Произвел замену 2621 на 2821, подключение по pppoe+nat, все работает, но перестало заходить на http://rutracker.org (остальные сайты вроде работают)
Вырезки конфига:
interface GigabitEthernet0/0
ip address 10.128.0.11 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
fair-queue
interface Dialer1
mtu 1480
ip address negotiated
ip nat outside
encapsulation ppp
ip route-cache policy
ip route-cache flow
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ip nat translation timeout 60
ip nat translation tcp-timeout 900
ip nat translation udp-timeout 45
ip nat translation syn-timeout 15
ip nat translation dns-timeout 5
ip nat translation icmp-timeout 5
ip nat translation port-timeout tcp 80 30
ip nat inside source list 10 interface Dialer1 overload
Дампим пакеты с клиентской машины при попытке зайти на сайт:
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
14:19:26.337373 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 66: 10.128.1.133.56584 > 195.82.146.114.80: S 97970897:97970897(0) win 5840 <mss 1460,nop,nop,sackOK,nop,wscale 6>
14:19:26.467867 00:19:5b:f2:2c:00 > 00:0f:38:6c:19:a8, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > 10.128.1.133.56584: S 370561435:370561435(0) ack 97970898 win 5840 <mss 1452>
14:19:26.467877 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 54: 10.128.1.133.56584 > 195.82.146.114.80: . ack 1 win 5840
14:19:26.468109 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 208: 10.128.1.133.56584 > 195.82.146.114.80: P 1:155(154) ack 1 win 5840
14:19:26.598604 00:19:5b:f2:2c:00 > 00:0f:38:6c:19:a8, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > 10.128.1.133.56584: . ack 155 win 6432
14:19:26.598872 00:19:5b:f2:2c:00 > 00:0f:38:6c:19:a8, ethertype IPv4 (0x0800), length 833: 195.82.146.114.80 > 10.128.1.133.56584: P 1:780(779) ack 155 win 6432
14:19:26.598878 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 54: 10.128.1.133.56584 > 195.82.146.114.80: . ack 780 win 7011
14:19:27.600201 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 255: 10.128.1.133.56584 > 195.82.146.114.80: P 155:356(201) ack 780 win 7011
14:19:27.992820 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 255: 10.128.1.133.56584 > 195.82.146.114.80: P 155:356(201) ack 780 win 7011
14:19:28.123265 00:19:5b:f2:2c:00 > 00:0f:38:6c:19:a8, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > 10.128.1.133.56584: . ack 356 win 7504
14:19:33.851232 00:0f:38:6c:19:a8 > 00:1a:e2:5e:32:60, ethertype IPv4 (0x0800), length 54: 10.128.1.133.56584 > 195.82.146.114.80: F 356:356(0) ack 780 win 7011
14:19:34.021822 00:19:5b:f2:2c:00 > 00:0f:38:6c:19:a8, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > 10.128.1.133.56584: . ack 357 win 7504
и тишина....
Если подампить с машины, которая подключена в инет напрямую видим такие пакеты:
14:13:55.488048 00:15:17:ab:6a:7f > 00:14:22:1a:21:34, ethertype IPv4 (0x0800), length 1514: 195.82.146.114.80 > x.x.x.x.38811: . 780:2240(1460) ack 416 win 7504
За кошконатом такого размера пакеты не замечены.
При подключении по пппое не кошкой а лин-вин, сайт этот тоже открывается нормально.
похоже на проблемы с MTU
некоторые сайты не пускают к себе не стандартные мту, например mail.ru (раньше по крайней мере не пускало..как сейчас не знаю)
C mtu игрался - бестолку.
mtu 1480
не просто так стоят, на 2621 без них были проблемы с посещением многих сайтов.
Снял дамп соединения с роутера, смотрящего в инет (к нему подключен пппое-сервер, к которому подключена кошка):
x.x.x.x - кошка
y.y.y.y - пппое-сервер
12:53:32.225367 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 66: x.x.x.x.60863 > 195.82.146.114.80: S 2784157706:2784157706(0) win 5840 <mss 1452,nop,nop,sackOK,nop,wscale 6>
12:53:32.354814 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > x.x.x.x.60863: S 264825784:264825784(0) ack 2784157707 win 5840 <mss 1460>
12:53:32.356508 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 54: x.x.x.x.60863 > 195.82.146.114.80: . ack 1 win 5840
12:53:32.357101 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 212: x.x.x.x.60863 > 195.82.146.114.80: P 1:159(158) ack 1 win 5840
12:53:32.486757 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > x.x.x.x.60863: . ack 159 win 6432
12:53:32.487048 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 833: 195.82.146.114.80 > x.x.x.x.60863: P 1:780(779) ack 159 win 6432
12:53:32.489188 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 54: x.x.x.x.60863 > 195.82.146.114.80: . ack 780 win 7011
12:53:33.490568 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 259: x.x.x.x.60863 > 195.82.146.114.80: P 159:364(205) ack 780 win 7011
12:53:33.623224 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 1506: 195.82.146.114.80 > x.x.x.x.60863: . 780:2232(1452) ack 364 win 7504
12:53:33.623268 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 1506: 195.82.146.114.80 > x.x.x.x.60863: . 2232:3684(1452) ack 364 win 7504
12:53:33.623854 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 590: y.y.y.y > 195.82.146.114: ICMP x.x.x.x unreachable - need to frag (mtu 1480), length 556
12:53:33.623860 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 590: y.y.y.y > 195.82.146.114: ICMP x.x.x.x unreachable - need to frag (mtu 1480), length 556
12:53:33.884220 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 259: x.x.x.x.60863 > 195.82.146.114.80: P 159:364(205) ack 780 win 7011
12:53:34.013850 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 60: 195.82.146.114.80 > x.x.x.x.60863: . ack 364 win 7504
12:53:34.018615 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 1506: 195.82.146.114.80 > x.x.x.x.60863: . 780:2232(1452) ack 364 win 7504
12:53:34.019080 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 590: y.y.y.y > 195.82.146.114: ICMP x.x.x.x unreachable - need to frag (mtu 1480), length 556
12:53:34.810497 00:1f:12:14:e6:36 > 00:15:17:ab:6a:7e, ethertype IPv4 (0x0800), length 1506: 195.82.146.114.80 > x.x.x.x.60863: . 780:2232(1452) ack 364 win 7504
12:53:34.810919 00:15:17:ab:6a:7e > 00:1f:12:14:e6:36, ethertype IPv4 (0x0800), length 590: y.y.y.y > 195.82.146.114: ICMP x.x.x.x unreachable - need to frag (mtu 1480), length 556
почему они упорно шлют размер 1506, хотя запрашиваем 1480?
