друзья, прикиньте:
есть маршрутизатор, две дырки: Интернет––>вход–––>NAT––>выход––>локальная сеть
и вот такая херня:
c7204#sh int gi0/1
GigabitEthernet0/1 is up, line protocol is up
Hardware is BCM1250 Internal MAC, address is 001c.b13c.7c1b (bia 001c.b13c.7c1 b)
Description: INET
30 second input rate 55756000 bits/sec, 22230 packets/sec
30 second output rate 22952000 bits/sec, 20316 packets/sec
c7204#sh int gi0/2
GigabitEthernet0/2 is up, line protocol is up
Hardware is BCM1250 Internal MAC, address is 001c.b13c.7c1a (bia 001c.b13c.7c1 a)
Description: LAN
30 second input rate 15592000 bits/sec, 8455 packets/sec
30 second output rate 48432000 bits/sec, 10432 packets/sec
это почему такое может быть? почему у меня на внешнем интерфейс в два раза больше пакетов? м?
c7204#sh run int gi0/1
Building configuration…
Current configuration : 336 bytes!
interface GigabitEthernet0/1
description —
bandwidth 56000
ip address 92.92.92.92 255.255.255.252
ip access–group NO_PRIV out
ip flow ingress
ip nat outside
ip virtual–reassembly
ip route–cache policy
ip tcp adjust–mss 1436
load–interval 30
duplex auto
speed auto
media–type rj45
no negotiation auto
fair–queue
end
sh run int gi0/2
Current configuration : 304 bytes!
interface GigabitEthernet0/2
description LAN
bandwidth 60000
ip address 192.168.99.199 255.255.255.0
ip access–group TRAP in
ip nat inside
load–interval 30
duplex auto
speed 100
media–type rj45
no negotiation auto
fair–queue
no cdp enable
end
#sh access–lists NO_PRIV
Extended IP access list NO_PRIV
10 deny ip 10.0.0.0 0.255.255.255 any (2 matches)
20 deny ip 192.168.0.0 0.0.255.255 any (9 matches)
70 permit ip any any (12579912 matches)
c7204#sh access–lists TRAP
Extended IP access list TRAP
100 deny tcp any any eq 445
110 deny tcp any any eq 135
120 permit ip 10.1.0.0 0.0.255.255 any (822302 matches)
130 permit ip 10.2.0.0 0.0.255.255 any (943491 matches)
140 permit ip 10.3.0.0 0.0.255.255 any (811462 matches)
150 permit ip 10.4.0.0 0.0.255.255 any (536763 matches)
160 permit ip 10.5.0.0 0.0.255.255 any (551573 matches)
170 permit ip 10.6.0.0 0.0.255.255 any (479398 matches)
180 permit ip 192.168.0.0 0.0.255.255 any (115565 matches)
190 permit ip 10.0.0.0 0.255.255.255 any (24349 matches)
200 permit ip any any (76278 matches)
возникли предположения, которые я отработал:
1. Флуд и паразитный трафик.
2. reassemble пакетов из–за разных размеров window–size на интерфейсах.
1. повесил на внешний интерфейс ip access–group SEPUKA in
в нём:
пермит для нашего трафика.
пермит для любого трафика
счётчик для любого трафика не крутится.
делаю вывод, что весь этот трафик пришёл в NAT, а дальше уже по каким–то причинам половина его откинулась
2. c7204#ping ПРОВАЙДЕР size 1500
Type escape sequence to abort.
Sending 5, 1500–byte ICMP Echos to ПРОВАЙДЕР, timeout is 2 seconds:!!!!!
и там и там полторы тысячи МТУ
друзья, прикиньте:
и вот такая херня:
c7204#sh int gi0/1
Description: INET
c7204#sh int gi0/2
Description: LAN
description —
bandwidth 56000
ip flow ingress
ip nat outside
load–interval 30
duplex auto
speed auto
media–type rj45
no negotiation auto
fair–queue
end
sh run int gi0/2
description LAN
bandwidth 60000
ip nat inside
load–interval 30
duplex auto
speed 100
media–type rj45
no negotiation auto
fair–queue
no cdp enable
end
в нём:
Пингуете неправильно, без DF-бита пакеты будут фрагментироваться и вы ничего не увидите.
Да, и конфиг целиком покажите. И выводы sh int тоже.
просто скопипастил не то
c7204#ping 82.112.0.1 size 1500 df-bit
Sending 5, 1500-byte ICMP Echos to 82.112.0.1, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (5/5), round-trip min/avg/max = 212/216/224 ms
весь конфиг:
c7204#sh run
Building configuration...
Current configuration : 23751 bytes
upgrade fpd auto
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname c7204
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone HNM 5
clock summer-time HNM recurring
no ip source-route
no ip icmp rate-limit unreachable DF
ip cef
no ip bootp server
no ip domain lookup
ip name-server 192.168.99.200
ip name-server 192.168.99.180
no ipv6 cef
multilink bundle-name authenticated
memory-size iomem 0
archive
log config
logging enable
notify syslog contenttype plaintext
hidekeys
path disk2:$h
write-memory
time-period 1440
ip rcmd rsh-enable
ip rcmd remote-host seven 192.168.99.186 root enable
ip rcmd remote-host seven 192.168.99.179 root enable
ip rcmd remote-host admin 192.168.99.179 root enable
description --
bandwidth 56000
ip address 82.62.176.118 255.255.255.252
ip access-group SEPUKA in
ip access-group NO_PRIV out
ip flow ingress
ip nat outside
ip virtual-reassembly
ip route-cache policy
load-interval 30
duplex auto
speed auto
media-type rj45
no negotiation auto
fair-queue
description LAN
bandwidth 60000
ip access-group TRAP in
ip nat inside
load-interval 30
duplex auto
speed 100
media-type rj45
no negotiation auto
fair-queue
no cdp enable
interface GigabitEthernet0/3
description INTERNET-LAND
bandwidth 2000
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
fair-queue
no cdp enable
router rip
network 192.168.99.0
no auto-summary
ip local pool setup_pool 192.168.99.201 192.168.99.231
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 82.62.176.117
ip route 10.0.0.0 255.0.0.0 192.168.99.159
ip route 192.168.0.0 255.255.0.0 192.168.99.159
ip route 212.220.123.12 255.255.255.255 82.62.176.117
no ip http server
no ip http secure-server
ip flow-export version 5
ip flow-export destination 192.168.99.179 9996
ip flow-top-talkers
top 10
sort-by bytes
ip nat translation tcp-timeout 3600
ip nat translation max-entries all-host 4000
no ip nat service skinny tcp port 2000
no ip nat service H225
ip nat pool LINKZ1 82.62.179.65 82.62.179.65 prefix-length 24
ip nat pool LINKZ2 82.62.179.66 82.62.179.66 prefix-length 24
ip nat pool LINKZ3 82.62.179.67 82.62.179.67 prefix-length 24
ip nat pool LINKZ4 82.62.179.68 82.62.179.68 prefix-length 24
ip nat pool LINKZ5 82.62.179.69 82.62.179.69 prefix-length 24
ip nat pool LINKZ6 82.62.179.70 82.62.179.70 prefix-length 24
ip nat pool LINK_LOW 82.62.179.72 82.62.179.72 prefix-length 27
ip nat pool LINK_IP 82.62.182.10 82.62.182.252 prefix-length 24
ip nat pool LINKZ 82.62.179.71 82.62.179.71 prefix-length 24
ip nat inside source list 101 pool LINKZ1 overload
ip nat inside source list 102 pool LINKZ2 overload
ip nat inside source list 103 pool LINKZ3 overload
ip nat inside source list 104 pool LINKZ4 overload
ip nat inside source list 105 pool LINKZ5 overload
ip nat inside source list 106 pool LINKZ6 overload
ip nat inside source list LINK pool LINK_LOW overload
ip nat inside source static 10.3.9.200 82.62.179.73
ip nat inside source static 192.168.99.185 82.62.179.74
ip nat inside source static 192.168.156.3 82.62.179.75
ip nat inside source static 192.168.156.2 82.62.179.76
ip nat inside source static 10.1.100.182 82.62.179.77
ip nat inside source static 192.168.114.3 82.62.179.79
ip nat inside source static 10.1.19.252 82.62.179.80
ip nat inside source static 10.1.19.249 82.62.179.81
ip nat inside source static 10.1.11.22 82.62.179.82
ip nat inside source static 192.168.153.2 82.62.179.83
ip nat inside source static 10.1.15.32 82.62.179.84
ip nat inside source static 10.2.21.29 82.62.179.85
ip nat inside source static 10.1.19.53 82.62.179.86
ip nat inside source static 192.168.105.2 82.62.179.87
ip nat inside source static 10.3.1.22 82.62.179.88
ip nat inside source static 192.168.128.2 82.62.179.89
ip nat inside source static 192.168.99.203 82.62.179.90
ip nat inside source static 10.1.19.251 82.62.182.6
ip nat inside source static 10.5.16.14 82.62.182.7
ip nat inside source static 192.168.99.244 82.62.182.8
ip nat inside source static 192.168.152.2 82.62.182.235
ip nat inside source static 10.2.21.34 82.62.182.236
ip nat inside source static 10.5.2.58 82.62.182.237
ip nat inside source static 10.4.23.34 82.62.182.238
ip nat inside source static 10.1.17.50 82.62.182.239
ip nat inside source static 10.2.1.225 82.62.182.240
ip nat inside source static 10.3.9.37 82.62.182.241
ip nat inside source static 192.168.160.242 82.62.182.242
ip nat inside source static 192.168.160.243 82.62.182.243
ip nat inside source static 192.168.160.244 82.62.182.244
ip nat inside source static 192.168.160.245 82.62.182.245
ip nat inside source static 192.168.160.246 82.62.182.246
ip nat inside source static 192.168.160.247 82.62.182.247
ip nat inside source static 192.168.160.248 82.62.182.248
ip nat inside source static 192.168.160.249 82.62.182.249
ip nat inside source static 192.168.160.250 82.62.182.250
ip nat inside source static 10.5.2.31 82.62.182.251
ip nat inside source static 10.5.9.32 82.62.182.252
ip nat inside source static 10.3.9.210 82.62.182.253
ip nat inside source static 10.1.100.100 82.62.182.254
ip access-list extended LINK
ip access-list extended LINK_IP
permit ip host 10.1.3.19 any
permit ip host 10.5.14.12 any
permit ip host 10.1.14.42 any
permit ip host 10.1.1.22 any
permit ip host 10.2.1.123 any
permit ip host 10.2.25.109 any
permit ip host 10.5.4.37 any
permit ip host 10.5.11.24 any
permit ip host 10.3.4.32 any
permit ip host 10.4.18.20 any
permit ip host 10.1.3.25 any
permit ip host 10.2.3.16 any
permit ip host 10.4.18.17 any
permit ip host 10.4.18.18 any
permit ip host 10.2.9.28 any
permit ip host 10.6.10.12 any
permit ip host 10.6.9.12 any
permit ip host 10.2.23.29 any
permit ip host 10.1.7.49 any
permit ip host 10.4.7.18 any
permit ip host 10.5.22.49 any
permit ip host 10.2.30.17 any
permit ip host 10.2.12.13 any
permit ip host 10.6.2.12 any
permit ip host 10.2.1.109 any
permit ip host 10.2.14.18 any
permit ip host 10.2.23.25 any
permit ip host 10.2.3.119 any
permit ip host 10.1.0.19 any
permit ip host 10.2.23.13 any
permit ip host 10.6.13.30 any
permit ip host 10.4.3.43 any
permit ip host 10.2.3.15 any
permit ip host 10.2.3.204 any
permit ip host 10.1.19.55 any
permit ip host 10.6.4.18 any
permit ip host 10.6.1.19 any
permit ip host 10.1.7.13 any
permit ip host 10.4.7.14 any
permit ip host 10.2.31.13 any
permit ip host 10.2.12.30 any
permit ip host 10.1.17.15 any
permit ip host 10.6.16.13 any
permit ip host 10.1.15.39 any
permit ip host 10.5.15.12 any
permit ip host 10.3.5.31 any
permit ip host 10.2.20.32 any
permit ip host 10.6.5.22 any
permit ip host 10.2.25.27 any
permit ip host 10.5.11.25 any
permit ip host 10.1.100.10 any
permit ip host 10.1.19.239 any
permit ip host 10.1.18.2 any
permit ip host 10.1.15.28 any
permit ip host 10.2.7.114 any
ip access-list extended LOCAL-NET
permit ip any 192.168.0.0 0.0.255.255
permit ip any 10.0.0.0 0.255.255.255
permit ip host 192.168.99.35 any
ip access-list extended NAT
permit gre 192.168.0.0 0.0.255.255 any
permit ipinip 192.168.0.0 0.0.255.255 any
permit ip host 10.0.15.250 any
ip access-list extended NO_PRIV
remark deny private subnets
permit ip any any
ip access-list extended PRIORITY
permit ip any host 192.168.99.160
ip access-list extended SEPUKA
permit tcp any any established
permit udp any any
permit tcp any 82.62.182.0 0.0.0.255
permit tcp any 82.62.179.64 0.0.0.31
permit ip any 82.62.182.0 0.0.0.255
permit ip any 82.62.179.64 0.0.0.31
permit ip any any
ip access-list extended TRAP
permit ip host 82.62.182.128 any
permit ip host 82.62.179.66 any
permit ip host 10.1.14.13 any
permit ip host 10.6.11.30 any
permit ip any host 10.6.11.30
deny udp host 10.6.1.34 any log
deny ip host 192.168.46.38 any
permit icmp any host 192.168.99.186 log
deny icmp host 10.2.10.54 any
permit ip any any
ip access-list extended inb
deny tcp any any eq 17300
deny tcp any any eq 1025
deny tcp any any eq 6588
deny tcp any any eq 4899
deny tcp any any eq 11758
deny tcp any any eq ident
deny tcp any any eq 5000
deny tcp any any eq 1433
deny tcp any any eq 1434
deny tcp any any eq 139
deny tcp any any eq 137
deny tcp any any eq 65005
deny tcp any any eq 12345
deny tcp any any eq 49624
deny tcp any any eq 61523
deny tcp any any eq 20168
deny tcp any any eq 58506
deny tcp any any eq 9898
deny tcp any any eq 2745
deny tcp any any eq 6129
deny tcp any any eq 5554
deny tcp any any eq 55551
deny tcp any any eq 58120
deny tcp any any eq 60689
deny tcp any any eq 59654
deny tcp any any eq 51765
deny tcp any any eq 56631
deny tcp any any eq 54099
deny tcp any any eq 57505
deny tcp any any eq 52659
deny tcp any any eq 65388
permit ip any any
ip access-list extended spam_out
deny ip host 10.1.19.198 any
permit tcp host 82.112.7.200 any
permit tcp any host 193.138.89.2 eq smtp
permit tcp any host 212.96.192.5 eq smtp
permit ip host 10.5.16.14 any
permit tcp any host 195.128.78.3 eq smtp
permit tcp host 192.168.99.186 any
permit tcp any host 82.116.3.42 eq smtp
permit tcp host 192.168.99.180 any eq smtp
permit tcp host 192.168.99.181 any eq smtp
permit tcp host 192.168.99.191 any eq smtp
permit tcp host 192.168.99.200 any eq smtp
permit tcp any host 89.111.176.249 eq smtp
permit tcp any host 89.111.179.17 eq smtp
permit tcp any host 82.204.219.251 eq smtp
permit tcp any host 87.226.173.3 eq smtp
permit tcp any host 81.200.29.222 eq smtp
permit tcp any host 87.251.138.2 eq smtp
permit tcp any host 213.85.107.237 eq smtp
permit tcp any host 84.204.97.106 eq smtp
permit tcp any host 85.21.97.66 eq smtp
permit tcp any host 212.76.171.18 eq smtp
permit tcp any host 194.67.23.114 eq smtp
permit tcp any host 213.180.204.38 eq smtp
permit tcp any host 194.67.23.111 eq smtp
permit tcp any host 81.19.66.20 eq smtp
permit tcp any host 217.16.16.82 eq smtp
permit tcp any host 217.197.114.135 eq smtp
permit tcp any host 195.128.76.166 eq smtp
permit tcp any host 212.38.99.196 eq smtp
permit tcp any host 195.239.148.164 eq smtp
permit tcp any host 209.85.135.27 eq smtp
permit tcp host 10.2.16.126 any eq smtp
permit tcp any 62.105.8.0 0.0.0.255 eq smtp
permit tcp host 10.2.16.125 any eq smtp
deny tcp any any eq smtp
permit ip host 10.1.11.200 any time-range OVO
permit ip any host 10.1.11.200 time-range OVO
permit ip host 10.6.0.12 any
permit ip any host 212.220.123.11
permit ip host 192.168.139.2 any
permit ip host 192.168.99.203 any
permit ip host 10.6.17.59 any
permit ip host 10.2.16.118 any
permit ip host 10.2.16.119 any
permit ip host 10.2.16.120 any
permit ip host 10.2.16.121 any
permit ip host 10.2.16.122 any
permit ip host 10.2.16.123 any
permit ip host 10.2.16.124 any
permit ip host 10.2.16.125 any
permit ip host 10.2.16.126 any
permit ip host 10.2.16.127 any
permit ip host 10.2.16.128 any
permit ip host 10.2.16.116 any
permit ip host 10.2.16.130 any
permit ip host 192.168.99.243 any
permit ip host 10.2.16.129 any
permit ip host 192.168.99.202 any
permit ip host 192.168.99.249 any
permit ip host 192.168.99.180 any
permit ip host 192.168.99.200 any
permit ip host 10.1.4.32 any
permit tcp any any eq 7777
permit tcp any any eq 2106
permit tcp any any eq 29000
permit ip any host 87.242.73.152
permit ip any host 87.242.73.93
permit ip host 10.1.19.252 any
permit ip host 192.168.130.4 any
permit ip 192.168.136.0 0.0.0.255 any
permit ip 10.1.18.0 0.0.0.255 any
permit ip host 10.1.19.33 any
permit ip 10.1.19.0 0.0.0.255 any
permit ip any any
logging alarm informational
logging trap debugging
logging source-interface GigabitEthernet0/2
logging 192.168.99.179
access-list 62 deny 0.0.0.0 log
access-list 62 deny 172.16.82.0 log
access-list 62 permit any
access-list 82 deny 0.0.0.0 log
access-list 82 deny 172.16.62.0 log
access-list 82 permit any
access-list 90 permit any
access-list 99 permit 212.248.28.200
access-list 99 permit 192.168.99.0 0.0.0.255
access-list 1301 permit 10.1.0.0 0.0.0.255
access-list 1302 permit 10.1.1.0 0.0.0.255
access-list 1303 permit 10.1.2.0 0.0.0.255
access-list 1304 permit 10.1.3.0 0.0.0.255
access-list 1305 permit 10.1.4.0 0.0.0.255
access-list 1306 permit 10.1.5.0 0.0.0.255
access-list 1307 permit 10.1.6.0 0.0.0.255
access-list 1308 permit 10.1.7.0 0.0.0.255
access-list 1309 permit 10.1.8.0 0.0.0.255
access-list 1310 permit 10.1.9.0 0.0.0.255
access-list 1311 permit 10.1.10.0 0.0.0.255
access-list 1312 permit 10.1.11.0 0.0.0.255
access-list 1313 permit 10.1.12.0 0.0.0.255
access-list 1314 permit 10.1.13.0 0.0.0.255
access-list 1315 permit 10.1.14.0 0.0.0.255
access-list 1316 permit 10.1.15.0 0.0.0.255
access-list 1317 permit 10.1.16.0 0.0.0.255
access-list 1318 permit 10.1.17.0 0.0.0.255
access-list 1319 permit 10.1.18.0 0.0.0.255
access-list 1320 permit 10.1.19.0 0.0.0.255
access-list 1321 permit 10.1.20.0 0.0.0.255
access-list 1322 permit 10.2.0.0 0.0.0.255
access-list 1323 permit 10.2.1.0 0.0.0.255
access-list 1324 permit 10.2.2.0 0.0.0.255
access-list 1325 permit 10.2.3.0 0.0.0.255
access-list 1326 permit 10.2.4.0 0.0.0.255
access-list 1327 permit 10.2.5.0 0.0.0.255
access-list 1328 permit 10.2.6.0 0.0.0.255
access-list 1329 permit 10.2.7.0 0.0.0.255
access-list 1330 permit 10.2.8.0 0.0.0.255
access-list 1331 permit 10.2.9.0 0.0.0.255
access-list 1332 permit 10.2.10.0 0.0.0.255
access-list 1333 permit 10.2.11.0 0.0.0.255
access-list 1334 permit 10.2.12.0 0.0.0.255
access-list 1335 permit 10.2.13.0 0.0.0.255
access-list 1336 permit 10.2.14.0 0.0.0.255
access-list 1337 permit 10.2.15.0 0.0.0.255
access-list 1338 permit 10.2.16.0 0.0.0.255
access-list 1339 permit 10.2.17.0 0.0.0.255
access-list 1340 permit 10.2.18.0 0.0.0.255
access-list 1341 permit 10.2.19.0 0.0.0.255
access-list 1342 permit 10.2.20.0 0.0.0.255
access-list 1343 permit 10.2.21.0 0.0.0.255
access-list 1344 permit 10.2.22.0 0.0.0.255
access-list 1345 permit 10.2.23.0 0.0.0.255
access-list 1346 permit 10.2.24.0 0.0.0.255
access-list 1347 permit 10.2.25.0 0.0.0.255
access-list 1348 permit 10.2.26.0 0.0.0.255
access-list 1349 permit 10.2.27.0 0.0.0.255
access-list 1350 permit 10.2.28.0 0.0.0.255
access-list 1351 permit 10.2.29.0 0.0.0.255
access-list 1352 permit 10.2.30.0 0.0.0.255
access-list 1353 permit 10.2.31.0 0.0.0.255
access-list 1354 permit 10.3.0.0 0.0.0.255
access-list 1355 permit 10.3.1.0 0.0.0.255
access-list 1356 permit 10.3.2.0 0.0.0.255
access-list 1357 permit 10.3.3.0 0.0.0.255
access-list 1358 permit 10.3.4.0 0.0.0.255
access-list 1359 permit 10.3.5.0 0.0.0.255
access-list 1360 permit 10.3.6.0 0.0.0.255
access-list 1361 permit 10.3.7.0 0.0.0.255
access-list 1362 permit 10.3.8.0 0.0.0.255
access-list 1363 permit 10.3.9.0 0.0.0.255
access-list 1364 permit 10.3.10.0 0.0.0.255
access-list 1365 permit 10.3.11.0 0.0.0.255
access-list 1366 permit 10.3.12.0 0.0.0.255
access-list 1367 permit 10.3.13.0 0.0.0.255
access-list 1368 permit 10.3.14.0 0.0.0.255
access-list 1369 permit 10.3.15.0 0.0.0.255
access-list 1370 permit 10.3.16.0 0.0.0.255
access-list 1371 permit 10.3.17.0 0.0.0.255
access-list 1372 permit 10.3.18.0 0.0.0.255
access-list 1373 permit 10.4.0.0 0.0.0.255
access-list 1374 permit 10.4.1.0 0.0.0.255
access-list 1375 permit 10.4.2.0 0.0.0.255
access-list 1376 permit 10.4.3.0 0.0.0.255
access-list 1377 permit 10.4.4.0 0.0.0.255
access-list 1378 permit 10.4.5.0 0.0.0.255
access-list 1379 permit 10.4.6.0 0.0.0.255
access-list 1380 permit 10.4.7.0 0.0.0.255
access-list 1381 permit 10.4.8.0 0.0.0.255
access-list 1382 permit 10.4.9.0 0.0.0.255
access-list 1383 permit 10.4.10.0 0.0.0.255
access-list 1384 permit 10.4.11.0 0.0.0.255
access-list 1385 permit 10.4.12.0 0.0.0.255
access-list 1386 permit 10.4.13.0 0.0.0.255
access-list 1387 permit 10.4.14.0 0.0.0.255
access-list 1388 permit 10.4.15.0 0.0.0.255
access-list 1389 permit 10.4.16.0 0.0.0.255
access-list 1390 permit 10.4.17.0 0.0.0.255
access-list 1391 permit 10.4.18.0 0.0.0.255
access-list 1392 permit 10.4.19.0 0.0.0.255
access-list 1393 permit 10.4.20.0 0.0.0.255
access-list 1394 permit 10.4.21.0 0.0.0.255
access-list 1395 permit 10.4.22.0 0.0.0.255
access-list 1396 permit 10.4.23.0 0.0.0.255
access-list 1397 permit 10.5.0.0 0.0.0.255
access-list 1398 permit 10.5.1.0 0.0.0.255
access-list 1399 permit 10.5.2.0 0.0.0.255
access-list 1400 permit 10.5.3.0 0.0.0.255
access-list 1401 permit 10.5.4.0 0.0.0.255
access-list 1402 permit 10.5.5.0 0.0.0.255
access-list 1403 permit 10.5.6.0 0.0.0.255
access-list 1404 permit 10.5.7.0 0.0.0.255
access-list 1405 permit 10.5.8.0 0.0.0.255
access-list 1406 permit 10.5.9.0 0.0.0.255
access-list 1407 permit 10.5.10.0 0.0.0.255
access-list 1408 permit 10.5.11.0 0.0.0.255
access-list 1409 permit 10.5.12.0 0.0.0.255
access-list 1410 permit 10.5.13.0 0.0.0.255
access-list 1411 permit 10.5.14.0 0.0.0.255
access-list 1412 permit 10.5.15.0 0.0.0.255
access-list 1413 permit 10.5.16.0 0.0.0.255
access-list 1414 permit 10.5.17.0 0.0.0.255
access-list 1415 permit 10.5.18.0 0.0.0.255
access-list 1416 permit 10.5.19.0 0.0.0.255
access-list 1417 permit 10.5.20.0 0.0.0.255
access-list 1418 permit 10.5.21.0 0.0.0.255
access-list 1419 permit 10.5.22.0 0.0.0.255
access-list 1420 permit 10.6.0.0 0.0.0.255
access-list 1421 permit 10.6.1.0 0.0.0.255
access-list 1422 permit 10.6.10.0 0.0.0.255
access-list 1423 permit 10.6.11.0 0.0.0.255
access-list 1424 permit 10.6.12.0 0.0.0.255
access-list 1425 permit 10.6.13.0 0.0.0.255
access-list 1426 permit 10.6.14.0 0.0.0.255
access-list 1427 permit 10.6.15.0 0.0.0.255
access-list 1428 permit 10.6.16.0 0.0.0.255
access-list 1429 permit 10.6.17.0 0.0.0.255
access-list 1430 permit 10.6.2.0 0.0.0.255
access-list 1431 permit 10.6.3.0 0.0.0.255
access-list 1432 permit 10.6.4.0 0.0.0.255
access-list 1433 permit 10.6.5.0 0.0.0.255
access-list 1434 permit 10.6.6.0 0.0.0.255
access-list 1435 permit 10.6.7.0 0.0.0.255
access-list 1436 permit 10.6.8.0 0.0.0.255
access-list 1437 permit 10.6.9.0 0.0.0.255
access-list 102 permit ip 10.2.0.0 0.0.255.255 any
access-list 103 permit ip 10.3.0.0 0.0.255.255 any
access-list 104 permit ip 10.4.0.0 0.0.255.255 any
access-list 105 permit ip 10.5.0.0 0.0.255.255 any
access-list 106 permit ip 10.6.0.0 0.0.255.255 any
access-list 111 permit ip host 192.168.99.160 any
access-list 160 permit ip any 192.168.0.0 0.0.255.255
access-list 161 permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 161 permit ip 172.16.0.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 161 permit ip 192.168.0.0 0.0.255.255 172.16.0.0 0.0.0.255
access-list 161 permit ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 161 permit ip 10.0.0.0 0.255.255.255 192.168.0.0 0.0.255.255
access-list 171 permit ip host 192.168.99.146 any
access-list 172 permit ip any host 192.168.99.146
access-list 173 permit ip any host 212.42.38.82
access-list 173 permit ip host 212.42.38.82 any
access-list 2248 permit ip any host 10.2.14.27
no cdp run
route-map link-map permit 10
description LINK personal IP map
match ip address LINK_IP
set ip next-hop 82.62.176.117
snmp-server community dliamrtg view v1default RO
snmp-server enable traps tty
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
alias exec whatsnew show archive config differences nvram:startup-config system:running-config
alias exec topsat sh ip flow top 10 aggregate destination-address sorted-by bytes descending match source-interface tun 82
alias exec polic sh policy-map interface gi0/2
alias exec topiland sh ip flow top 10 aggregate source-address sorted-by bytes descending match destination-interface tun 62
alias exec topisat sh ip flow top 10 aggregate source-address sorted-by bytes descending match destination-interface tun 82
alias exec topsat100 sh ip flow top 100 aggregate destination-address sorted-by bytes descending match source-interface tun 82
alias exec topland100 sh ip flow top 100 aggregate destination-address sorted-by bytes descending match source-interface tun 62
alias exec topisat100 sh ip flow top 100 aggregate source-address sorted-by bytes descending match destination-interface tun82
alias exec topland sh ip flow top 10 aggregate destination-address sorted-by bytes descending match source-interface tun 62
alias exec topilink sh ip flow top 10 aggregate source-address sorted-by bytes descending match destination-interface gi0/2.1
alias exec topilink100 sh ip flow top 100 aggregate source-address sorted-by bytes descending match destination-interface gi0/2.1
alias exec toplink100 sh ip flow top 100 aggregate destination-address sorted-by bytes descending match source-interface gi0/2.1
alias exec topilink25 sh ip flow top 25 aggregate source-address sorted-by bytes ^ descending match destination-interface gi0/2.1
alias exec toplink25 sh ip flow top 25 aggregate destination-address sorted-by bytes descending match source-interface gi0/2.1
alias exec toplink sh ip flow top 10 aggregate destination-address sorted-by bytes descending match source-interface gi0/1
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 99 in
login local
transport input telnet
line vty 5 15
session-timeout 600
access-class 99 in
exec-timeout 600 0
login local
transport input ssh
time-range OVO
periodic daily 8:00 to 20:00
end
c7204# sh int
Hardware is BCM1250 Internal MAC, address is 001c.b13c.7c1b (bia 001c.b13c.7c1b)
Description: --
Internet address is 82.62.176.118/30
MTU 1500 bytes, BW 56000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 116/255, rxload 247/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is XON, input flow-control is XON
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 3/75/0/373534 (size/max/drops/flushes); Total output drops: 8836
Queueing strategy: weighted fair
Output queue: 0/1000/64/2451 (size/max total/threshold/drops)
Conversations 0/251/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42000 kilobits/sec
30 second input rate 54348000 bits/sec, 27725 packets/sec
30 second output rate 25613000 bits/sec, 26329 packets/sec
110977788 packets input, 2269470781 bytes, 0 no buffer
Received 6271 broadcasts, 0 runts, 0 giants, 0 throttles
289 input errors, 0 CRC, 0 frame, 289 overrun, 0 ignored
0 watchdog, 2106 multicast, 0 pause input
0 input packets with dribble condition detected
4157706692 packets output, 3528575350 bytes, 0 underruns
9 output errors, 0 collisions, 5 interface resets
0 unknown protocol drops
0 babbles, 0 late collision, 0 deferred
9 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
GigabitEthernet0/1.1 is deleted, line protocol is down
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Encapsulation ARPA
Hardware is BCM1250 Internal MAC, address is 001c.b13c.7c1a (bia 001c.b13c.7c1a)
Description: LAN
Internet address is 192.168.99.199/24
MTU 1500 bytes, BW 60000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 179/255, rxload 57/255
Input queue: 0/75/29394/4807825 (size/max/drops/flushes); Total output drops: 8567
Output queue: 0/1000/64/3929 (size/max total/threshold/drops)
Conversations 0/104/256 (active/max active/max total)
Available Bandwidth 45000 kilobits/sec
30 second input rate 13417000 bits/sec, 7075 packets/sec
30 second output rate 42180000 bits/sec, 8467 packets/sec
2268335917 packets input, 2966837109 bytes, 0 no buffer
Received 2588 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 1 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
2514329602 packets output, 3265283656 bytes, 0 underruns
7 output errors, 0 collisions, 5 interface resets
7 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/2.1 is deleted, line protocol is down
Encapsulation ARPA
GigabitEthernet0/3 is administratively down, line protocol is down
Hardware is BCM1250 Internal MAC, address is 001c.b13c.7c19 (bia 001c.b13c.7c19)
Description: INTERNET-LAND
MTU 1500 bytes, BW 2000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Auto-duplex, Auto Speed, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Available Bandwidth 1500 kilobits/sec
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 packets output, 0 bytes, 0 underruns
1 output errors, 0 collisions, 0 interface resets
1 lost carrier, 0 no carrier, 0 pause output
NVI0 is administratively down, line protocol is down
Hardware is NVI
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 output errors, 0 collisions, 0 interface resets
SSLVPN-VIF0 is up, line protocol is up
Hardware is SSLVPN_VIF
Interface is unnumbered. Using address of SSLVPN-VIF0 (0.0.0.0)
MTU 1406 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Edited by В Густелёв
То есть сети 82.62.179.x/y 82.62.182.0/24 на вашей стороне только в pool-ах ната, а у вышестоящего провайдера зарулены к вам статикой ?
Если да, то вам нужно прописать маршрут на эти сети в Null0. Иначе, при не нахождении подходящей сессии (трансляции) для пакетика, он будет гоняться между вашим роутером и аплинком до исчерпания ttl.
Проматчить такой трафик можно аццеслистом матчащим на выходе пакетеки, которые должны приходить к вам.
Что-то вроде:
ip access-list extended TRAP2
permit ip any any
int Gi0/2
ip access-group TRAP2 out
Что-то вроде:
permit ip any any
int Gi0/2
и у нас есть победитель дракона!
Так выше уже же написали:
Да, классическая беда.
Лучше всего, первым делом, получив сеть любого размера, зароутить ее целиком в null, с большой метрикой.
Чтоб потом не беспокоиться.
