telephonist Posted June 10, 2010 Posted June 10, 2010 (edited) Есть странное наблюдение, что центральный свич ( Edge-Core ES4612 ) перестраивает STP дерево каждый раз при изменении состояния порта на Alcatel LS 6224 это очень грустно :( В логе все свичи, кроме тех возле которых есть комментарии - Dlink DES-3526 Jun 10 09:30:57 sw-4-3 %LINK-I-Up: e3^M ( Alcatel LS 6224 ) Jun 10 09:31:29 csw Jun 10 8:31:29 o2_uzsnmpSTA topology change notification. ( Edge-Core ES4612 ) Jun 10 09:31:29 sw26 10.10.2.26 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:29 sw25_2 10.10.1.225 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:29 sw20 10.10.2.20 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:29 sw25_1 10.10.1.125 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:29 sw37 10.10.2.37 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:29 sw33 10.10.2.33 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:29 sw38 10.10.1.38 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:29 sw25 10.10.1.25 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:29 sw35 10.10.2.35 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:30 sw61 10.10.1.61 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:30 sw19 10.10.1.19 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:30 sw27 10.10.1.27 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:30 sw29 10.10.1.29 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:30 sw28 10.10.2.28 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:30 sw31 10.10.2.31 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:30 sw21 10.10.1.21 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:33 csw Jun 10 8:31:33 o2_uzsnmpSTA topology change notification. ( Edge-Core ES4612 ) Jun 10 09:31:33 sw37 10.10.2.37 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:34 sw27 10.10.1.27 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:34 sw29 10.10.1.29 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:34 sw28 10.10.2.28 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:35 sw25_2 10.10.1.225 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:35 sw25_1 10.10.1.125 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:35 sw38 10.10.1.38 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:36 sw19 10.10.1.19 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:37 sw21 10.10.1.21 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:37 sw25 10.10.1.25 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:39 sw61 10.10.1.61 INFO: Topology changed (Instance:0, port:26) Jun 10 09:31:39 sw36 10.10.1.36 INFO: Topology changed (Instance:0, port:25) Jun 10 09:31:39 sw30 10.10.2.30 INFO: Topology changed (Instance:0, port:26) На Alcatel LS6224 STP настроено так interface range ethernet e(1-24) port storm-control broadcast enable exit spanning-tree mode rstp spanning-tree pathcost method long interface range ethernet e(1-24) spanning-tree guard root exit Состояние STP на Alcatel такое # sh spanning-tree Spanning tree enabled mode RSTP Default port cost method: long Root ID Priority 0 Address 00:12:cf:c6:31:70 Cost 60000 Port g2 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 32768 Address 00:12:cf:85:35:20 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Number of topology changes 183 last change occurred 00:12:30 ago Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Interfaces Name State Prio.Nbr Cost Sts Role PortFast Type ------ -------- -------- --------- ------ ---- -------- ----------------- e1 enabled 128.1 2000000 Dsbl Dsbl No - e2 enabled 128.2 2000000 Dsbl Dsbl No - e3 enabled 128.3 200000 Frw Desg No P2P (RSTP) e4 enabled 128.4 2000000 Dsbl Dsbl No - e5 enabled 128.5 2000000 Dsbl Dsbl No - e6 enabled 128.6 2000000 Dsbl Dsbl No - e7 enabled 128.7 200000 Frw Desg No P2P (RSTP) e8 enabled 128.8 2000000 Dsbl Dsbl No - e9 enabled 128.9 2000000 Dsbl Dsbl No - e10 enabled 128.10 2000000 Dsbl Dsbl No - e11 enabled 128.11 2000000 Dsbl Dsbl No - e12 enabled 128.12 2000000 Dsbl Dsbl No - e13 enabled 128.13 2000000 Dsbl Dsbl No - e14 enabled 128.14 2000000 Dsbl Dsbl No - e15 enabled 128.15 2000000 Dsbl Dsbl No - e16 enabled 128.16 2000000 Dsbl Dsbl No - e17 enabled 128.17 2000000 Dsbl Dsbl No - e18 enabled 128.18 2000000 Dsbl Dsbl No - e19 enabled 128.19 2000000 Dsbl Dsbl No - e20 enabled 128.20 2000000 Dsbl Dsbl No - e21 enabled 128.21 2000000 Dsbl Dsbl No - e22 enabled 128.22 2000000 Dsbl Dsbl No - e23 enabled 128.23 2000000 Dsbl Dsbl No - e24 enabled 128.24 2000000 Dsbl Dsbl No - g1 enabled 128.49 20000 Frw Desg No P2P (RSTP) g2 enabled 128.50 20000 Frw Root No P2P (RSTP) g3 enabled 128.51 2000000 Dsbl Dsbl No - g4 enabled 128.52 2000000 Dsbl Dsbl No - ch1 enabled 128.1000 20000 Dsbl Dsbl No - ch2 enabled 128.1001 20000 Dsbl Dsbl No - ch3 enabled 128.1002 20000 Dsbl Dsbl No - ch4 enabled 128.1003 20000 Dsbl Dsbl No - ch5 enabled 128.1004 20000 Dsbl Dsbl No - ch6 enabled 128.1005 20000 Dsbl Dsbl No - ch7 enabled 128.1006 20000 Dsbl Dsbl No - ch8 enabled 128.1007 20000 Dsbl Dsbl No - На Edge-Core ES4612 настройки и состояние такие: Vty-0#sh spanning-tree Spanning-tree information --------------------------------------------------------------- Spanning tree mode :RSTP Spanning tree enable/disable :enable Instance :0 VLANs configuration :1-4094 Priority :0 Bridge Hello Time (sec.) :2 Bridge Max Age (sec.) :20 Bridge Forward Delay (sec.) :15 Root Hello Time (sec.) :2 Root Max Age (sec.) :20 Root Forward Delay (sec.) :15 Max hops :20 Remaining hops :20 Designated Root: 0.0012CFC63170 Current root port :0 Current root cost :0 Number of topology changes :526 Last topology changes time (sec.):1057 Transmission limit :3 Path Cost Method :long --------------------------------------------------------------- Eth 1/ 7 information --------------------------------------------------------------- Admin status : enable Role : designate State : forwarding Path cost : 10000 Priority : 128 Designated cost : 0 Designated port : 128.7 Designated root: 0.0012CFC63170 Designated bridge: 0.0012CFC63170 Fast forwarding : disable Forward transitions : 5 Admin edge port : disable Oper edge port : disable Admin Link type : auto Oper Link type : point-to-point Spanning Tree Status : enable Eth 1/ 8 information --------------------------------------------------------------- Admin status : enable Role : designate State : forwarding Path cost : 10000 Priority : 128 Designated cost : 0 Designated port : 128.8 Designated root: 0.0012CFC63170 Designated bridge: 0.0012CFC63170 Fast forwarding : disable Forward transitions : 5 Admin edge port : disable Oper edge port : disable Admin Link type : auto Oper Link type : point-to-point Spanning Tree Status : enable Edited June 10, 2010 by telephonist Вставить ник Quote
ginodman Posted June 10, 2010 Posted June 10, 2010 порты которые подлючены к клиентам (не к свичам) нужно поставить в portfast (edgeport) на 6224 Вставить ник Quote
Max P Posted June 10, 2010 Posted June 10, 2010 4612 у вас случаем не тормозит? проц не перегружен у него? у меня сейчас такая же проблема, только в паре с длинками 3526, но тут уже похоже тупо 4612 не справляется Вставить ник Quote
telephonist Posted June 10, 2010 Author Posted June 10, 2010 4612 у вас случаем не тормозит? проц не перегружен у него? у меня сейчас такая же проблема, только в паре с длинками 3526, но тут уже похоже тупо 4612 не справляется Как определить, что тормозит? Вставить ник Quote
telephonist Posted June 10, 2010 Author Posted June 10, 2010 порты которые подлючены к клиентам (не к свичам) нужно поставить в portfast (edgeport) на 6224 Так и сделал везде. Жду эффекта. Вставить ник Quote
Max P Posted June 11, 2010 Posted June 11, 2010 4612 у вас случаем не тормозит? проц не перегружен у него? у меня сейчас такая же проблема, только в паре с длинками 3526, но тут уже похоже тупо 4612 не справляется Как определить, что тормозит? для начала пингами на него, если пинг скачет выше 100 - значит трындец ему, ну и в телнете на нем же в момент тормозов очень уж некомфортно Вставить ник Quote
s.lobanov Posted June 11, 2010 Posted June 11, 2010 У edge-core есть snmp oid для мониторинга нагрузки на процессор. Просто постройте график Вставить ник Quote
Max P Posted June 11, 2010 Posted June 11, 2010 конкретно у 4612 его нет, нет его и в cli, данную инфу запрашивали у производителя :( Вставить ник Quote
mousus Posted June 11, 2010 Posted June 11, 2010 у меня такая железяка работает с новой прошивкой и 1 кольцом тоесть на 1 и 2 портах stp включено на остальных отключено при включении на других портах stp кольцо начинает постоянно перестраиваться Вставить ник Quote
telephonist Posted June 11, 2010 Author Posted June 11, 2010 4612 у вас случаем не тормозит? проц не перегружен у него? у меня сейчас такая же проблема, только в паре с длинками 3526, но тут уже похоже тупо 4612 не справляется Как определить, что тормозит? для начала пингами на него, если пинг скачет выше 100 - значит трындец ему, ну и в телнете на нем же в момент тормозов очень уж некомфортно Нет с пингами все ок. Около 2 мСек Вставить ник Quote
telephonist Posted June 14, 2010 Author Posted June 14, 2010 (edited) порты которые подлючены к клиентам (не к свичам) нужно поставить в portfast (edgeport) на 6224 Дождался результата - та же хрень! Как только дергается 3-е кольцо (там где LS 6224 ) сразу начиается лихорадка по остальным кольцам! Вот такой статус на алкателе: # sh spanning-tree Spanning tree enabled mode RSTP Default port cost method: long Root ID Priority 0 Address 00:12:cf:c6:31:70 Cost 80000 Port g1 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 32768 Address 00:12:cf:54:a5:60 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Number of topology changes 243 last change occurred 05:51:02 ago Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Interfaces Name State Prio.Nbr Cost Sts Role PortFast Type ------ -------- -------- --------- ------ ---- -------- ----------------- e1 enabled 128.1 2000000 Dsbl Dsbl Yes - e2 enabled 128.2 2000000 Dsbl Dsbl Yes - e3 enabled 128.3 2000000 Dsbl Dsbl Yes - e4 enabled 128.4 2000000 Dsbl Dsbl Yes - e5 enabled 128.5 2000000 Dsbl Dsbl Yes - e6 enabled 128.6 2000000 Dsbl Dsbl Yes - e7 enabled 128.7 2000000 Dsbl Dsbl Yes - e8 enabled 128.8 2000000 Dsbl Dsbl Yes - e9 enabled 128.9 2000000 Dsbl Dsbl Yes - e10 enabled 128.10 2000000 Dsbl Dsbl Yes - e11 enabled 128.11 200000 Frw Desg Yes P2P (RSTP) e12 enabled 128.12 2000000 Dsbl Dsbl Yes - e13 enabled 128.13 2000000 Dsbl Dsbl Yes - e14 enabled 128.14 2000000 Dsbl Dsbl Yes - e15 enabled 128.15 2000000 Dsbl Dsbl Yes - e16 enabled 128.16 2000000 Dsbl Dsbl Yes - e17 enabled 128.17 2000000 Dsbl Dsbl Yes - e18 enabled 128.18 2000000 Dsbl Dsbl Yes - e19 enabled 128.19 2000000 Dsbl Dsbl Yes - e20 enabled 128.20 2000000 Dsbl Dsbl Yes - e21 enabled 128.21 2000000 Dsbl Dsbl Yes - e22 enabled 128.22 2000000 Dsbl Dsbl Yes - e23 enabled 128.23 2000000 Dsbl Dsbl Yes - e24 enabled 128.24 2000000 Dsbl Dsbl Yes - g1 enabled 128.49 20000 Frw Root No P2P (RSTP) g2 enabled 128.50 20000 Dscr Altn No P2P (RSTP) g3 enabled 128.51 2000000 Dsbl Dsbl No - g4 enabled 128.52 2000000 Dsbl Dsbl No - ch1 enabled 128.1000 20000 Dsbl Dsbl No - ch2 enabled 128.1001 20000 Dsbl Dsbl No - ch3 enabled 128.1002 20000 Dsbl Dsbl No - ch4 enabled 128.1003 20000 Dsbl Dsbl No - ch5 enabled 128.1004 20000 Dsbl Dsbl No - ch6 enabled 128.1005 20000 Dsbl Dsbl No - ch7 enabled 128.1006 20000 Dsbl Dsbl No - ch8 enabled 128.1007 20000 Dsbl Dsbl No - Edited June 14, 2010 by telephonist Вставить ник Quote
N4cer Posted December 13, 2010 Posted December 13, 2010 (edited) Товарисчи, раздумываю над покупкой 2х таки железок (4612) в качестве агрегации в квартале. Оба свича распрланировал на один квартал. Оба 4612 идут до ядра по 4м гигабитным каналам каждый. на каждом SFP порте висит 3 свича 3526 подключенных через 1гб последовательно. всего около 33 свичей, вытянет зверек? Edited December 13, 2010 by N4cer Вставить ник Quote
mousus Posted December 14, 2010 Posted December 14, 2010 не напрягаясь если звездой, с кольцами на нём лучше не экспериментировать, стабильно он 1 кольцо на 16 ёжиков 3528М держит но даже с новой прошивкой у него бывают сюрпризы с резким увеличением загрузки проца до непингуемого состояния, ну и gvrp лучше не включать на нём Вставить ник Quote
