Начались непонятные проблемы с exim.
При попытке отправить скольконить бобльшое письмо (с аттачем) - конект к серверу отваливается по таймауту.
15:57:41   437 host in rfc1413_hosts? yes (matched "*")
15:57:41   437 doing ident callback
15:57:46   437 ident connection to 92.243.69.252 failed: Connection timed out
15:57:46   437 sender_fullhost = [92.243.69.252]
15:57:46   437 sender_rcvhost = [92.243.69.252]
15:57:46   437 Process 437 is handling incoming connection from [92.243.69.252]
15:57:46   437 host in host_lookup? yes (matched "*")
15:57:46   437 looking up host name for 92.243.69.252
15:57:46   437 DNS lookup of 252.69.243.92.in-addr.arpa (PTR) succeeded
15:57:46   437 IP address lookup yielded 92.243.69.252.addr.datapoint.ru
15:57:46   437 gethostbyname2(af=inet6) returned 3 (NO_RECOVERY)
15:57:46   437 gethostbyname2 looked up these IP addresses:
15:57:46   437   name=92.243.69.252.addr.datapoint.ru address=92.243.69.252
15:57:46   437 checking addresses for 92.243.69.252.addr.datapoint.ru
15:57:46   437   92.243.69.252 OK
15:57:46   437 sender_fullhost = 92.243.69.252.addr.datapoint.ru
[92.243.69.252]
15:57:46   437 sender_rcvhost = 92.243.69.252.addr.datapoint.ru
([92.243.69.252])
15:57:46   437 set_process_info:   437 handling incoming connection from
92.243.69.252.addr.datapoint.ru [92.243.69.252]
15:57:46   437 host in host_reject_connection? no (option unset)
15:57:46   437 host in sender_unqualified_hosts? no (option unset)
15:57:46   437 host in recipient_unqualified_hosts? no (option unset)
15:57:46   437 host in helo_verify_hosts? no (option unset)
15:57:46   437 host in helo_try_verify_hosts? no (option unset)
15:57:46   437 host in helo_accept_junk_hosts? no (option unset)
15:57:46   437 expanding: $smtp_active_hostname ESMTP Exim $version_number
$tod_full
15:57:46   437    result: fs1.tinconet.ru ESMTP Exim 4.69 Tue, 02 Mar 2010
15:57:46 +0300
15:57:46   437 SMTP>> 220 fs1.tinconet.ru ESMTP Exim 4.69 Tue, 02 Mar 2010
15:57:46 +0300
15:57:46   437 Process 437 is ready for new message
15:57:46   437 smtp_setup_msg entered
15:57:46   437 SMTP<< EHLO goletsa
15:57:46   437 sender_fullhost = 92.243.69.252.addr.datapoint.ru (goletsa)
[92.243.69.252]
15:57:46   437 sender_rcvhost = 92.243.69.252.addr.datapoint.ru ([92.243.69.252]
helo=goletsa)
92.243.69.252.addr.datapoint.ru (goletsa) [92.243.69.252]
15:57:46   437 host in pipelining_advertise_hosts? yes (matched "*")
15:57:46   437 host in auth_advertise_hosts? yes (matched "*")
15:57:46   437 host in tls_advertise_hosts? no (option unset)
15:57:46   437 SMTP>> 250-fs1.tinconet.ru Hello 92.243.69.252.addr.datapoint.ru
[92.243.69.252]
15:57:46   437 250-SIZE 10485760
15:57:46   437 250-PIPELINING
15:57:46   437 250 HELP
15:57:46   437 SMTP<< MAIL FROM:<Goletsa@mail.ru> SIZE=7128027
15:57:46   437 spool directory space = 30796104K inodes = 60944174 check_space =
0K inodes = 0 msg_size = 7133027
15:57:46   437 using ACL "acl_check_mail"
15:57:46   437 processing "accept"
15:57:46   437 accept: condition test succeeded
15:57:46   437 SMTP>> 250 OK
15:57:46   437 SMTP<< RCPT TO:<goletsa@gmail.com>
15:57:46   437 using ACL "acl_check_rcpt"
15:57:46   437 check hosts = :
15:57:46   437 host in ":"? no (end of list)
15:57:46   437 accept: condition test failed
15:57:46   437 processing "deny"
15:57:46   437 check domains = +local_domains
15:57:46   437 gmail.com in "@:localhost:tinconet.ru"? no (end of list)
15:57:46   437 gmail.com in "+local_domains"? no (end of list)
15:57:46   437 deny: condition test failed
15:57:46   437 check domains = !+local_domains
15:57:46   437 cached no match for +local_domains
15:57:46   437 cached lookup data = NULL
15:57:46   437 gmail.com in "!+local_domains"? yes (end of list)
15:57:46   437 check local_parts = ^[./|] : ^.*[@%!`#&?] : ^.*/\\.\\./
15:57:46   437 expanding: ^[./|] : ^.*[@%!`#&?] : ^.*/\\.\\./
15:57:46   437    result: ^[./|] : ^.*[@%!`#&?] : ^.*/\.\./
15:57:46   437 goletsa in "^[./|] : ^.*[@%!`#&?] : ^.*/\.\./"? no (end of
list)
15:57:46   437 check local_parts = postmaster
15:57:46   437 goletsa in "postmaster"? no (end of list)
15:57:46   437 check !acl = acl_local_deny_exceptions
15:57:46   437 using ACL "acl_local_deny_exceptions"
15:57:46   437 check hosts = ${if
exists{/etc/exim4/host_local_deny_exceptions}{/etc/exim4/host_local_deny_excepti
ons}{}}
15:57:46   437 expanding: /etc/exim4/host_local_deny_exceptions
15:57:46   437    result: /etc/exim4/host_local_deny_exceptions
15:57:46   437 condition: exists{/etc/exim4/host_local_deny_exceptions}
15:57:46   437    result: false
15:57:46   437 skipping: result is not used
15:57:46   437 expanding: ${if
ons}{}}
15:57:46   437 host in ""? no (end of list)
15:57:46   437 check senders = ${if
exists{/etc/exim4/sender_local_deny_exceptions}{/etc/exim4/sender_local_deny_exc
eptions}{}}
15:57:46   437 expanding: /etc/exim4/sender_local_deny_exceptions
15:57:46   437    result: /etc/exim4/sender_local_deny_exceptions
15:57:46   437 condition: exists{/etc/exim4/sender_local_deny_exceptions}
eptions}{}}
15:57:46   437 Goletsa@mail.ru in ""? no (end of list)
exists{/etc/exim4/local_host_whitelist}{/etc/exim4/local_host_whitelist}{}}
15:57:46   437 expanding: /etc/exim4/local_host_whitelist
15:57:46   437    result: /etc/exim4/local_host_whitelist
15:57:46   437 condition: exists{/etc/exim4/local_host_whitelist}
exists{/etc/exim4/local_sender_whitelist}{/etc/exim4/local_sender_whitelist}{}}
15:57:46   437 expanding: /etc/exim4/local_sender_whitelist
15:57:46   437    result: /etc/exim4/local_sender_whitelist
15:57:46   437 condition: exists{/etc/exim4/local_sender_whitelist}
15:57:46   437 end of ACL "acl_local_deny_exceptions": implicit DENY
exists{/etc/exim4/local_sender_callout}{/etc/exim4/local_sender_callout}{}}
15:57:46   437 expanding: /etc/exim4/local_sender_callout
15:57:46   437    result: /etc/exim4/local_sender_callout
15:57:46   437 condition: exists{/etc/exim4/local_sender_callout}
15:57:46   437 check hosts = +relay_from_hosts
"10.5.240.0/20:92.243.69.0/24:172.16.0.0/20:192.168.0.0/16 : 127.0.0.1 :
::::1"? yes (matched "92.243.69.0/24")
15:57:46   437 host in "+relay_from_hosts"? yes (matched
"+relay_from_hosts")
15:57:46   437 check control = submission/sender_retain
15:57:46   437 SMTP>> 250 Accepted
15:57:47   437 SMTP<< DATA
15:57:47   437 SMTP>> 354 Enter message, ending with "." on a line by itself
15:57:47   437 search_tidyup called
15:57:47   437 host in ignore_fromline_hosts? no (option unset)
15:57:47   437 >>Headers received:
15:57:47   437 Date: Tue, 2 Mar 2010 15:57:30 +0300
15:57:47   437 From: Alexey Golets <Goletsa@mail.ru>
15:57:47   437 X-Mailer: Voyager (v4.0.18.4) Professional
15:57:47   437 Reply-To: Alexey Golets <Goletsa@mail.ru>
15:57:47   437 X-Priority: 3 (Normal)
15:57:47   437 Message-ID: <1893043634.20100302155730@mail.ru>
15:57:47   437 To: goletsa@gmail.com
15:57:47   437 Subject: dsad
15:57:47   437 MIME-Version: 1.0
15:57:47   437 Content-Type: multipart/mixed;
15:57:47   437  boundary="----------C9C730EBABBAE"
15:57:47   437
15:57:47   437 address match: subject=Goletsa@mail.ru pattern=*@+local_domains
15:57:47   437 mail.ru in "@:localhost:tinconet.ru"? no (end of list)
15:57:47   437 mail.ru in "+local_domains"? no (end of list)
15:57:47   437 Goletsa@mail.ru in "*@+local_domains"? no (end of list)
pattern=*@smtp.tinconet.ru
15:57:47   437 mail.ru in "smtp.tinconet.ru"? no (end of list)
15:57:47   437 Goletsa@mail.ru in "*@smtp.tinconet.ru"? no (end of list)
15:57:47   437 rewritten sender = Goletsa@mail.ru
15:57:47   437 rewrite_one_header: type=F:
15:57:47   437 rewrite_one_header: type=R:
15:57:47   437 rewrite_one_header: type=T:
15:57:47   437 >>Headers after rewriting and local additions:
15:57:47   437 F From: Alexey Golets <Goletsa@mail.ru>
15:57:47   437 R Reply-To: Alexey Golets <Goletsa@mail.ru>
15:57:47   437 I Message-ID: <1893043634.20100302155730@mail.ru>
15:57:47   437 T To: goletsa@gmail.com
15:57:47   437
ТУТ КЛИЕНТ ОТВАЛИВАЕТСЯ ПО ТАЙМАУТУ
15:57:47   437
15:58:58   437 Data file written for message 1NmRfX-000073-0C
15:58:58   437 expanding: ${tod_full}
15:58:58   437    result: Tue, 02 Mar 2010 15:58:58 +0300
15:58:58   437 condition: def:sender_rcvhost
15:58:58   437    result: true
15:58:58   437 expanding: from $sender_rcvhost
15:58:58   437
15:58:58   437    result: from 92.243.69.252.addr.datapoint.ru ([92.243.69.252]
helo=goletsa)
15:58:58   437
15:58:58   437 condition: def:sender_ident
15:58:58   437    result: false
15:58:58   437 expanding: $sender_ident
15:58:58   437 skipping: result is not used
15:58:58   437 expanding: from ${quote_local_part:$sender_ident}
15:58:58   437 condition: def:sender_helo_name
15:58:58   437 expanding: (helo=$sender_helo_name)
15:58:58   437
15:58:58   437    result: (helo=)
15:58:58   437
15:58:58   437 expanding: ${if def:sender_ident {from
${quote_local_part:$sender_ident} }}${if def:sender_helo_name
{(helo=$sender_helo_name)
15:58:58   437  }}
15:58:58   437 condition: def:received_protocol
15:58:58   437 expanding: with $received_protocol
15:58:58   437    result: with esmtp
15:58:58   437 condition: def:tls_cipher
15:58:58   437 expanding: ($tls_cipher)
15:58:58   437
15:58:58   437    result: ()
15:58:58   437
15:58:58   437 condition: def:sender_address
15:58:58   437 expanding: (envelope-from <$sender_address>)
15:58:58   437
15:58:58   437    result: (envelope-from <Goletsa@mail.ru>)
15:58:58   437
15:58:58   437 condition: def:received_for
15:58:58   437  for $received_for
15:58:58   437  for goletsa@gmail.com
15:58:58   437 expanding: Received: ${if def:sender_rcvhost {from
$sender_rcvhost
15:58:58   437  }{${if def:sender_ident {from ${quote_local_part:$sender_ident}
}}${if def:sender_helo_name {(helo=$sender_helo_name)
15:58:58   437  }}}}by $primary_hostname ${if def:received_protocol {with
$received_protocol}} ${if def:tls_cipher {($tls_cipher)
15:58:58   437  }}(Exim $version_number)
15:58:58   437  ${if def:sender_address {(envelope-from <$sender_address>)
15:58:58   437  }}id $message_exim_id${if def:received_for {
15:58:58   437  for $received_for}}
15:58:58   437    result: Received: from 92.243.69.252.addr.datapoint.ru
([92.243.69.252] helo=goletsa)
15:58:58   437  by fs1.tinconet.ru with esmtp (Exim 4.69)
15:58:58   437  (envelope-from <Goletsa@mail.ru>)
15:58:58   437  id 1NmRfX-000073-0C
15:58:58   437 >>Generated Received: header line
15:58:58   437 P Received: from 92.243.69.252.addr.datapoint.ru ([92.243.69.252]
helo=goletsa)
15:58:58   437  for goletsa@gmail.com; Tue, 02 Mar 2010 15:58:58 +0300
15:58:58   437 using ACL "acl_check_data"
15:58:58   437 processing "deny"
15:58:58   437 check malware = *
15:58:58   437 condition: def:return_path
15:58:58   437 expanding: $return_path
15:58:58   437 expanding: MAILER-DAEMON
15:58:58   437    result: MAILER-DAEMON
15:58:58   437 expanding: X-Envelope-From: <${sender_address}>
15:58:58   437
15:58:58   437    result: X-Envelope-From: <Goletsa@mail.ru>
15:58:58   437
15:58:58   437 expanding: X-Envelope-To: <${received_for}>
15:58:58   437
15:58:58   437    result: X-Envelope-To: <>
15:58:58   437
15:58:58   437 expanding: From ${if
def:return_path{$return_path}{MAILER-DAEMON}} ${tod_bsdinbox}
15:58:58   437 ${if def:sender_address{X-Envelope-From: <${sender_address}>
15:58:58   437 }}${if def:received_for{X-Envelope-To: <${received_for}>
15:58:58   437 }}
15:58:58   437    result: From MAILER-DAEMON Tue Mar 02 15:58:58 2010
15:58:58   437 X-Envelope-From: <Goletsa@mail.ru>
15:58:58   437
15:58:58   437 waiting for data on socket
15:58:59   437 deny: condition test failed
15:58:59   437 processing "accept"
15:58:59   437 accept: condition test succeeded
15:58:59   437 unspool_mbox(): unlinking
'/var/spool/exim4/scan/1NmRfX-000073-0C/1NmRfX-000073-0C.eml'
15:58:59   437 calling local_scan(); timeout=300
15:58:59   437 expanding: $primary_hostname
15:58:59   437    result: fs1.tinconet.ru
15:58:59   437 LOG: MAIN
15:58:59   437   SA: Debug: SATruncBodyCond expand returned: '0'
15:58:59   437   SA: Action: check skipped due to message size (7148281 bytes)
and SATruncBodyCond expanded to false (Message-Id: 1NmRfX-000073-0C). From
<Goletsa@mail.ru> (host=92.243.69.252.addr.datapoint.ru [92.243.69.252]) for
goletsa@gmail.com
15:58:59   437 local_scan() returned 0 NULL
15:58:59   437 expanding: ${tod_full}
15:58:59   437    result: Tue, 02 Mar 2010 15:58:59 +0300
15:58:59   437 Writing spool header file
15:58:59   437 Size of headers = 741
15:58:59   437   <= Goletsa@mail.ru H=92.243.69.252.addr.datapoint.ru (goletsa)
[92.243.69.252] P=esmtp S=7149022 id=1893043634.20100302155730@mail.ru
15:58:59   437 SMTP>> 250 OK id=1NmRfX-000073-0C
15:58:59   437 search_tidyup called
15:58:59   437 Sender: Goletsa@mail.ru
15:58:59   437 Recipients:
15:58:59   437   goletsa@gmail.com
15:58:59   437 forked delivery process 837
15:58:59   437 Process 437 is ready for new message
15:58:59   437 smtp_setup_msg entered
15:58:59   437 SMTP<< RSET
15:58:59   437 SMTP>> 250 Reset OK
15:58:59   437 SMTP>> 421 fs1.tinconet.ru lost input connection
15:58:59   437 LOG: smtp_connection MAIN
15:58:59   437   SMTP connection from 92.243.69.252.addr.datapoint.ru (goletsa)
[92.243.69.252] lost
До этого пару месяцев когда настраивал в связке с ahamvi-new и sa - все работало.
Debian Lenny, все ставилось со стандартных репозиторий.
