diesels Posted December 15, 2010 Posted December 15, 2010 В общем модем такой zyxel P660R-T1 System Name: P660R-T1 ZyNOS F/W Version: V3.40(AHO.3) | 10/08/2007 DSL FW Version:DMT FwVer: 3.7.9.7_A_TC, HwVer: T14F7_0.0 Standard:ADSL_G.dmt В диагностике пишет вот что : ATM status [ SAR Counters ] inPkts = 0x00070add, inDiscards = 0x00000031 inF4Pkts = 0x00000000, inF5Pkts = 0x00000000 inDMATaskEnd = 0x00000000, inBufErr = 0x00000000 inCrcErr = 0x0000000d inBufOverflow = 0x00000005, inBufMaxLenErr= 0x00000000 inBufLenErr = 0x0000001f, inBufDescrOV = 0x00000001 outPkts = 0x000570c9, outDiscards = 0x00000183 outF4Pkts = 0x00000000, outF5Pkts = 0x00000000 softRstCnt = 0x00000000 noise margin upstream: 7 db output power downstream: 16 db attenuation upstream: 31 db carrier load: number of bits per symbol(tone) tone 0- 31: 00 00 00 34 56 78 88 88 78 77 76 66 66 55 44 40 tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 noise margin downstream: 7 db output power upstream: 12 db attenuation downstream: 63 db carrier load: number of bits per symbol(tone) tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 32- 63: 00 00 00 00 00 23 33 34 44 32 02 26 78 99 a9 99 tone 64- 95: 0a 99 98 46 89 98 98 79 89 88 98 68 88 87 78 77 tone 96-127: 77 86 66 67 52 06 55 65 63 55 55 44 04 44 44 40 tone 128-159: 23 33 22 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Провайдер Ютел, по тарифу должно быть 4 мегабита, реально получается около 1. скорость скачки не больше 122-160 кбайт в сек. Пробовал на разных серверах. торах. В поддержке говорят что у меня модем гавно. Ну вроде как зухели делали раньше на совесть. Думаю может просто он у меня устарел ? или все таки линия с большими помехами. Вставить ник Quote
msdt Posted December 15, 2010 Posted December 15, 2010 >noise margin upstream: 7 db >noise margin downstream: 7 db Соотношение сигнал/шум на границе минимально приемлемого для ADSL (хотя, возможно, в настройках дэслама выставлены такие целевые SNR). >attenuation upstream: 31 db >attenuation downstream: 63 db И затухание чрезмерно большое. Хотя есть вероятность, что модем врет. Но скорее всего линия никуда не годная. P.S. Есть возможность протестироваться с каким-либо другим модемом? Вставить ник Quote
diesels Posted December 15, 2010 Author Posted December 15, 2010 Буду пробовать. другой ставить. как будут новости напишу. Вставить ник Quote
diesels Posted December 15, 2010 Author Posted December 15, 2010 Спасибо за ответ. Вставить ник Quote
Ivan_83 Posted December 15, 2010 Posted December 15, 2010 Убрать сплитер, отключить от линии всё, кроме модема и повторно посмотреть что пишет модем о линии. Вставить ник Quote
diesels Posted December 18, 2010 Author Posted December 18, 2010 Это без сплитера. noise margin downstream: 6 db output power upstream: 12 db attenuation downstream: 63 db carrier load: number of bits per symbol(tone) tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 32- 63: 00 00 22 02 34 45 55 55 55 54 03 57 89 aa aa aa tone 64- 95: 0a 9a a9 97 87 89 99 99 98 88 87 78 88 77 77 77 tone 96-127: 77 77 77 76 66 55 66 66 65 55 55 55 45 54 44 44 tone 128-159: 34 44 33 22 00 00 20 22 22 22 00 02 20 00 00 00 tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 noise margin upstream: 6 db output power downstream: 16 db attenuation upstream: 31 db carrier load: number of bits per symbol(tone) tone 0- 31: 00 00 00 46 67 88 88 88 88 88 77 77 66 66 55 40 tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Вставить ник Quote
diesels Posted December 18, 2010 Author Posted December 18, 2010 ADSL Status Showtime/Data DSL Up Time 0:7:14 Data Path Interleaved Standard G.dmt Bandwidth Down/Up(kbps) 2144/576 SNR Margin Down/Up(dB) 8.0/6.0 Attenuation Down/Up(dB) 56.0/31.5 CRC Down/Up 18/0 FEC Down/Up 76/6 HEC Down/Up 14/0 Это вот с таким модемом, ютел дарил в подарок Product Name SmartAX MT880 Physical Address 00:18:02:6B:39:7C Software Release V100R002B025 Firmware Release E.37.5.55 Release Date (2007-04-12) Batch ID RCC1P7.025.E37555 Я как понял цифры особо не изменились. Это без сплитера. Вывод линия гавно. Сопутствующий вопрос. если модем поставить на улицу. кирдык ему не будет ?у нас мороз до -50 бывает. Или его как то замотать ? Вставить ник Quote
Ivan_83 Posted December 20, 2010 Posted December 20, 2010 Это без сплитера. Я как понял цифры особо не изменились. Это без сплитера. Вывод линия гавно. Сопутствующий вопрос. если модем поставить на улицу. кирдык ему не будет ?у нас мороз до -50 бывает. Или его как то замотать ? Вы от линии телефонной всё остальное отключали?Модему самому сплитер не нужен, он нужен телефону, чтобы не ловить помехи самому при разговоре и не мешатся модему своими помехами. На улицу смысла нет, лучше туда хорошую линию до щитка и прямо в сплитер. Хуавеи вроде не плохие, которые я видел/настраивал работали и не создавали проблем. Вставить ник Quote
diesels Posted December 21, 2010 Author Posted December 21, 2010 у нас от щитка 1 км. линию тянули десятку. потом еще один щиток, и уже по базе раскидали. вот я и думаю может от нашего щитка поставить. хотя это всего метров 40 будет по витой паре. Вставить ник Quote
