911 Posted October 4, 2010 Posted October 4, 2010 Добрый день! Может кто подскажет, как собрать xbtt трекер на FreeBSD 8.1 amd64? # uname -a FreeBSD media.foboss.net 8.1-STABLE FreeBSD 8.1-STABLE #0 r212618: Wed Sep 15 21:26:51 UTC 2010 dima@fileserver.fob:/usr/obj/usr/src/sys/FSERV amd64 # g++ -v Using built-in specs. Target: amd64-undermydesk-freebsd Configured with: FreeBSD/amd64 system compiler Thread model: posix gcc version 4.2.1 20070719 [FreeBSD] # pkg_info | grep boost boost-all-1.43.0 The "meta-port" for boost libraries boost-docs-1.43.0 Documentation for libraries from boost.org boost-jam-1.43.0 Build tool from the boost.org boost-libs-1.43.0_1 Free portable C++ libraries (without Boost.Python) boost-python-libs-1.43.0 Framework for interfacing Python and C++ Выдает вот такую ошибку при сборке: # ./make.sh In file included from server.h:5, from connection.cpp:9: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from server.h:5, from connection.cpp:9: epoll.h:34: error: 'epoll_event' has not been declared connection.cpp: In member function 'virtual void Cconnection::process_events(int)': connection.cpp:285: error: 'EPOLLIN' was not declared in this scope connection.cpp:285: error: 'EPOLLPRI' was not declared in this scope connection.cpp:285: error: 'EPOLLERR' was not declared in this scope connection.cpp:285: error: 'EPOLLHUP' was not declared in this scope connection.cpp:286: error: 'EPOLLOUT' was not declared in this scope In file included from epoll.cpp:2: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from epoll.cpp:2: epoll.h:34: error: 'epoll_event' has not been declared epoll.cpp: In member function 'int Cepoll::create(int)': epoll.cpp:20: error: 'epoll_create' was not declared in this scope epoll.cpp: In member function 'int Cepoll::ctl(int, int, int, void*)': epoll.cpp:29: error: 'epoll_event' was not declared in this scope epoll.cpp:29: error: expected `;' before 'e' epoll.cpp:30: error: 'e' was not declared in this scope epoll.cpp:32: error: 'epoll_ctl' was not declared in this scope epoll.cpp: At global scope: epoll.cpp:38: error: 'int Cepoll::wait' is not a static member of 'class Cepoll' epoll.cpp:38: error: 'epoll_event' was not declared in this scope epoll.cpp:38: error: 'events' was not declared in this scope epoll.cpp:38: error: expected primary-expression before 'int' epoll.cpp:38: error: expected primary-expression before 'int' epoll.cpp:38: error: initializer expression list treated as compound expression epoll.cpp:39: error: expected ',' or ';' before '{' token In file included from server.h:5, from server.cpp:2: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from server.h:5, from server.cpp:2: epoll.h:34: error: 'epoll_event' has not been declared server.cpp: In member function 'int Cserver::run()': server.cpp:67: error: 'EPOLL_CTL_ADD' was not declared in this scope server.cpp:67: error: 'EPOLLIN' was not declared in this scope server.cpp:67: error: 'EPOLLOUT' was not declared in this scope server.cpp:67: error: 'EPOLLPRI' was not declared in this scope server.cpp:67: error: 'EPOLLERR' was not declared in this scope server.cpp:67: error: 'EPOLLHUP' was not declared in this scope server.cpp:83: error: 'EPOLL_CTL_ADD' was not declared in this scope server.cpp:83: error: 'EPOLLIN' was not declared in this scope server.cpp:83: error: 'EPOLLPRI' was not declared in this scope server.cpp:83: error: 'EPOLLERR' was not declared in this scope server.cpp:83: error: 'EPOLLHUP' was not declared in this scope server.cpp:113: error: 'epoll_event' was not declared in this scope server.cpp:113: error: template argument 1 is invalid server.cpp:113: error: invalid type in declaration before ';' token server.cpp:122: error: request for member 'data' in 'events', which is of non-class type 'int' server.cpp:122: error: request for member 'size' in 'events', which is of non-class type 'int' server.cpp:130: error: invalid types 'int[int]' for array subscript server.cpp:130: error: invalid types 'int[int]' for array subscript server.cpp: In member function 'void Cserver::accept(const Csocket&)': server.cpp:234: error: 'EPOLLIN' was not declared in this scope server.cpp:238: error: 'EPOLL_CTL_ADD' was not declared in this scope server.cpp:238: error: 'EPOLLOUT' was not declared in this scope server.cpp:238: error: 'EPOLLPRI' was not declared in this scope server.cpp:238: error: 'EPOLLERR' was not declared in this scope server.cpp:238: error: 'EPOLLHUP' was not declared in this scope server.cpp:238: error: 'EPOLLET' was not declared in this scope In file included from server.h:5, from tcp_listen_socket.cpp:4: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from server.h:5, from tcp_listen_socket.cpp:4: epoll.h:34: error: 'epoll_event' has not been declared In file included from server.h:5, from transaction.h:3, from transaction.cpp:2: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from server.h:5, from transaction.h:3, from transaction.cpp:2: epoll.h:34: error: 'epoll_event' has not been declared In file included from server.h:5, from transaction.h:3, from udp_listen_socket.cpp:4: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from server.h:5, from transaction.h:3, from udp_listen_socket.cpp:4: epoll.h:34: error: 'epoll_event' has not been declared udp_listen_socket.cpp: In member function 'virtual void Cudp_listen_socket::process_events(int)': udp_listen_socket.cpp:19: error: 'EPOLLIN' was not declared in this scope In file included from server.h:5, from XBT Tracker.cpp:5: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from server.h:5, from XBT Tracker.cpp:5: epoll.h:34: error: 'epoll_event' has not been declared может кто сталкивался? Вставить ник Quote
marikoda Posted October 4, 2010 Posted October 4, 2010 (edited) UPD. Ниже правильно написали, что нужно пользоваться другим скриптом сборки Edited October 4, 2010 by marikoda Вставить ник Quote
Deac Posted October 4, 2010 Posted October 4, 2010 http://re-tracker.ru/index.php?showtopic=313 Бан в гугле - страшное дело. :) Вставить ник Quote
s.lobanov Posted October 4, 2010 Posted October 4, 2010 http://re-tracker.ru/index.php?showtopic=313Бан в гугле - страшное дело. :) Ну кстати инструкция так себе, для ретрекера mysql не нужен. Вот вполне достаточный конфиг для ретркера: log_access = 0 log_announce = 0 anonymous_connect = 1 anonymous_announce = 1 debug = 0 gzip_debug = 0 gzip_scrape = 0 announce_interval = 600 listen_port = 80 auto_register = 1 mysql_host = - pid_file = /var/run/xbt_tracker.pid Вставить ник Quote
911 Posted October 4, 2010 Author Posted October 4, 2010 (edited) http://re-tracker.ru/index.php?showtopic=313Бан в гугле - страшное дело. :) страшное ))только проблема в том, что [root@media /usr/local/xbt/Tracker]# ls -l | grep make -rwxr-xr-x 1 root wheel 522 Oct 4 19:07 make.sh нет у меня make.bsd.sh ((( что делать? Edited October 4, 2010 by 911 Вставить ник Quote
s.lobanov Posted October 4, 2010 Posted October 4, 2010 мда... вы фряхой сами рулите или дали погонять? :) http://sourceforge.net/projects/xbtt/forum...4/topic/3395068 №5 Вставить ник Quote
911 Posted October 4, 2010 Author Posted October 4, 2010 мда... вы фряхой сами рулите или дали погонять? :) http://sourceforge.net/projects/xbtt/forum...4/topic/3395068 №5 [root@media /usr/local/xbt/Tracker]# grep '/usr/local/include' make.sh g++ $@ -DEPOLL -DNDEBUG -I ../misc -I . -O3 -o xbt_tracker -I /usr/local/include \ как бы это первым делом было добавлено :) Вставить ник Quote
s.lobanov Posted October 4, 2010 Posted October 4, 2010 -DEPOLL это Вы сами добавили или было? Вставить ник Quote
911 Posted October 4, 2010 Author Posted October 4, 2010 -DEPOLL это Вы сами добавили или было?было, я тока -I /usr/local/include добавил -DEPOLL это Вы сами добавили или было?убрал, заработало :) спасибо ;) Вставить ник Quote
pvk Posted October 6, 2010 Posted October 6, 2010 Добрый день уважаемое комьюнити. У меня похожая проблема с установкой XBTT - трекера на FreeBSD 8.1-STABLE При попытке выполнить ./make.sh получаю примерно такой же список ошибок. Подскажите пожалуйста, как исправить эту ситуацию. Если честно, не всё понятно из изложенного выше. Вроде сделал всё как написано, а исправить всё равно не получилось. = U, T = const unsigned char*]' ../misc/xbt/virtual_binary.h: In member function 'const_memory_range Cvirtual_binary::range() const': ../misc/xbt/virtual_binary.h:86: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h: In member function 'memory_range Cvirtual_binary::mutable_range()': ../misc/xbt/virtual_binary.h:91: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:93: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:97: error: invalid use of incomplete type 'class Cvirtual_binary_source' ../misc/xbt/virtual_binary.h:13: error: forward declaration of 'class Cvirtual_binary_source' ../misc/xbt/virtual_binary.h:99: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h: In member function 'void Cvirtual_binary::resize(size_t)': ../misc/xbt/virtual_binary.h:114: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:117: error: 'm_source' was not declared in this scope In file included from server.h:4, from transaction.h:3, from transaction.cpp:2: connection.h: At global scope: connection.h:9: error: 'boost' has not been declared connection.h:9: error: expected `{' before 'noncopyable' connection.h:9: error: function definition does not declare parameters In file included from server.h:5, from transaction.h:3, from transaction.cpp:2: epoll.h:29: error: 'boost' has not been declared epoll.h:29: error: expected `{' before 'noncopyable' epoll.h:29: error: function definition does not declare parameters In file included from ../misc/xbt/database.h:5, from server.h:13, from transaction.h:3, from transaction.cpp:2: ../misc/xbt/sql_result.h:15: error: 'boost' has not been declared ../misc/xbt/sql_result.h:15: error: expected `{' before 'noncopyable' ../misc/xbt/sql_result.h:15: error: function definition does not declare parameters ../misc/xbt/sql_result.h:86: error: expected `)' before ',' token ../misc/xbt/sql_result.h:102: error: 'MYSQL_ROW' does not name a type ../misc/xbt/sql_result.h:104: error: 'boost' has not been declared ../misc/xbt/sql_result.h:104: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/sql_result.h:104: error: expected ';' before '<' token ../misc/xbt/sql_result.h: In member function 'Csql_row::operator bool() const': ../misc/xbt/sql_result.h:94: error: 'm_data' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'Csql_field Csql_row::operator[](size_t) const': ../misc/xbt/sql_result.h:99: error: 'm_data' was not declared in this scope ../misc/xbt/sql_result.h: At global scope: ../misc/xbt/sql_result.h:112: error: expected `)' before '*' token ../misc/xbt/sql_result.h:141: error: ISO C++ forbids declaration of 'MYSQL_RES' with no type ../misc/xbt/sql_result.h:141: error: expected ';' before '*' token ../misc/xbt/sql_result.h:146: error: expected `;' before 'boost' ../misc/xbt/sql_result.h:146: error: 'boost' has not been declared ../misc/xbt/sql_result.h:146: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/sql_result.h:146: error: expected ';' before '<' token ../misc/xbt/sql_result.h: In member function 'int Csql_result::c_fields() const': ../misc/xbt/sql_result.h:128: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:128: error: 'mysql_num_fields' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'int Csql_result::c_rows() const': ../misc/xbt/sql_result.h:133: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:133: error: 'mysql_num_rows' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'void Csql_result::data_seek(int)': ../misc/xbt/sql_result.h:138: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:138: error: 'mysql_data_seek' was not declared in this scope In file included from server.h:13, from transaction.h:3, from transaction.cpp:2: ../misc/xbt/database.h: At global scope: ../misc/xbt/database.h:7: error: 'boost' has not been declared ../misc/xbt/database.h:7: error: expected `{' before 'noncopyable' ../misc/xbt/database.h:7: error: function definition does not declare parameters In file included from transaction.h:3, from transaction.cpp:2: server.h:64: error: 'boost' has not been declared server.h:64: error: ISO C++ forbids declaration of 'array' with no type server.h:64: error: expected ';' before '<' token server.h:170: error: 'boost' has not been declared server.h:170: error: ISO C++ forbids declaration of 'ptr_list' with no type server.h:170: error: typedef name may not be a nested-name-specifier server.h:170: error: expected ';' before '<' token server.h:199: error: 't_connections' does not name a type server.h:201: error: field 'm_epoll' has incomplete type In file included from udp_listen_socket.cpp:1: stdafx.h:3:29: error: boost/foreach.hpp: No such file or directory In file included from client.h:3, from udp_listen_socket.h:3, from udp_listen_socket.cpp:2: ../misc/socket.h:3:32: error: boost/shared_ptr.hpp: No such file or directory ../misc/socket.h:4:29: error: boost/utility.hpp: No such file or directory In file included from ../misc/socket.h:6, from client.h:3, from udp_listen_socket.h:3, from udp_listen_socket.cpp:2: ../misc/xbt/const_memory_range.h:3:27: error: boost/array.hpp: No such file or directory In file included from config.h:3, from server.h:3, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/config_base.h:3:38: error: boost/algorithm/string.hpp: No such file or directory In file included from connection.h:5, from server.h:4, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/xbt/virtual_binary.h:3:29: error: boost/version.hpp: No such file or directory In file included from server.h:5, from transaction.h:3, from udp_listen_socket.cpp:4: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from transaction.h:3, from udp_listen_socket.cpp:4: server.h:10:44: error: boost/ptr_container/ptr_list.hpp: No such file or directory server.h:11:43: error: boost/ptr_container/ptr_map.hpp: No such file or directory In file included from ../misc/xbt/database.h:5, from server.h:13, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/xbt/sql_result.h:13:25: error: mysql/mysql.h: No such file or directory In file included from ../misc/socket.h:6, from client.h:3, from udp_listen_socket.h:3, from udp_listen_socket.cpp:2: ../misc/xbt/const_memory_range.h:34: error: 'boost' has not been declared ../misc/xbt/const_memory_range.h:34: error: expected `)' before '<' token ../misc/xbt/const_memory_range.h:40: error: 'boost' has not been declared ../misc/xbt/const_memory_range.h:40: error: expected `)' before '<' token ../misc/xbt/const_memory_range.h:156: error: expected ',' or '...' before '::' token ../misc/xbt/const_memory_range.h:156: error: ISO C++ forbids declaration of 'boost' with no type ../misc/xbt/const_memory_range.h:162: error: expected ',' or '...' before '::' token ../misc/xbt/const_memory_range.h:162: error: ISO C++ forbids declaration of 'boost' with no type ../misc/xbt/const_memory_range.h: In constructor 'const_memory_range_base<T>::const_memory_range_base(int)': ../misc/xbt/const_memory_range.h:158: error: 'v' was not declared in this scope ../misc/xbt/const_memory_range.h: In constructor 'const_memory_range_base<T>::const_memory_range_base(int)': ../misc/xbt/const_memory_range.h:164: error: 'v' was not declared in this scope In file included from client.h:3, from udp_listen_socket.h:3, from udp_listen_socket.cpp:2: ../misc/socket.h: At global scope: ../misc/socket.h:70: error: 'boost' has not been declared ../misc/socket.h:70: error: expected `{' before 'noncopyable' ../misc/socket.h:70: error: function definition does not declare parameters ../misc/socket.h:120: error: 'boost' has not been declared ../misc/socket.h:120: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/socket.h:120: error: expected ';' before '<' token ../misc/socket.h: In member function 'Csocket::operator SOCKET() const': ../misc/socket.h:117: error: 'm_source' was not declared in this scope In file included from config.h:3, from server.h:3, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/config_base.h: In member function 'std::istream& Cconfig_base::load(std::istream&)': ../misc/config_base.h:61: error: 'boost' has not been declared ../misc/config_base.h:61: error: 'boost' has not been declared In file included from connection.h:5, from server.h:4, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/xbt/virtual_binary.h: At global scope: ../misc/xbt/virtual_binary.h:13: error: 'boost' has not been declared ../misc/xbt/virtual_binary.h:13: error: expected `{' before 'noncopyable' ../misc/xbt/virtual_binary.h:13: error: function definition does not declare parameters ../misc/xbt/virtual_binary.h:135: error: 'boost' has not been declared ../misc/xbt/virtual_binary.h:135: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/virtual_binary.h:135: error: expected ';' before '<' token ../misc/xbt/const_memory_range.h: In instantiation of 'const_memory_range_base<const unsigned char*>': ../misc/xbt/virtual_binary.h:56: instantiated from here ../misc/xbt/const_memory_range.h:162: error: 'template<long unsigned int U> const_memory_range_base::const_memory_range_base(int) [with long unsigned int U = U, T = const unsigned char*]' cannot be overloaded ../misc/xbt/const_memory_range.h:156: error: with 'template<long unsigned int U> const_memory_range_base::const_memory_range_base(int) [with long unsigned int U = U, T = const unsigned char*]' ../misc/xbt/virtual_binary.h: In member function 'const_memory_range Cvirtual_binary::range() const': ../misc/xbt/virtual_binary.h:86: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h: In member function 'memory_range Cvirtual_binary::mutable_range()': ../misc/xbt/virtual_binary.h:91: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:93: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:97: error: invalid use of incomplete type 'class Cvirtual_binary_source' ../misc/xbt/virtual_binary.h:13: error: forward declaration of 'class Cvirtual_binary_source' ../misc/xbt/virtual_binary.h:99: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h: In member function 'void Cvirtual_binary::resize(size_t)': ../misc/xbt/virtual_binary.h:114: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:117: error: 'm_source' was not declared in this scope In file included from server.h:4, from transaction.h:3, from udp_listen_socket.cpp:4: connection.h: At global scope: connection.h:9: error: 'boost' has not been declared connection.h:9: error: expected `{' before 'noncopyable' connection.h:9: error: function definition does not declare parameters In file included from server.h:5, from transaction.h:3, from udp_listen_socket.cpp:4: epoll.h:29: error: 'boost' has not been declared epoll.h:29: error: expected `{' before 'noncopyable' epoll.h:29: error: function definition does not declare parameters In file included from ../misc/xbt/database.h:5, from server.h:13, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/xbt/sql_result.h:15: error: 'boost' has not been declared ../misc/xbt/sql_result.h:15: error: expected `{' before 'noncopyable' ../misc/xbt/sql_result.h:15: error: function definition does not declare parameters ../misc/xbt/sql_result.h:86: error: expected `)' before ',' token ../misc/xbt/sql_result.h:102: error: 'MYSQL_ROW' does not name a type ../misc/xbt/sql_result.h:104: error: 'boost' has not been declared ../misc/xbt/sql_result.h:104: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/sql_result.h:104: error: expected ';' before '<' token ../misc/xbt/sql_result.h: In member function 'Csql_row::operator bool() const': ../misc/xbt/sql_result.h:94: error: 'm_data' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'Csql_field Csql_row::operator[](size_t) const': ../misc/xbt/sql_result.h:99: error: 'm_data' was not declared in this scope ../misc/xbt/sql_result.h: At global scope: ../misc/xbt/sql_result.h:112: error: expected `)' before '*' token ../misc/xbt/sql_result.h:141: error: ISO C++ forbids declaration of 'MYSQL_RES' with no type ../misc/xbt/sql_result.h:141: error: expected ';' before '*' token ../misc/xbt/sql_result.h:146: error: expected `;' before 'boost' ../misc/xbt/sql_result.h:146: error: 'boost' has not been declared ../misc/xbt/sql_result.h:146: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/sql_result.h:146: error: expected ';' before '<' token ../misc/xbt/sql_result.h: In member function 'int Csql_result::c_fields() const': ../misc/xbt/sql_result.h:128: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:128: error: 'mysql_num_fields' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'int Csql_result::c_rows() const': ../misc/xbt/sql_result.h:133: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:133: error: 'mysql_num_rows' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'void Csql_result::data_seek(int)': ../misc/xbt/sql_result.h:138: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:138: error: 'mysql_data_seek' was not declared in this scope In file included from server.h:13, from transaction.h:3, from udp_listen_socket.cpp:4: ../misc/xbt/database.h: At global scope: ../misc/xbt/database.h:7: error: 'boost' has not been declared ../misc/xbt/database.h:7: error: expected `{' before 'noncopyable' ../misc/xbt/database.h:7: error: function definition does not declare parameters In file included from transaction.h:3, from udp_listen_socket.cpp:4: server.h:64: error: 'boost' has not been declared server.h:64: error: ISO C++ forbids declaration of 'array' with no type server.h:64: error: expected ';' before '<' token server.h:170: error: 'boost' has not been declared server.h:170: error: ISO C++ forbids declaration of 'ptr_list' with no type server.h:170: error: typedef name may not be a nested-name-specifier server.h:170: error: expected ';' before '<' token server.h:199: error: 't_connections' does not name a type server.h:201: error: field 'm_epoll' has incomplete type udp_listen_socket.cpp: In member function 'virtual void Cudp_listen_socket::process_events(int)': udp_listen_socket.cpp:19: error: 'EPOLLIN' was not declared in this scope In file included from XBT Tracker.cpp:1: stdafx.h:3:29: error: boost/foreach.hpp: No such file or directory In file included from config.h:3, from XBT Tracker.cpp:4: ../misc/config_base.h:3:38: error: boost/algorithm/string.hpp: No such file or directory In file included from client.h:3, from connection.h:3, from server.h:4, from XBT Tracker.cpp:5: ../misc/socket.h:3:32: error: boost/shared_ptr.hpp: No such file or directory ../misc/socket.h:4:29: error: boost/utility.hpp: No such file or directory In file included from ../misc/socket.h:6, from client.h:3, from connection.h:3, from server.h:4, from XBT Tracker.cpp:5: ../misc/xbt/const_memory_range.h:3:27: error: boost/array.hpp: No such file or directory In file included from connection.h:5, from server.h:4, from XBT Tracker.cpp:5: ../misc/xbt/virtual_binary.h:3:29: error: boost/version.hpp: No such file or directory In file included from server.h:5, from XBT Tracker.cpp:5: epoll.h:6:23: error: sys/epoll.h: No such file or directory In file included from XBT Tracker.cpp:5: server.h:10:44: error: boost/ptr_container/ptr_list.hpp: No such file or directory server.h:11:43: error: boost/ptr_container/ptr_map.hpp: No such file or directory In file included from ../misc/xbt/database.h:5, from server.h:13, from XBT Tracker.cpp:5: ../misc/xbt/sql_result.h:13:25: error: mysql/mysql.h: No such file or directory In file included from config.h:3, from XBT Tracker.cpp:4: ../misc/config_base.h: In member function 'std::istream& Cconfig_base::load(std::istream&)': ../misc/config_base.h:61: error: 'boost' has not been declared ../misc/config_base.h:61: error: 'boost' has not been declared In file included from ../misc/socket.h:6, from client.h:3, from connection.h:3, from server.h:4, from XBT Tracker.cpp:5: ../misc/xbt/const_memory_range.h: At global scope: ../misc/xbt/const_memory_range.h:34: error: 'boost' has not been declared ../misc/xbt/const_memory_range.h:34: error: expected `)' before '<' token ../misc/xbt/const_memory_range.h:40: error: 'boost' has not been declared ../misc/xbt/const_memory_range.h:40: error: expected `)' before '<' token ../misc/xbt/const_memory_range.h:156: error: expected ',' or '...' before '::' token ../misc/xbt/const_memory_range.h:156: error: ISO C++ forbids declaration of 'boost' with no type ../misc/xbt/const_memory_range.h:162: error: expected ',' or '...' before '::' token ../misc/xbt/const_memory_range.h:162: error: ISO C++ forbids declaration of 'boost' with no type ../misc/xbt/const_memory_range.h: In constructor 'const_memory_range_base<T>::const_memory_range_base(int)': ../misc/xbt/const_memory_range.h:158: error: 'v' was not declared in this scope ../misc/xbt/const_memory_range.h: In constructor 'const_memory_range_base<T>::const_memory_range_base(int)': ../misc/xbt/const_memory_range.h:164: error: 'v' was not declared in this scope In file included from client.h:3, from connection.h:3, from server.h:4, from XBT Tracker.cpp:5: ../misc/socket.h: At global scope: ../misc/socket.h:70: error: 'boost' has not been declared ../misc/socket.h:70: error: expected `{' before 'noncopyable' ../misc/socket.h:70: error: function definition does not declare parameters ../misc/socket.h:120: error: 'boost' has not been declared ../misc/socket.h:120: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/socket.h:120: error: expected ';' before '<' token ../misc/socket.h: In member function 'Csocket::operator SOCKET() const': ../misc/socket.h:117: error: 'm_source' was not declared in this scope In file included from connection.h:5, from server.h:4, from XBT Tracker.cpp:5: ../misc/xbt/virtual_binary.h: At global scope: ../misc/xbt/virtual_binary.h:13: error: 'boost' has not been declared ../misc/xbt/virtual_binary.h:13: error: expected `{' before 'noncopyable' ../misc/xbt/virtual_binary.h:13: error: function definition does not declare parameters ../misc/xbt/virtual_binary.h:135: error: 'boost' has not been declared ../misc/xbt/virtual_binary.h:135: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/virtual_binary.h:135: error: expected ';' before '<' token ../misc/xbt/const_memory_range.h: In instantiation of 'const_memory_range_base<const unsigned char*>': ../misc/xbt/virtual_binary.h:56: instantiated from here ../misc/xbt/const_memory_range.h:162: error: 'template<long unsigned int U> const_memory_range_base::const_memory_range_base(int) [with long unsigned int U = U, T = const unsigned char*]' cannot be overloaded ../misc/xbt/const_memory_range.h:156: error: with 'template<long unsigned int U> const_memory_range_base::const_memory_range_base(int) [with long unsigned int U = U, T = const unsigned char*]' ../misc/xbt/virtual_binary.h: In member function 'const_memory_range Cvirtual_binary::range() const': ../misc/xbt/virtual_binary.h:86: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h: In member function 'memory_range Cvirtual_binary::mutable_range()': ../misc/xbt/virtual_binary.h:91: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:93: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:97: error: invalid use of incomplete type 'class Cvirtual_binary_source' ../misc/xbt/virtual_binary.h:13: error: forward declaration of 'class Cvirtual_binary_source' ../misc/xbt/virtual_binary.h:99: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h: In member function 'void Cvirtual_binary::resize(size_t)': ../misc/xbt/virtual_binary.h:114: error: 'm_source' was not declared in this scope ../misc/xbt/virtual_binary.h:117: error: 'm_source' was not declared in this scope In file included from server.h:4, from XBT Tracker.cpp:5: connection.h: At global scope: connection.h:9: error: 'boost' has not been declared connection.h:9: error: expected `{' before 'noncopyable' connection.h:9: error: function definition does not declare parameters In file included from server.h:5, from XBT Tracker.cpp:5: epoll.h:29: error: 'boost' has not been declared epoll.h:29: error: expected `{' before 'noncopyable' epoll.h:29: error: function definition does not declare parameters In file included from ../misc/xbt/database.h:5, from server.h:13, from XBT Tracker.cpp:5: ../misc/xbt/sql_result.h:15: error: 'boost' has not been declared ../misc/xbt/sql_result.h:15: error: expected `{' before 'noncopyable' ../misc/xbt/sql_result.h:15: error: function definition does not declare parameters ../misc/xbt/sql_result.h:86: error: expected `)' before ',' token ../misc/xbt/sql_result.h:102: error: 'MYSQL_ROW' does not name a type ../misc/xbt/sql_result.h:104: error: 'boost' has not been declared ../misc/xbt/sql_result.h:104: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/sql_result.h:104: error: expected ';' before '<' token ../misc/xbt/sql_result.h: In member function 'Csql_row::operator bool() const': ../misc/xbt/sql_result.h:94: error: 'm_data' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'Csql_field Csql_row::operator[](size_t) const': ../misc/xbt/sql_result.h:99: error: 'm_data' was not declared in this scope ../misc/xbt/sql_result.h: At global scope: ../misc/xbt/sql_result.h:112: error: expected `)' before '*' token ../misc/xbt/sql_result.h:141: error: ISO C++ forbids declaration of 'MYSQL_RES' with no type ../misc/xbt/sql_result.h:141: error: expected ';' before '*' token ../misc/xbt/sql_result.h:146: error: expected `;' before 'boost' ../misc/xbt/sql_result.h:146: error: 'boost' has not been declared ../misc/xbt/sql_result.h:146: error: ISO C++ forbids declaration of 'shared_ptr' with no type ../misc/xbt/sql_result.h:146: error: expected ';' before '<' token ../misc/xbt/sql_result.h: In member function 'int Csql_result::c_fields() const': ../misc/xbt/sql_result.h:128: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:128: error: 'mysql_num_fields' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'int Csql_result::c_rows() const': ../misc/xbt/sql_result.h:133: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:133: error: 'mysql_num_rows' was not declared in this scope ../misc/xbt/sql_result.h: In member function 'void Csql_result::data_seek(int)': ../misc/xbt/sql_result.h:138: error: 'h' was not declared in this scope ../misc/xbt/sql_result.h:138: error: 'mysql_data_seek' was not declared in this scope In file included from server.h:13, from XBT Tracker.cpp:5: ../misc/xbt/database.h: At global scope: ../misc/xbt/database.h:7: error: 'boost' has not been declared ../misc/xbt/database.h:7: error: expected `{' before 'noncopyable' ../misc/xbt/database.h:7: error: function definition does not declare parameters In file included from XBT Tracker.cpp:5: server.h:64: error: 'boost' has not been declared server.h:64: error: ISO C++ forbids declaration of 'array' with no type server.h:64: error: expected ';' before '<' token server.h:170: error: 'boost' has not been declared server.h:170: error: ISO C++ forbids declaration of 'ptr_list' with no type server.h:170: error: typedef name may not be a nested-name-specifier server.h:170: error: expected ';' before '<' token server.h:199: error: 't_connections' does not name a type server.h:201: error: field 'm_epoll' has incomplete type XBT Tracker.cpp: In function 'int main1()': XBT Tracker.cpp:31: error: aggregate 'Cdatabase database' has incomplete type and cannot be defined XBT Tracker.cpp:37: error: expected type-specifier XBT Tracker.cpp:37: error: expected unqualified-id before '&' token XBT Tracker.cpp:37: error: expected `)' before '&' token XBT Tracker.cpp:37: error: expected `{' before '&' token XBT Tracker.cpp:37: error: 'e' was not declared in this scope XBT Tracker.cpp:37: error: expected `;' before ')' token Вставить ник Quote
s.lobanov Posted October 7, 2010 Posted October 7, 2010 1. У Вас буста нет 2. -DEPOLL тоже надо убрать 3. Нужны хедеры и либы мускуля Вставить ник Quote
pvk Posted October 7, 2010 Posted October 7, 2010 Я прошу прощения, за очередной нубовский вопрос, а как это сделать? Ну или где поискать, чтобы не задавать подбных вопросов в следующий раз.. Вставить ник Quote
Deac Posted October 7, 2010 Posted October 7, 2010 Яндекс, Гугл и пр. Тема весьма популярная. Вставить ник Quote
pvk Posted October 7, 2010 Posted October 7, 2010 Deac Большое спасибо за вразумительный ответ и дельный совет. На 9 из 10 ресурсов ответ примерно такой же. Ничего личного, но смысл от такого комментария? Отправить человека, который ищет решение проблемы искать дальше? Я не имею, пока представления о том, каким образом необходимо решить эту проблему. Ничего личного против Вас, Deac, не имею, наболело уже. Вставить ник Quote
Deac Posted October 7, 2010 Posted October 7, 2010 Вот ведь, а у меня находится! http://re-tracker.ru/index.php?showtopic=494 Развёрнутое руководство по safety xbtt и ссылка на ресурс из моего же поста. Вставить ник Quote
