop_RegXruleNumInfo: stack=0x826F8F7C; count=1
002521: .Feb 14 16:27:33: voip_rtcp_close_session
002522: .Feb 14 16:27:33: voip_rtcp_stop_session:
002523: .Feb 14 16:27:33: voip_rtcp_stop_session: stop session
002524: .Feb 14 16:27:33: voip_rtcp_stop_session: ERROR - Dest IP Addr=0, no RTCP pkt sent
002525: .Feb 14 16:27:33: Cleaning up sess=81E02FA4, sp=18822, dp=0
002526: .Feb 14 16:27:34: regxrule_stack_pop_RegXruleNumInfo: stack=0x81E04C78; count=1
002527: .Feb 14 16:27:34: voip_rtp_create_session: callID=60, dstCallID=-1 laddr=10.10.0.2, lport=17852,raddr=10.10.0.1, rport=17200, type=3, sig_tos=3, ip_tos=5
002528: .Feb 14 16:27:34: voip_rtcp_get_cname: cname=0.0.0@10.10.0.2
002529: .Feb 14 16:27:34: voip_rtp_update_xmit_info
002530: .Feb 14 16:27:34: voip_rtp_update_xmit_info, dstvdbptr: 0, dstCallID -1, gccb: 82968034, xmitFunc 0,context 0
002531: .Feb 14 16:27:34: voip_rtp_update_xmit_info Context is NULL, exit
002532: .Feb 14 16:27:34: voip_rtp_set_non_rtp_call: Non-RTP call end
002533: .Feb 14 16:27:34: voip_rtcp_start_session:
002534: .Feb 14 16:27:34: voip_rtcp_start_session: start session
002535: .Feb 14 16:27:34: regxrule_stack_push_RegXruleNumInfo: stack=0x81E04C78; count=0
002536: .Feb 14 16:27:34: regxrule_profile_translate: Error: invalid input; callinfo=0x829511D8 profilep=0x0 rtype=calling
002537: .Feb 14 16:27:34: regxrule_profile_translate: Error: invalid input; callinfo=0x829511D8 profilep=0x0 rtype=redirect-called
002538: .Feb 14 16:27:34: regxrule_profile_translate: Error: invalid input; callinfo=0x829511D8 profilep=0x0 rtype=called
002539: .Feb 14 16:27:34: voip_rtp_update_callinfo: first_pak=TRUE, new_ssrc=0
002540: .Feb 14 16:27:34: voip_rtp_update_xmit_info
002541: .Feb 14 16:27:34: voip_rtp_update_xmit_info, dstvdbptr: 0, dstCallID -1, gccb: 82968034, xmitFunc 0,context 0
002542: .Feb 14 16:27:34: voip_rtp_update_xmit_info Context is NULL, exit
002543: .Feb 14 16:27:35: voip_rtp_update_callinfo: RTCP disabled
002544: .Feb 14 16:27:35: voip_rtp_update_callinfo: RTP address/port changes A0A0001:4330->0:0
002545: .Feb 14 16:27:35: voip_rtp_update_callinfo: first_pak=TRUE, new_ssrc=0
002546: .Feb 14 16:27:35: voip_rtp_update_xmit_info
002547: .Feb 14 16:27:35: voip_rtp_update_xmit_info, dstvdbptr: 0, dstCallID -1, gccb: 82968034, xmitFunc 0,context 0
002548: .Feb 14 16:27:35: voip_rtp_update_xmit_info Context is NULL, exit
002549: .Feb 14 16:27:35: voip_rtp_stop_disc_timer
002550: .Feb 14 16:27:35: voip_rtcp_remove_ccb
002551: .Feb 14 16:27:35: regxrule_stack_pop_RegXruleNumInfo: stack=0x81E04C78; count=1
002552: .Feb 14 16:27:35: voip_rtcp_close_session
002553: .Feb 14 16:27:35: voip_rtcp_stop_session:
002554: .Feb 14 16:27:35: voip_rtcp_stop_session: stop session
002555: .Feb 14 16:27:35: voip_rtcp_stop_session: ERROR - Dest IP Addr=0, no RTCP pkt sent
002556: .Feb 14 16:27:35: Cleaning up sess=81E032E0, sp=17852, dp=0
В двух словах
АТС подключена к FXO портам.
Внутрений номер пробрасывается в другой город.
При звонке с FXS звонок проходит и можно разговаривать.
При звонке с FXO звонок проходит и через 2~15 сек обрывается.
Дебаг ловит ошибку 002555: .Feb 14 16:27:35: voip_rtcp_stop_session: ERROR - Dest IP Addr=0, no RTCP pkt sent
и еще страннее
Прошу знающих помочь в решение данной проблемы.!
За кошака точно нескажу, а вот в AddPac'ах при connection plar (со стороны FXO) сия бага лечилась прописываением ring detect-timeout 70 на порт. Возможно и тут нечто подобное нужно.
Edited by Morze
на порт или диал пиир ?
насколько я понимаю кошка и аддпак сильно не отличаюстя
в этой кошке не нашел где писать сие ((
сюда
voice-port 2/0
connection plar 210
Вот мне тоже всегда казалось, что кошка и пак как братья близнецы. Возможно ком*** зовется немного иначе.
Log Buffer (8192 bytes):
6 11:23:52: RTP(4797): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C374B, ssrc=E540001
007131: Feb 16 11:23:52: RTP(4798): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C37EB, ssrc=E540001
007132: Feb 16 11:23:52: RTP(4799): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C388B, ssrc=E540001
007133: Feb 16 11:23:52: RTP(4256): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C4C8B, ssrc=D670002
007134: Feb 16 11:23:52: RTP(4800): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C392B, ssrc=E540001
007135: Feb 16 11:23:52: RTP(4801): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C39CB, ssrc=E540001
007136: Feb 16 11:23:52: RTP(4802): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3A6B, ssrc=E540001
007137: Feb 16 11:23:52: RTP(4803): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3B0B, ssrc=E540001
007138: Feb 16 11:23:52: RTP(4804): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3BAB, ssrc=E540001
007139: Feb 16 11:23:52: RTP(4805): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3C4B, ssrc=E540001
007140: Feb 16 11:23:52: RTP(4806): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3CEB, ssrc=E540001
007141: Feb 16 11:23:52: RTP(4807): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3D8B, ssrc=E540001
007142: Feb 16 11:23:52: RTP(4808): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3E2B, ssrc=E540001
007143: Feb 16 11:23:52: RTP(4809): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3ECB, ssrc=E540001
007144: Feb 16 11:23:52: RTP(4810): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C3F6B, ssrc=E540001
007145: Feb 16 11:23:52: RTP(4811): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C400B, ssrc=E540001
007146: Feb 16 11:23:52: RTP(4812): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C40AB, ssrc=E540001
007147: Feb 16 11:23:52: RTP(4813): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C414B, ssrc=E540001
007148: Feb 16 11:23:52: RTP(4823): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C478B, ssrc=E540001
007149: Feb 16 11:23:53: RTP(4257): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C4D2B, ssrc=D670002
007150: Feb 16 11:23:53: RTP(4824): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C482B, ssrc=E540001
007151: Feb 16 11:23:53: RTP(4258): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C4DCB, ssrc=D670002
007152: Feb 16 11:23:53: RTP(4259): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C4E6B, ssrc=D670002
007153: Feb 16 11:23:53: RTP(4825): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C48CB, ssrc=E540001
007154: Feb 16 11:23:53: RTP(4260): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C4F0B, ssrc=D670002
007155: Feb 16 11:23:53: RTP(4826): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C496B, ssrc=E540001
007156: Feb 16 11:23:53: RTP(4261): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C4FAB, ssrc=D670002
007157: Feb 16 11:23:53: RTP(4827): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4A0B, ssrc=E540001
007158: Feb 16 11:23:53: RTP(4828): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4AAB, ssrc=E540001
007159: Feb 16 11:23:53: RTP(4296): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C658B, ssrc=D670002
007160: Feb 16 11:23:53: RTP(4829): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4B4B, ssrc=E540001
007161: Feb 16 11:23:53: RTP(4830): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4BEB, ssrc=E540001
007162: Feb 16 11:23:53: RTP(4831): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4C8B, ssrc=E540001
007163: Feb 16 11:23:53: RTP(4832): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4D2B, ssrc=E540001
007164: Feb 16 11:23:53: RTP(4833): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4DCB, ssrc=E540001
007165: Feb 16 11:23:53: RTP(4834): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4E6B, ssrc=E540001
007166: Feb 16 11:23:53: RTP(4835): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4F0B, ssrc=E540001
007167: Feb 16 11:23:53: RTP(4836): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C4FAB, ssrc=E540001
007168: Feb 16 11:23:53: RTP(4837): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C504B, ssrc=E540001
007169: Feb 16 11:23:53: RTP(4838): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C50EB, ssrc=E540001
007170: Feb 16 11:23:53: RTP(4839): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C518B, ssrc=E540001
007171: Feb 16 11:23:53: RTP(4840): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C522B, ssrc=E540001
007172: Feb 16 11:23:53: RTP(4841): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C52CB, ssrc=E540001
007173: Feb 16 11:23:53: RTP(4842): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C536B, ssrc=E540001
007174: Feb 16 11:23:53: RTP(4843): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C540B, ssrc=E540001
007175: Feb 16 11:23:53: RTP(4844): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C54AB, ssrc=E540001
007176: Feb 16 11:23:53: RTP(4845): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C554B, ssrc=E540001
007177: Feb 16 11:23:53: RTP(4863): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C608B, ssrc=E540001
007178: Feb 16 11:23:53: RTP(4297): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C662B, ssrc=D670002
007179: Feb 16 11:23:53: RTP(4864): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C612B, ssrc=E540001
007180: Feb 16 11:23:53: voip_rtcp_send_event: event=EV_STATS
007181: Feb 16 11:23:53: voip_rtcp_stats_req: rtcp_interval=6391
007182: Feb 16 11:23:53: voip_rtcp_stats_req:delay=75 rtt=918
007183: Feb 16 11:23:53: voip_rtcp_stats_req: rtp_member ptr=0x8261CA8C,
rtp stream: previous lost packets=51, current lost packets=192
total lost packets for the call=192
007184: Feb 16 11:23:54: RTP(4865): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C61CB, ssrc=E540001
007185: Feb 16 11:23:54: RTP(4298): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C66CB, ssrc=D670002
007186: Feb 16 11:23:54: RTP(4299): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C676B, ssrc=D670002
007187: Feb 16 11:23:54: RTP(4300): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C680B, ssrc=D670002
007188: Feb 16 11:23:54: RTP(4866): fs rx d=10.10.0.1(16524), pt=0, ts=FB5C626B, ssrc=E540001
007189: Feb 16 11:23:54: RTP(4301): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C68AB, ssrc=D670002
007190: Feb 16 11:23:54: RTP(4302): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C694B, ssrc=D670002
007191: Feb 16 11:23:54: RTP(4303): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C69EB, ssrc=D670002
007192: Feb 16 11:23:54: RTP(4304): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C6A8B, ssrc=D670002
007193: Feb 16 11:23:54: RTP(4305): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C6B2B, ssrc=D670002
007194: Feb 16 11:23:54: RTP(4330): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C7ACB, ssrc=D670002
007195: Feb 16 11:23:54: recv:
007196: Feb 16 11:23:54: RR: ssrc=0xD670002 rr_loss=0xBB000183 rr_ehsr=4256 rr_jitter=600 rr_lsr=0xEBF0E9B2 rr_dlsr=0x87DF3
007197: Feb 16 11:23:54: SDES: ssrc=0xE540001 name=1 len=15 data=0.0.0@10.10.0.1
007198: Feb 16 11:23:54: BYE: ssrc=0xE540001
007199: Feb 16 11:23:54: rtcp_round_trip_delay: ssrc=0xD670002
007200: Feb 16 11:23:54: RTT: now_mid_32=0xEBFA25F7 rr->rr_dlsr=0x87DF3 rr->rr_lsr=0xEBF0E9B2 rtt=743 (ms)
007201: Feb 16 11:23:54: RTP(4331): fs tx d=10.10.0.1(16524), pt=0, ts=FB5C7B6B, ssrc=D670002
007202: Feb 16 11:23:54: voip_rtp_update_callinfo: first_pak=TRUE, new_ssrc=0
007203: Feb 16 11:23:54: voip_rtp_update_xmit_info
007204: Feb 16 11:23:54: voip_rtp_update_xmit_info, dstvdbptr: 825D7934, dstCallID 18, gccb: 81DDA750, xmitFunc 0,context 0
007205: Feb 16 11:23:54: voip_rtp_update_xmit_info xmit_func is NULL
007206: Feb 16 11:23:54: voip_rtp_stop_disc_timer
007207: Feb 16 11:23:54: //18/1F4027F58003/CCAPI/ccGetCallActiveByCallID: cc_spi_call_get() returned -7. (setup_time=0x15688C, index=0x1)
007208: Feb 16 11:23:54: //18/1F4027F58003/CCAPI/cc_api_call_disconnect_done: cause=16,retry=0,vcCauseCode=0
007209: Feb 16 11:23:54: voip_rtp_stop_disc_timer
007210: Feb 16 11:23:54: voip_rtcp_remove_ccb
007211: Feb 16 11:23:54: voip_rtcp_send_event: event=EV_DESTROY
007212: Feb 16 11:23:54: //17/1F4027F58003/CCAPI/cc_api_call_disconnect_done: cause=16,retry=0,vcCauseCode=0
007213: Feb 16 11:23:54: regxrule_stack_pop_RegXruleNumInfo: stack=0x826769E0; count=2
007214: Feb 16 11:23:54: //18/xxxxxxxxxxxx/CCAPI/cc_get_call_entry: callID (0x12) not found
007215: Feb 16 11:23:54: voip_rtcp_destroy_idle
007216: Feb 16 11:23:54: voip_rtcp_close_session
007217: Feb 16 11:23:54: voip_rtcp_stop_session:
007218: Feb 16 11:23:54: voip_rtcp_stop_session: stop session
007219: Feb 16 11:23:54: Cleaning up sess=81DFCCE0, sp=17192, dp=16524
Вот что удалось выловить, изменил только тип протокола на sipv2
ring detect-timeout 70 - не знает он этой комманды (((
Не интересный лог. А дамп вайршарком или tcpdump'ом снять не?
Или хотя бы debug ccsip all, если я ничего не путаю.
По поводу отбоя звонка вопросы есть. ~2-15 после поднятия или до? Голос есть при этом, и в какую сторону, если есть?
leveler wiresharkom снять трудно, дебаг debug ccsip all попробую снять.
Я же говорил, Fxo - FXS соединение устанавливается, можно успеть погворить и 2~15 сек, отбой.
с FXS на FXO звонки проходят на ура, говрит можно сколько влезит.
Щас удалось выяснить законномерность, при игре с IP MTU и ip tcp-adjussment подобрал такое значение когда звонок проходит, с FXO - FXS и можно гвоорить, проговорил 3 минуты
Неужеле все упирается в MTU?
дак вот хз, пока седня не поигрался, появилась проблема заикания при разговоре, в любую сторону, то есть слышно что трубку взяли, говорят, а что говрят черт ногу сломит, (обрывы присутсвовали)...
Выставил знчения ве вроде заработало
