В инете полно инструкций как это сделать.
делаю
так
vlan database
vlan 50
interface Vlan50
ip address 192.168.50.1 255.255.255.0
no shutdown
Switch#show ip interface brief
Interface IP-Address OK? Method Status Protocol
Vlan1 192.168.30.33 YES NVRAM up up
Vlan50 192.168.50.1 YES manual up down
GigabitEthernet0/1 unassigned YES unset up up
GigabitEthernet0/2 unassigned YES unset up up
GigabitEthernet0/3 unassigned YES unset up up
GigabitEthernet0/4 unassigned YES unset up up
GigabitEthernet0/5 unassigned YES unset down down
GigabitEthernet0/6 unassigned YES unset down down
GigabitEthernet0/7 unassigned YES unset down down
Switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.30.20 to network 0.0.0.0
C 192.168.30.0/24 is directly connected, Vlan1
S* 0.0.0.0/0 [1/0] via 192.168.30.20
Маршрут на 192.168.50.0/24 в таблице не появился, интерфейс Vlan50 в down
мой конфиг
Current configuration : 3424 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Switch
username admin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
spanning-tree extend system-id
vlan internal allocation policy ascending
vlan 20
name DMZ
vlan 50
vlan 501
name UPstream1
vlan 502
name UPstream2
vlan 503
name UPstream3
interface GigabitEthernet0/1
switchport mode access
speed 1000
duplex full
interface GigabitEthernet0/2
speed 1000
duplex full
interface GigabitEthernet0/3
speed 1000
duplex full
interface GigabitEthernet0/4
speed 1000
duplex full
interface GigabitEthernet0/5
speed 1000
duplex full
interface GigabitEthernet0/6
speed 1000
duplex full
interface GigabitEthernet0/7
speed 1000
duplex full
interface GigabitEthernet0/8
speed 1000
duplex full
interface GigabitEthernet0/9
speed 1000
duplex full
interface GigabitEthernet0/10
speed 1000
duplex full
interface GigabitEthernet0/11
speed 1000
duplex full
interface GigabitEthernet0/12
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 20,501,502
switchport mode trunk
speed 1000
duplex full
interface GigabitEthernet0/13
speed 1000
duplex full
interface GigabitEthernet0/14
speed 1000
duplex full
interface GigabitEthernet0/15
speed 1000
duplex full
interface GigabitEthernet0/16
speed 1000
duplex full
interface GigabitEthernet0/17
speed 1000
duplex full
interface GigabitEthernet0/18
speed 1000
duplex full
interface GigabitEthernet0/19
load-interval 30
speed 1000
duplex full
interface GigabitEthernet0/20
speed 1000
duplex full
interface GigabitEthernet0/21
speed 1000
duplex full
interface GigabitEthernet0/22
speed 1000
duplex full
interface GigabitEthernet0/23
speed 1000
duplex full
interface GigabitEthernet0/24
speed 1000
duplex full
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
switchport access vlan 54
interface Vlan1
ip address 192.168.30.33 255.255.255.0
interface Vlan50
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.30.20
ip http server
duplex full
speed 1000
duplex full
interface Vlan1
interface Vlan50
ip classless
ip http server
snmp-server community public RO
snmp-server location SERVER-ROOM
snmp-server contact user@domain
control-plane
line con 0
login local
line vty 0 4
exec-timeout 15 0
logging synchronous
login local
line vty 5 15
login
end
Vlan ы vlan 501
name UPstream1
vlan 502
name UPstream2
vlan 503
name UPstream3
настраивали раньше, они сейчас не используются, могут ли эти vlan мешать созданию маршрутизации ?
Чтобы int vlan50 был в UP, нужно чтобы он был прописан хотя бы на одном физическом порту, который в UP. У вас большинство аксессных портов в 1 влане, в транках также нет 50 влана.
Спасибо John
т.е. если в моем случае
int gi 0/5
switchport access vlan 50
а в 5 порт воткнуть патчкорд -- интерфейс Vlan50 поднимется ?
А с транковыми портами аналогично, тоже порт Catalist-а соединить с другим коммутатором с транковым портом ? Или достаточно добавить Vlan50 в транковый порт, даже если он в down ?
P.S. сейчас не могу проверить
int gi 0/5
Да, если на другом конце патчкорда тоже что то будет подключено.
Физика также должна быть в UP.
