vadislaus Posted March 2, 2010 Posted March 2, 2010 (edited) Привет всем! Есть сервер с сетевыми картами Intel 82576, драйвер: ethtool -i eth0 driver: igb version: 2.1.1 firmware-version: 1.4-3 модуль igb грузится со следующими параметрами: options igb IntMode=3,3 RSS=4,4 VMDQ=4,4 QueuePairs=0,0 При просмотре ethtool -S eth0 tx_queue_0_packets: 37188815606 tx_queue_0_bytes: 27483174263095 tx_queue_0_restart: 1605 tx_queue_1_packets: 0 tx_queue_1_bytes: 0 rx_queue_0_packets: 56725607685 rx_queue_0_bytes: 36201030789217 rx_queue_0_drops: 0 rx_queue_0_csum_err: 1409 rx_queue_0_alloc_failed: 0 rx_queue_1_packets: 0 rx_queue_1_bytes: 0 rx_queue_1_drops: 0 rx_queue_1_csum_err: 0 rx_queue_1_alloc_failed: 0 Ядро - 2.6.31 Вопрос, почему очереди не работают? lspci -v 01:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01) Subsystem: Super Micro Computer Inc Device 0100 Flags: bus master, fast devsel, latency 0, IRQ 16 Memory at fafe0000 (32-bit, non-prefetchable) Memory at fafc0000 (32-bit, non-prefetchable) I/O ports at ec00 Memory at fafbc000 (32-bit, non-prefetchable) Expansion ROM at faf80000 [disabled] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+ Capabilities: [70] MSI-X: Enable+ Count=10 Masked- Capabilities: [a0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [150] Alternative Routing-ID Interpretation (ARI) Capabilities: [160] Single Root I/O Virtualization (SR-IOV) Kernel driver in use: igb Kernel modules: igb 01:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01) Subsystem: Super Micro Computer Inc Device 0100 Flags: bus master, fast devsel, latency 0, IRQ 17 Memory at faf20000 (32-bit, non-prefetchable) Memory at faf00000 (32-bit, non-prefetchable) I/O ports at e880 Memory at faefc000 (32-bit, non-prefetchable) Expansion ROM at faec0000 [disabled] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+ Capabilities: [70] MSI-X: Enable+ Count=10 Masked- Capabilities: [a0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [150] Alternative Routing-ID Interpretation (ARI) Capabilities: [160] Single Root I/O Virtualization (SR-IOV) Kernel driver in use: igb Kernel modules: igb Edited March 2, 2010 by vadislaus Вставить ник Quote
Умник Posted March 3, 2010 Posted March 3, 2010 options igb IntMode=3,3 RSS=4,4 VMDQ=4,4 QueuePairs=0,0 IntMode и VMDQ попробуйте убрать. Вставить ник Quote
Jugernault Posted March 17, 2010 Posted March 17, 2010 Есть сервер с сетевыми картами Intel 82576...Трафик ip или pppoe? - Нечто похоже наблюдаю с pppoe трафиком.Описание проблемы и обсуждение здесь. Вставить ник Quote
