Zohan Posted November 7, 2010 Posted November 7, 2010 (edited) есть Ubuntu 10.10 server root@iptv:~/dvb# scan -a 0 ./trans.conf > channels.conf scanning ./trans.conf using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0' initial transponder 11034000 H 27500000 9 >>> tune to: 11034:h:0:27500 DVB-S IF freq is 1284000 0x0000 0x06a5: pmt_pid 0x0064 GlobeCast -- TV CORAN (running) 0x0000 0x06a6: pmt_pid 0x00c8 GlobeCast -- TV TAMAZIGHT (running) 0x0000 0x06a7: pmt_pid 0x012c GlobeCast -- Sarafan (running) 0x0000 0x06a8: pmt_pid 0x0190 GlobeCast -- Shanson TV (running) 0x0000 0x06da: pmt_pid 0x1518 GlobeCast -- Chanson (running) 0x0000 0x06a9: pmt_pid 0x01f4 Globecast -- 2M Maroc (running) 0x0000 0x06db: pmt_pid 0x0226 Globecast -- Radio 2M (running) 0x0000 0x06aa: pmt_pid 0x0258 Globecast -- CCTV9 (running) 0x0000 0x06ab: pmt_pid 0x02bc Globecast -- SHANT TV (running) 0x0000 0x06ac: pmt_pid 0x0320 Globecast -- RTR (running) 0x0000 0x06ae: pmt_pid 0x03e8 Globecast -- Vesti (running) 0x0000 0x06af: pmt_pid 0x044c Globecast -- Berbere Television (running, scrambled) 0x0000 0x06c3: pmt_pid 0x044d Globecast -- Radio Berbere (running) 0x0000 0x06b4: pmt_pid 0x0640 GlobeCast -- AZTV (running) 0x0000 0x06c4: pmt_pid 0x064a GCF -- Aztv Radio (running) 0x0000 0x06b1: pmt_pid 0x0514 GlobeCast -- Game One (running, scrambled) 0x0000 0x06b2: pmt_pid 0x0578 GlobeCast -- Al Jazeera Intl (running) root@iptv:~/dvb# szap -c ./channels.conf -n 7 -x reading channels from file './channels.conf' zapping to 7 'Vesti': sat 0, frequency = 11034 MHz V, symbolrate 27500000, vpid = 0x03fc, apid = 0x0406 sid = 0x06ae using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0' status 00 | signal c01e | snr 7770 | ber 00009e00 | unc fffffffe | status 1f | signal baa1 | snr c063 | ber 000002c0 | unc fffffffe | FE_HAS_LOCK собрал VLC из исходников: ./configure --enable-dvb --enable-v4l --disable-xcb --disable-skins2 --enable-run-as-root --prefix=/usr ./compile make install запускаю: #!/bin/bash /usr/bin/cvlc -vvv --color --ttl 12 --ts-es-id-pid --dvb-adapter=0 --programs=1710 dvb:// --dvb-frequency=11034000 --dvb-srate=27500000 --dvb-voltage=18 --dvb-fec=9 --sout-standard-access=http --sout-standard-mux=ts --sout '#duplicate{dst=std{dst=10.0.0.176:8001},select="program=1710"}' порт открыт, но ничего не вещается:( root@iptv:~/dvb# ./vlc.shVLC media player 1.1.4 The Luggage (revision exported) [0x877b8fc] main libvlc debug: VLC media player - 1.1.4 The Luggage [0x877b8fc] main libvlc debug: Copyright © 1996-2010 the VideoLAN team [0x877b8fc] main libvlc debug: revision exported [0x877b8fc] main libvlc debug: configured with ./configure '--enable-dvb' '--enable-v4l' '--disable-xcb' '--disable-skins2' '--enable-run-as-root' '--prefix=/usr' [0x877b8fc] main libvlc debug: translation test: code is "ru" [0x877b8fc] main libvlc debug: checking plugin modules [0x877b8fc] main libvlc debug: loading plugins cache file /usr/lib/vlc/plugins/plugins-04041e-3e8.dat [0x877b8fc] main libvlc debug: recursively browsing `/usr/lib/vlc/plugins' [0x877b8fc] main libvlc debug: saving plugins cache /usr/lib/vlc/plugins/plugins-04041e-3e8.dat [0x877b8fc] main libvlc debug: module bank initialized (395 modules) [0x877b8fc] main libvlc debug: opening config file (/root/.config/vlc/vlcrc) [0x877b8fc] main libvlc debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 FPU [0x877b8fc] main libvlc debug: looking for memcpy module: 3 candidates [0x877b8fc] main libvlc debug: using memcpy module "memcpymmxext" [0x882a3a4] main input debug: Creating an input for 'Медиа-библиотека' [0x882a3a4] main input debug: Input is a meta file: disabling unneeded options [0x882a3a4] main input debug: using timeshift granularity of 50 MiB [0x882a3a4] main input debug: using timeshift path '/tmp' [0x882a3a4] main input debug: `file/xspf-open:///root/.local/share/vlc/ml.xspf' gives access `file' demux `xspf-open' path `/root/.local/share/vlc/ml.xspf' [0x882a3a4] main input debug: creating demux: access='file' demux='xspf-open' path='/root/.local/share/vlc/ml.xspf' [0x88291dc] main demux debug: looking for access_demux module: 2 candidates [0x88291dc] main demux debug: no access_demux module matching "file" could be loaded [0x88291dc] main demux debug: TIMER module_need() : 0.997 ms - Total 0.997 ms / 1 intvls (Avg 0.997 ms) [0x882a3a4] main input debug: creating access 'file' path='/root/.local/share/vlc/ml.xspf' [0x88114ac] main access debug: looking for access module: 2 candidates [0x88114ac] filesystem access debug: opening file `/root/.local/share/vlc/ml.xspf' [0x88114ac] main access debug: using access module "filesystem" [0x88114ac] main access debug: TIMER module_need() : 0.604 ms - Total 0.604 ms / 1 intvls (Avg 0.604 ms) [0x8810d84] main stream debug: Using AStream*Stream [0x8810d84] main stream debug: pre buffering [0x8810d84] main stream debug: received first data after 0 ms [0x8810d84] main stream debug: pre-buffering done 314 bytes in 0s - 13332 KiB/s [0x881166c] main stream debug: looking for stream_filter module: 5 candidates [0x881166c] main stream debug: no stream_filter module matching "any" could be loaded [0x881166c] main stream debug: TIMER module_need() : 0.786 ms - Total 0.786 ms / 1 intvls (Avg 0.786 ms) [0x881166c] main stream debug: looking for stream_filter module: 1 candidate [0x881166c] main stream debug: using stream_filter module "stream_filter_record" [0x881166c] main stream debug: TIMER module_need() : 0.314 ms - Total 0.314 ms / 1 intvls (Avg 0.314 ms) [0x882a3a4] main input debug: creating demux: access='file' demux='xspf-open' path='/root/.local/share/vlc/ml.xspf' [0x88122ec] main demux debug: looking for demux module: 1 candidate [0x88122ec] playlist demux debug: using XSPF playlist reader [0x88122ec] main demux debug: using demux module "playlist" [0x88122ec] main demux debug: TIMER module_need() : 0.758 ms - Total 0.758 ms / 1 intvls (Avg 0.758 ms) [0x88135c4] main demux meta debug: looking for meta reader module: 2 candidates [0x88135c4] lua demux meta debug: Trying Lua scripts in /root/.local/share/vlc/lua/meta/reader [0x88135c4] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader [0x88135c4] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac [0x88135c4] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader [0x88135c4] main demux meta debug: no meta reader module matching "any" could be loaded [0x88135c4] main demux meta debug: TIMER module_need() : 4.760 ms - Total 4.760 ms / 1 intvls (Avg 4.760 ms) [0x882a3a4] main input debug: `file/xspf-open:///root/.local/share/vlc/ml.xspf' successfully opened [0x88135c4] main xml debug: looking for xml module: 2 candidates [0x88135c4] main xml debug: using xml module "xml" [0x88135c4] main xml debug: TIMER module_need() : 0.803 ms - Total 0.803 ms / 1 intvls (Avg 0.803 ms) [0x88122ec] playlist demux debug: parsed 0 tracks successfully [0x88135c4] main xml debug: removing module "xml" [0x882a3a4] main input debug: EOF reached [0x88122ec] main demux debug: removing module "playlist" [0x881166c] main stream debug: removing module "stream_filter_record" [0x88114ac] main access debug: removing module "filesystem" [0x882a3a4] main input debug: TIMER input launching for 'Медиа-библиотека' : 9.425 ms - Total 9.425 ms / 1 intvls (Avg 9.425 ms) [0x8813cc4] main interface debug: looking for interface module: 1 candidate [0x8813cc4] main interface debug: using interface module "hotkeys" [0x8813cc4] main interface debug: TIMER module_need() : 0.433 ms - Total 0.433 ms / 1 intvls (Avg 0.433 ms) [0x8818dcc] main interface debug: looking for interface module: 1 candidate Blocked: call to unsetenv("DBUS_ACTIVATION_ADDRESS") Blocked: call to unsetenv("DBUS_ACTIVATION_BUS_TYPE") [0x8818dcc] inhibit interface error: Failed to connect to the D-Bus session daemon: /bin/dbus-launch terminated abnormally with the following error: Autolaunch error: X11 initialization failed. [0x8818dcc] main interface debug: no interface module matching "inhibit,none" could be loaded [0x8818dcc] main interface debug: TIMER module_need() : 2.978 ms - Total 2.978 ms / 1 intvls (Avg 2.978 ms) [0x8818dcc] main interface error: no suitable interface module [0x878a184] main playlist debug: Activated [0x878a184] main playlist debug: adding item `dvb://' ( dvb:// ) [0x8827e64] main interface debug: looking for interface module: 1 candidate [0x8827e64] main interface debug: using interface module "signals" [0x8827e64] main interface debug: TIMER module_need() : 0.602 ms - Total 0.602 ms / 1 intvls (Avg 0.602 ms) [0x8828f24] main interface debug: looking for interface module: 1 candidate [0x8828f24] main interface debug: no interface module matching "globalhotkeys,none" could be loaded [0x8828f24] main interface debug: TIMER module_need() : 1.146 ms - Total 1.146 ms / 1 intvls (Avg 1.146 ms) [0x8828f24] main interface error: no suitable interface module [0x877b8fc] main libvlc error: interface "globalhotkeys,none" initialization failed [0x8828f24] main interface debug: looking for interface module: 1 candidate [0x8828f24] dummy interface: using the dummy interface module... [0x8828f24] main interface debug: using interface module "dummy" [0x8828f24] main interface debug: TIMER module_need() : 0.493 ms - Total 0.493 ms / 1 intvls (Avg 0.493 ms) [0x878a184] main playlist debug: rebuilding array of current - root Плейлист [0x878a184] main playlist debug: rebuild done - 1 items, index -1 [0x878a184] main playlist debug: processing request item null node Плейлист skip 0 [0x878a184] main playlist debug: starting new item [0x878a184] main playlist debug: creating new input thread [0x881d3d4] main input debug: Creating an input for 'dvb://' [0x881d3d4] main input debug: thread (input) created at priority 10 (input/input.c:214) [0x881d3d4] main input debug: thread started [0x881aeb4] main stream output debug: using sout chain=`duplicate{dst=std{dst=10.0.0.176:8001},select="program=1710"}' [0x881aeb4] main stream output debug: stream=`duplicate' [0x881b074] main stream out debug: looking for sout stream module: 1 candidate [0x881b074] stream_out_duplicate stream out debug: creating 'duplicate' [0x881b074] stream_out_duplicate stream out debug: * adding `std{dst=10.0.0.176:8001}' [0x881aeb4] main stream output debug: stream=`std' [0x881b62c] main stream out debug: looking for sout stream module: 1 candidate [0x881b62c] main stream out debug: set config option: sout-standard-dst to 10.0.0.176:8001 [0x881b62c] stream_out_standard stream out debug: creating `http/ts://10.0.0.176:8001' [0x881b62c] stream_out_standard stream out debug: extension is 176:8001 [0x881b62c] stream_out_standard stream out debug: extension -> mux=(null) [0x881b62c] stream_out_standard stream out debug: using `http/ts://10.0.0.176:8001' [0x881c9fc] main access out debug: looking for sout access module: 1 candidate [0x881c9fc] main access out: creating httpd [0x881c9fc] main access out debug: net: listening to 100.0.0.176 port 8001 [0x881c9fc] main access out debug: using sout access module "access_output_http" [0x881c9fc] main access out debug: TIMER module_need() : 0.720 ms - Total 0.720 ms / 1 intvls (Avg 0.720 ms) [0x881b62c] stream_out_standard stream out debug: access opened [0x882f8fc] main mux debug: looking for sout mux module: 1 candidate [0x882f8fc] mux_ts mux debug: shaping=200000 pcr=70000 dts_delay=400000 [0x882f8fc] main mux debug: using sout mux module "mux_ts" [0x882f8fc] main mux debug: TIMER module_need() : 1.213 ms - Total 1.213 ms / 1 intvls (Avg 1.213 ms) [0x881aeb4] main stream output debug: muxer support adding stream at any time [0x881aeb4] main stream output debug: muxer prefers to wait for all ES before starting to mux [0x881b62c] stream_out_standard stream out debug: mux opened [0x881b62c] main stream out debug: using sout stream module "stream_out_standard" [0x881b62c] main stream out debug: TIMER module_need() : 2.549 ms - Total 2.549 ms / 1 intvls (Avg 2.549 ms) [0x881b074] stream_out_duplicate stream out debug: * apply selection `program=1710' [0x881b074] main stream out debug: using sout stream module "stream_out_duplicate" [0x881b074] main stream out debug: TIMER module_need() : 3.017 ms - Total 3.017 ms / 1 intvls (Avg 3.017 ms) [0x881d3d4] main input debug: using timeshift granularity of 50 MiB [0x881d3d4] main input debug: using timeshift path '/tmp' [0x881d3d4] main input debug: `dvb://' gives access `dvb' demux `' path `' [0x881d3d4] main input debug: creating demux: access='dvb' demux='' path='' [0x8830de4] main demux debug: looking for access_demux module: 0 candidates [0x8830de4] main demux debug: no access_demux module matched "dvb" [0x8830de4] main demux debug: TIMER module_need() : 0.195 ms - Total 0.195 ms / 1 intvls (Avg 0.195 ms) [0x881d3d4] main input debug: creating access 'dvb' path='' [0x8830bdc] main access debug: looking for access module: 1 candidate [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/frontend0 [0x8830bdc] dvb access debug: Frontend Info: [0x8830bdc] dvb access debug: name = ST STV0299 DVB-S [0x8830bdc] dvb access debug: type = QPSK (DVB-S) [0x8830bdc] dvb access debug: frequency_min = 950000 (kHz) [0x8830bdc] dvb access debug: frequency_max = 2150000 (kHz) [0x8830bdc] dvb access debug: frequency_stepsize = 125 [0x8830bdc] dvb access debug: frequency_tolerance = 0 [0x8830bdc] dvb access debug: symbol_rate_min = 1000000 (kHz) [0x8830bdc] dvb access debug: symbol_rate_max = 45000000 (kHz) [0x8830bdc] dvb access debug: symbol_rate_tolerance (ppm) = 500 [0x8830bdc] dvb access debug: notifier_delay (ms) = 0 [0x8830bdc] dvb access debug: Frontend Info capability list: [0x8830bdc] dvb access debug: inversion auto [0x8830bdc] dvb access debug: forward error correction 1/2 [0x8830bdc] dvb access debug: forward error correction 2/3 [0x8830bdc] dvb access debug: forward error correction 3/4 [0x8830bdc] dvb access debug: forward error correction 5/6 [0x8830bdc] dvb access debug: forward error correction 7/8 [0x8830bdc] dvb access debug: forward error correction auto [0x8830bdc] dvb access debug: card can do QPSK [0x8830bdc] dvb access debug: End of capability list [0x8830bdc] dvb access debug: trying to tune the frontend... [0x8830bdc] dvb access debug: frequency 11034000 is in Ku-band [0x8830bdc] dvb access debug: using inversion=2 [0x8830bdc] dvb access debug: using fec=9 [0x8830bdc] dvb access debug: using voltage=18 [0x8830bdc] dvb access debug: using tone=0 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/dvr0 [0x8830bdc] dvb access debug: setting filter on PAT [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 0 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/ca0 [0x8830bdc] dvb access warning: CAMInit: opening CAM device failed (No such file or directory) [0x8830bdc] main access debug: using access module "dvb" [0x8830bdc] main access debug: TIMER module_need() : 71.366 ms - Total 71.366 ms / 1 intvls (Avg 71.366 ms) [0x881b91c] main stream debug: Using AStream*Block [0x881b91c] main stream debug: pre buffering [0x8830bdc] dvb access debug: frontend has acquired signal [0x8830bdc] dvb access debug: frontend has acquired carrier [0x8830bdc] dvb access debug: frontend has acquired stable FEC [0x8830bdc] dvb access debug: frontend has acquired sync [0x8830bdc] dvb access debug: frontend has acquired lock [0x8830bdc] dvb access debug: - Bit error rate: 1280 [0x8830bdc] dvb access debug: - Signal strength: 47627 [0x8830bdc] dvb access debug: - SNR: 49089 [0x881b91c] main stream debug: received first data after 130 ms [0x881b91c] main stream debug: prebuffering done 188 bytes in 0s - 1 KiB/s [0x882ec1c] main stream debug: looking for stream_filter module: 5 candidates [0x882ec1c] main stream debug: no stream_filter module matching "any" could be loaded [0x882ec1c] main stream debug: TIMER module_need() : 0.205 ms - Total 0.205 ms / 1 intvls (Avg 0.205 ms) [0x882ec1c] main stream debug: looking for stream_filter module: 1 candidate [0x882ec1c] main stream debug: using stream_filter module "stream_filter_record" [0x882ec1c] main stream debug: TIMER module_need() : 0.140 ms - Total 0.140 ms / 1 intvls (Avg 0.140 ms) [0x881d3d4] main input debug: creating demux: access='dvb' demux='ts' path='' [0x881bdb4] main demux debug: looking for demux module: 1 candidate [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 17 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 20 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 18 libdvbpsi error (PSI decoder): TS discontinuity (received 13, expected 0) for PID 0 [0x881bdb4] ts demux debug: PATCallBack called [0x881bdb4] ts demux debug: new PAT ts_id=12600 version=6 current_next=1 [0x881bdb4] ts demux debug: * number=0 pid=16 [0x881bdb4] ts demux debug: * number=1703 pid=300 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 300 [0x881bdb4] ts demux debug: * number=1704 pid=400 [0x881bdb4] ts demux debug: * number=1705 pid=500 [0x881bdb4] ts demux debug: * number=1706 pid=600 [0x881bdb4] ts demux debug: * number=1707 pid=700 [0x881bdb4] ts demux debug: * number=1708 pid=800 [0x881bdb4] ts demux debug: * number=1710 pid=1000 [0x881bdb4] ts demux debug: * number=1711 pid=1100 [0x881bdb4] ts demux debug: * number=1716 pid=1600 [0x881bdb4] ts demux debug: * number=1701 pid=100 [0x881bdb4] ts demux debug: * number=1702 pid=200 [0x881bdb4] ts demux debug: * number=1731 pid=1101 [0x881bdb4] ts demux debug: * number=1732 pid=1610 [0x881bdb4] ts demux debug: * number=1754 pid=5400 [0x881bdb4] ts demux debug: * number=1755 pid=550 [0x881bdb4] ts demux debug: * number=1713 pid=1300 [0x881bdb4] ts demux debug: * number=1714 pid=1400 [0x881bdb4] ts demux debug: PMTCallBack called [0x881bdb4] ts demux debug: new PMT program number=1703 version=28 pid_pcr=320 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 320 [0x881bdb4] ts demux debug: * descriptor : unknown (0xe) [0x881bdb4] ts demux debug: * descriptor : unknown (0xc) [0x881bdb4] ts demux debug: * es pid=320 type=2 dr->i_tag=0x52 [0x881bdb4] ts demux debug: * es pid=320 type=2 dr->i_tag=0x2 [0x881bdb4] ts demux debug: * es pid=320 type=2 dr->i_tag=0xe [0x881bdb4] ts demux debug: * es pid=320 type=2 dr->i_tag=0x6 [0x881bdb4] ts demux debug: * es pid=320 type=2 fcc=mpgv [0x881d3d4] main input debug: selecting program id=1703 [0x881bdb4] ts demux debug: * es pid=330 type=4 dr->i_tag=0x52 [0x881bdb4] ts demux debug: * es pid=330 type=4 dr->i_tag=0x3 [0x881bdb4] ts demux debug: * es pid=330 type=4 dr->i_tag=0xe [0x881bdb4] ts demux debug: * es pid=330 type=4 dr->i_tag=0xa [0x881bdb4] ts demux debug: found language: fre [0x881bdb4] ts demux debug: * es pid=330 type=4 fcc=mpga [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 330 [0x881bdb4] main demux debug: using demux module "ts" [0x881bdb4] main demux debug: TIMER module_need() : 831.925 ms - Total 831.925 ms / 1 intvls (Avg 831.925 ms) [0x881bdb4] ts demux debug: DEMUX_SET_GROUP -1 0xb6fcf2ac [0x8830bdc] dvb access debug: DMXUnsetFilter: closing demux 12 [0x8830bdc] dvb access debug: DMXUnsetFilter: closing demux 13 [0x8830bdc] dvb access debug: DMXUnsetFilter: closing demux 14 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 1000 [0x881d3d4] main input debug: starting in async mode [0x8830bdc] dvb access warning: unimplemented query in control [0x8835754] main demux meta debug: looking for meta reader module: 2 candidates [0x8835754] lua demux meta debug: Trying Lua scripts in /root/.local/share/vlc/lua/meta/reader [0x8835754] lua demux meta debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader [0x8835754] lua demux meta debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac [0x8835754] lua demux meta debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader [0x8835754] main demux meta debug: no meta reader module matching "any" could be loaded [0x8835754] main demux meta debug: TIMER module_need() : 1.185 ms - Total 1.185 ms / 1 intvls (Avg 1.185 ms) [0x881d3d4] main input debug: `dvb://' successfully opened [0x881bdb4] ts demux debug: PMTCallBack called [0x881bdb4] ts demux debug: new PMT program number=1710 version=28 pid_pcr=1020 [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 1020 [0x881bdb4] ts demux debug: * descriptor : unknown (0xe) [0x881bdb4] ts demux debug: * descriptor : unknown (0xc) [0x881bdb4] ts demux debug: * es pid=1020 type=2 dr->i_tag=0x52 [0x881bdb4] ts demux debug: * es pid=1020 type=2 dr->i_tag=0x2 [0x881bdb4] ts demux debug: * es pid=1020 type=2 dr->i_tag=0xe [0x881bdb4] ts demux debug: * es pid=1020 type=2 dr->i_tag=0x6 [0x881bdb4] ts demux debug: * es pid=1020 type=2 fcc=mpgv [0x8835acc] main decoder debug: looking for packetizer module: 21 candidates [0x8835acc] main decoder debug: using packetizer module "packetizer_mpegvideo" [0x8835acc] main decoder debug: TIMER module_need() : 3.557 ms - Total 3.557 ms / 1 intvls (Avg 3.557 ms) [0x8835acc] main decoder debug: thread (decoder) created at priority 0 (input/decoder.c:301) [0x8835acc] main decoder debug: thread started [0x881bdb4] ts demux debug: * es pid=1030 type=4 dr->i_tag=0x52 [0x881bdb4] ts demux debug: * es pid=1030 type=4 dr->i_tag=0x3 [0x881bdb4] ts demux debug: * es pid=1030 type=4 dr->i_tag=0xe [0x881bdb4] ts demux debug: * es pid=1030 type=4 dr->i_tag=0xa [0x881bdb4] ts demux debug: found language: fre [0x881bdb4] ts demux debug: * es pid=1030 type=4 fcc=mpga [0x884096c] main decoder debug: looking for packetizer module: 21 candidates [0x884096c] main decoder debug: using packetizer module "mpeg_audio" [0x884096c] main decoder debug: TIMER module_need() : 0.924 ms - Total 0.924 ms / 1 intvls (Avg 0.924 ms) [0x884096c] main decoder debug: thread (decoder) created at priority 5 (input/decoder.c:301) [0x884096c] main decoder debug: thread started [0x8830bdc] dvb access debug: Opening device /dev/dvb/adapter0/demux0 [0x8830bdc] dvb access debug: DMXSetFilter: DMX_PES_OTHER for PID 1030 libdvbpsi error (PSI decoder): TS discontinuity (received 5, expected 0) for PID 17 [0x881bdb4] ts demux warning: first packet for pid=1020 cc=0x4 [0x881bdb4] ts demux warning: first packet for pid=1030 cc=0xa [0x881bdb4] ts demux warning: discontinuity received 0xc instead of 0xf (pid=1020) [0x881bdb4] ts demux warning: discontinuity received 0xe instead of 0x2 (pid=1030) [0x881d3d4] main input debug: switching to sync mode libdvbpsi error (PSI decoder): TS discontinuity (received 4, expected 2) for PID 1000 [0x881bdb4] ts demux debug: PMTCallBack called libdvbpsi error (PSI decoder): TS discontinuity (received 6, expected 3) for PID 0 [0x881bdb4] ts demux debug: PATCallBack called libdvbpsi error (PSI decoder): TS discontinuity (received 14, expected 6) for PID 17 [0x8835acc] packetizer_mpegvideo decoder debug: size 544x576 fps=25.000 [0x881aeb4] main stream output debug: adding a new sout input (sout_input:0x883b9f8) [0x881b074] stream_out_duplicate stream out debug: duplicated a new stream codec=mpgv (es=1020 group=1710) [0x882f8fc] main mux debug: adding a new input [0x882f8fc] mux_ts mux debug: adding input codec=mpgv pid=68 [0x882f8fc] mux_ts mux debug: new PCR PID is 68 [0x881b074] stream_out_duplicate stream out debug: - added for output 0 [0x884096c] mpeg_audio decoder debug: MPGA channels:2 samplerate:48000 bitrate:128 [0x881aeb4] main stream output debug: adding a new sout input (sout_input:0x883d030) [0x881b074] stream_out_duplicate stream out debug: duplicated a new stream codec=mpga (es=1030 group=1710) [0x882f8fc] main mux debug: adding a new input [0x882f8fc] mux_ts mux debug: adding input codec=mpga pid=69 [0x882f8fc] mux_ts mux debug: - lang=fra [0x881b074] stream_out_duplicate stream out debug: - added for output 0 [0x881bdb4] ts demux warning: discontinuity received 0x7 instead of 0x2 (pid=1020) [0x881bdb4] ts demux warning: discontinuity received 0xa instead of 0x5 (pid=1030) libdvbpsi error (PSI decoder): TS discontinuity (received 0, expected 6) for PID 1000 [0x881bdb4] ts demux debug: PMTCallBack called libdvbpsi error (PSI decoder): TS discontinuity (received 2, expected 7) for PID 0 [0x881bdb4] ts demux debug: PATCallBack called libdvbpsi error (PSI decoder): TS discontinuity (received 12, expected 15) for PID 17 [0x881bdb4] ts demux warning: discontinuity received 0xf instead of 0x3 (pid=1020) libdvbpsi error (PSI decoder): TS discontinuity (received 6, expected 13) for PID 17 [0x881bdb4] ts demux debug: PSINewTableCallBack: table 0x42(66) ext=0x3138(12600) [0x881bdb4] ts demux debug: SDTCallBack called [0x881bdb4] ts demux debug: new SDT ts_id=12600 version=6 current_next=1 network_id=318 [0x881bdb4] ts demux debug: * service id=1701 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=TV CORAN [0x881d3d4] main input debug: EsOutProgramMeta: number=1701 [0x881bdb4] ts demux debug: * service id=1702 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=TV TAMAZIGHT [0x881d3d4] main input debug: EsOutProgramMeta: number=1702 [0x881bdb4] ts demux debug: * service id=1703 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=Sarafan [0x881d3d4] main input debug: EsOutProgramMeta: number=1703 [0x881bdb4] ts demux debug: * service id=1704 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=Shanson TV [0x881d3d4] main input debug: EsOutProgramMeta: number=1704 [0x881bdb4] ts demux debug: * service id=1754 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=Chanson [0x881d3d4] main input debug: EsOutProgramMeta: number=1754 [0x881bdb4] ts demux debug: * service id=1705 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=Globecast name=2M Maroc [0x881d3d4] main input debug: EsOutProgramMeta: number=1705 [0x881bdb4] ts demux debug: * service id=1755 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=2 provider=Globecast name=Radio 2M [0x881d3d4] main input debug: EsOutProgramMeta: number=1755 [0x881bdb4] ts demux debug: * service id=1706 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=Globecast name=CCTV9 [0x881d3d4] main input debug: EsOutProgramMeta: number=1706 [0x881bdb4] ts demux debug: * service id=1707 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=Globecast name=SHANT TV [0x881d3d4] main input debug: EsOutProgramMeta: number=1707 [0x881bdb4] ts demux debug: * service id=1708 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=Globecast name=RTR [0x881d3d4] main input debug: EsOutProgramMeta: number=1708 [0x881bdb4] ts demux debug: * service id=1710 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=Globecast name=Vesti [0x881d3d4] main input debug: EsOutProgramMeta: number=1710 [0x881bdb4] ts demux debug: * service id=1711 eit schedule=0 present=0 running=4 free_ca=1 [0x881bdb4] ts demux debug: - type=1 provider=Globecast name=Berbere Television [0x881d3d4] main input debug: EsOutProgramMeta: number=1711 [0x881bdb4] ts demux debug: * service id=1731 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=2 provider=Globecast name=Radio Berbere [0x881d3d4] main input debug: EsOutProgramMeta: number=1731 [0x881bdb4] ts demux debug: * service id=1716 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=AZTV [0x881d3d4] main input debug: EsOutProgramMeta: number=1716 [0x881bdb4] ts demux debug: * service id=1732 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=2 provider=GCF name=Aztv Radio [0x881d3d4] main input debug: EsOutProgramMeta: number=1732 [0x881bdb4] ts demux debug: * service id=1713 eit schedule=0 present=0 running=4 free_ca=1 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=Game One [0x881d3d4] main input debug: EsOutProgramMeta: number=1713 [0x881bdb4] ts demux debug: * service id=1714 eit schedule=0 present=0 running=4 free_ca=0 [0x881bdb4] ts demux debug: - type=1 provider=GlobeCast name=Al Jazeera Intl [0x881d3d4] main input debug: EsOutProgramMeta: number=1714 libdvbpsi error (PSI decoder): TS discontinuity (received 15, expected 0) for PID 20 [0x881bdb4] ts demux debug: PSINewTableCallBack: table 0x70(112) ext=0x0(0) В чем может быть причина? Edited November 7, 2010 by Zohan Вставить ник Quote
Zohan Posted November 8, 2010 Author Posted November 8, 2010 Выяснил что такой запуск: /usr/bin/cvlc -vvv --color --ttl 12 --ts-es-id-pid --dvb-adapter=0 --programs=1708 dvb:// --dvb-frequency=11034000 --dvb-srate=27500000 --dvb-voltage=18 дает в окне SSH видео в виде ASCII т.е. каналы принимаются перепробовал все методы выходного потока - болт, не вещается:( Вставить ник Quote
Снежкин Posted November 8, 2010 Posted November 8, 2010 Стоп! Какой спутник и какой транспондер вы пытаетесь принять? Вставить ник Quote
Zohan Posted November 8, 2010 Author Posted November 8, 2010 Стоп!Какой спутник и какой транспондер вы пытаетесь принять? Если не ошибаюсь, то Sirius2 вот список каналов на 11034000/27500000 0x0000 0x06a5: pmt_pid 0x0064 GlobeCast -- TV CORAN (running) 0x0000 0x06a6: pmt_pid 0x00c8 GlobeCast -- TV TAMAZIGHT (running) 0x0000 0x06a7: pmt_pid 0x012c GlobeCast -- Sarafan (running) 0x0000 0x06a8: pmt_pid 0x0190 GlobeCast -- Shanson TV (running) 0x0000 0x06da: pmt_pid 0x1518 GlobeCast -- Chanson (running) 0x0000 0x06a9: pmt_pid 0x01f4 Globecast -- 2M Maroc (running) 0x0000 0x06db: pmt_pid 0x0226 Globecast -- Radio 2M (running) 0x0000 0x06aa: pmt_pid 0x0258 Globecast -- CCTV9 (running) 0x0000 0x06ab: pmt_pid 0x02bc Globecast -- SHANT TV (running) 0x0000 0x06ac: pmt_pid 0x0320 Globecast -- RTR (running) 0x0000 0x06ae: pmt_pid 0x03e8 Globecast -- Vesti (running) 0x0000 0x06af: pmt_pid 0x044c Globecast -- Berbere Television (running) 0x0000 0x06c3: pmt_pid 0x044d Globecast -- Radio Berbere (running) 0x0000 0x06b4: pmt_pid 0x0640 GlobeCast -- AZTV (running) 0x0000 0x06c4: pmt_pid 0x064a GCF -- Aztv Radio (running) 0x0000 0x06b1: pmt_pid 0x0514 GlobeCast -- Game One (running, scrambled) 0x0000 0x06b2: pmt_pid 0x0578 GlobeCast -- Al Jazeera Intl (running) Вставить ник Quote
Снежкин Posted November 8, 2010 Posted November 8, 2010 это не сириус, это hotbird 6 http://www.opennet.ru/base/net/skystar_video.txt.html Вставить ник Quote
Zohan Posted November 8, 2010 Author Posted November 8, 2010 это не сириус, это hotbird 6 http://www.opennet.ru/base/net/skystar_video.txt.html Делал все это не раз - просто вывод на экран идет и просто фильм из файла получается транслировать, а транслировать поток со спутника нет :( Зметил что на моменте когда должна идти буферизация потока - она не идет. Вставить ник Quote
Снежкин Posted November 8, 2010 Posted November 8, 2010 (edited) а если вот так? -vvv --color --ttl 12 --ts-es-id-pid --dvb-adapter=0 --programs=1710 dvb: \ --dvb-frequency=11034000 --dvb-srate=27500000 --dvb-voltage=18 --dvb-fec=3 \ --sout-standard-access=http --sout-standard-mux=ts \ --sout='#duplicate{dst=std{dst=10.0.0.176:8001},select="program=1710"}' Edited November 8, 2010 by Снежкин Вставить ник Quote
Zohan Posted November 8, 2010 Author Posted November 8, 2010 а если вот так? -vvv --color --ttl 12 --ts-es-id-pid --dvb-adapter=0 --programs=1710 dvb: \ --dvb-frequency=11034000 --dvb-srate=27500000 --dvb-voltage=18 --dvb-fec=3 \ --sout-standard-access=http --sout-standard-mux=ts \ --sout='#duplicate{dst=std{dst=10.0.0.176:8001},select="program=1710"}' То же самое, но в логе кое-что поменялось. Вставить ник Quote
Снежкин Posted November 8, 2010 Posted November 8, 2010 могу конечно ошибаться, но что-то у вас не то с дровами Вставить ник Quote
Zohan Posted November 9, 2010 Author Posted November 9, 2010 могу конечно ошибаться, но что-то у вас не то с дровамиЧистая Ubunta 10.10 server i386, при установке была добавлена только одна роль OpenSSH Server. Драйвера: # lsmod | grep dvb dvb_pll 9053 1 dvb_core 88505 2 stv0299,b2c2_flexcop Вставить ник Quote
Zohan Posted November 9, 2010 Author Posted November 9, 2010 ФАК!!!! Проблема была здесь: -vvv --color --ttl 12 --ts-es-id-pid --dvb-adapter=0 --programs=1710 а нужно -vvv --color --ttl 12 --ts-es-id-pid --dvb-adapter=0 --program 1710 хотя во всех руководствах написано именно "--programs=" Вставить ник Quote
Снежкин Posted November 9, 2010 Posted November 9, 2010 ну так это... рабочий конфиг в студию чтоли... Вставить ник Quote
Zohan Posted November 9, 2010 Author Posted November 9, 2010 (edited) ну так это... рабочий конфиг в студию чтоли...Конфиг чего? Вот строка запуска: /usr/bin/cvlc -vvvv --ttl 12--color --ts-es-id-pid --dvb-adapter=0 --program=1708 dvb:// --dvb-frequency=11034000 --dvb-srate=27500000 --dvb-voltage=18 --dvb-fec=9 --sout-standard-access=http --sout-mux-caching=5000 --sout-standard-mux=ts --sout '#duplicate{dst=std{dst=10.0.0.176:8001},select="program=1708", dst=std{dst=10.0.0.176:8002},select="program=1710"}' как только заменяю --programs=1708,1710 на --program=1708 то работает, но вещается естественно только 1 указанный канал что за глюк? Edited November 9, 2010 by Zohan Вставить ник Quote
Zohan Posted November 11, 2010 Author Posted November 11, 2010 (edited) ну так это... рабочий конфиг в студию чтоли...Конфиг чего? Вот строка запуска: /usr/bin/cvlc -vvvv --ttl 12--color --ts-es-id-pid --dvb-adapter=0 --program=1708 dvb:// --dvb-frequency=11034000 --dvb-srate=27500000 --dvb-voltage=18 --dvb-fec=9 --sout-standard-access=http --sout-mux-caching=5000 --sout-standard-mux=ts --sout '#duplicate{dst=std{dst=10.0.0.176:8001},select="program=1708", dst=std{dst=10.0.0.176:8002},select="program=1710"}' как только заменяю --programs=1708,1710 на --program=1708 то работает, но вещается естественно только 1 указанный канал что за глюк? Оказывается не глюк, а карточка не видела пиды каналов без опции: --dvb-budget-mode Edited November 11, 2010 by Zohan Вставить ник Quote
