Помогите ответить на пару вопросов.
При необходимости переведу:) Спасибо!
There are 13 root servers that control the overall DNS lookup process for the entire
Internet. If these 13 servers were to become unavailable, much of the Internet would be
inaccessible. Resources would have to be accessed via IP address, not by host name.
However, hackers once managed to attack 11 of the 13 root servers, resulting in
degraded performance. Surprisingly, Internet users did not notice any difference. Can
you explain in details why?
и
Suppose your network utilises a WINS server. Also, assume you are the network
administrator and were called in to troubleshoot a problem in which the WINS server
itself could not be accessed using NetBIOS name resolution. Assume all other machines
are working and communicating properly with the WINS server in order to resolve
NetBIOS names. Describe what you view to be the most likely cause of this network’s
problem.
викторина чтоле? и где такую траву берёте?
hackers once managed to attack 11 of the 13 root servers, resulting in degraded performance
да, при атаке было "попробованы" 11 штук, но по-настоящему "прилегли" только 2, которые не были пропатчены up to date.
И их активно дедосили. Причем дедовскими методами, т.е. был прописан бан сначала всем пакетам с pktLen>512b, ну и после этого ~ 4.5 тыс корейским IP, после чего вся "атака" закончилась.
Если кому не сложно, помогите с двумя последними:) Спасибо!
Suppose you are the administrator of a slow wide area network. As your network is
very slow, it is absolutely essential that WAN traffic be reduced to the minimum amount
necessary. Because of this, you have already decided not to store Active Directory integrated
zones and secondary zones. You need some kind of local DNS but you also
need reduced network traffic. What is probably your best remaining option? Describe
this option and how it is set up on the network.
и
Your administrative user account is a member of the Enterprise Admins and Schema
Admins groups in your company's Active Directory forest. The forest consists of a single
domain named bcdtrain.com that is running in Windows 2000 native mode. Your
company recently acquired a new subsidiary. To support this subsidiary, you plan to
create a new domain tree in the forest that will contain a tree root domain named meddev.
com and a child domain named research.meddev.com.
The Domain Name System (DNS) server service is installed on two of the domain
controllers for bcdtrain.com. The DNS zone for bcdtrain.com is configured as an Active
Directory-integrated zone. You create a new zone named meddev.com on one of these
DNS servers, and you accept the default settings for the zone.
The domain controllers for the new domains will be computers that are running
Windows Server 2003. You run the Adprep utility with the forestprep option from the
Windows Server 2003 installation CD-ROM to update the forest's schema to support the
new domains.
What additional step must you perform to ensure that you can create the child domain in
the new domain tree?
Кстати, все как-то забывают, что даже если все корневые сервера полягут, то в кэшах еще довольно долго будут жить данные. Так что доступность ресурса по имени будет прямо пропорциональна его популярности.
Топикстартеру с этими вопросами вообще не сюда, а на sysadmins.ru :)
Некоторым, кто озаботился настройкой DNS сервера, в течении недели (кажется там такой expire стоит) глубоко пофиг на корневые сервера..... локальное размещение рутовой зоны и in-addr.arpa рулит....
А насчет брать из кеша... что то наиболее полулярные ресурсы имеют TTL от силы по часу. вон вконтакте пол часа, их НСы 2.5. Хорошо для 1 уровня доменов ТТЛы поболе обычно.
