Ivan Rostovikov Posted September 10, 2010 Posted September 10, 2010 Есть такое ядро: Catalyst 6500 System image file is "sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI3.bin Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1333WG7U 3 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAD083704PL 4 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1152BHR4 6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1130VGY0 Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 1 Distributed Forwarding Card WS-F6700-DFC3B SAL1222S3GA 4.6 Ok 3 Centralized Forwarding Card WS-F6700-CFC SAL1327T7YX 4.1 Ok 4 Centralized Forwarding Card WS-F6700-CFC SAL1202CCDM 4.0 Ok 6 Policy Feature Card 3 WS-F6K-PFC3B SAL1130VZ46 2.3 Ok 6 MSFC3 Daughterboard WS-SUP720 SAL1111JVQV 3.0 Ok создана VLAN 143 interface Vlan143 ip unnumbered Loopback10 no ip redirects no ip unreachables no ip proxy-arp service-policy input POLICY-MAP service-policy output POLICY-MAP end policy-map POLICY-MAP class CLASS-MAP police 10100000 conform-action transmit exceed-action drop class-map match-any CLASS-MAP match any В этом вилане абонент. По факту трафик ограничивается только в сторону абонента. От абонента - не ограничивается. А хочется... Какие советы ? Вставить ник Quote
Asco Posted September 10, 2010 Posted September 10, 2010 zzz#sh run | inc qos mls qos vlan-based zzz#sh policy-map int vl173 de Vlan173 Service-policy input: 20Mb class-map: class-default (match-any) Match: any police : 20000000 bps 625000 limit 625000 extended limit Earl in slot 5 : Traffic: Total bytes 30-s bytes peak bytes 5-min avg bps peak bps ----------------------------------------------------------------------------------------------------------- Offered 354667933006 4340130 1475245 1786944 4399224 Agg-fwd 354626193580 4340130 1475245 1786944 4399224 Exceed 41739426 0 0 0 0 Service-policy output: 20Mb class-map: class-default (match-any) Match: any police : 20000000 bps 625000 limit 625000 extended limit Earl in slot 5 : Traffic: Total bytes 30-s bytes peak bytes 5-min avg bps peak bps ----------------------------------------------------------------------------------------------------------- Offered 163314016676 1668502 603535 502240 993880 Agg-fwd 163280603305 1668502 603535 502240 993880 Exceed 33413371 0 0 0 0 zzz# Вставить ник Quote
Ivan Rostovikov Posted September 10, 2010 Author Posted September 10, 2010 >mls qos vlan-based Т.е. это надо сказать на физическом интерфейсе ? Вставить ник Quote
secandr Posted September 13, 2010 Posted September 13, 2010 сказать mls qos vlan-based на физическом интерфейсе и mls qos в глобальном режиме конфигурации Вставить ник Quote
