Очень-очень дешево весь спектр родной памяти и оборудования
Guest Ramar
Память
MEM-128M-AS53______128MB DRAM memory for 5300_________________________250
MEM1700-16D________Cisco 1700 16MB DRAM DIMM__________________________95
MEM1700-16MFC______Cisco 1700 16MB Mini-Flash Card_______________________280
MEM1700-32D_________Cisco 1700 32MB DRAM DIMM________________________180
MEM2600-32D_________32 MB DRAM DIMM for the Cisco 2600 Series_____________140
MEM2600-64D_________64MB DRAM for the 2600 (2x32MB)_____________________285
MEM2600XM-32D______32MB DIMM DRAM for the Cisco 2600XM________________274
MEM2600XM-32FS_____32MB Flash SIMM for the Cisco 2600XM_________________360
MEM2600XM-64D______64MB DIMM DRAM for the Cisco 2600XM________________300
MEM2650-32D_________32MB DRAM DIMM for the Cisco 265x only_______________145
MEM2650-64D_________64MB DRAM DIMM for the Cisco 265x only_______________270
MEM3600-16FC_______16Mb Flash Card for the Cisco 3600 series________________225
MEM3600-16FS_______16MB Flash Memory for the 3600_______________________240
MEM3600-2x16FS_____32MB Flash for 3600 ( 2X16mb flash )____________________400
MEM3640-2X32D______64MB DRAM for the Cisco 3640 (2x32MB DRAM SIMMs)____315
MEM3640-4X32D______128MB DRAM for the Cisco 3640 (4x32MB DRAM SIMMs)___360
Маршрутизаторы
CISCO3640A_________Cisco 3600 4-slot Modular router-AC with IP Software________3000
CISCO3725__________3700 Series, 2-Slot, Dual FE, Multiservice Access Router_____5000
NM-4T______________4-Port Serial WAN Interface Card________________________2000
NM-8A/S____________8-Port Async/Sync Serial Network Module_________________1440
WIC-2T_____________2-Port Serial WAN Interface Card________________________350
WIC-1T_____________1-Port Serial WAN Interface Card________________________175
VWIC-1MFT-E1______1-Port RJ-48 Multiflex Trunk - E1_________________________1300
Коммутаторы
WS-C2924-XL-EN____24-port 10/100 Switch (Enterprise Edition)__________________650
Сервера доступа
AS53-E1-120DM_____Cisco AS5300 120 MICA DMM Modems 4 E1/PRI Card_______6400
AS53-E1-240DM_____Cisco AS5300 240 MICA DMM Modems 8 E1/PRI Card______13500
AS535-4E1-120-AC___AC AS5350; 4E1, 120 ports, IP+ IOS, 120 Data Lic__________22080
Кабели
CAB-232MT_________RS-232 Cable, DTE, Male, 10 Feet_______________________35
CAB-232FC_________RS-232 Cable, DCE, Female, 10 Feet_____________________35
CAB-E1-PRI_________E1 ISDN PRI CABLE, 10 FOOT__________________________35
CAB-SS-V35MT______V.35 Cable, DTE Male to Smart Serial, 10 Feet______________35
CAB-V35MT_________V.35 Cable, DTE, Male, 10 Feet__________________________35
Jera Systems, Москва, Россия
Тел. : +7 095 926-4025
+7 095 926-4026
Факс : +7 095 926-4027
