Andrei Posted April 21, 2010 Posted April 21, 2010 Подключение к магистралу сделано двумя фреймованными Е1, собранными в мультилинк на cisco 3620: c3620#sh ver Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-IK8O3S-M), Version 12.2(13), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Tue 19-Nov-02 14:03 by pwade Image text-base: 0x60008930, data-base: 0x612B4000 ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) c3620 uptime is 1 day, 9 hours, 2 minutes System returned to ROM by reload System restarted at 08:14:43 CHE Tue Apr 20 2010 System image file is "flash:c3620-ik8o3s-mz.122-13.bin" cisco 3620 (R4700) processor (revision 0x81) with 49152K/16384K bytes of memory. Processor board ID 24807390 R4700 CPU at 80Mhz, Implementation 33, Rev 1.0 Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). Primary Rate ISDN software, Version 1.1. 1 FastEthernet/IEEE 802.3 interface(s) 2 Serial network interface(s) 2 Channelized E1/PRI port(s) DRAM configuration is 32 bits wide with parity disabled. 29K bytes of non-volatile configuration memory. 16384K bytes of processor board System flash (Read/Write) Configuration register is 0x2102 Фрагмент конфига, касающийся мультилинка: controller E1 1/0 framing NO-CRC4 channel-group 0 timeslots 1-31 description To Rostelecom ! controller E1 1/1 framing NO-CRC4 channel-group 0 timeslots 1-31 description To Rostelecom ! ! ! interface Multilink1 description ### MultiLink to Rostelecom bandwidth 4096 ip address 94.хх.хх.хх 255.255.255.252 ip verify unicast reverse-path no ip redirects no ip proxy-arp no cdp enable ppp multilink no ppp multilink fragmentation multilink-group 1 hold-queue 4096 in hold-queue 4096 out ! interface FastEthernet1/0 description ### To Local ip address 10.1.2.2 255.255.255.248 secondary ip address 87.ххх.ххх.х 255.255.255.248 no ip redirects no ip unreachables no ip proxy-arp ip accounting output-packets no ip mroute-cache duplex auto speed auto hold-queue 4096 in hold-queue 4096 out ! interface Serial1/0:0 description To Rostelecom bandwidth 2048 no ip address ip verify unicast reverse-path no ip redirects no ip unreachables no ip proxy-arp encapsulation ppp no ip route-cache cef no fair-queue no cdp enable ppp multilink multilink-group 1 hold-queue 4096 in hold-queue 4096 out ! interface Serial1/1:0 description To Rostelecom bandwidth 2048 no ip address ip verify unicast reverse-path no ip redirects no ip unreachables no ip proxy-arp encapsulation ppp no ip route-cache cef no fair-queue no cdp enable ppp multilink multilink-group 1 hold-queue 4096 in hold-queue 4096 out В пределе (нагружали несколькими потоками wget-а) канал дает около 3,5 мбит/сек, вместо ожидаемых 3,8-3,9 :( На той стороне стоит Juniper, никаких шейперов/полисеров как утверждается там нет (да и не нужны они, т.к. линк собран из 2-х Е1). Может что не так в конфиге? Параметр "clock rate " на Serial Interface в этом случае имеет значение? Вставить ник Quote
Ivan Rostovikov Posted April 21, 2010 Posted April 21, 2010 (edited) Т.е. балансировка per-packet ? Интерфейсы нагружаются равномерно ? >timeslots 1-31 типа framed ? значит - 1 таймслот на каждом E1. Итого -128k Так я понимаю ? Edited April 21, 2010 by Ivan Rostovikov Вставить ник Quote
Картуччо Posted April 21, 2010 Posted April 21, 2010 (edited) Попробуй удалить мультилинк интерфейс, сделать default для сериалов и потестировать с конфигом без излишеств: interface Multilink1 ip address .... ppp multilink ppp multilink fragment disable ppp multilink group 1 interface Serial0/1/0:1 no ip address encapsulation ppp ppp multilink ppp multilink group 1 Ну и конечно проверить на наличие каких-либо ошибок show controller e1 show int mu1 show int Serial1/0:0 show int Serial1/1:0 show ppp mu Как раз с Ростелекомом доводилось поднимать мультилинки от 2 до 8 Е1. Если ошибок на потоках и интерфейсах не было, то с полосой было все ОК. Edited April 21, 2010 by Картуччо Вставить ник Quote
Andrei Posted April 22, 2010 Author Posted April 22, 2010 Т.е. балансировка per-packet ?Интерфейсы нагружаются равномерно ? Балансировка явно не указана, но Е1 нагружаются равномерно: если посмотреть sh int mult 1 и затем сразу же show int Serial1/0:0 и show int Serial1/1:0 , то видно, что нагрузка поделена между Е1 равномерно. >timeslots 1-31типа framed ? значит - 1 таймслот на каждом E1. Итого -128k Так я понимаю ? Нет. Мультилинк из 2-х потоков- фреймированный: (30 * 64) * 2 = 3840 - не фреймированный: (32*64)*2 = 4096 Т.е. в моем случае должно быть пимерно 2*30*64 = 3840 Кбит/сек = 480 Кбайт/сек, а реально выше 3500 Кбит/сек (440 Кбайт/сек) не поднимается. сделать default для сериаловА как - можно по-точнее подскажите? show controller e1show int mu1 show int Serial1/0:0 show int Serial1/1:0 show ppp mu Вот что видно сейчас (утро, нагрузка около 60%): c3620#sh controller E1 E1 1/0 is up. Applique type is Channelized E1 - balanced Description: To Rostelecom No alarms detected. alarm-trigger is not set Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line. Data in current interval (378 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs Total Data (last 24 hours) 0 Line Code Violations, 0 Path Code Violations, 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins, 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs E1 1/1 is up. Applique type is Channelized E1 - balanced Description: To Rostelecom No alarms detected. alarm-trigger is not set Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line. Data in current interval (380 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs Total Data (last 24 hours) 0 Line Code Violations, 0 Path Code Violations, 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins, 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs c3620#show int mu1 Multilink1 is up, line protocol is up Hardware is multilink group interface Description: ### MultiLink to Rostelecom Internet address is 94.хх.хх.хх/30 MTU 1500 bytes, BW 4096 Kbit, DLY 100000 usec, reliability 255/255, txload 41/255, rxload 143/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 2 seconds on reset LCP Open, multilink Open Open: IPCP Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters 2d00h Input queue: 0/4096/118/0 (size/max/drops/flushes); Total output drops: 23982 Queueing strategy: fifo Output queue: 0/4096 (size/max) 5 minute input rate 2305000 bits/sec, 494 packets/sec 5 minute output rate 661000 bits/sec, 423 packets/sec 74852624 packets input, 2077718393 bytes, 9318 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 66269860 packets output, 3475622159 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions c3620#show int Serial1/0:0 Serial1/0:0 is up, line protocol is up Hardware is DSX1 Description: To Rostelecom MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec, reliability 255/255, txload 41/255, rxload 143/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Open, multilink Open Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 2d00h Input queue: 0/4096/1128/0 (size/max/drops/flushes); Total output drops: 70 Queueing strategy: fifo Output queue: 0/4096 (size/max) 5 minute input rate 1155000 bits/sec, 238 packets/sec 5 minute output rate 335000 bits/sec, 206 packets/sec 37754609 packets input, 1250760944 bytes, 2881 no buffer Received 0 broadcasts, 0 runts, 0 giants, 141 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 33181552 packets output, 2008302248 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 output buffer failures, 0 output buffers swapped out 3 carrier transitions Timeslot(s) Used:1-31, Transmitter delay is 0 flags c3620#show int Serial1/1:0 Serial1/1:0 is up, line protocol is up Hardware is DSX1 Description: To Rostelecom MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec, reliability 255/255, txload 41/255, rxload 144/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) LCP Open, multilink Open Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 2d00h Input queue: 0/4096/1322/0 (size/max/drops/flushes); Total output drops: 207 Queueing strategy: fifo Output queue: 0/4096 (size/max) 5 minute input rate 1158000 bits/sec, 241 packets/sec 5 minute output rate 335000 bits/sec, 206 packets/sec 37733637 packets input, 1246500376 bytes, 165 no buffer Received 0 broadcasts, 0 runts, 0 giants, 165 throttles 2 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored, 1 abort 33140429 packets output, 2000428754 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 3 carrier transitions Timeslot(s) Used:1-31, Transmitter delay is 0 flags c3620#show ppp mu Multilink1, bundle name is 94.хх.хх.хх Bundle up for 2d00h 2051777 lost fragments, 27048682 reordered, 0 unassigned 19378 discarded, 3004 lost received, 41/255 load 0xC071FA received sequence, 0xF3690E sent sequence Member links: 2 active, 0 inactive (max not set, min not set) Se1/1:0, since 1d15h, last rcvd seq C071FB Se1/0:0, since 10:22:16, last rcvd seq C071F6 Потоки приходят к нам по релейке, в ней конечно возможны "замирания", в sh log иногда прокскакивают записи вида .Apr 21 00:03:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:0, changed state to down .Apr 21 00:03:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:0, changed state to up .Apr 21 22:14:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:0, changed state to down .Apr 21 22:15:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0:0, changed state to up но редко - может быть раз в 3-4 дня. Вставить ник Quote
Картуччо Posted April 22, 2010 Posted April 22, 2010 (edited) Т.е. в моем случае должно быть пимерно 2*30*64 = 3840 Кбит/сек = 480 Кбайт/сек, а реально выше 3500 Кбит/сек (440 Кбайт/сек) не поднимается.Ну, вообще-то мультилинк имеет еще и свои накладные расходы.Например, в документации на RADовские RICi-8E1 сразу оговорено, что будет не 16 мбпс, а только 14.5 Но, если правильно помню, на мультилинках 2Е1 рисовалось в максимуме все же побольше, чем 3.5 мбпс сделать default для сериаловА как - можно по-точнее подскажите? имел в виду чтобы конфиг на интерфейсах построчно не зачищатьdefault int Serial1/0:0 2051777 lost fragments, 27048682 reordered, 0 unassigned 19378 discarded, 3004 lost received, 41/255 load И вот какие у меня sh ppp mu: Multilink1, bundle name is UAK5-R1 Endpoint discriminator is UAK5-R1 Bundle up for 2w2d, total bandwidth 4096, load 1/255 Receive buffer limit 24000 bytes, frag timeout 1000 ms 0/0 fragments/bytes in reassembly list 0 lost fragments, 527797 reordered 1/42 discarded fragments/bytes, 2 lost received 0x309BC0 received sequence, 0x492D07 sent sequence Member links: 2 active, 0 inactive (max not set, min not set) Se0/1/1:1, since 2w2d Se0/1/0:1, since 2w2d No inactive multilink interfaces Multilink1, bundle name is UAK8-R1 Endpoint discriminator is UAK8-R1 Bundle up for 14w3d, total bandwidth 3968, load 2/255 Receive buffer limit 24000 bytes, frag timeout 1000 ms 0/0 fragments/bytes in reassembly list 6 lost fragments, 89518206 reordered 0/0 discarded fragments/bytes, 0 lost received 0xC6CF21 received sequence, 0xC4A632 sent sequence Member links: 2 active, 0 inactive (max not set, min not set) Se0/3/1:1, since 5d08h Se0/1/0:1, since 6w5d No inactive multilink interfaces Edited April 22, 2010 by Картуччо Вставить ник Quote
Andrei Posted April 22, 2010 Author Posted April 22, 2010 имел в виду чтобы конфиг на интерфейсах построчно не зачищатьdefault int Serial1/0:0 Попробую переделать в период наименьшей нагрузки. 2051777 lost fragments, 27048682 reordered, 0 unassigned19378 discarded, 3004 lost received, 41/255 load Как можно диагностировать причину этой гадости, т.к. "2051777 lost fragments" из "27048682 reordered" это 7,5% - похоже как раз именно та полоса, которую я недобираю из мультилинка.На контроллерах ошибок не видно: c3620# sh controller E1 1/0 E1 1/0 is up. Applique type is Channelized E1 - balanced Description: To Rostelecom No alarms detected. alarm-trigger is not set Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line. Data in current interval (259 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs ... Total Data (last 24 hours) 0 Line Code Violations, 0 Path Code Violations, 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins, 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs c3620# sh controller E1 1/1 E1 1/1 is up. Applique type is Channelized E1 - balanced Description: To Rostelecom No alarms detected. alarm-trigger is not set Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line. Data in current interval (259 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs ... Total Data (last 24 hours) 0 Line Code Violations, 0 Path Code Violations, 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins, 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs Вставить ник Quote
Картуччо Posted April 22, 2010 Posted April 22, 2010 (edited) Для начала надо переделать конфигурацию как я выше приводил и потестировать снова. Конфиг будет несколько отличаться, та как железки и софт разные. Так же не мешает РТ попросить проверить с их стороны. Edited April 22, 2010 by Картуччо Вставить ник Quote
Andrei Posted April 22, 2010 Author Posted April 22, 2010 Для начала надо переделать конфигурацию как я выше приводил и потестировать снова.ОК. Завтра с утра. Так же не мешает РТ попросить проверить с их стороны.Говорят, что проверяли. Даже мерили с ними канал iperf-ом, но получили противоречивые данные. Вставить ник Quote
fenix-vt Posted April 22, 2010 Posted April 22, 2010 - фреймированный: (30 * 64) * 2 = 3840 - фреймированный: 31 * 64 * 2 = 3968 куда вы еще один TS дели? ;) channel-group 0 timeslots 1-31 Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 куда вы еще один TS дели? ;)Синхра. Картуччо, вобщем сделал я как вы советовали: c3620#conf t Enter configuration commands, one per line. End with CNTL/Z. c3620(config)#int mult 1 c3620(config-if)#shut c3620(config-if)#no int mult 1 % Removed 'multilink-group' from interface Serial1/0:0 % Removed 'multilink-group' from interface Serial1/1:0 c3620(config)#default int Serial1/0:0 Building configuration... % Cannot enable CDP on this interface, since CDP is not running Interface Serial1/0:0 set to default configuration c3620(config)#default int Serial1/1:0 Building configuration... % Cannot enable CDP on this interface, since CDP is not running Interface Serial1/1:0 set to default configuration и потом interface Multilink1 ip address 94.хх.хх.хх 255.255.255.252 ppp multilink ppp multilink fragment disable ppp multilink group 1 interface Serial1/0:0 no ip address encapsulation ppp ppp multilink ppp multilink group 1 interface Serial1/1:0 no ip address encapsulation ppp ppp multilink ppp multilink group 1 Получившийся конфиг: interface Multilink1 description ### MultiLink to Rostelecom bandwidth 4096 ip address 94.хх.хх.хх 255.255.255.252 ip verify unicast reverse-path no ip redirects no ip proxy-arp no cdp enable ppp multilink no ppp multilink fragmentation multilink-group 1 hold-queue 4096 in hold-queue 4096 out ! ... ! interface Serial1/0:0 no ip address no ip proxy-arp encapsulation ppp no cdp enable ppp multilink multilink-group 1 ! interface Serial1/1:0 no ip address no ip proxy-arp encapsulation ppp no cdp enable ppp multilink multilink-group 1 После 50 минут работы lost fragments опять присутствуют и со временем счетчики растут, хотя в % остается примерно на том же уровне: Multilink1, bundle name is 94.хх.хх.хх Bundle up for 00:49:52 15502 lost fragments, 270928 reordered, 0 unassigned 29 discarded, 0 lost received, 36/255 load 0x101B51 received sequence, 0xD25F1 sent sequence Member links: 2 active, 0 inactive (max not set, min not set) Se1/0:0, since 00:49:52, last rcvd seq 101B50 Se1/1:0, since 00:49:52, last rcvd seq 101B4F c3620#sh int mult 1 Multilink1 is up, line protocol is up Hardware is multilink group interface Description: ### MultiLink to Rostelecom Internet address is 94.хх.хх.хх/30 MTU 1500 bytes, BW 4096 Kbit, DLY 100000 usec, reliability 255/255, txload 35/255, rxload 138/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 2 seconds on reset LCP Open, multilink Open Open: IPCP Last input 00:00:02, output never, output hang never Last clearing of "show interface" counters 3d00h Input queue: 0/4096/118/8 (size/max/drops/flushes); Total output drops: 23986 Queueing strategy: fifo Output queue: 0/4096 (size/max) 5 minute input rate 2226000 bits/sec, 423 packets/sec 5 minute output rate 567000 bits/sec, 362 packets/sec 113411787 packets input, 199253776 bytes, 9318 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 99563569 packets output, 582474035 bytes, 0 underruns 0 output errors, 0 collisions, 6 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions sh controller E1 ошибок не показывает. Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 Total output drops: 23986 Этот счетчик тянется с прошлого конфига. Он почему-то не обнулился несмотря на то, что я убивал мультилинк-интерфейс и сбрасывал в дефаулт сериалы. Растет этот счетчик крайне медленно - за день на 4. Вставить ник Quote
Картуччо Posted April 23, 2010 Posted April 23, 2010 И загрузка интерфейса всё так же менее 3.5 мбпс ? Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 Сейчас загрузка 5 minute input rate 3407000 bits/sec, 642 packets/sec Пытаюсь нагрузить канал: wget -O /dev/null ftp://ftp.drweb.com/pub/drweb/iso/drweb-600-livecd.iso Одновременно смотрел iperf: iperf -c 89.хх.хх.хх -d ------------------------------------------------------------ Server listening on TCP port 5001 TCP window size: 85.3 KByte (default) ------------------------------------------------------------ ------------------------------------------------------------ Client connecting to 89.хх.хх.хх, TCP port 5001 TCP window size: 16.0 KByte (default) ------------------------------------------------------------ [ 6] local 87.226.хх.х port 50959 connected with 89.237.хх.хх port 5001 [ 6] 0.0-10.1 sec 2.08 MBytes 1.73 Mbits/sec Т.е. грубо можно сложить показания циски (3,4 мбит/сек) и iperf-а (1,73 Мбит/сек) = более 5 Мбит/сек. Странный результат. Либо я неверно трактую полученные данные. Вставить ник Quote
Картуччо Posted April 23, 2010 Posted April 23, 2010 Лучше добавить интерфейс мультилинка в какой-нибудь мониторинг и уже потом трактовать графики. Вставить ник Quote
zander Posted April 23, 2010 Posted April 23, 2010 В лабораторных условиях собрали мультилинк на 2х Е1 на цисках - результат тот же ~3,5 мбит/с Вставить ник Quote
Картуччо Posted April 23, 2010 Posted April 23, 2010 Не, джентльмены, что-то где-то у вас не так. Ради интереса прогрузил в двух разных узлах такие же мультилинки 2хЕ1, тоже Ростелеком. Верхний график на картинке с анфреймед: controller E1 0/1/0 channel-group 1 unframed нижний график с настройками как у ТС: controller E1 0/1/0 channel-group 1 timeslots 1-31 Полосы по 4 мегабита уже слабо актуальны, поэтому мультики стоят на самый крайний резервный случай почти пустые. Поток трафика выставил в 3.8 Mbps. Вставить ник Quote
fenix-vt Posted April 23, 2010 Posted April 23, 2010 куда вы еще один TS дели? ;)Синхра. для синхронизации используется TS0один из 32. 32-1 = 31. не? Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 Лучше добавить интерфейс мультилинка в какой-нибудь мониторинг и уже потом трактовать графики.Мониторинг есть, вот картинка, которую рисует mrtg (oid - 1.3.6.1.2.1.2.2.1.10.1): что-то где-то у вас не так.Согласен. Вот и ищу - где? Полосы по 4 мегабита уже слабо актуальныВ небольших городках зауралья еще актуальны Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 для синхронизации используется TS0один из 32. 32-1 = 31. не? На сколько я помню, таймслоты нумеруются с 1 по 31, 16-й синхра, остальные 30 - собственно полезная нагрузка. Вставить ник Quote
Картуччо Posted April 23, 2010 Posted April 23, 2010 Картинку перевести в биты, а то смотрится как порнография. Насчет таймслотов неправильно. Да и полки как таковой на графике не видно. Надо поддать нагрузки :) Вставить ник Quote
fenix-vt Posted April 23, 2010 Posted April 23, 2010 (edited) для синхронизации используется TS0один из 32. 32-1 = 31. не? На сколько я помню, таймслоты нумеруются с 1 по 31, 16-й синхра, остальные 30 - собственно полезная нагрузка. нет.0 -- фреймовая синхронизация (для образования структуры Е1) 1-31 -- полезная нагрузка. Если в потоке Е1 присутствует еще и телефонная сигнализация (не путать с синхронизацией), то тогда таймслотов для проключения телефонных, разговорных, каналов дйствительно 30. У вас же не PRI, а данные. Вы описали channel-group 1 timeslots 1-31 , то есть все 31 TS. И скорость у вас должна быть еще больше, чем вы думаете :) а вот почему "не грузится"... по графику MRTG у вас вроде как и грузится, кстати. т.к. мртг у вас отображает в байтах/с график мртг рисует, на мой взгляд, неправильно хотя бы потому, что автор MRTG думал, что в одном килобите 1024 бита. а не 1000, как есть в реале. может, и вы тоже думаете так же? :) 31*2*64к=3968кбит/с 3968 / 8 = 496 кбайт/с если взять поправку на ошибку мртг 1024/1000 получится 484,375 кбайт/с надо, разумеется, еще понимать, что мртг с мультилинка снимает уже нагрузку tcp/ip (без учета служебного пакетирования для мультилинка и собственно PPP) не знаю, как помне -- нагрузка, судя по графику, абсолютно адекватна. IMHO Edited April 23, 2010 by fenix-vt Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 Может не тот oid смотрю? sh-2.05b# snmpwalk 87.ххх.ххх.ххх -v 2c -c public 1.3.6.1.2.1.2.2.1.10 IF-MIB::ifInOctets.1 = Counter32: 3423022484 IF-MIB::ifInOctets.2 = Counter32: 0 IF-MIB::ifInOctets.5 = Counter32: 3892130191 IF-MIB::ifInOctets.6 = Counter32: 3885977698 IF-MIB::ifInOctets.7 = Counter32: 2804261320 На графике 1.3.6.1.2.1.2.2.1.10.1 и 1.3.6.1.2.1.2.2.1.16.1 Картинку перевести в биты, а то смотрится как порнография.Как? В лог-то подают циферки правильные:sh-2.05b# snmpwalk 87.ххх.ххх.ххх -v 2c -c public 1.3.6.1.2.1.2.2.1.10.1 IF-MIB::ifInOctets.1 = Counter32: 3513626768 sh-2.05b# snmpwalk 87.ххх.ххх.ххх -v 2c -c public 1.3.6.1.2.1.2.2.1.16.1 IF-MIB::ifOutOctets.1 = Counter32: 409904023 Да и полки как таковой на графике не видно. Надо поддать нагрузки :)Сейчас запустил wget с 4х разных терминальных сессий с сервака тянет: wget -O /dev/null ftp://ftp.drweb.com/pub/drweb/iso/drweb-600-livecd.iso Вставить ник Quote
Картуччо Posted April 23, 2010 Posted April 23, 2010 Для перевода картинки в биты надо указать в опциях для этого таргета параметр bits. Оиды вовсе не нужны, можно указать таргет по индексу интерфейса. Вставить ник Quote
Andrei Posted April 23, 2010 Author Posted April 23, 2010 график мртг рисует, на мой взгляд, неправильно хотя бы потому, что автор MRTG думал, что в одном килобите 1024 бита.а не 1000, как есть в реале. может, и вы тоже думаете так же? :) 31*2*64к=3968кбит/с 3968 / 8 = 496 кбайт/с если взять поправку на ошибку мртг 1024/1000 получится 484,375 кбайт/с надо, разумеется, еще понимать, что мртг с мультилинка снимает уже нагрузку tcp/ip (без учета служебного пакетирования для мультилинка и собственно PPP) Было бы 496 кбайт/с или хотя бы 484, я бы может и не спрашивал бы.К тому же для меня mrtg - всего лишь ориентир. Наиболее реально наверное отражает ситуацию данные, получаемые по sh int mult 1 sh int FastEthernet1/0 Вот тут-то больше 3500000 bits/sec и не бывает Вставить ник Quote
