Сталкнулся с непонятной проблемой на CISCO ASR 1002, в виде зарезания исходящего трафика.
Тестовая конфигурация:
Building configuration...
Current configuration : 1515 bytes
version 12.2
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
service unsupported-transceiver
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
no aaa new-model
ip subnet-zero
no ip source-route
multilink bundle-name authenticated
redundancy
mode none
interface GigabitEthernet0/0/0
description INTERNET
ip address aaa.bbb.ccc.233 255.255.255.252
logging event link-status
speed 100
no negotiation auto
interface GigabitEthernet0/0/1
ip address xxx.yyy.zzz.1 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
router bgp NNNNN
no synchronization
bgp log-neighbor-changes
network xxx.yyy.zzz.0 mask 255.255.192.0
neighbor aaa.bbb.ccc.234 remote-as 20485
no auto-summary
ip classless
ip route xxx.yyy.zzz.0 255.255.192.0 Null0
no ip http server
no ip http secure-server
control-plane
line con 0
stopbits 1
line aux 0
line vty 0 4
login
transport input telnet
end
Скорость по договору 6Мбит/сек. При тестировании скорости speedtest, копирование по ftp в обе стороны, scp -> download=6Мбит/сек upload=1Мбит/сек
Подключаюсь непосредственно ноутом к интерфейсу 0/0/1
full duplex прописан, он в конфигурации не отображается как ни странно
Router#sh int gi 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
Hardware is 4XGE-BUILT-IN, address is 0025.84af.3700 (bia 0025.84af.3700)
Description: INTERNET
Internet address is aaa.bbb.ccc.233/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive not supported
Full Duplex, 100Mbps, link type is force-up, media type is T
output flow-control is on, input flow-control is on
ARP type: ARPA, ARP Timeout 04:00:00
Last input 01:20:12, output 00:01:35, output hang never
Last clearing of "show interface" counters never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 148000 bits/sec, 92 packets/sec
5 minute output rate 24000 bits/sec, 8 packets/sec
3182513 packets input, 439768102 bytes, 0 no buffer
Received 95 broadcasts (0 IP multicasts)
0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 1 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
246417 packets output, 31720532 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
Edited by Lord Askel
если IOS не 02.05.02.122-33.XNE2 то рекомендую обновить, много странностей ASR с ним пропало.
