Есть Cisco 7201
C7201#show ver
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 11:19 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
C7201 uptime is 5 weeks, 31 minutes
System returned to ROM by power-on
System restarted at 20:54:58 N.Nov Mon Oct 4 2010
System image file is "disk0:/c7200p-adventerprisek9-mz.124-22.T.bin"
Пропадает память куда то в течении месяца, помогает только перезагруз. В чем мо жет быть дело и как с этим бороться??
C7201#show memory
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor    67F29A0   813745844   710395148   103350696   102540084    68211044
      I/O   38000000    67108864    32459916    34648948    34648948    33752828
Transient   37000000    16777216       91344    16685872    16028516    16680084
--More--
C7201#show processes memory sorted allocated
Processor Pool Total:  813745844 Used:  710260064 Free:  103485780
      I/O Pool Total:   67108864 Used:   32445392 Free:   34663472
Transient Pool Total:   16777216 Used:      91312 Free:   16685904
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
276   0 4160880344 3858924144  306436872          0          0 VTEMPLATE Backgr
273   0 3791208268  922426400      58976     117936          0 RADIUS
256   0 3387287164  649801740     846096          0          0 PPPoE Discovery
  93   0 3227955680        504      18296          0          0 PPP Hooks
267   0 3202849480          0      13244          0          0 PDU DISPATCHER
   0   0 2716689276 2709876692     708320     286700          0 *Dead*
  75   0 2652369512          0       7244      11340          0 AAA ACCT Proc
112   0 2464276136   17106400      19024        520          0 PPP IP Route
  20   0 2412223796 2411861356     226780      84500          0 ARP Background
  41   0 2302196476        960     181732      16308          0 Net Background
270   0 2027540832 2027540832      13244          0          0 SNMP ConfCopyPro
255   0 2000150184  930427460     974244      16308          0 PPPoE Background
137   0 1401489972 1934685448      71804          0          0 PPP Bind
107   0 1183642428          0      10336          0          0 IP Background
  82   0 1127547948 1103217676   23383160    4857320       2860 ADJ resolve proc
   1   0 1050419900 1049485192     954368          0          0 Chunk Manager
186   0  976592732 3278500476      17860       1560          0 BGP I/O
  95   0  925435688 2185862340     127384          0          0 SSS Manager
271   0  863559320  863635476      14260      43092          0 SNMP Traps
  19   0  689000260  688898572      69820          0          0 ARP Input
  76   0  633025436          0      56628       8316          0 ACCT Periodic Pr
268   0  519982780 3722832776      13244          0          0 SNMP ENGINE
  85   0  487134300   18550324   46700256   15509012    3199680 IP Input
261   0  435761016 3984586004    1521732     257920          0 PPP Events
277   0  385123668 3010379176  190614004          0          0 BGP Router
   0   0  375153756  306155872   65513204          0          0 *Init*
108   0  353675300 1572015380   62436020          0          0 IP RIB Update
  74   0  223857784      16388       9364          0          0 AAA Server
216   0  146140512  905370600       7244          0          0 AAA SEND STOP EV
  45   0  127947156  125880712    2107604       5076          0 Per-Second Jobs
163   0  104647564  104647564       7244          0          0 CRM_CALL_UPDATE_
283   3   79709480   79696704      26272          0          0 Virtual Exec
228   0   65293428   65252008      43840       4536          0 Syslog
   6   0   43752216   19916412   31430448   15119752   12371676 Pool Manager
279   0   29538424   29534548      11060        780          0 BGP Open
266   0   13082036   13080448      14316          0          0 IP SNMP
116   0    7608672  414434392      13244          0          0 TCP Protocols
115   0    5173168    5406076      79136      13260          0 TCP Timer
113   0    2056972    2054384      15832          0          0 PPP IPCP
284   4    1428540    1425512      16476          0          0 Virtual Exec
202   0    1197700    1065792      13496          0          0 IPSEC key engine
164   0     669956          0      10444          0          0 BGP Scheduler
  59   0     651792       1328     632464          0          0 USB Startup
  32   0     526252          0     536496     213192          0 EEM ED Syslog
282   2     497828     451484      59252          0          0 Virtual Exec
  83   0     492600    2488216     374048          0          0 IP ARP Adjacency
показать конфиг для начала, тут конечно есть телепаты, но их мало, и они ленивые.
Такое ощущение что виновато pppoe
aaa new-model
aaa authentication ppp test_ppp group radius local
aaa authorization network test_ppp group radius
aaa accounting send stop-record authentication failure
aaa accounting delay-start
aaa accounting jitter maximum 60
aaa accounting update newinfo periodic 1
aaa accounting exec test_ppp
action-type start-stop
group radius
aaa accounting network test_ppp
group radius
bba-group pppoe global
virtual-template 1
sessions max limit 500
sessions per-vc limit 1000
sessions per-mac limit 15000
interface Loopback1
description PPPoE connect
ip address 89.28.198.2 255.255.255.255
interface GigabitEthernet0/1.1500
description PPPoE_access
encapsulation dot1Q 1500
no ip redirects
no ip proxy-arp
ip flow ingress
no ip mroute-cache
pppoe enable group global
pppoe max-sessions 1000
no cdp enable
interface Virtual-Template1
ip unnumbered Loopback1
ip flow ingress
ip tcp header-compression
peer default ip address pool PPPoE1
ppp authentication chap callin test_ppp
ppp authorization test_ppp
ppp accounting test_ppp
ip local pool PPPoE1 x.x.x.x y.y.y.y
radius-server attribute 44 include-in-access-req
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 31 mac format ietf
radius-server host z.z.z.z auth-port 1812 acct-port 1813
radius-server key 7 083541451909151817
radius-server vsa send authentication
Может что-то кописься из-за аккаутинга???
В логах ничего необычного нету.
Edited by detx
