Стоит cisco 7507 +billing , при кол-ве сессий 30-50 шт нагрузка CPU 30-45% немогу понять почему....? решение было выбрано на 1000-1500 абонентов (сессий). Так вот посмотрел форум и сложилось мнение что pppoe менее грузит проц cisco? Что посоветуете перейти на pppoe или есть еще какие либо решения?
Заранее благодарен.
rsp какой? интерфейсы, трафик.
решение было выбрано на 1000-1500 абонентов (сессий). %)
Имхо, под 1000 абонентов такую железку выбирать в качестве браса, если тока абоненты диалапные...
Edited by pliskinsad
Cisco Internetwork Operating System Software
IOS RSP Software (RSP-JK9O3SV-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 20:51 by dchih
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.0(17)S4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 2 days, 8 hours, 29 minutes
System returned to ROM by reload at 18:24:58 UTC Sat Oct 2 2010
System image file is "sup-slot0:/rsp-jk9o3sv-mz.123-26.bin"
Last reload reason: Reload command
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco RSP4 (R5000) processor with 131072K/2072K bytes of memory.
R5000 CPU at 200MHz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Chassis Interface.
1 VIP2 R5K controller (2 FastEthernet).
2 FastEthernet/IEEE 802.3 interface(s)
123K bytes of non-volatile configuration memory.
83200K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 3.
Configuration register is 0x2102
Траф 8-12 mb/s
Посоветуйте решение на 1500-2000 сессий +radius ........
на 1000-1500 абонентов? Вообще не понимаю по какому принципу выбирали :)
Озвучте бюджет.
А по существу железка уже давно мертвая, лучше избавьтесь и купите что нибудь другое. Да и не bras это, скорей больше под бордер железка.
Да ладно вам... У меня даже 3725 терминирует до 100 pptp до 1Мбит/сек без шифрования + 1Е1 для остатков диалапа и загрузка проца больше 15-17% не поднимается. Тут наверное надо все же конфиг циски смотреть.
по хорошему 7201 как минимум.
По бюджетнее решение есть ?
на нервах, в том числе и своих, не экономят.
если смотреть побюджетнее среди кошек - быстро упретесь в производительность (особенно если планируете тарифы со скоростью выше 1мбит/с давать). если вы с цифрой 1.5-2к не сильно преувеличиваете конечно.
а так действительно - писюки ваше решение, если 72ая давит вас как жаба.. можете посмотреть варианты в шасси - те же 7204/7206 и к ним NPE-G2. выйдет несколько дешевле чем 7201, особенно если смотреть в б/у.
разве что места занимать будет больше на порядок.
Edited by darkagent
О! Некрофилия.
Это как раз по моей части.
Для начала sh run сюда.
Потом,
1. ip cef или ip cef distri в конфиге ?
2. Порт, на котором терминируется vpdn , он куда воткнут? в ВИП?
ps есть у меня такая машина на складе.
Гудит как пылесос. Жрет 1 киловатт. Рекомендую заменить на что нибудь покомпактнее, пока не вылетели в трубу на счетах за электроэнергию. (а ведь ее еще и охлаждать надо...)
А, кстати, загрузка КАКОГО CPU вас беспокоит? В вашем конфиге их ДВА.
О! Некрофилия.
Потом,
Router#show run
Building configuration...
Current configuration : 2168 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
no service single-slot-reload-enable
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $
enable password 7
aaa new-model
aaa authentication login default local
aaa authentication ppp default group radius
aaa authorization exec default local
aaa authorization network default group radius
aaa accounting network default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
ip subnet-zero
ip domain name router
ip name-server xxxxxxx
ip cef distributed
ip audit po max-events 100
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
! Default PPTP VPDN group
accept-dialin
protocol any
virtual-template 1
local name pptp_gateway
username admin password
no ip rcmd domain-lookup
interface FastEthernet0/0/0
description FOR_CLIENTS
ip address xx.xx.xx.xx 255.255.255.0 secondary
no ip redirects
ip nat inside
half-duplex
interface FastEthernet0/1/0
description INTERNET
ip address 100.1.1.2 255.0.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
half-duplex
interface Virtual-Template1
ip unnumbered FastEthernet0/0/0
ip mtu 1492
ip nat inside
autodetect encapsulation ppp
ppp authentication chap pap callin
ip nat inside source list 4 interface FastEthernet0/1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 100.1.1.1
no ip http server
no ip http secure-server
ip radius source-interface FastEthernet0/1/0
access-list 4 permit 10.100.0.0 0.0.0.255
access-list 60 permit 100.1.1.3
access-list 68 permit
access-list 68 deny any
snmp-server community
radius-server configure-nas
radius-server host 100.1.1.3 auth-port 1812 acct-port 1813 key 7
radius-server timeout 30
radius-server key 7
line con 0
line aux 0
line vty 0 4
end
Router#show ip cef
Prefix Next Hop Interface
0.0.0.0/0 100.1.1.1 FastEthernet0/1/0
0.0.0.0/32 receive
10.0.0.0/24 attached FastEthernet0/0/0
10.0.0.0/32 receive
10.0.0.1/32 receive
10.0.0.8/32 10.0.0.8 FastEthernet0/0/0
10.0.0.9/32 10.0.0.9 FastEthernet0/0/0
10.0.0.21/32 10.0.0.21 FastEthernet0/0/0
10.0.0.22/32 10.0.0.22 FastEthernet0/0/0
10.0.0.41/32 10.0.0.41 FastEthernet0/0/0
10.0.0.43/32 10.0.0.43 FastEthernet0/0/0
10.0.0.47/32 10.0.0.47 FastEthernet0/0/0
10.0.0.48/32 10.0.0.48 FastEthernet0/0/0
10.0.0.51/32 10.0.0.51 FastEthernet0/0/0
10.0.0.52/32 10.0.0.52 FastEthernet0/0/0
10.0.0.66/32 10.0.0.66 FastEthernet0/0/0
10.0.0.67/32 10.0.0.67 FastEthernet0/0/0
10.0.0.80/32 10.0.0.80 FastEthernet0/0/0
10.0.0.84/32 10.0.0.84 FastEthernet0/0/0
10.0.0.85/32 10.0.0.85 FastEthernet0/0/0
10.0.0.89/32 10.0.0.89 FastEthernet0/0/0
10.0.0.91/32 10.0.0.91 FastEthernet0/0/0
10.0.0.92/32 10.0.0.92 FastEthernet0/0/0
10.0.0.93/32 10.0.0.93 FastEthernet0/0/0
10.0.0.94/32 10.0.0.94 FastEthernet0/0/0
10.0.0.95/32 10.0.0.95 FastEthernet0/0/0
10.0.0.97/32 10.0.0.97 FastEthernet0/0/0
10.0.0.100/32 10.0.0.100 FastEthernet0/0/0
10.0.0.107/32 10.0.0.107 FastEthernet0/0/0
10.0.0.108/32 10.0.0.108 FastEthernet0/0/0
10.0.0.109/32 10.0.0.109 FastEthernet0/0/0
10.0.0.111/32 10.0.0.111 FastEthernet0/0/0
10.0.0.199/32 10.0.0.199 FastEthernet0/0/0
10.0.0.255/32 receive
10.1.0.0/24 attached FastEthernet0/0/0
10.1.0.0/32 receive
10.1.0.1/32 receive
10.1.0.11/32 10.1.0.11 FastEthernet0/0/0
10.1.0.14/32 10.1.0.14 FastEthernet0/0/0
10.1.0.15/32 10.1.0.15 FastEthernet0/0/0
10.1.0.16/32 10.1.0.16 FastEthernet0/0/0
10.1.0.17/32 10.1.0.17 FastEthernet0/0/0
10.1.0.18/32 10.1.0.18 FastEthernet0/0/0
10.1.0.19/32 10.1.0.19 FastEthernet0/0/0
10.1.0.24/32 10.1.0.24 FastEthernet0/0/0
10.1.0.25/32 10.1.0.25 FastEthernet0/0/0
10.1.0.30/32 10.1.0.30 FastEthernet0/0/0
10.1.0.31/32 10.1.0.31 FastEthernet0/0/0
10.1.0.33/32 10.1.0.33 FastEthernet0/0/0
10.1.0.34/32 10.1.0.34 FastEthernet0/0/0
10.1.0.35/32 10.1.0.35 FastEthernet0/0/0
10.1.0.36/32 10.1.0.36 FastEthernet0/0/0
10.1.0.37/32 10.1.0.37 FastEthernet0/0/0
10.1.0.38/32 10.1.0.38 FastEthernet0/0/0
10.1.0.41/32 10.1.0.41 FastEthernet0/0/0
10.1.0.42/32 10.1.0.42 FastEthernet0/0/0
10.1.0.43/32 10.1.0.43 FastEthernet0/0/0
10.1.0.255/32 receive
10.100.0.9/32 attached Virtual-Access24
10.100.0.10/32 attached Virtual-Access5
10.100.0.11/32 attached Virtual-Access35
10.100.0.12/32 attached Virtual-Access19
10.100.0.13/32 attached Virtual-Access31
10.100.0.18/32 attached Virtual-Access39
10.100.0.22/32 attached Virtual-Access30
10.100.0.25/32 attached Virtual-Access17
10.100.0.29/32 attached Virtual-Access9
10.100.0.30/32 attached Virtual-Access3
10.100.0.31/32 attached Virtual-Access26
10.100.0.36/32 attached Virtual-Access4
10.100.0.37/32 attached Virtual-Access18
10.100.0.39/32 attached Virtual-Access13
10.100.0.40/32 attached Virtual-Access15
10.100.0.45/32 attached Virtual-Access8
10.100.0.49/32 attached Virtual-Access37
10.100.0.55/32 attached Virtual-Access28
10.100.0.57/32 attached Virtual-Access22
10.100.0.59/32 attached Virtual-Access7
10.100.0.60/32 attached Virtual-Access16
10.100.0.61/32 attached Virtual-Access23
10.100.0.62/32 attached Virtual-Access36
10.100.0.72/32 attached Virtual-Access20
10.100.0.74/32 attached Virtual-Access38
10.100.0.76/32 attached Virtual-Access32
10.100.0.112/32 attached Virtual-Access14
10.100.0.170/32 attached Virtual-Access10
10.100.0.192/32 attached Virtual-Access33
10.100.0.206/32 attached Virtual-Access27
10.100.0.248/32 attached Virtual-Access12
10.100.0.249/32 attached Virtual-Access34
10.100.0.250/32 attached Virtual-Access29
10.100.0.252/32 attached Virtual-Access21
10.100.0.253/32 attached Virtual-Access11
10.100.0.254/32 attached Virtual-Access25
100.0.0.0/8 attached FastEthernet0/1/0
100.0.0.0/32 receive
100.1.1.1/32 100.1.1.1 FastEthernet0/1/0
100.1.1.2/32 receive
100.1.1.3/32 100.1.1.3 FastEthernet0/1/0
100.255.255.255/32 receive
224.0.0.0/4 drop
224.0.0.0/24 receive
255.255.255.255/32 receive
Порт который терминирует pptp воткнут в свич (catalyst 3L).
Скажите может перейти на pppoe ? Есть идея перейти на pppoe+dhcp ,свичи везде управляемые,
При трафе 3 mb/s
Router#show proc cpu
CPU utilization for five seconds: 24%/6%; one minute: 27%; five minutes: 31%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 2 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 324 46028 7 0.00% 0.00% 0.00% 0 Load Meter
3 892 12118 73 0.00% 0.00% 0.00% 0 CEF Scanner
4 3568 914271 3 0.00% 0.00% 0.00% 0 CEF IPC Backgrou
5 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN
6 101900 23903 4263 0.00% 0.04% 0.05% 0 Check heaps
7 56 47 1191 0.00% 0.00% 0.00% 0 Pool Manager
8 0 2 0 0.00% 0.00% 0.00% 0 Timers
9 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
10 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
11 16 767 20 0.00% 0.00% 0.00% 0 AAA high-capacit
12 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
13 0 3837 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
14 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
15 208 230051 0 0.00% 0.00% 0.00% 0 IPC Periodic Tim
16 204 230051 0 0.00% 0.00% 0.00% 0 IPC Deferred Por
17 8532 230567 37 0.00% 0.00% 0.00% 0 IPC Seat Manager
18 62464 231569 269 0.00% 0.03% 0.01% 0 ARP Input
19 360 11507 31 0.00% 0.00% 0.00% 0 HC Counter Timer
20 20 396 50 0.00% 0.00% 0.00% 0 DDR Timers
21 0 3 0 0.00% 0.00% 0.00% 0 Entity MIB API
22 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
23 304 230138 1 0.00% 0.00% 0.00% 0 GraphIt
24 0 2 0 0.00% 0.00% 0.00% 0 c7500 Entity MIB
25 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
26 0 1 0 0.00% 0.00% 0.00% 0 DSS Process
27 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
28 4 1 4000 0.00% 0.00% 0.00% 0 Microcode Loader
29 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
30 448 94227 4 0.00% 0.00% 0.00% 0 Net Background
31 64 1649 38 0.00% 0.00% 0.00% 0 Logger
32 412 230049 1 0.00% 0.00% 0.00% 0 TTY Background
33 2188 230140 9 0.00% 0.00% 0.00% 0 Per-Second Jobs
34 0 1 0 0.00% 0.00% 0.00% 0 IP Crashinfo Inp
35 0 1 0 0.00% 0.00% 0.00% 0 DSX3MIB ll handl
36 4 1 4000 0.00% 0.00% 0.00% 0 POS APS Event Pr
37 0 2 0 0.00% 0.00% 0.00% 0 Link Monitor Tra
38 0 2 0 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN
39 976 230054 4 0.00% 0.00% 0.00% 0 RSP Background
40 164 23014 7 0.00% 0.00% 0.00% 0 LC Stats Update
41 0 1 0 0.00% 0.00% 0.00% 0 Memory Scanner
42 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process
43 0 3836 0 0.00% 0.00% 0.00% 0 Slave Time
44 0 1 0 0.00% 0.00% 0.00% 0 Slave IPC OIR
45 0 19 0 0.00% 0.00% 0.00% 0 CRYPTO IKMP IPC
46 744 65149 11 0.00% 0.00% 0.00% 0 Chassis Daemon
47 4 3836 1 0.00% 0.00% 0.00% 0 RSP Chassis Back
48 0 1 0 0.00% 0.00% 0.00% 0 RSP IPC DRAMQ Se
49 0 2 0 0.00% 0.00% 0.00% 0 MIP Mailbox
50 0 1 0 0.00% 0.00% 0.00% 0 CT3 Mailbox
51 0 1 0 0.00% 0.00% 0.00% 0 CE3 Mailbox
52 0 1 0 0.00% 0.00% 0.00% 0 HAL Mailbox
53 0 1 0 0.00% 0.00% 0.00% 0 SRP Event Proc
54 8180 1168325 7 0.00% 0.00% 0.00% 0 IPC CBus process
55 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
56 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
57 0 4 0 0.00% 0.00% 0.00% 0 TurboACL
58 0 2 0 0.00% 0.00% 0.00% 0 TurboACL chunk
59 168 452 371 0.00% 0.00% 0.00% 0 AAA Server
60 2632 73329 35 0.00% 0.00% 0.00% 0 AAA ACCT Proc
61 1600 72577 22 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
62 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
63 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
64 13549444 8337659 1625 33.59% 20.92% 23.49% 0 IP Input
65 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
66 1520 34528 44 0.00% 0.00% 0.00% 0 CDP Protocol
67 204 830 245 0.00% 0.00% 0.00% 0 SSS Manager
68 24 30685 0 0.00% 0.00% 0.00% 0 SSS Test Client
69 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
70 1260 898986 1 0.00% 0.00% 0.00% 0 SSS Feature Time
71 44 1209 36 0.00% 0.00% 0.00% 0 PPP Hooks
72 0 386 0 0.00% 0.00% 0.00% 0 MOP Protocols
73 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
74 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA
75 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
76 0 1 0 0.00% 0.00% 0.00% 0 DMLP Counter
77 0 3 0 0.00% 0.00% 0.00% 0 IP Hdr Comp Proc
78 752 8341 90 0.00% 0.00% 0.00% 0 IP Background
79 164 4591 35 0.00% 0.00% 0.00% 0 IP RIB Update
80 0 2 0 0.00% 0.00% 0.00% 0 SNMP Timers
81 704 754 933 0.00% 0.00% 0.00% 0 PPP IP Route
82 168 1378 121 0.00% 0.00% 0.00% 0 PPP IPCP
83 2524 126023 20 0.00% 0.00% 0.00% 0 TCP Timer
84 8 16 500 0.00% 0.00% 0.00% 0 TCP Protocols
85 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
86 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
87 0 769 0 0.00% 0.00% 0.00% 0 HTTP CORE
88 424 1517 279 0.00% 0.00% 0.00% 0 DHCPD Receive
89 31972 3836 8334 0.00% 0.01% 0.00% 0 IP Cache Ager
90 0 1 0 0.00% 0.00% 0.00% 0 COPS
91 0 4 0 0.00% 0.00% 0.00% 0 PPP SSS
92 72 434 165 0.00% 0.00% 0.00% 0 PPP Bind
93 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
94 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
95 396 3837 103 0.00% 0.00% 0.00% 0 Adj Manager
96 6660 301043 22 0.00% 0.01% 0.00% 0 CEF process
97 4208 2293287 1 0.00% 0.01% 0.00% 0 MDFS RP process
98 0 1 0 0.00% 0.00% 0.00% 0 AToM manager
99 16 402 39 0.00% 0.00% 0.00% 0 AToM switching m
100 0 1 0 0.00% 0.00% 0.00% 0 AToM LDP manager
101 2948 936228 3 0.00% 0.00% 0.00% 0 IPC LC Message H
102 0 1 0 0.00% 0.00% 0.00% 0 Inspect Timer
103 10428 1137 9171 0.00% 0.00% 0.00% 0 VTEMPLATE Backgr
104 0 2 0 0.00% 0.00% 0.00% 0 URL filter proc
105 0 768 0 0.00% 0.00% 0.00% 0 Authentication P
106 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
107 0 1 0 0.00% 0.00% 0.00% 0 IDS Timer
108 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder
109 392 230059 1 0.00% 0.00% 0.00% 0 RUDPV1 Main Proc
110 0 1 0 0.00% 0.00% 0.00% 0 bsm_timers
111 144 230058 0 0.00% 0.00% 0.00% 0 bsm_xmt_proc
112 0 2 0 0.00% 0.00% 0.00% 0 RLM groups Proce
113 20 9207 2 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_
114 0 38 0 0.00% 0.00% 0.00% 0 LOCAL AAA
115 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
116 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
117 12 53 226 0.00% 0.00% 0.00% 0 VPDN failure man
118 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
119 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
121 0 2 0 0.00% 0.00% 0.00% 0 ASNL
122 0 2 0 0.00% 0.00% 0.00% 0 VSP_MGR
123 0 1 0 0.00% 0.00% 0.00% 0 Crypto Support
124 0 1 0 0.00% 0.00% 0.00% 0 VoIP AAA
125 4 1 4000 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN
126 0 1 0 0.00% 0.00% 0.00% 0 RPMS_PROC_MAIN
127 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_HTSP
128 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2
129 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE
130 0 1 0 0.00% 0.00% 0.00% 0 sssapp
131 0 1 0 0.00% 0.00% 0.00% 0 http client proc
132 0 1 0 0.00% 0.00% 0.00% 0 Encrypt Proc
133 0 1 0 0.00% 0.00% 0.00% 0 Key Proc
134 0 4 0 0.00% 0.00% 0.00% 0 Crypto CA
135 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL
136 0 4 0 0.00% 0.00% 0.00% 0 Crypto ACL
137 0 8 0 0.00% 0.00% 0.00% 0 Crypto Delete Ma
138 32 180 177 0.00% 0.00% 0.00% 0 Crypto IKMP
139 304 11511 26 0.00% 0.00% 0.00% 0 IPSEC key engine
140 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
141 0 1 0 0.00% 0.00% 0.00% 0 CRYPTO QoS proce
142 0 1 0 0.00% 0.00% 0.00% 0 SYSMGT Events
143 88 625 140 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
144 0 1 0 0.00% 0.00% 0.00% 0 IMA Traps
145 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
146 0 1 0 0.00% 0.00% 0.00% 0 IpSecMibTopN
147 680 460290 1 0.00% 0.00% 0.00% 0 cbus utilization
148 0 1 0 0.00% 0.00% 0.00% 0 VPDN Scal
149 252 230002 1 0.00% 0.00% 0.00% 0 trunk conditioni
150 0 1 0 0.00% 0.00% 0.00% 0 trunk conditioni
151 632 992 637 0.63% 0.18% 0.08% 2 Virtual Exec
153 732 18793 38 0.00% 0.00% 0.00% 0 Net Input
154 1892 46031 41 0.00% 0.00% 0.00% 0 Compute load avg
155 54884 3882 14138 0.00% 0.01% 0.00% 0 Per-minute Jobs
156 272 4859 55 0.00% 0.00% 0.00% 0 VPDN SSS manager
157 0 1 0 0.00% 0.00% 0.00% 0 L2X Socket proce
158 8572 835899 10 0.00% 0.00% 0.00% 0 L2X Data Daemon
159 76 46026 1 0.00% 0.00% 0.00% 0 L2F management d
160 0 2 0 0.00% 0.00% 0.00% 0 L2TP mgmt daemon
161 27224 147089 185 0.07% 0.01% 0.00% 0 PPTP Mgmt
162 72760 316590 229 0.15% 0.08% 0.08% 0 PPTP Data
163 9572 14257365 0 0.07% 0.01% 0.00% 0 PPPoE Background
164 36 22 1636 0.00% 0.00% 0.00% 0 PPPoE Discovery
165 455980 6039617 75 0.95% 0.84% 0.89% 0 IP NAT Ager
166 3380 74899 45 0.00% 0.01% 0.00% 0 TCP Driver
167 152 1352 112 0.00% 0.00% 0.00% 0 TCP Listener
168 15736 7172115 2 0.07% 0.02% 0.01% 0 PPP manager
169 20932 7177468 2 0.07% 0.03% 0.04% 0 PPP Events
170 340 230063 1 0.00% 0.00% 0.00% 0 Multilink PPP
171 2324 13848 167 0.00% 0.00% 0.00% 0 IP SNMP
172 740 6924 106 0.00% 0.00% 0.00% 0 PDU DISPATCHER
173 3128 6924 451 0.00% 0.00% 0.00% 0 SNMP ENGINE
174 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
175 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
176 79576 1874478 42 0.00% 0.05% 0.07% 0 NAT MIB Helper
177 9656 147541 65 0.00% 0.01% 0.00% 0 RADIUS
179 0 6 0 0.00% 0.00% 0.00% 0 AAA Accounting
180 8 1918 4 0.00% 0.00% 0.00% 0 DHCPD Timer
181 20 65202 0 0.00% 0.00% 0.00% 0 DHCPD Database
182 0 1 0 0.00% 0.00% 0.00% 0 Clock Sync Serve
Вот хистори :
Router#show proc cpu hi
Router 10:33:53 AM Tuesday Oct 5 2010 UTC
4422222222222222244444333333333322222222223333322222333333
3322222444445555500000999992222266666777774444477777666665
100
90
80
70
60
50
40 ** ********** ********
30 ** ************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
4324343445434564544434333355344563433365433333434342433323
0994525311538241197096814602525627514022233742430808001386
100
90
80
70
60 * ** *
50 ** *** *** * ** *** * **
40 ** ******#* ###*#****** *##****#** #** * * *** * **
30 ##*###*################*#########*##**######*##*##*##*##*#**
20 ############################################################
10 ############################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
66675445333322672324434543222213 1111111111111 9
4892598835509689047616541396727793332549931020232011028763436666
100 *
90 *
80 * *
70 *** ** *
60 ***** * ** *
50 ******** ** * ** *
40 ******** ** ** ****** * *
30 #####*********** ************ * *
20 ########*************#####****** *
10 ###########################*####* * ****************** ****
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Edited by RG-45
для начала давайте попробуем убрать с нее нат, следайте route-map с заворотом трафика на сервер где и делайте нат.
а никого не смущает то что проблема возникла на цифре 30-50 сессий, при планируемых 1000-1500?
нат вы конечно уберете, но потом весело будет смотреть на то как кошка взахлеб пойдет по трафику.
еще б неплохо убрать half-duplex на интерфейсах.
оно может и мелочь, но на мелочах жизнь строится.
Edited by darkagent
для начала - не стоит писать какие либо password тут. Ибо есть http://ifm.net.nz/cookbooks/passwordcracker.html
Далее.
1. NAT убрать.
2. Разобраться с дуплексом на интерфейсах.
3. Поставить MTU на Virtuial-Template 1 равный 1400 ибо имеет место быть фрагментация.
4. sh proc c s
По всему, судя по 64 13549444 8337659 1625 33.59% 20.92% 23.49% 0 IP Input - основная нагрузка от роутинга/ната.
Далее.
1. NAT убрать.
4. sh proc c s
1. NAT убрать.
Убрать на сервер ?
2.Разобраться с дуплексом на интерфейсах.
Что ставить ? Варианты, зависимотсь ?
3.Поставить MTU на Virtuial-Template 1 равный 1400 ибо имеет место быть фрагментация.
Для PPPOE тотже MTU будет ? Просто принято решение перейти на PPPoE +Dhcp (задолбали чудики кторые вместо своего ип ставят ип Cisco (AS)
Да и с pppoe абонентское оборудование реальнее работате(проверено)
Edited by RG-45
1. NAT убрать.
Убрать на сервер ?
1. да, на какую нибудь linux/bsd машину
2. full-duplex, очевидно же. это как минимум избавит от возможных коллизий и сопутствующих input error
3. можете подобрать опытным путем. начинаете с 1492 и на понижение с шагом по 8 байт.
dhcp на этой же циске будет?
нет на отдельной машине...
1. Убрать NAT на рядом стоящий linux box. Официальная рекомендация циски времен этого гроба (7507)
2. Уточнить, что за PA стоят в VIPe. Были такие, что не умели full duplex. Уточнить, что стоИт ЗА этими адаптерами и согласовать full duplex. Лучше всего жестко прибить руками.
3. Для PPPOE MTU можно сделать побольше. Пруфлинк http://zyxel.ru/content/support/knowledgebase/KB-1571
Общие соображения: PPPOE меньше грузит NAS чем PPTP. Но в отличие от PPTP это протокол L2. А значит не маршрутизируемый. Придется совать кошку во все виланы access сети.
Вообще, железка с RSP4 и VIP4-80 лопатит по 150-200 мегабит на слот без шифрования. + феноменальная отказоустойчивость. Два RSP и порты в разных слотах в etherchannel и два БП. И красота. Устойчиво к любым одиночным отказам.
Подскажите конфиг cisco , как теперь завернуть с cisco NAT на linux машинку . Да и на какой интерфейс cisco лучше повесить машину с NAT.
Коли речь пошла и про Linux, то почему не взять пару тройку писюков, которые всёравно будут дешевле cisco и не воспользоваться ppoe или pptp на них?
