AntonS Posted November 14, 2010 Posted November 14, 2010 (edited) l2tp_server: create bundle template A set iface enable proxy-arp set iface idle 1800 set iface enable tcpmssfix set ipcp yes vjcomp set ipcp dns xx.xx.xx.xx set bundle enable compression set ccp yes mppc set mppc yes e40 set mppc yes e128 set mppc yes stateless create link template N l2tp set link action bundle A set link enable multilink set l2tp enable incoming set link yes acfcomp protocomp set link no pap chap set link enable chap set link keep-alive 10 60 set link mtu 1460 set link mru 1460 # set link mtu 1500 # set link mru 1500 set l2tp disable windowing set l2tp enable always-ack set link enable incoming set link enable peer-as-calling set radius retries 3 set radius timeout 3 set radius me 10.1.1.1 set radius server 10.1.1.1 1812 1813 set radius config /etc/radius.conf set radius enable message-authentic set auth acct-update 300 # set auth disable internal set auth max-logins 1 set auth enable radius-auth не могу понять почему в windows xp тупо виснет соединение при нагрзуке на dlink 655 идут потери а в windows 7 все ок Edited November 14, 2010 by AntonS Вставить ник Quote
