Схема сети:
Internet ---[em0 ---router em1]--DES3828--[em0 ---accounter2----em1]--DGS1224T--clients
Сервер:
[root@ /]# uname -a
FreeBSD accounter2.x.ru 7.2-RELEASE FreeBSD 7.2-RELEASE #1: Fri Oct 30 07:40:53 MSK 2009
2xXEON 5350 (8 ядер)
В нём имеем:
2 сетевые карты Intel 1000 Pro 6.9.6 1Гбит/c, в последствии обновлены до 6.9.21
На сервере крутится:
mpd с шифрованием
ng_car (шейпинг)
mysql
utm5
Проблема в следующем, всё живет где то до потока в 100Мбит/с, дальше потихоньку начинает умирать,
top -SP:
531 processes: 20 running, 496 sleeping, 14 waiting, 1 lock
CPU 0:  0.0% user,  0.0% nice, 71.8% system,  2.3% interrupt, 26.0% idle
CPU 1:  2.3% user,  0.0% nice, 69.5% system,  2.3% interrupt, 26.0% idle
CPU 2:  3.1% user,  0.0% nice, 66.9% system,  2.4% interrupt, 27.6% idle
CPU 3:  3.9% user,  0.0% nice, 70.1% system,  0.0% interrupt, 26.0% idle
CPU 4:  0.8% user,  0.0% nice, 61.5% system,  1.5% interrupt, 36.2% idle
CPU 5:  0.8% user,  0.0% nice, 62.3% system,  0.8% interrupt, 36.2% idle
CPU 6:  3.1% user,  0.0% nice, 56.3% system,  2.3% interrupt, 38.3% idle
CPU 7:  2.3% user,  0.0% nice, 64.3% system,  0.0% interrupt, 33.3% idle
Mem: 1908M Active, 249M Inact, 236M Wired, 83M Cache, 112M Buf, 19M Free
Swap: 20G Total, 1356K Used, 20G Free
  PID USERNAME  THR PRI NICE   SIZE    RES STATE  C   TIME   WCPU COMMAND
   37 root        1 128    -     0K     8K CPU1   6 575:48 55.18% em0 taskq
    2 root        1 -68    -     0K     8K sleep  2 225:56 44.38% ng_queue0
    6 root        1 -68    -     0K     8K CPU6   6 225:55 44.09% ng_queue4
    7 root        1 -68    -     0K     8K *ng_no 2 225:58 43.46% ng_queue5
    3 root        1 -68    -     0K     8K sleep  3 225:55 43.16% ng_queue1
    4 root        1 -68    -     0K     8K CPU4   4 225:58 42.38% ng_queue2
    9 root        1 -68    -     0K     8K CPU5   5 225:52 42.09% ng_queue7
    5 root        1 -68    -     0K     8K CPU0   2 225:53 41.80% ng_queue3
    8 root        1 -68    -     0K     8K CPU7   7 225:54 41.16% ng_queue6
   38 root        1 -68    -     0K     8K CPU2   2 201:35 38.28% em1 taskq
   12 root        1 171 ki31     0K     8K RUN    6 908:35 37.16% idle: cpu6
   13 root        1 171 ki31     0K     8K RUN    5 890:05 34.67% idle: cpu5
   14 root        1 171 ki31     0K     8K RUN    4 869:03 33.69% idle: cpu4
   11 root        1 171 ki31     0K     8K RUN    7 912:26 33.40% idle: cpu7
   16 root        1 171 ki31     0K     8K CPU2   2 851:14 30.08% idle: cpu2
   15 root        1 171 ki31     0K     8K RUN    3 864:26 29.39% idle: cpu3
   18 root        1 171 ki31     0K     8K RUN    0 766:18 25.98% idle: cpu0
   17 root        1 171 ki31     0K     8K RUN    1 671:13 24.66% idle: cpu1
   19 root        1 -68    -     0K     8K RUN    2  44:11  6.15% swi4: clock sio
49171 root      367  54  -10   131M 51968K select 5   0:00  3.47% utm5_core
  682 root        1  96    0 59204K 16996K select 6  48:52  1.66% mpd4
3437 mysql      25  44    0  1749M  1704M ucond  3   0:00  1.66% mysqld
   21 root        1  96    -     0K     8K WAIT   5  62:12  0.00% swi1: net
   55 root        1 -68    -     0K     8K -      2   5:31  0.00% dummynet
[root@accounter2 /usr/src]# netstat -w1 -h
            input        (Total)           output
   packets  errs      bytes    packets  errs      bytes colls
       44K     0        22M        50K     0        31M     0
       42K    55        21M        47K     0        29M     0
       41K     0        21M        46K     0        30M     0
       43K     4        22M        49K     0        31M     0
       42K   164        21M        48K     0        29M     0
       41K    76        21M        47K     0        31M     0
       43K   209        22M        49K     0        32M     0
[root@accounter2 /usr/src]# netstat -w1 -h -I em0
            input          (em0)           output
       17K    21        11M        11K     0       3.6M     0
       16K    78        11M        10K     0       3.1M     0
       17K   140        12M        10K     0       3.1M     0
       16K     0        10M       9.4K     0       3.2M     0
[root@accounter2 /usr/src]# netstat -w1 -h -I em1
            input          (em1)           output
       14K     0       5.7M        19K     0        14M     0
       12K     0       4.5M        14K     0        10M     0
       13K     0       4.3M        18K     0        12M     0
       12K     0       4.6M        17K     0        12M     0
       14K     0       5.1M        18K     0        13M     0
Видно что потери на интерфейсе em0, который смотрит в сторону роутера.
что было сделано:
1. Обновлены дрова до 6.9.21
2. sysctl.conf:
kern.ipc.maxsockbuf=10485760
net.inet.ip.forwarding=1
net.graph.maxdgram=524288
net.graph.recvspace=524288
3. loader.conf:
geom_mirror_load="YES"
if_em_load="YES"
netgraph_load="YES"
ng_ipfw_load="YES"
ng_car_load="YES"
autoboot_delay="3"
kern.ipc.maxpipekva="32000000"
4. а) Отключение резалки не дает результата.
б) Ночью когда нагрузка не велика, iperfом генерил нагрузку
60К pps 40Мб/с прокачивается без ошибок.
в) на свитчах flow control выключен
5. Пробовали менять свитчи/патчкорды - улучшений нет.
sysctl -a | grep em
dev.em.0.%desc: Intel(R) PRO/1000 Network Connection 6.9.21
dev.em.0.%driver: em
dev.em.0.%location: slot=0 function=0
dev.em.0.%pnpinfo: vendor=0x8086 device=0x1096 subvendor=0x8086 subdevice=0x3484 class=0x020000
dev.em.0.%parent: pci5
dev.em.0.debug: -1
dev.em.0.stats: -1
dev.em.0.rx_int_delay: 0
dev.em.0.tx_int_delay: 66
dev.em.0.rx_abs_int_delay: 66
dev.em.0.tx_abs_int_delay: 66
dev.em.0.rx_processing_limit: 100
dev.em.1.%desc: Intel(R) PRO/1000 Network Connection 6.9.21
dev.em.1.%driver: em
dev.em.1.%location: slot=0 function=1
dev.em.1.%pnpinfo: vendor=0x8086 device=0x1096 subvendor=0x8086 subdevice=0x3484 class=0x020000
dev.em.1.%parent: pci5
dev.em.1.debug: -1
dev.em.1.stats: -1
dev.em.1.rx_int_delay: 0
dev.em.1.tx_int_delay: 66
dev.em.1.rx_abs_int_delay: 66
dev.em.1.tx_abs_int_delay: 66
dev.em.1.rx_processing_limit: 100
sysctl -a | grep forw
kern.smp.forward_roundrobin_enabled: 1
kern.smp.forward_signal_enabled: 1
net.inet.ip.forwarding: 1
net.inet.ip.fastforwarding: 1
net.inet6.ip6.forwarding: 0
sysctl -a | grep isr
net.isr.swi_count: 11055948
net.isr.drop: 0
net.isr.queued: 2976347
net.isr.deferred: 117785462
net.isr.directed: 1664621091
net.isr.count: 1781606424
net.isr.direct: 1
net.route.netisr_maxqlen: 256
Feb 19 20:28:45 accounter2 em0: Sequence errors = 0
Feb 19 20:28:45 accounter2 em0: Defer count = 0
Feb 19 20:28:45 accounter2 em0: Missed Packets = 3106231
Feb 19 20:28:45 accounter2 em0: Receive No Buffers = 8068013
Feb 19 20:28:45 accounter2 em0: Receive Length Errors = 0
Feb 19 20:28:45 accounter2 em0: Receive errors = 0
Feb 19 20:28:45 accounter2 em0: Crc errors = 0
Feb 19 20:28:45 accounter2 em0: Alignment errors = 0
Feb 19 20:28:45 accounter2 em0: Collision/Carrier extension errors = 0
Feb 19 20:28:45 accounter2 em0: RX overruns = 116026
Feb 19 20:28:45 accounter2 em0: watchdog timeouts = 0
Feb 19 20:28:45 accounter2 em0: RX MSIX IRQ = 0 TX MSIX IRQ = 0 LINK MSIX IRQ = 0
Feb 19 20:28:45 accounter2 em0: XON Rcvd = 0
Feb 19 20:28:45 accounter2 em0: XON Xmtd = 0
Feb 19 20:28:45 accounter2 em0: XOFF Rcvd = 0
Feb 19 20:28:45 accounter2 em0: XOFF Xmtd = 0
Feb 19 20:28:45 accounter2 em0: Good Packets Rcvd = 689415590
Feb 19 20:28:45 accounter2 em0: Good Packets Xmtd = 599617766
Feb 19 20:28:45 accounter2 em0: TSO Contexts Xmtd = 31
Feb 19 20:28:45 accounter2 em0: TSO Contexts Failed = 0
В последствии отключил TSO и RXCSUM
ifconfig em0 -rxcsum -tso
ifconfig em1 -rxcsum -tso
что также не дало результатов.
Сейчас уже пересобрал ядро с патчем:
ставлю http://alter.org.ua/en/soft/fbsd/netisr/
и ставлю драйвера от яндекса.....больше мыслей нет...подскажиет что делать?
P.S.
Кол-во одновременных pptp сессий ~600
В логах ничего подозрительного нет.
Edited by kirush
sysctl dev.em.0.rx_int_delay=250
sysctl dev.em.1.rx_int_delay=250
sysctl dev.em.0.tx_int_delay=250
sysctl dev.em.1.tx_int_delay=250
sysctl dev.em.0.rx_abs_int_delay=250
sysctl dev.em.1.rx_abs_int_delay=250
sysctl dev.em.0.tx_abs_int_delay=250
sysctl dev.em.1.tx_abs_int_delay=250
sysctl dev.em.0.rx_processing_limit=400
sysctl dev.em.1.rx_processing_limit=400
loader.conf
hw.em.rxd=1024
hw.em.txd=1024
начните с этого.
loader.conf
hw.em.rxd=1024
hw.em.txd=1024
начните с этого.
с этими параметрами уже игрался, не заметно разницы.
А вот в loader.conf ща запихну:
только формат там кажется такой:
hw.em.rxd="1024"
hw.em.txd="1024"
После наложения патча: http://alter.org.ua/en/soft/fbsd/netisr/
Выставления net.isr.direct=0
и выставления net.isr.maxthreads=5...8 (ставил 8, по кол-ву ядер).
Потери уменьшились, но не исчезли:
       12K    12       9.9M       9.6K     0       3.0M     0
       12K     0        10M       9.8K     0       2.7M     0
       13K     0        10M        10K     0       2.9M     0
       12K     0       9.7M        10K     0       3.1M     0
       12K    37       9.8M        11K     0       3.2M     0
       11K     0        10M       9.7K     0       3.0M     0
       11K     0       9.3M       9.8K     0       3.0M     0
       11K     0       9.3M       8.9K     0       2.7M     0
       12K     0       9.4M       9.4K     0       3.0M     0
       11K    23       8.8M       8.3K     0       2.8M     0
       12K     0       9.3M       8.7K     0       2.8M     0
как только включаю fastforwarding начинаются потери.
Edited by kirush
Попробуйте передавать правила с УТМ с помощью радиус атрибутов, а не заворачивать ng_car через ipfw, тогда процесс nq-queue должен уйти в нули. Хотя при трафике в 100 Мб должно и так работать, если не сильно накручено с правилами.
Отключение резалки не приводит к результатам.
Ну просто провода перетыкните, настройки перекиньте с одного на другой и посмотрите - останется ли эффект на конкретном сетевом выходе. Хотя более советовать ничего не буду - удачи:)
Нашел в сервере слот, воткнул туда без рамки (с креплением) Intel Pro 1000Mbit/s, подцепил к ней кабель. Потери исчезли, но пинг вырос вместо стандартных 2-3мс до 50-60мс.
Feb 20 20:33:24 accounter2 em2: Excessive collisions = 0
Feb 20 20:33:24 accounter2 em2: Sequence errors = 0
Feb 20 20:33:24 accounter2 em2: Defer count = 0
Feb 20 20:33:24 accounter2 em2: Missed Packets = 172362
Feb 20 20:33:24 accounter2 em2: Receive No Buffers = 403352
Feb 20 20:33:24 accounter2 em2: Receive Length Errors = 0
Feb 20 20:33:24 accounter2 em2: Receive errors = 0
Feb 20 20:33:24 accounter2 em2: Crc errors = 0
Feb 20 20:33:24 accounter2 em2: Alignment errors = 0
Feb 20 20:33:24 accounter2 em2: Collision/Carrier extension errors = 0
Feb 20 20:33:24 accounter2 em2: RX overruns = 4807
Feb 20 20:33:24 accounter2 em2: watchdog timeouts = 0
Feb 20 20:33:24 accounter2 em2: RX MSIX IRQ = 0 TX MSIX IRQ = 0 LINK MSIX IRQ = 0
Feb 20 20:33:24 accounter2 em2: XON Rcvd = 0
Feb 20 20:33:24 accounter2 em2: XON Xmtd = 0
Feb 20 20:33:24 accounter2 em2: XOFF Rcvd = 0
Feb 20 20:33:24 accounter2 em2: XOFF Xmtd = 0
Feb 20 20:33:24 accounter2 em2: Good Packets Rcvd = 35824657
Feb 20 20:33:24 accounter2 em2: Good Packets Xmtd = 29948788
Feb 20 20:33:24 accounter2 em2: TSO Contexts Xmtd = 0
Feb 20 20:33:24 accounter2 em2: TSO Contexts Failed = 0
почему то пакеты попадают:
в Missed Packets = 172362
в Receive No Buffers = 403352
Может заменить на какую либо сетевку 2х головую? помощней...?
Edited by kirush
яндекс-драйвера попробуйте.
драйвера от яндекса нафик, они оптимизированы для веб серверов
надо начать с обновления до стабл, мин тюниг и посм как минимизировать правила файрволла
Драйвера от яндекса пробовали не помогло.
Проблему подтвердили несколько знакомых в 7.2 с драйверами em, происходит переполнение буфера сетевой карты.
Поможет только обновление ОС.
Цитата со странички наложеного ранее патча http://alter.org.ua/ru/soft/fbsd/netisr/:
Фактически, на время обработки входящего пакета сетевая карта будет заблокирована. Это неплохо смотрится при преобладающем входящем трафике и на однопроцессорных машинах.
Аналогично, у меня при включении фастфорвардинга трафик/ппс падает раз в пять + зашкаливающие пинги итд.
п.с. Выключите фастфорвардинг.
Я бы попробовал не обновление системы, а самые свежие драйверы с сайта Интела.
Что говорит "sysctl net.inet.ip | grep intr_queue" ?
получается дрова от интела лучше работают чем родные во фре ?
пробовал дрова для igb- родные 1.4.1 - система еле едет. кол-во перевариваемых пакетов внесколько раз меньше, дрова от интела 1.8.4 работают лучше, но есть проблема со стабильностью
Какого рода проблемы со стабильностью? Вот какраз сегодня ночью воткнул ЕТ-шку двухголовую в один из бордеров на 7.2, драйвера 1.8.4
            input         (igb0)           output
       31K     0        21M        21K     0       9.7M     0
       32K     0        22M        22K     0        11M     0
       30K     0        21M        21K     0        10M     0
       31K     0        21M        21K     0        11M     0
       30K     0        21M        22K     0        11M     0
       30K     0        21M        22K     0        10M     0
       31K     0        22M        22K     0        10M     0
       31K     0        22M        24K     0        12M     0
       31K     0        22M        24K     0        11M     0
       29K     0        21M        22K     0        11M     0
       30K     0        22M        21K     0        10M     0
       31K     0        21M        23K     0        12M     0
       30K     0        22M        22K     0        10M     0
       29K     0        21M        22K     0        10M     0
       28K     0        20M        23K     0        12M     0
       29K     0        22M        23K     0        12M     0
       28K     0        21M        20K     0       9.5M     0
sysctl.conf пустой
# cat /boot/loader.conf
if_igb_load="YES"
hw.igb.rxd=4096
hw.igb.txd=4096
hw.igb.enable_aim=1
hw.igb.low_latency=1000
hw.igb.ave_latency=2000
hw.igb.bulk_latency=4000
hw.igb.rx_process_limit=400
hw.igb.fc_setting=0
hw.igb.lro=0
машина ребутилась временами, даже сейчас вылетает в panic
Fatal trap 12: page fault while in kernel mode
cpuid = 0; apic id = 00
fault virtual address   = 0x6bee2000
fault code              = supervisor read, page not present
instruction pointer     = 0x20:0x806fbef1
stack pointer           = 0x28:0xd2231bc4
frame pointer           = 0x28:0xd2231bd8
code segment            = base 0x0, limit 0xfffff, type 0x1b
                        = DPL 0, pres 1, def32 1, gran 1
processor eflags        = interrupt enabled, resume, IOPL = 0
current process         = 26 (irq257: igb0)
trap number             = 12
panic: page fault
cpuid = 0
Uptime: 15m24s
что это за параметр ?
hw.igb.fc_setting=0
кстати в текущий момент трафика через сетевушку бежит также порядка 30кппс, но посм что будет вечером, сейчас проц загружен проц на 70.
стоит core2duo 3Ghz
Edited by Mechanic
дрова от интела - это и есть родные :)
просто на сайте интела они более свежие, чем в релизе freebsd.
core2 quad Q6600, 7.0-RELEASE, em 6.7.3-yandex, intel PRO 1000PT Dual:
            input          (em0)           output
       51K     0        32M        59K     0        38M     0
       49K     0        30M        58K     0        37M     0
       49K     0        31M        57K     0        37M     0
       49K     0        30M        57K     0        37M     0
       50K     0        31M        57K     0        37M     0
       49K     0        31M        57K     0        36M     0
И это далеко не предел возможностей.
Топикстартеру - купить нормальную сетевуху. Да, и вынести всякие UTM, mysql и иже с ними на отдельный сервер, этому на роутере не место.
Edited by dsk
Решил проблему установкой FreeBSD 8.0
Проблема можно сказать исчезла:
[root@accounter /usr/src]# netstat -w1 -h
53K 0 27M 52K 0 30M 0
51K 0 26M 51K 0 29M 0
56K 0 28M 54K 0 31M 0
51K 0 26M 53K 0 31M 0
53K 0 28M 53K 0 32M 0
в часы пик до 60М
Загрузка системы около 10-15%, interrupt не более 7-10%.
UTM/mysql уносить - жирно ему будет. Достаточно мощный сервер,
2xXeon3.0 53я серия.
На фряхе 8 всплыли другие проблемы:
1. kernel: ifa_del_loopback_route: deletion failed в логах, но это вроде решено в STABLE
2. Дурацкая проблема:
date
Wed Feb 24 19:26:18 MSK 2010
в логах, dhcpd пишет правильное время
kernel пишет UTCшное
netup-debug правильное
netup-radius UTCшное
и куда рыть не понятно.
timezone заменено на +3
Edited by kirush
date
Это скорее всего не проблема, а фича.
Про dhcpd можно прочитать на официальном сайте, там было рассказано почему так и почему менять не будут.
а сколько трафика может пропустить сетевушка сидящая на pci шине ?
текущая Intel на материнке пропускает порядка 300мбит суммарного трафика и порядка 80кппс( в обе стороны), может быть это ее предел ?
Edited by Mechanic
