antaeus Posted December 6, 2010 Posted December 6, 2010 (edited) Cisco 881, IOS - (C880DATA-UNIVERSALK9_NPE-M), Version 15.1(1)T1, RELEASE SOFTWARE (fc2), PPPoE клиент работает, все подключается, но после разрыва соединения(например выключаю адсл модем), pppoe не поднимается. Прилагаю конфиг: no service padservice tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime localtime service timestamps log datetime localtime service password-encryption no service dhcp ................................ bba-group pppoe global ! ! interface Tunnel0 ip address 172.16.111.2 255.255.255.252 tunnel source Dialer1 tunnel destination %адрес% ! interface FastEthernet0 description INSIDE ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 description OUTSIDE no ip address no ip unreachables duplex auto speed auto pppoe-client dial-pool-number 1 no keepalive no cdp enable ! interface Virtual-Template1 ip unnumbered FastEthernet0 ip mtu 1492 autodetect encapsulation ppp ppp authentication chap ms-chap ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$ ip address 192.168.199.1 255.255.255.0 ip access-group Inside in ip tcp adjust-mss 1452 ! interface Dialer1 ip address negotiated no ip proxy-arp ip mtu 1492 ip flow ingress ip virtual-reassembly encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer idle-timeout 0 dialer persistent delay initial 30 dialer persistent delay 15 no keepalive ppp authentication pap callin ppp pap sent-username %юзер% password 7 %пассворд% no cdp enable Edited December 6, 2010 by antaeus Вставить ник Quote
antaeus Posted December 6, 2010 Author Posted December 6, 2010 добавил в interface Dialer1 dialer idle-timeout 0 dialer persistent delay initial 30 dialer persistent delay 15 не помогло Вставить ник Quote
