Имеется машинка:
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel® Xeon® CPU X3460 @ 2.80GHz (2799.98-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x106e5 Family = 6 Model = 1e Stepping = 5
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLU
SH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x98e3fd<SSE3,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,POP
CNT>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
Cores per package: 8
Logical CPUs per core: 2
usable memory = 2092572672 (1995 MB)
avail memory = 2016489472 (1923 MB)
ACPI APIC Table: <INTEL S3420GPX>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
cpu0 (BSP): APIC ID: 0
cpu1 (AP/HT): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP/HT): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP/HT): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP/HT): APIC ID: 7
ioapic0 <Version 2.0> irqs 0-23 on motherboard
lapic0: Forcing LINT1 to edge trigger
kbd1 at kbdmux0
ichwd module loaded
smbios0: <System Management BIOS> at iomem 0xf0440-0xf045e on motherboard
smbios0: Version: 2.5, BCD Revision: 2.5
acpi0: <INTEL S3420GPX> on motherboard
FreeBSD vpn3 7.3-STABLE FreeBSD 7.3-STABLE #0: Mon May 24 18:16:51 EEST 2010 root@vpn3:/usr/obj/usr/src/sys/vpn3-amd64 amd64
дрова сетевушек
vpn3# sysctl dev.em
dev.em.0.%desc: Intel(R) PRO/1000 Network Connection 7.0.5
dev.em.0.%driver: em
dev.em.0.%location: slot=25 function=0 handle=\_SB_.PCI0.ILAN
dev.em.0.%pnpinfo: vendor=0x8086 device=0x10ef subvendor=0x8086 subdevice=0x34ec class=0x020000
dev.em.0.%parent: pci0
dev.em.0.debug: -1
dev.em.0.stats: -1
dev.em.0.rx_int_delay: 600
dev.em.0.tx_int_delay: 600
dev.em.0.rx_abs_int_delay: 1200
dev.em.0.tx_abs_int_delay: 1200
dev.em.0.rx_processing_limit: 1024
dev.em.0.wake: 0
dev.em.1.%desc: Intel(R) PRO/1000 Network Connection 7.0.5
dev.em.1.%driver: em
dev.em.1.%location: slot=0 function=0 handle=\_SB_.PCI0.PEX4.HART
dev.em.1.%pnpinfo: vendor=0x8086 device=0x10d3 subvendor=0x8086 subdevice=0x34ec class=0x020000
dev.em.1.%parent: pci7
dev.em.1.debug: -1
dev.em.1.stats: -1
dev.em.1.rx_int_delay: 600
dev.em.1.tx_int_delay: 600
dev.em.1.rx_abs_int_delay: 1200
dev.em.1.tx_abs_int_delay: 1200
dev.em.1.rx_processing_limit: 1024
last pid:  4075;  load averages:  2.48,  2.37,  2.10                                up 15+22:55:45  18:41:56
98 processes:  12 running, 66 sleeping, 19 waiting, 1 lock
CPU:  0.4% user,  0.0% nice, 28.9% system,  9.4% interrupt, 61.3% idle
Mem: 56M Active, 1009M Inact, 480M Wired, 9692K Cache, 209M Buf, 380M Free
Swap: 4096M Total, 4096M Free
  PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME    CPU COMMAND
   43 root     -68    -     0K    16K CPU5    5 623:21 86.87% irq257: em1
   17 root     171 ki31     0K    16K RUN     1 380.3H 75.20% idle: cpu1
   44 root     -68    -     0K    16K *em1:r  2  19:05 74.37% em1 rxq
   15 root     171 ki31     0K    16K CPU3    3 380.0H 72.17% idle: cpu3
   11 root     171 ki31     0K    16K CPU7    7 380.0H 68.26% idle: cpu7
   12 root     171 ki31     0K    16K CPU6    6 379.9H 64.36% idle: cpu6
   18 root     171 ki31     0K    16K CPU0    0 378.7H 57.96% idle: cpu0
   16 root     171 ki31     0K    16K CPU2    2 371.5H 55.76% idle: cpu2
   14 root     171 ki31     0K    16K CPU4    4 379.8H 55.08% idle: cpu4
   13 root     171 ki31     0K    16K RUN     5 380.1H 51.86% idle: cpu5
    7 root     -68    -     0K    16K sleep   4 124:30 19.19% ng_queue5
    3 root     -68    -     0K    16K sleep   0 124:34 18.46% ng_queue1
    4 root     -68    -     0K    16K sleep   3 124:35 18.36% ng_queue2
    2 root     -68    -     0K    16K CPU2    2 124:35 18.07% ng_queue0
    9 root     -68    -     0K    16K sleep   1 124:26 18.07% ng_queue7
    8 root     -68    -     0K    16K sleep   7 124:42 17.97% ng_queue6
    5 root     -68    -     0K    16K CPU6    6 124:30 17.97% ng_queue3
    6 root     -68    -     0K    16K sleep   2 124:32 17.77% ng_queue4
   38 root     -68    -     0K    16K -       6  91:11  8.50% em0 taskq
22861 root      46    0 46828K 24828K select  0  24:18  1.76% mpd5
91623 root      44    0 26624K  8372K select  2   6:18  0.68% snmpd
   45 root     -68    -     0K    16K WAIT    4   7:53  0.29% irq258: em1
при этом
# vmstat -i
interrupt                          total       rate
irq14: ata0                      1175166          0
irq21: ehci0                           7          0
irq23: ehci1                         283          0
cpu0: timer                   2755175361       1998
irq256: em0                     94535538         68
irq257: em1                    418056494        303
irq258: em1                    239044670        173
irq261: em1                          624          0
cpu1: timer                   2755175224       1998
cpu7: timer                   2755174764       1998
cpu3: timer                   2755175435       1998
cpu5: timer                   2755174870       1998
cpu2: timer                   2755175435       1998
cpu4: timer                   2755174870       1998
cpu6: timer                   2755174765       1998
Total                        22794213506      16534
не могу понять, почему такая нагрузка 86.87% irq257: em1 ???
какие дрова для сетевушек можно еще попробовать ?
last pid: 13696;  load averages:  1.72,  1.48,  1.50                                up 16+00:47:36  20:33:47
96 processes:  18 running, 59 sleeping, 19 waiting
CPU 0:  0.8% user,  0.0% nice, 14.7% system,  2.6% interrupt, 82.0% idle
CPU 1:  0.0% user,  0.0% nice, 17.7% system,  0.0% interrupt, 82.3% idle
CPU 2:  0.0% user,  0.0% nice,  2.6% system, 78.3% interrupt, 19.1% idle
CPU 3:  0.7% user,  0.0% nice, 20.2% system,  0.7% interrupt, 78.3% idle
CPU 4:  0.0% user,  0.0% nice, 25.9% system,  2.3% interrupt, 71.8% idle
CPU 5:  0.0% user,  0.0% nice, 21.4% system,  0.4% interrupt, 78.2% idle
CPU 6:  0.0% user,  0.0% nice, 18.8% system,  1.5% interrupt, 79.7% idle
CPU 7:  0.4% user,  0.0% nice, 20.7% system,  1.9% interrupt, 77.1% idle
Mem: 56M Active, 1010M Inact, 482M Wired, 9692K Cache, 209M Buf, 378M Free
  PID USERNAME PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
   18 root     171 ki31     0K    16K RUN     0 380.0H 90.97% idle: cpu0
   43 root     -68    -     0K    16K CPU2    2 721:12 89.89% irq257: em1
   17 root     171 ki31     0K    16K RUN     1 381.7H 87.70% idle: cpu1
   12 root     171 ki31     0K    16K RUN     6 381.2H 86.87% idle: cpu6
   13 root     171 ki31     0K    16K RUN     5 381.4H 85.16% idle: cpu5
   15 root     171 ki31     0K    16K RUN     3 381.4H 83.59% idle: cpu3
   11 root     171 ki31     0K    16K RUN     7 381.3H 81.30% idle: cpu7
   14 root     171 ki31     0K    16K RUN     4 381.0H 75.00% idle: cpu4
   16 root     171 ki31     0K    16K RUN     2 372.1H 21.58% idle: cpu2
    8 root     -68    -     0K    16K RUN     1 143:59 14.70% ng_queue6
    6 root     -68    -     0K    16K CPU4    4 143:49 14.70% ng_queue4
    7 root     -68    -     0K    16K CPU1    7 143:46 14.70% ng_queue5
    9 root     -68    -     0K    16K CPU6    6 143:43 14.45% ng_queue7
    3 root     -68    -     0K    16K CPU7    7 143:52 14.36% ng_queue1
    2 root     -68    -     0K    16K RUN     4 143:53 14.16% ng_queue0
    5 root     -68    -     0K    16K CPU5    5 143:46 14.16% ng_queue3
    4 root     -68    -     0K    16K CPU3    3 143:52 14.06% ng_queue2
   38 root     -68    -     0K    16K -       0 101:10  7.57% em0 taskq
   44 root     -68    -     0K    16K -       0  53:06  2.39% em1 rxq
22861 root      45    0 46828K 24828K select  0  28:09  1.37% mpd5
   45 root     -68    -     0K    16K WAIT    4   8:38  0.49% irq258: em1
91623 root      44    0 26624K  8372K select  0   7:11  0.49% snmpd
Copyright © 1992-2010 The FreeBSD Project.
Copyright © 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
CNT>
kbd1 at kbdmux0
ichwd module loaded
acpi0: [iTHREAD]
acpi0: Power Button (fixed)
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 3.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> at device 0.0 on pci1
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> at device 2.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> at device 3.0 on pci2
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> at device 4.0 on pci2
pci5: <ACPI PCI bus> on pcib5
pci0: <base peripheral> at device 8.0 (no driver attached)
pci0: <base peripheral> at device 8.1 (no driver attached)
pci0: <base peripheral> at device 8.2 (no driver attached)
pci0: <base peripheral> at device 8.3 (no driver attached)
pci0: <base peripheral> at device 16.0 (no driver attached)
pci0: <base peripheral> at device 16.1 (no driver attached)
em0: <Intel® PRO/1000 Network Connection 7.0.5> port 0x2020-0x203f mem 0xb1a00000-0xb1a1ffff,0xb1a24000-0xb1a24fff irq 16 at device 25.0 on pci0
em0: Using MSI interrupt
em0: [FILTER]
em0: Ethernet address: 00:15:17:c7:de:8b
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xb1a21000-0xb1a213ff irq 21 at device 26.0 on pci0
ehci0: [GIANT-LOCKED]
ehci0: [iTHREAD]
usb0: EHCI version 1.0
usb0: <EHCI (generic) USB 2.0 controller> on ehci0
usb0: USB revision 2.0
uhub0: <Intel EHCI root hub, class 9/0, rev 2.00/1.00, addr 1> on usb0
uhub0: 2 ports with 2 removable, self powered
uhub1: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on uhub0
uhub1: single transaction translator
uhub1: 6 ports with 6 removable, self powered
pcib6: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci6: <ACPI PCI bus> on pcib6
pcib7: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci7: <ACPI PCI bus> on pcib7
em1: <Intel® PRO/1000 Network Connection 7.0.5> port 0x1000-0x101f mem 0xb1900000-0xb191ffff,0xb1920000-0xb1923fff irq 16 at device 0.0 on pci7
em1: Using MSIX interrupts with 5 vectors
em1: [iTHREAD]
em1: [iTHREAD]
em1: [iTHREAD]
em1: [iTHREAD]
em1: [iTHREAD]
em1: Ethernet address: 00:15:17:c7:de:8a
pcib8: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
pci8: <ACPI PCI bus> on pcib8
vgapci0: <VGA-compatible display> mem 0xb0000000-0xb0ffffff,0xb1800000-0xb1803fff,0xb1000000-0xb17fffff irq 17 at device 0.0 on pci8
pcib9: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
pci9: <ACPI PCI bus> on pcib9
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xb1a20000-0xb1a203ff irq 23 at device 29.0 on pci0
ehci1: [GIANT-LOCKED]
ehci1: [iTHREAD]
usb1: EHCI version 1.0
usb1: <EHCI (generic) USB 2.0 controller> on ehci1
usb1: USB revision 2.0
uhub2: <Intel EHCI root hub, class 9/0, rev 2.00/1.00, addr 1> on usb1
uhub2: 2 ports with 2 removable, self powered
uhub3: <vendor 0x8087 product 0x0020, class 9/0, rev 2.00/0.00, addr 2> on uhub2
uhub3: single transaction translator
uhub3: 8 ports with 8 removable, self powered
ukbd0: <American Megatrends Inc. Virtual Keyboard and Mouse, class 0/0, rev 1.10/1.00, addr 3> on uhub3
kbd2 at ukbd0
ums0: <American Megatrends Inc. Virtual Keyboard and Mouse, class 0/0, rev 1.10/1.00, addr 3> on uhub3
ums0: X report 0x0002 not supported
device_attach: ums0 attach returned 6
ukbd1: <vendor 0x0566 product 0x3107, class 0/0, rev 1.10/1.00, addr 4> on uhub3
kbd3 at ukbd1
uhid0: <vendor 0x0566 product 0x3107, class 0/0, rev 1.10/1.00, addr 4> on uhub3
pcib10: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci10: <ACPI PCI bus> on pcib10
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel ATA controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x2070-0x207f,0x2060-0x206f irq 18 at device 31.2 on pci0
ata0: <ATA channel 0> on atapci0
ata0: [iTHREAD]
ata1: <ATA channel 1> on atapci0
ata1: [iTHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
atapci1: <Intel ATA controller> port 0x2088-0x208f,0x20a4-0x20a7,0x2080-0x2087,0x20a0-0x20a3,0x2050-0x205f,0x2040-0x204f irq 22 at device 31.5 on pci0
atapci1: [iTHREAD]
ata2: <ATA channel 0> on atapci1
ata2: [iTHREAD]
ata3: <ATA channel 1> on atapci1
ata3: [iTHREAD]
acpi_button0: <Sleep Button> on acpi0
sio0: configured irq 4 not in bitmap of probed irqs 0
sio0: port may not be enabled
sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
sio0: type 16550A
sio0: [FILTER]
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
cpu0: <ACPI CPU> on acpi0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
cpu1: <ACPI CPU> on acpi0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
cpu2: <ACPI CPU> on acpi0
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
cpu3: <ACPI CPU> on acpi0
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
cpu4: <ACPI CPU> on acpi0
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
p4tcc4: <CPU Frequency Thermal Control> on cpu4
cpu5: <ACPI CPU> on acpi0
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
p4tcc5: <CPU Frequency Thermal Control> on cpu5
cpu6: <ACPI CPU> on acpi0
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
p4tcc6: <CPU Frequency Thermal Control> on cpu6
cpu7: <ACPI CPU> on acpi0
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
p4tcc7: <CPU Frequency Thermal Control> on cpu7
ipmi1: <IPMI System Interface> on isa0
device_attach: ipmi1 attach returned 16
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc9fff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
atkbd: unable to set the command byte.
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [iTHREAD]
psm0: unable to set the command byte.
ppc0: cannot reserve I/O port range
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
sio1: configured irq 3 not in bitmap of probed irqs 0
sio1: port may not be enabled
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Timecounters tick every 1.000 msec
ipfw2 initialized, divert loadable, nat enabled, rule-based forwarding enabled, default to deny, logging limited to 100 packets/entry by default
ad0: 76319MB <Seagate ST380215AS 4.AAB> at ata0-master UDMA33
ipmi0: IPMI device rev. 1, firmware rev. 1.2, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
lapic1: Forcing LINT1 to edge trigger
SMP: AP CPU #1 Launched!
lapic7: Forcing LINT1 to edge trigger
SMP: AP CPU #7 Launched!
lapic3: Forcing LINT1 to edge trigger
SMP: AP CPU #3 Launched!
lapic5: Forcing LINT1 to edge trigger
SMP: AP CPU #5 Launched!
lapic2: Forcing LINT1 to edge trigger
SMP: AP CPU #2 Launched!
lapic4: Forcing LINT1 to edge trigger
SMP: AP CPU #4 Launched!
lapic6: Forcing LINT1 to edge trigger
SMP: AP CPU #6 Launched!
Trying to mount root from ufs:/dev/ad0s1a
em0: Media change is blocked due to SOL/IDER session.
em1: link state changed to UP
em0: link state changed to UP
ukbd1: at uhub3 port 6 (addr 4) disconnected
ukbd1: detached
uhid0: at uhub3 port 6 (addr 4) disconnected
uhid0: detached
pid 70784 (try), uid 0: exited on signal 10
pptp+l2tp
net.isr.direct: 1
net.inet.ip.forwarding: 1
не совсем понятно, почему нагрузка по прерываниям до 90% , а кол-во прерываний до 350 ??!!
Читать умеете ? там был fastforwarding а не forwarding.
Отключите net.isr.direct и увидите сколько там реально при 350 прерываниях, при включенном у вас в первом прерывании весь swi:net сидит.
сорри net.inet.ip.fastforwarding: 0
поставил net.isr.direct=0
last pid: 61214;  load averages:  0.64,  0.62,  0.51                                up 16+17:24:49  13:11:00
98 processes:  10 running, 69 sleeping, 19 waiting
CPU:  0.2% user,  0.0% nice,  1.8% system,  4.2% interrupt, 93.7% idle
Mem: 51M Active, 1037M Inact, 475M Wired, 9692K Cache, 209M Buf, 363M Free
   17 root     171 ki31     0K    16K CPU1    1 397.3H 100.00% idle: cpu1
   18 root     171 ki31     0K    16K CPU0    0 395.3H 99.17% idle: cpu0
   16 root     171 ki31     0K    16K RUN     2 384.1H 98.88% idle: cpu2
   15 root     171 ki31     0K    16K RUN     3 396.8H 98.68% idle: cpu3
   14 root     171 ki31     0K    16K CPU4    4 396.3H 97.36% idle: cpu4
   12 root     171 ki31     0K    16K CPU6    6 396.6H 92.48% idle: cpu6
   13 root     171 ki31     0K    16K RUN     5 396.9H 90.87% idle: cpu5
   11 root     171 ki31     0K    16K CPU7    7 396.8H 77.39% idle: cpu7
   19 root     -44    -     0K    16K CPU5    4   0:41 44.29% swi1: net
    9 root     -68    -     0K    16K sleep   0 197:22  2.39% ng_queue7
    3 root     -68    -     0K    16K sleep   7 197:33  2.29% ng_queue1
    4 root     -68    -     0K    16K sleep   2 197:33  2.10% ng_queue2
    6 root     -68    -     0K    16K sleep   3 197:29  2.10% ng_queue4
    5 root     -68    -     0K    16K sleep   0 197:29  2.10% ng_queue3
    2 root     -68    -     0K    16K sleep   4 197:37  1.95% ng_queue0
    7 root     -68    -     0K    16K sleep   4 197:26  1.76% ng_queue5
    8 root     -68    -     0K    16K sleep   0 197:43  1.66% ng_queue6
   43 root     -68    -     0K    16K WAIT    2 979:34  1.27% irq257: em1
   38 root     -68    -     0K    16K -       0 144:31  1.17% em0 taskq
а подскажите вариант разгрузить машинку ?
поставить другие сетевушки ?
Edited by Mechanic
как-бы это сложно реализуемо в одночасье избавиться от pptp, переходим постепенно на "прямое" включение (реал ип по eth)
У меня нет опыта с 7.3-STABLE и mpd5 на yandex драйвере или igb(4). По отдельности все работает, но как оно себя поведет именно в Вашем случае без тестов
сказать сложно.
онбордные сетевушки не используют igb(4)
там em дрова
попробую посмотреть новые дрова от интела
хмм, на интеле последннийе дрова 6.9.21
Edited by Mechanic
82574L вообще мерзкая штука, а у Вас еще и сочетание софта отвратительное. Попробуйте перенести нагрузку на em0, может полегчает малость...
ну это смотря для кого оптимальным. Я бы поставил яндексовский драйвер для начала. Но вам советовать не могу,так как результат непредсказуем
Покажите пожалста, где Вы видите, чтоб он распараллеливался ? А то может я слепой.
на 7ке свежие драйвера не пробовал, на 8ке - начало распараллеливать. И опять же pppoe по ядрам не делится.
   17 root     171 ki31     0K    16K CPU1    1 523.1H 100.00% idle: cpu1
   16 root     171 ki31     0K    16K CPU2    2 504.3H 95.26% idle: cpu2
   15 root     171 ki31     0K    16K CPU3    3 519.8H 91.55% idle: cpu3
   14 root     171 ki31     0K    16K RUN     4 518.0H 91.16% idle: cpu4
   18 root     171 ki31     0K    16K CPU0    0 514.9H 89.79% idle: cpu0
   12 root     171 ki31     0K    16K CPU6    6 516.3H 86.77% idle: cpu6
   13 root     171 ki31     0K    16K CPU5    5 515.9H 85.25% idle: cpu5
   19 root     -44    -     0K    16K CPU7    7  45.5H 69.68% swi1: net
   11 root     171 ki31     0K    16K RUN     7 503.7H 68.99% idle: cpu7
[b]   7 root     -68    -     0K    16K sleep   0 420:04  4.39% ng_queue5
    8 root     -68    -     0K    16K sleep   6 420:38  4.30% ng_queue6
    5 root     -68    -     0K    16K CPU6    6 420:30  4.20% ng_queue3
    2 root     -68    -     0K    16K sleep   0 420:17  4.20% ng_queue0
    9 root     -68    -     0K    16K sleep   2 419:45  4.20% ng_queue7
    4 root     -68    -     0K    16K sleep   4 420:06  3.96% ng_queue2
    3 root     -68    -     0K    16K sleep   5 420:09  3.76% ng_queue1
    6 root     -68    -     0K    16K sleep   2 420:11  3.47% ng_queue4[/b]
   43 root     -68    -     0K    16K WAIT    2  18.1H  2.10% irq257: em1
   38 root     -68    -     0K    16K -       0 258:15  1.17% em0 taskq
   45 root     -68    -     0K    16K WAIT    4  39:49  0.20% irq258: em1
91623 root      44    0 27648K  8852K select  7  34:30  0.10% snmpd
   20 root     -32    -     0K    16K WAIT    4 164:54  0.00% swi4: clock sio
22861 root      44    0 43756K 22060K select  1  85:21  0.00% mpd5
   44 root     -68    -     0K    16K -       6  53:48  0.00% em1 rxq
   65 root      20    -     0K    16K syncer  4  21:05  0.00% syncer
   26 root      44    -     0K    16K -       0  17:19  0.00% yarrow
   46 root     -68    -     0K    16K -       2  11:48  0.00% em1 txq
ng_queue0-7 считал, что это и есть распараллеливание
Edited by Mechanic
Судя по нагрузке - трафика почти нет. Распараллеливание надо смотреть на сильно нагруженном сервере.
:-) Я бы на Вашем месте перечитал тему раз пять... прежде чем комментировать.
