Есть разношорстное оборудование
DLINK DES-3028
Cisco cat 29 серии 35 серии
Способ предоставления услуг PPPoE.
Каким образом можно ограничить по порту, чтобы ходил только PPPoE??
#DES-3028 1-24 customers, 25 Dowlink, 26 Uplink
config traffic trap none
config traffic control 1-28 broadcast enable action shutdown threshold 64000
config traffic control 1-28 multicast enable action shutdown threshold 64000
config traffic_segmentation 1-25,27-28 forward_list 26
config traffic_segmentation 26 forward_list 1-28
disable port_security trap_log
config port_security ports 1-24 admin_state enable max_learning_addr 1 lock_address_mode DeleteOnTimeout
config port_security ports 25-28 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnTimeout
config vlan default delete 1-28
config vlan default add forbidden 1-28
create vlan krb-control tag 19
config vlan krb-control add tagged 25-28
create vlan PPPoE(207) tag 207
config vlan PPPoE(207) add tagged 25-28
config vlan PPPoE(207) add untagged 1-24
enable loopdetect
config loopdetect ports 1-28 state enable
config ipif System vlan krb-control ipaddress 172.16.4.103/24 state enable
create iproute default 172.16.4.1 1
create access_profile packet_content_mask offset_0-15 0x0 0x0 0x0 0xFFFF00FF profile_id 1
#Disable PADO
config access_profile profile_id 1 add access_id 1 packet_content offset 12 0x88630007 port 1-25,27-28 deny
#Disable PADI
config access_profile profile_id 1 add access_id 2 packet_content offset 12 0x88630009 port 26 deny
create access_profile ethernet ethernet_type profile_id 2
config access_profile profile_id 2 add access_id 1 ethernet ethernet_type 0x8863 port 1-24 permit
config access_profile profile_id 2 add access_id 2 ethernet ethernet_type 0x8864 port 1-24 permit
create access_profile ethernet source_mac 00-00-00-00-00-00 profile_id 3
config access_profile profile_id 3 add access_id 1 ethernet source_mac 00-00-00-00-00-00 port 25-28 permit
create access_profile ethernet source_mac 00-00-00-00-00-00 profile_id 4
config access_profile profile_id 4 add access_id 1 ethernet source_mac 00-00-00-00-00-00 port 1-28 deny
Суть - разрешить с портов 1-24 только пакеты PPPoE и только "на верх"
25 порт - для соединения со следущим свичем.
19 влан - управляющий.
207 - абонентский (изолированый)
На 29-х каталистах так не сделать :-(
Некоторые бродкасты (например, DHCP) вроде бы через такое правило проходят.
  • 3 years later...
Это если включен дхцп-релей, сии пакеты обрабатываются цпу, емнип.
Edited by pppoetest
  • 2 weeks later...
# PPPoE
create access_profile                                        ethernet ethernet_type profile_id 1
config access_profile profile_id 1 add access_id auto_assign ethernet ethernet_type 0x8863 port all permit
config access_profile profile_id 2 add access_id auto_assign ethernet ethernet_type 0x8864 port all permit
# DHCP
create access_profile                                        ip udp src_port_mask 0xffff dst_port_mask 0xffff profile_id 3
config access_profile profile_id 3 add access_id auto_assign ip udp src_port        68   dst_port        67 port 1-24 permit
# deny all
config access_profile profile_id 4 add access_id auto_assign ethernet source_mac 00-00-00-00-00-00 port 1-24 deny
Через DHCP выдаете юзерам любые адреса только для того, чтобы венда не выключала сетевушку.
