Добрый день
Есть Cisco C10008 (PRE2-RP) терминирует pppoe, в пиках до 4 тысяч сессий, трафика до 500 егабит
независимо от нагрузки и количества сессий, загрузка процессора прыгает до 60-80%,
не могу понять почему.
при нормальном стоянии процесс IP Input от 0 до 2%
вывод show pxf cpu context почти всегда показывает около 2%
Cisco C10008 (PRE2-RP) processor (revision ) with 950271K/94208K bytes of memory.
Processor board ID TBC06121331
R7000 CPU at 500Mhz, Implementation 0x27, Rev 5.1, 256KB L2, 8192KB L3 Cache
Backplane version 1.0, 8 slot
Last reset from register reset
PXF processor tmc0 is running.
PXF processor tmc1 is running.
PXF processor tmc2 is running.
PXF processor tmc3 is running.
1 FastEthernet interface
2 Gigabit Ethernet interfaces
2045K bytes of non-volatile configuration memory.
cat10k#show processes cpu sorted
CPU utilization for five seconds: 56%/25%; one minute: 57%; five minutes: 56%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
134 101604376 372723009 272 23.34% 23.13% 22.97% 0 IP Input
51 40593400 5043685 8048 2.15% 1.10% 1.06% 0 Per-Second Jobs
216 49659596 253409252 195 1.19% 0.89% 0.83% 0 C10K Netflow Toa
214 25212336 5191002 4856 1.03% 0.98% 0.96% 0 c10k_periodic_st
142 3283424 1438125 2283 0.55% 0.76% 0.77% 0 PPP IP Route
215 5241080 506562 10346 0.47% 0.22% 0.20% 0 STATS DMA Daemon
299 3149292 177204130 17 0.39% 0.20% 0.16% 0 RADIUS
288 8642688 174180878 49 0.39% 0.34% 0.32% 0 PPP Events
143 5211048 11900759 437 0.31% 0.35% 0.25% 0 SSS Manager
cat10k#show pxf cpu context
FP context statistics count rate (since last time command was run)
feed_back 225006832892 98322
new_work_from_lc 217734102820 95064
new_work_from_rp 1846170348 1845
new_work_from_replay 0 0
null_context 30124304277747 6099128
6294360
FP average context/sec 1min 5min 60min
feed_back 103368 100068 85338 cps
new_work_from_lc 99661 96709 82011 cps
new_work 1818 1853 1953 cps
new_work_from_replay 0 0 0 cps
null_context 6192894 6150031 6173045 cps
Total 6397742 6348662 6342347 cps
FP context utilization 1min 5min 60min
Actual 3 % 3 % 2 %
Theoretical 3 % 3 % 2 %
Maximum 99 % 99 % 99 %
Edited by psa79
cat10k#show inventory
NAME: "Chassis", DESCR: "C10000 Edge Service Router (ESR) Chassis"
PID: ESR-CHASSIS , VID: , SN: 00021651183
NAME: "module 1/0", DESCR: "1 pt Gigabit Ethernet line card (requires a GBIC)"
PID: ESR-1GE , VID: , SN: CAB0438EGFF
NAME: "module 2/0", DESCR: "1 pt Gigabit Ethernet line card (requires a GBIC)"
PID: ESR-1GE , VID: , SN: CAT065008LK
NAME: "RP A", DESCR: "Performance Routing Engine"
PID: ESR-PRE2 , VID: V02 , SN: CAT07360UAV
NAME: "RP A flash card 0", DESCR: "Flash Card"
PID: ESR-PRE-MEM-FD128 , VID: , SN:
NAME: "power-supply 0", DESCR: "DC POWER ENTRY MODULE FOR ESR10008"
PID: ESR-PWR-DC , VID: , SN:
NAME: "fan-tray", DESCR: "BLOWER ASSEMBLY FOR ESR10008"
PID: ESR-BLOWER , VID: , SN:
пробовал IOS-ы
c10k2-k91p11-mz.122-33.SB7.bin
c10k2-k91p11u2-mz.122-31.SB16.bin
c10k2-k91p11u2-mz.122-33.SB7.bin
эфект тотже
Edited by psa79
не могу не вставить свои 5 копеек. у нас стоит ESR 10008 с PRE4. работает нормально, без нареканий. но ввел команду sh pxf log и вот что мне выдал роутер: CPU 0 HTDP error COB3_FB_EMPTY_ERR: Pool Empty.
причем такие сообщения проскакивают довольно часто.
НИкто не в курсе что бы это означало?? Гугл молчит, сайт циски тоже..........
Очевидно, что часть трафика у вас не обрабатывается PXF, а свитичится на CPU. Причем часть того, что свитчится на CPU не может смаршрутизироваться в CEF. Скорее всего у вас есть какие-то фичи, которые не могут быть обработаны в PXF. Я-бы начал с внимательного прочтения Release Notes к вашему софту на предмет того, какие фичи поддерживаются в PXF. Ну сравнивал-бы с тем, что у Вас сконфигурировано.
Ну и вообще конфиг полезно постить :) , а то здешние телепаты удаленно только две первые строчки увидеть могут :)
сразу скажу от ospf никакого роутинга не получаю, он только чтоб бордер знал какие абоненты подключены
aaa new-model
aaa authentication password-prompt password:
aaa authentication username-prompt login:
aaa authentication login default local
aaa authentication login dialers group radius
aaa authentication ppp default group radius
aaa authorization exec default local
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting update periodic 10
aaa accounting network default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
facility-alarm core-temperature major 58
facility-alarm core-temperature minor 50
facility-alarm intake-temperature major 54
facility-alarm intake-temperature minor 45
card 1/0 1gigethernet-1
card 2/0 1gigethernet-1
ip subnet-zero
no ip gratuitous-arps
no ip rcmd domain-lookup
ip name-server 10.3.3.1
ip name-server 10.3.3.2
vpdn enable
vpdn aaa attribute nas-ip-address vpdn-nas
vpdn aaa attribute nas-port vpdn-nas
archive
log config
logging enable
hidekeys
redundancy
mode sso
class-map match-all test
match access-group name acl_user
class-map match-any ua-ix
match access-group name acl_ua-ix_in
class-map match-all all_user
policy-map k128
class class-default
police 128000 16384 16384 conform-action transmit exceed-action drop violate-action drop
policy-map m8
class class-default
police 8392000 1048576 1048576 conform-action transmit exceed-action drop violate-action drop
policy-map m5
class class-default
police 5240000 655360 655360 conform-action transmit exceed-action drop violate-action drop
policy-map m4
class class-default
police 4192000 524288 524288 conform-action transmit exceed-action drop violate-action drop
policy-map k256
class class-default
police 264000 32768 32768 conform-action transmit exceed-action drop violate-action drop
policy-map m1
class class-default
police 1048000 131072 131072 conform-action transmit exceed-action drop violate-action drop
policy-map k512
class class-default
police 528000 65536 65536 conform-action transmit exceed-action drop violate-action drop
policy-map m3
class class-default
police 3144000 393216 393216 conform-action transmit exceed-action drop violate-action drop
policy-map m2
class class-default
police 2096000 262144 262144 conform-action transmit exceed-action drop violate-action drop
policy-map k64
class class-default
police 64000 8216 8216 conform-action transmit exceed-action drop violate-action drop
policy-map m15
class class-default
police 15360000 1310720 1310720 conform-action transmit exceed-action drop violate-action drop
policy-map k32
class class-default
police 32000 4096 4096 conform-action transmit exceed-action drop violate-action drop
policy-map k1024
class class-default
policy-map m10
class class-default
police 10488000 1310720 1310720 conform-action transmit exceed-action drop violate-action drop
policy-map m20
class class-default
police 20976000 2621440 2621440 conform-action transmit exceed-action drop violate-action drop
bba-group pppoe global
virtual-template 1
sessions max limit 10000
sessions per-mac limit 1
sessions per-vlan limit 4096
sessions auto cleanup
interface Loopback0
ip address 172.16.0.10 255.255.255.255
interface FastEthernet0/0/0
no ip address
shutdown
speed 100
full-duplex
interface GigabitEthernet1/0/0
no ip address
ip route-cache policy
negotiation auto
interface GigabitEthernet1/0/0.21
encapsulation dot1Q 21
no ip redirects
no ip proxy-arp
pppoe enable group global
...........................(около 200 vlan интерфейсов настроенных одинаково)
interface GigabitEthernet1/0/0.732
encapsulation dot1Q 732
no ip redirects
no ip proxy-arp
interface GigabitEthernet2/0/0
no ip address
negotiation auto
interface GigabitEthernet2/0/0.100
encapsulation dot1Q 100
ip address 10.4.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
shutdown
interface GigabitEthernet2/0/0.150
encapsulation dot1Q 150
ip address 10.3.3.58 255.255.255.192
ip access-group 101 in
no ip redirects
no ip proxy-arp
interface GigabitEthernet2/0/0.156
encapsulation dot1Q 156
ip address 10.200.3.3 255.255.255.224
ip flow ingress
ip flow egress
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback0
ip access-group 100 in
no ip proxy-arp
ip mtu 1492
ip tcp header-compression
ip tcp adjust-mss 1300
no peer default ip address
ppp authentication ms-chap-v2 ms-chap chap pap
router ospf 3
router-id 10.200.3.3
no log-adjacency-changes
area 0 authentication message-digest
redistribute connected subnets
network 10.200.3.0 0.0.0.31 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 10.200.3.2
ip flow-export version 5
ip flow-export destination 10.3.3.11 9996
no ip http server
ip access-list extended acl_user
permit ip any any
logging facility local5
logging source-interface GigabitEthernet2/0/0.150
logging 10.3.3.11
access-list 1 deny 10.3.3.2
access-list 1 deny 10.3.3.50
access-list 1 permit 10.3.3.0 0.0.0.255
access-list 1 deny any
access-list 2 permit 10.3.3.34
access-list 2 deny any
access-list 100 deny tcp any 10.3.3.0 0.0.0.255 eq 22
access-list 100 deny tcp any 10.3.3.0 0.0.0.255 eq 3306
access-list 100 permit ip any host 10.3.3.1
access-list 100 permit ip any host 10.3.3.2
access-list 100 permit ip any host 10.3.3.50
access-list 100 permit ip any host 10.3.3.43
access-list 100 permit ip any host 10.3.3.38
access-list 100 permit ip 195.5.124.0 0.0.1.255 any
access-list 100 permit ip 195.222.124.0 0.0.3.255 any
access-list 100 deny ip any 10.0.0.0 0.255.255.255
access-list 100 deny ip any 172.16.0.0 0.7.255.255
access-list 100 deny ip any 192.168.0.0 0.0.255.255
access-list 100 permit ip any any
access-list 101 deny ip any host 172.16.0.10
access-list 101 permit ip 10.3.3.0 0.0.0.255 host 10.3.3.58
access-list 101 permit ip 10.200.3.0 0.0.0.31 10.200.3.0 0.0.0.31
access-list 101 deny ip any host 10.200.3.3
access-list 101 deny ip any host 10.3.3.58
access-list 101 permit ip any any
snmp-server community public RO 2
radius-server attribute 8 include-in-access-req
radius-server attribute 31 mac format unformatted
radius-server attribute 31 send nas-port-detail mac-only
radius-server host x.x.x.x auth-port 1812 acct-port 1813
radius-server key xxxx
radius-server vsa send accounting
radius-server vsa send authentication
Edited by psa79
стандартные грабли и очередной наступивший...
no ip tcp header-compression
спасибо сделал, посмотрю как будет работать.
а вот ms-chap убирать нельзя, много роутеров его используют (побывал, было слишком много жалоб)
ну огребете потом =)
например так
http://www.opennet.ru/openforum/vsluhforumID6/17564.html
и вот так
http://forum.nag.ru/forum/index.php?showtopic=58493
Edited by fozz
