detx Posted April 9, 2010 Posted April 9, 2010 Есть cisco 871 прописываю на интерфейсе secondary ip. Но из сети ip пингануть не могу в чем проблема masl#show ver Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc. Compiled Thu 14-Aug-08 07:43 by prod_rel_team ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE masl uptime is 14 weeks, 5 days, 5 hours, 31 minutes System returned to ROM by power-on System image file is "flash:c870-advsecurityk9-mz.124-15.T7.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 871 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memory. Processor board ID FCZ12471113 MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10 5 FastEthernet interfaces 128K bytes of non-volatile configuration memory. 24576K bytes of processor board System flash (Intel Strataflash) Configuration register is 0x2102 masl#show run Building configuration... Current configuration : 1775 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname masl ! boot-start-marker boot-end-marker ! enable secret 5 "блаблабла" ! no aaa new-model ! ! dot11 syslog ip cef ! ! ! ! username tech password 7 "бла" username mktel password 7 "бла" ! ! archive log config hidekeys ! ! ! ! ! interface Tunnel0 ip address 192.168.4.1 255.255.255.0 ip tcp adjust-mss 1436 tunnel source FastEthernet4 tunnel destination бла бла ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ip address блабла 255.255.255.240 duplex auto speed auto ! interface Vlan1 ip address 192.168.222.2 255.255.255.0 secondary ip address блабла 255.255.255.240 ! ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.4.2 ! no ip http server no ip http secure-server ! access-list 23 permit блабла access-list 23 permit блабла ! ! ! control-plane ! ! line con 0 no modem enable line aux 0 line vty 0 4 access-class 23 in login tacacs ! scheduler max-task-time 5000 end masl# пробую пингануть 192.168.222.2 не пинугется подключен через interface FastEthernet2 Пробую пингануть основной ip пингуется через interface FastEthernet2 Настраиваю тоже самое на 851 циске все работает не подскажите в чем может быть проблема???? Вставить ник Quote
detx Posted April 10, 2010 Author Posted April 10, 2010 Что никто не знает или недостаточно информации???? Вставить ник Quote
Stak Posted April 11, 2010 Posted April 11, 2010 По фиченавигатору не проверяли, есть ли поддержка secondary address в c870-advsecurity имадже? ЕМНИП, там был ряд ограничений по функционалу... в advipservices их нет. Вставить ник Quote
detx Posted April 11, 2010 Author Posted April 11, 2010 По фиченавигатору не проверяли, есть ли поддержка secondary address в c870-advsecurity имадже? ЕМНИП, там был ряд ограничений по функционалу... в advipservices их нет. В Cisco Feature Navigator именно этой фишки почему-то вообще не нашел(может конечно не правильно искал) в понедельник попробую прошить посмотрю что получиться)) Вставить ник Quote
