Сейчас пытаюсь посмотреть какие данные он присылает option82 . кто нибудь с ним работал?
Как настроить чтоб он отдавал опцию 82 - есть планы исользовать его на узлах агрегации - аксесные порты и транковые - вот конфиг
!LanSwitch BuildRun
enable
configure terminal
![VLAN]
interface range ethernet 0/0/1 to ethernet 0/0/5 ethernet 0/0/8 ethernet 0/0/1
7 to ethernet 0/0/24
switchport mode trunk
exit
vlan 1
no switchport ethernet 0/0/7 to ethernet 0/0/8
exit
vlan 12
switchport ethernet 0/0/1 to ethernet 0/0/5
exit
vlan 900
switchport ethernet 0/0/1 to ethernet 0/0/5 ethernet 0/0/7 to ethernet 0/0/9 e
thernet 0/0/17 to ethernet 0/0/24
exit
vlan 903
switchport ethernet 0/0/1 to ethernet 0/0/2
exit
![DEVICE]
interface ethernet 0/0/1
exit
interface ethernet 0/0/2
exit
interface ethernet 0/0/3
exit
interface ethernet 0/0/4
exit
interface ethernet 0/0/5
exit
interface ethernet 0/0/6
exit
interface ethernet 0/0/7
speed 1000
duplex full
switchport access vlan 900
exit
interface ethernet 0/0/8
switchport trunk native vlan 900
exit
interface ethernet 0/0/9
exit
interface ethernet 0/0/10
exit
interface ethernet 0/0/11
exit
interface ethernet 0/0/12
exit
interface ethernet 0/0/13
exit
interface ethernet 0/0/14
exit
interface ethernet 0/0/15
exit
interface ethernet 0/0/16
exit
interface ethernet 0/0/17
exit
interface ethernet 0/0/18
exit
interface ethernet 0/0/19
exit
interface ethernet 0/0/20
exit
interface ethernet 0/0/21
exit
interface ethernet 0/0/22
exit
interface ethernet 0/0/23
exit
interface ethernet 0/0/24
exit
interface ethernet 0/1/1
exit
interface ethernet 0/1/2
exit
![STP]
spanning-tree mode mstp
no spanning-tree
exit
no spanning-tree
exit
![MSTP]
spanning-tree mst revision 10
spanning-tree mst name qtech
spanning-tree mst instance 1 priority 8192
spanning-tree mst instance 1 vlan 12
spanning-tree mst instance 2 priority 8192
spanning-tree mst instance 2 vlan 900
spanning-tree mst instance 1 port-priority 96
spanning-tree mst instance 2 port-priority 96
exit
![DHCP]
dhcp-relay
dhcp-relay hide server-ip
dhcp option82
![IF]
interface vlan-interface 900
ip address 172.16.2.121 255.255.255.0
exit
![SSH]
ssh
![ERRP]
errp
errp domain 0
control-vlan 903
ring 0 role transit primary-port ethernet 0/0/1 secondary-port ethernet 0/0/2
level 0
ring 0 enable
exit
dhcp-relay
dhcp option82
dhcp option82 strategy keep
dhcp-server 1 ip xx.xx.xx.xxx
interface vlan-interface xxx
dhcp-server 1
у меня работает вот такая конструкция
спасибо огромное выручили - получилось))))))
увидел наконец от него долгожданную
Option: (t=82,l=18) Agent Information Option
        Option: (82) Agent Information Option
        Length: 18
        Value: 010600040384001502080006001FCE103986
        Agent Circuit ID: 000403840015
        Agent Remote ID: 0006001FCE103986
    End Option
Edited by vlad_odmin
