sanoka Posted February 25, 2019 Posted February 25, 2019 Из-за чего могла закончится память? Вроде везде пишут, что BGP использует память RP. Для проверки попробую вместо fullview ограничиться дефолтом. Вставить ник Quote
Telesis Posted February 25, 2019 Posted February 25, 2019 show platform software memory forwarding-manager fp active brief Вставить ник Quote
sanoka Posted February 25, 2019 Posted February 25, 2019 15 минут назад, Telesis сказал: show platform software memory forwarding-manager fp active brief asr1002_test#show platform software memory forwarding-manager fp active brief module allocated requested allocs frees ------------------------------------------------------------------------------ AOM asynchronous co... 36220 36188 4 0 AOM basic data 40772 40740 5 1 AOM batch 161 137 3 0 AOM links array 41804347 41803563 98 0 AOM object 95004342 95003558 98 0 AOM tree node 86871137 86842209 3668 52 AOM tree root 40209 40177 201 197 AOM update state 280212 280180 17 13 AOM uplink update node 16218 16186 1428 1424 ATM LIB Info_st 80 64 2 0 ATM RX Buffers 344 336 1 0 BFD Offload 4848 4840 1 0 BFD Session 64 56 1 0 CENT RC 40 32 1 0 CENT RC vrf 40 32 1 0 CENT auto tunnel 40 32 1 0 CENT dc_id site_ip map 40 32 1 0 CENT local channel db 40 32 1 0 CENT multi nexthop map 40 32 1 0 CENT neighbor chann... 40 32 1 0 CENT site prefix 40 32 1 0 CPP ACL 116 108 1 0 CPP ACL 0 0 1 1 CPP ACL 14092 14084 1 0 CPP AEM DEFERRED EX... 179 155 3 0 CPP AEM SUB-TASK CHUNK 37082 37050 504 500 CPP AEM TASK CHUNK 24790 24758 502 498 CPP BQS RM 12312 12288 3 0 CPP CEF MPLS Gtrie 26928940 23081924 1011855 530978 CPP CEF MPLS Infras... 0 0 14 14 CPP CEF MPLS Load B... 187 139 83 77 CPP CEF MPLS MPLS 161 105 7 0 CPP CEF MPLS Unicas... 88 64 3 0 CPP Datapath Servic... 4104 4096 1 0 CPP Debug Log 88 80 1 0 CPP Debug Log 88 80 1 0 CPP ERSPAN 0 0 80663 80663 CPP ESS IPSUB 160 144 2 0 CPP EVC Static 1032 1024 1 0 CPP Ethernet Static 1144 1128 2 0 CPP Exmem Manager 7640287 7634783 694 6 CPP Features 4558088 4545720 6910 5364 CPP Frame Relay Static 188 164 3 0 CPP GIC Initialization 49640 49560 10 0 CPP GIC MSG CNTX CHUNK 65754 65722 4 0 CPP HA 1122 1034 11 0 CPP HASH CHUNK 98514 98482 17 13 CPP I/F DB 64 24 5 0 CPP ICMP 32840 32824 2 0 CPP IPMC CHUNK NAME 738 594 18 0 CPP IPMC GLOBAL 360 352 1 0 CPP IPMC GTRIE NODE 64 56 1 0 CPP Internal I/F 128 120 1 0 CPP L2MC CHUNK NAME 738 594 18 0 CPP L2MC Unknown 1376 1368 1 0 CPP L2MC Unknown 64 56 1 0 CPP LSM CHUNK NAME 720 576 18 0 CPP LSM Unknown 1344 1336 1 0 CPP List Hdr Chunk 114902 114870 4 0 CPP Metadata 4104 4096 1 0 CPP OTV Static 572 564 1 0 CPP PBR 4104 4096 1 0 CPP Platform 12 4 1 0 CPP QOS 28 12 2 0 CPP QOS 1060 1036 3 0 CPP RR Manager 1220 1180 5 0 CPP RRM Client CTX ... 16604 16572 5649 5645 CPP SBC 32 24 1 0 CPP SBS async CTX C... 1627 1595 4 0 CPP SIA 184 160 3 0 CPP SLM 1024 164 140 3 0 CPP SLM 128 40151 40111 5 0 CPP SLM 256 72919 72879 5 0 CPP SLM 32 15574 15534 5 0 CPP SLM 512 138455 138415 5 0 CPP SLM 64 23766 23726 5 0 CPP SMI 4108 4084 3 0 CPP SMI Client CTX ... 7388 7356 4 0 CPP SPA MARMOT 65616 65600 2 0 CPP Stats Block 9920 9600 40 0 CPP Stile 8344 8320 3 0 CPP UIDB REMOTE API... 175 151 3 0 CPP XC Static 568 560 1 0 CPP uIDB Config 112 96 2 0 CPP uIDB RM Initial... 1032 1024 1 0 Cloud Web Security ... 4104 4096 1 0 Common Identity Dat... 4104 4096 1 0 Connected Enterprise 4104 4096 1 0 Crypto-device 32 16 2 0 DEVOBJ 76268 76140 16 0 DPSS feature object 52 36 2 0 EPBR FIA 40 32 1 0 EPBR feature object 40 32 1 0 Embedded Packet Cap... 4104 4096 1 0 Enhanced Policy Bas... 4104 4096 1 0 Ethernet CFM 1032 1024 1 0 FCID 376 280 17 5 FHS SG Filter 52 36 2 0 FHS Temp 4104 4096 1 0 Flow Metadata 4104 4096 1 0 Flow Metric Engine 4104 4096 1 0 IPHC LIB Info_st 52 44 1 0 IPHC RX Buffers 200 192 1 0 Identity Infrastruc... 4104 4096 1 0 L2 forwarding table 100 84 2 0 L2 mcast fwd olist 100 84 2 0 LISP Source Filter ... 64 56 1 0 LSM replicate list 88 72 2 0 MPLS Interface 88 72 2 0 Metric Mediation Agent 4104 4096 1 0 OSLib DEbug Flags O... 14120 11720 300 0 OSLib EVM Objects 2204 2100 22 9 OSLib Hash Lib Objects 131168 131160 1 0 OSLib IdMgr Objects 1065016 1065008 1 0 OSLib Misc Objects 528 264 33 0 OSLib Mutex Objects 16920 12408 564 0 OSLib R/W Lock Objects 3120 2080 130 0 OSLib SMC Objects 48 32 36043 36041 One Firewall 5136 5120 2 0 PLU CFG 6218180 3355036 2938121 2580228 QFP PfR Static Memory 1168 1152 2 0 SMC CHANNEL CHUNK 34477 34429 6 0 SMC MESSAGE CHUNK 450773 450741 4 0 SSLVPN 536 520 2 0 SSLVPN Connection 232 200 4 0 SSLVPN Gateway 84 68 2 0 Summary 372377383 361716447 8526407 7193790 Tunnel Flow 328 280 10 4 Virtual Private LAN... 1032 1024 1 0 acl 8795 8259 104 37 acl-bind 320 280 5 0 acl-ref 64 56 1 0 adj 63752 60600 408 14 alg sip blacklist 64 56 1 0 alg sip processor 64 56 1 0 alg sip timer 64 56 1 0 alg vtcp service 64 56 1 0 atom-disp 224 192 4 0 atom-imp 112 96 2 0 atom-xconnect 224 192 4 0 bridge-domain 64 56 1 0 bundle 88 72 2 0 cc-config 200 160 7 2 cdllib 1668 1660 4 3 cgm-lib 1464 1112 72 28 chunk 52724700 52702132 3348 527 cidb-dir 64 56 1 0 cidb-session 64 56 1 0 cond_dbg feature in... 76 60 2 0 cws-tun-radius-attrib 64 56 1 0 cws-ubit 64 56 1 0 cxsc-avc 64 56 1 0 cxsc-avc-complete 64 56 1 0 cxsc-avc-group 64 56 1 0 cxsc-avc-group-comp... 64 56 1 0 cxsc-domain-cfg 64 56 1 0 cxsc-init 64 56 1 0 cxsc-intf-table 64 56 1 0 cxsc-intf-table-domain 64 56 1 0 cxsc-pcap-cfg 64 56 1 0 cxsc-pcap-drop-capt... 64 56 1 0 cxsc-policy-complete 64 56 1 0 cxsc-proposition 64 56 1 0 cxsc-proposition-su... 64 56 1 0 cxsc-row 64 56 1 0 cxsc-syslog-cfg 64 56 1 0 cxsc-table 64 56 1 0 dpidb-config 44768 44008 184 89 dsp-resource 48 40 1 0 dsp-session_leg 48 40 1 0 ecfm lemp 76 60 2 0 eoam-cfm-efp 64 56 1 0 eoam-cfm-mp-cfg 64 56 1 0 eoam-cfm-port-cfg 64 56 1 0 eos-choice 128 104 3 0 ess-accounting 92 76 2 0 ess-cgm 92 76 2 0 ess-drl 92 76 2 0 ess-ffr 92 76 2 0 ess-ipv6-accounting 92 76 2 0 ess-l4r 92 76 2 0 ess-pbhk 92 76 2 0 ess-segment 64 56 1 0 ether-dplb-info 64 56 1 0 ether-dplb-tbl 12 4 1 0 eventutil 117395 117075 56 16 fman-infra 491604 491588 2 0 fman-infra-avl 15808 13832 247 0 fman-infra-cce 4136 4120 2 0 fman-infra-dpidb 1071 799 34 0 fman-infra-ipc 20374 14286 761 0 fman-infra-qos 5876 5668 26 0 fman-ipsec 80 64 2 0 fmd-filter-binding 64 56 1 0 frr 112 96 2 0 frr primary path 112 96 2 0 fw-param-map 621 605 2 0 fw-zone 25 17 1 0 gal-check-choice 56 48 1 0 hash-alg 200 152 16 10 imgr-avl 300 292 1 0 imgr-cfg-util 43264 43256 9 8 imgr-hapi-lib 0 0 5040 5040 imgr-ipsecmgr 1111048 1111040 1 0 imgr-n2 112 104 10065 10064 imgr-policy 8204 8196 1 0 imgr-static 1460 1220 30 0 intf-list 88 72 2 0 iphc-profile 64 56 1 0 l2 control protocol 64 56 1 0 label 112 96 2 0 li_md 64 56 1 0 link-oam 64 56 1 0 lisp 88 72 2 0 lmep table 76 60 2 0 loadbalance 1528 1432 1927071 1927059 loadbalance-map 88 72 2 0 lookup 472 360 20 6 ma table 76 60 2 0 mfr-bundle 76 60 2 0 mlp-bundle 76 60 2 0 mma-action 64 56 1 0 mma-attr-class-group 64 56 1 0 mma-fdef 64 56 1 0 mma-fmp-rtp-param 64 56 1 0 mma-interface-feature 64 56 1 0 mma-monitor 64 56 1 0 mp prefix info 92 76 2 0 n2mcp-async 40 32 5030 5029 nat-maxent 0 0 22286 22286 nat-pap-settings 300 284 2 0 nat64 CGM class 64 56 1 0 nat64 adjacency 64 56 1 0 nat64 alias 64 56 1 0 nat64 dynamic mapping 64 56 1 0 nat64 dynamic mappi... 64 56 1 0 nat64 intf 64 56 1 0 nat64 limit 64 56 1 0 nat64 logging 64 56 1 0 nat64 map-t bmr 64 56 1 0 nat64 map-t dmr 64 56 1 0 nat64 pool 64 56 1 0 nat64 pool ID 64 56 1 0 nat64 pool range 64 56 1 0 nat64 replication 64 56 1 0 nat64 service 64 56 1 0 nat64 static mapping 64 56 1 0 nat64 static mappin... 64 56 1 0 nat64 timeout 64 56 1 0 onefw identity- dir 64 56 1 0 onefw identity- ses... 64 56 1 0 otv-decap 112 96 2 0 otv-encap 112 96 2 0 otv-site-isis 64 56 1 0 pbr_if_cfg 64 56 1 0 pbr_routemap 128 112 2 0 pbr_routemap_seq 64 56 1 0 pfr if bind 92 76 2 0 pfr nbar appl 92 76 2 0 plugin-config 80 64 4 2 punt-interface 0 0 3 3 push-counter 88 72 2 0 qos-choice 48 40 1 0 rl2gp-cfg 76 60 2 0 rmep table 76 60 2 0 route-pfx 44240172 40393188 2459777 1978904 route-subblock 46 30 2 0 route-tbl 624 528 12 0 sbc-call 131084 131076 1 0 sbc-global 196 140 7 0 sbc-media-fork-sess 65548 65540 1 0 sbc-media-pool 64 56 1 0 sbc-pinhole 65548 65540 1 0 sbc-sbl-adjacency 65548 65540 1 0 sbc-sbl-pfilter 524300 524292 1 0 sbc-sfx_register 262156 262148 1 0 sbc-tdm 131084 131076 1 0 spa-config 40 24 2 0 sslinfra_aaa 800 680 15 0 sslinfra_config 179 147 4 0 sslinfra_context 1032 1024 1 0 sslinfra_session 24 8 2 0 static appl sig 92 76 2 0 stile-fia 64 56 1 0 stile-interface 64 56 1 0 stile_xdr_config 64 56 1 0 trccfg 256 248 5 4 uipeer 9288 9264 9 6 unknown 16 8 1 0 urpf-config 64 56 1 0 urpf-list 15472 10392 3555 2920 vasi-pair 8012 8004 1 0 vc-config 4032 3808 28 0 vrf vrf 224 184 5 0 vxlan-decap 112 96 2 0 vxlan-encap 112 96 2 0 wccp-acl 64 56 1 0 wccp-ce 64 56 1 0 wccp-exl-in-intf 64 56 1 0 wccp-hash 64 56 1 0 wccp-intf 64 56 1 0 wccp-svc 64 56 1 0 Вставить ник Quote
zhenya` Posted February 26, 2019 Posted February 26, 2019 в драм QFP явно fib таблица лежит. Вставить ник Quote
sanoka Posted February 26, 2019 Posted February 26, 2019 8 минут назад, zhenya` сказал: в драм QFP явно fib таблица лежит. А можно поподробнее для простых смертных? Что делать то? Убрал один fullview с циски, но ей от этого стало только хуже, пришлось ребутить. После ребута уже с одним fullview все равно память загружена под завязку. Сегодня постараюсь убрать второй fullview. Вставить ник Quote
zhenya` Posted February 26, 2019 Posted February 26, 2019 ну число best path то не убавилось особо. попробуйте отфильтровать /24 ) Вставить ник Quote
sanoka Posted February 26, 2019 Posted February 26, 2019 2 минуты назад, zhenya` сказал: ну число best path то не убавилось особо. попробуйте отфильтровать /24 ) Сейчас уже отфильтровано /16, боюсь представить что будет, если фильтр отключу. Вставить ник Quote
zhenya` Posted February 26, 2019 Posted February 26, 2019 34 минуты назад, sanoka сказал: Сейчас уже отфильтровано /16, боюсь представить что будет, если фильтр отключу. show ip cef summ show ip route summ Вставить ник Quote
Telesis Posted February 26, 2019 Posted February 26, 2019 show platform software status control-processor brief monitor platform software process f0 show log P/S выкладывайте в spoiler Вставить ник Quote
sanoka Posted February 26, 2019 Posted February 26, 2019 Скрытый текст asr1002_test#sh ip cef summary IPv4 CEF is enabled for distributed and running VRF Default 212553 prefixes (212553/0 fwd/non-fwd) Table id 0x0 Database epoch: 2 (212553 entries at this epoch) asr1002_test#sh ip route summary IP routing table name is default (0x0) IP routing table maximum-paths is 32 Route Source Networks Subnets Replicates Overhead Memory (bytes) connected 0 20 0 1440 3600 static 7 71 0 5616 14040 application 0 0 0 0 0 bgp xxxxx 47 212325 0 15290784 38226960 External: 212372 Internal: 0 Local: 0 internal 3800 9186680 Total 3854 212416 0 15297840 47431280 asr1002_test#show platform software status control-processor brief Load Average Slot Status 1-Min 5-Min 15-Min RP0 Healthy 0.21 0.16 0.25 ESP0 Healthy 0.00 0.00 0.02 SIP0 Healthy 0.00 0.00 0.00 Memory (kB) Slot Status Total Used (Pct) Free (Pct) Committed (Pct) RP0 Healthy 3874484 3228648 (83%) 645836 (17%) 2990740 (77%) ESP0 Healthy 969068 954192 (98%) 14876 ( 2%) 871412 (90%) SIP0 Healthy 471812 335640 (71%) 136172 (29%) 302808 (64%) CPU Utilization Slot CPU User System Nice Idle IRQ SIRQ IOwait RP0 0 2.59 2.19 0.00 94.90 0.09 0.19 0.00 ESP0 0 3.69 19.08 0.00 77.12 0.00 0.09 0.00 SIP0 0 2.90 1.30 0.00 95.80 0.00 0.00 0.00 top - 04:44:07 up 23:16, 0 users, load average: 0.30, 0.07, 0.03 Tasks: 103 total, 1 running, 102 sleeping, 0 stopped, 0 zombie Cpu(s): 3.6%us, 20.2%sy, 0.0%ni, 76.2%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st Mem: 969068k total, 962284k used, 6784k free, 4032k buffers Swap: 0k total, 0k used, 0k free, 175600k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 9391 root 20 0 1019m 481m 38m S 19.5 50.9 278:06.91 fman_fp_image 9623 root 20 0 47812 7644 3400 S 2.0 0.8 17:57.52 hman 7499 root 20 0 386m 9.8m 4332 S 1.0 1.0 11:29.89 cman_fp 8033 root 20 0 594m 70m 22m S 0.7 7.5 6:42.79 cpp_cp_svr 4 root -50 0 0 0 0 S 0.3 0.0 5:36.80 sirq-timer/0 12 root -50 0 0 0 0 S 0.3 0.0 4:56.62 sirq-rcu/0 27364 binos 20 0 2652 1260 1004 R 0.3 0.1 0:00.03 top 1 root 20 0 2152 636 548 S 0.0 0.1 0:08.45 init 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root -50 0 0 0 0 S 0.0 0.0 0:00.00 sirq-high/0 5 root -50 0 0 0 0 S 0.0 0.0 0:00.38 sirq-net-tx/0 6 root -50 0 0 0 0 S 0.0 0.0 0:44.90 sirq-net-rx/0 7 root -50 0 0 0 0 S 0.0 0.0 0:00.00 sirq-block/0 8 root -50 0 0 0 0 S 0.0 0.0 0:00.00 sirq-block-iopo 9 root -50 0 0 0 0 S 0.0 0.0 0:01.98 sirq-tasklet/0 10 root -50 0 0 0 0 S 0.0 0.0 0:00.00 sirq-sched/0 11 root -50 0 0 0 0 S 0.0 0.0 0:00.01 sirq-hrtimer/0 Log Buffer (4096 bytes): NG: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 25 23:17:02.049: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 25 23:27:12.058: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 25 23:37:22.074: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 25 23:47:32.116: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 25 23:57:42.135: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 00:07:52.162: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 00:18:02.182: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 00:28:12.186: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 00:38:22.210: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 00:48:32.223: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 00:58:42.231: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% *Feb 26 01:08:52.253: %PLATFORM-4-ELEMENT_WARNING: R0/0: smand: ESP/0: Committed Memory value 91% exceeds warning level 90% Вставить ник Quote
Telesis Posted February 26, 2019 Posted February 26, 2019 (edited) версия софта какая? (возможно у вас bug CSCtj47922 или CSCuq31464) PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 9391 root 20 0 1019m 481m 38m S 19.5 50.9 278:06.91 fman_fp_image При том, что у вас сейчас не FullView, память задействована на 50% Edited February 26, 2019 by Telesis Вставить ник Quote
sanoka Posted February 26, 2019 Posted February 26, 2019 37 минут назад, Telesis сказал: версия софта какая? Cisco IOS XE Software, Version 03.16.05.S - Extended Support Release Cisco IOS Software, ASR1000 Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc2) Compiled Thu 19-Jan-17 09:41 by mcpre Вставить ник Quote
Telesis Posted February 28, 2019 Posted February 28, 2019 On 2/26/2019 at 10:46 AM, sanoka said: Сейчас уже отфильтровано /16, боюсь представить что будет, если фильтр отключу. Reboot после настройки делали? Если не делали то есть вероятность, что память просто не высвободилась. 1) Сделайте reboot 2) Ждем загрузки BGP (с фильтрами) 3) show platform software process list F0 (cman_fp смотрите за процессом сколько памяти) 4) Повторяйте (каждый день, несколько дней) пункт 3, и наблюдаем не будет расти размер памяти процесса. 5) Если идет каждодневный рост, тогда стоит подумать и сменить софт. Вставить ник Quote
floop Posted February 28, 2019 Posted February 28, 2019 Был один роутер, который мог раз в полгода "зависнуть". Ребут восстанавливал работоспособность. Оказалось, враги постоянно долбятся на него по ssh и из-за этого память медленно но верно "утекала". Решили проблему навесив ACL для ssh. Вставить ник Quote
sanoka Posted February 28, 2019 Posted February 28, 2019 Как ни странно, но после ребута память частично освободилась. До отключения одного fullview ребут не помогал. Скрытый текст asr1002_test#show platform resources **State Acronym: H - Healthy, W - Warning, C - Critical Resource Usage Max Warning Critical State ---------------------------------------------------------------------------------------------------- RP0 (ok, active) H Control Processor 10.18% 100% 90% 95% H DRAM 2221MB(58%) 3783MB 90% 95% H ESP0(ok, active) H Control Processor 21.80% 100% 90% 95% H DRAM 751MB(79%) 946MB 90% 95% H QFP H TCAM 8cells(0%) 65536cells 45% 55% H DRAM 127367KB(48%) 262144KB 80% 90% H IRAM 10453KB(7%) 131072KB 80% 90% H SIP0 H Control Processor 4.30% 100% 90% 95% H DRAM 328MB(71%) 460MB 90% 95% H asr1002_test#show ip cef summary IPv4 CEF is enabled for distributed and running VRF Default 216356 prefixes (216356/0 fwd/non-fwd) Table id 0x0 Database epoch: 2 (216356 entries at this epoch) asr1002_test#show ip route summary IP routing table name is default (0x0) IP routing table maximum-paths is 32 Route Source Networks Subnets Replicates Overhead Memory (bytes) connected 0 18 0 1296 3240 static 7 71 0 5616 14040 application 0 0 0 0 0 bgp xxxxx 47 216138 0 15565320 38913300 External: 216185 Internal: 0 Local: 0 internal 3828 9344180 Total 3882 216227 0 15572232 48274760 Но все равно кажется, что слишком много памяти занято. Сейчас на циске только один частично зафильтрованный fullview. Получается, что она не тянет даже 1 fullview. Если у кого-нибудь есть аналогичная циска, выложите пожалуйста статистику использования памяти. Вставить ник Quote
floop Posted February 28, 2019 Posted February 28, 2019 Скрытый текст show platform resources **State Acronym: H - Healthy, W - Warning, C - Critical Resource Usage Max Warning Critical State ---------------------------------------------------------------------------------------------------- RP0 (ok, active) H Control Processor 9.99% 100% 90% 95% H DRAM 2653MB(70%) 3783MB 90% 95% H ESP0(ok, active) W Control Processor 23.23% 100% 90% 95% H DRAM 847MB(89%) 946MB 90% 95% H QFP W TCAM 190cells(0%) 65536cells 45% 55% H DRAM 209824KB(80%) 262144KB 80% 90% W IRAM 92817KB(70%) 131072KB 80% 90% H SIP0 H Control Processor 2.80% 100% 90% 95% H DRAM 319MB(69%) 460MB 90% 95% H show ip cef summary IPv4 CEF is enabled for distributed and running VRF Default 29738 prefixes (29738/0 fwd/non-fwd) Table id 0x0 Database epoch: 2 (29738 entries at this epoch) show ip route summary IP routing table name is default (0x0) IP routing table maximum-paths is 32 Route Source Networks Subnets Replicates Overhead Memory (bytes) connected 0 18 0 1296 3240 static 0 9 0 648 1620 application 0 0 0 0 0 bgp ***** 3200 26398 0 2131056 5327640 External: 29598 Internal: 0 Local: 0 internal 987 1366140 Total 4187 26425 0 2133000 6698640 Вставить ник Quote
Telesis Posted February 28, 2019 Posted February 28, 2019 On 2/25/2019 at 1:28 PM, sanoka said: ASR1002/ESP5 совсем упустили, с ESP5 про full view стоит забыть. Вставить ник Quote
melmaxnvk Posted April 7, 2019 Posted April 7, 2019 (edited) До недавнего времени на ASR1002 было 2 FullView+IX, все работало стабильно: #sh platform Chassis type: ASR1002 Slot Type State Insert time (ago) --------- ------------------- --------------------- ----------------- 0 ASR1002-SIP10 ok 2w3d 0/0 4XGE-BUILT-IN ok 2w3d R0 ASR1002-RP1 ok, active 2w3d F0 ASR1000-ESP5 ok, active 2w3d P0 ASR1002-PWR-AC ok 2w3d P1 ASR1002-PWR-AC ok 2w3d Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 07120202 12.2(33r)XNC R0 08011017 12.2(33r)XNC F0 07091401 12.2(33r)XNC #sh ver Cisco IOS XE Software, Version 03.13.06.S - Extended Support Release Cisco IOS Software, ASR1000 Software (PPC_LINUX_IOSD-ADVENTERPRISE-M), Version 15.4(3)S6, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Thu 04-Aug-16 05:12 by mcpre ... System image file is "bootflash:asr1000rp1-adventerprise.03.13.06.S.154-3.S6-ext.bin" ... cisco ASR1002 (2RU) processor (revision 2RU) with 1661134K/6147K bytes of memory. Processor board ID FOX1449G28F 4 Gigabit Ethernet interfaces 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 7798783K bytes of eUSB flash at bootflash:. #sh platform software status control-processor brief Load Average Slot Status 1-Min 5-Min 15-Min RP0 Healthy 0.09 0.13 0.10 ESP0 Healthy 0.25 0.25 0.28 SIP0 Healthy 0.00 0.00 0.00 Memory (kB) Slot Status Total Used (Pct) Free (Pct) Committed (Pct) RP0 Healthy 3874476 3599488 (93%) 274988 ( 7%) 2964020 (77%) ESP0 Healthy 969060 924360 (95%) 44700 ( 5%) 875560 (90%) SIP0 Healthy 471804 288640 (61%) 183164 (39%) 194444 (41%) CPU Utilization Slot CPU User System Nice Idle IRQ SIRQ IOwait RP0 0 9.89 3.89 0.00 85.81 0.19 0.19 0.00 ESP0 0 5.59 16.68 0.00 68.03 0.00 0.19 9.49 SIP0 0 1.60 0.90 0.00 97.49 0.00 0.00 0.00 #sh ip bgp sum BGP table version is 783548831, main routing table version 783548831 751213 network entries using 108174672 bytes of memory 3206114 path entries using 256489120 bytes of memory 506091/117364 BGP path/bestpath attribute entries using 80974560 bytes of memory 217753 BGP AS-PATH entries using 8569260 bytes of memory 1 BGP ATTR_SET entries using 40 bytes of memory 8999 BGP community entries using 550600 bytes of memory 293 BGP extended community entries using 10250 bytes of memory 600 BGP route-map cache entries using 21600 bytes of memory 0 BGP filter-list cache entries using 0 bytes of memory BGP using 454790062 total bytes of memory 1603116 received paths for inbound soft reconfiguration BGP activity 5555003/4803790 prefixes, 57673971/54467857 paths, scan interval 60 secs Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd BGP IX 4 ASN1 151234 24875 783548637 0 0 1w0d 108583 BGP FullView-1 4 ASN2 1455358 24866 783548637 0 0 1w0d 750890 BGP FullView-2 4 ASN3 3217965 12548 783548708 0 0 1w0d 743514 #sh ip route summary IP routing table name is default (0x0) IP routing table maximum-paths is 32 Route Source Networks Subnets Replicates Overhead Memory (bytes) connected 0 815 0 58720 146700 static 0 11 0 792 1980 application 0 0 0 0 0 ospf 100 14 131 0 10440 26680 Intra-area: 0 Inter-area: 5 External-1: 0 External-2: 140 NSSA External-1: 0 NSSA External-2: 0 bgp ASN 197548 553626 0 54084568 135211320 External: 751174 Internal: 0 Local: 0 internal 7326 29936220 Total 204888 554583 0 54154520 165322900 Недавно потребовалось принять ещё 250К маршрутов, вот тут то память и закончилась. %COMMON_FIB-3-NOMEM: Memory allocation failure for validating prefix in IPv4 CEF [0x10C3A2B4] (fatal) (8308 subsequent failures). %COMMON_FIB-4-DISABLING: IPv4 CEF is being disabled due to a fatal error. Временно зафильтровал префиксы /24. После фильтрации до подключения нового bgp получилось вот так: #sh platform resources **State Acronym: H - Healthy, W - Warning, C - Critical Resource Usage Max Warning Critical State ---------------------------------------------------------------------------------------------------- RP0 (ok, active) W Control Processor 12.00% 100% 90% 95% H DRAM 3515MB(92%) 3783MB 90% 95% W ESP0(ok, active) W Control Processor 21.18% 100% 90% 95% H DRAM 896MB(94%) 946MB 90% 95% W QFP H TCAM 488cells(0%) 65536cells 45% 55% H DRAM 179743KB(68%) 262144KB 80% 90% H IRAM 58656KB(44%) 131072KB 80% 90% H SIP0 H Control Processor 2.61% 100% 90% 95% H DRAM 281MB(61%) 460MB 90% 95% H #sh ip route sum IP routing table name is default (0x0) IP routing table maximum-paths is 32 Route Source Networks Subnets Replicates Overhead Memory (bytes) connected 0 770 0 55480 138600 static 0 11 0 792 1980 application 0 0 0 0 0 ospf 100 14 133 0 10584 27048 Intra-area: 0 Inter-area: 5 External-1: 0 External-2: 142 NSSA External-1: 0 NSSA External-2: 0 bgp ASN 92489 295236 0 27916200 69790500 External: 387725 Internal: 0 Local: 0 internal 6400 16197060 Total 98903 296150 0 27983056 86155188 #show ip cef summary IPv4 CEF is enabled for distributed and running VRF Default 389180 prefixes (389179/1 fwd/non-fwd) Table id 0x0 Database epoch: 3 Epoch statistics: Epoch 2: 235 entries Epoch 3: 389180 entries #sh ip bgp sum BGP table version is 1211191, main routing table version 1211191 751490 network entries using 108214560 bytes of memory 2354999 path entries using 188399920 bytes of memory 386102/69620 BGP path/bestpath attribute entries using 61776320 bytes of memory 217459 BGP AS-PATH entries using 8553734 bytes of memory 1 BGP ATTR_SET entries using 40 bytes of memory 9029 BGP community entries using 556964 bytes of memory 297 BGP extended community entries using 10362 bytes of memory 640 BGP route-map cache entries using 23040 bytes of memory 0 BGP filter-list cache entries using 0 bytes of memory BGP using 367534900 total bytes of memory 1604904 received paths for inbound soft reconfiguration BGP activity 6332438/5580939 prefixes, 61837613/59482614 paths, scan interval 60 secs Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd BGP IX 4 ASN1 34618 2708 1211021 0 0 20:36:19 109781 BGP FullView-1 4 ASN2 252566 2703 1211021 0 0 20:36:18 321753 BGP FullView-2 4 ASN3 601660 1363 1211021 0 0 20:36:20 318550 После принятия 250К доп. маршрутов #sh platform resources **State Acronym: H - Healthy, W - Warning, C - Critical Resource Usage Max Warning Critical State ---------------------------------------------------------------------------------------------------- RP0 (ok, active) H Control Processor 28.24% 100% 90% 95% H DRAM 3212MB(84%) 3783MB 90% 95% H ESP0(ok, active) C Control Processor 24.00% 100% 90% 95% H DRAM 902MB(95%) 946MB 90% 95% C QFP H TCAM 484cells(0%) 65536cells 45% 55% H DRAM 189727KB(72%) 262144KB 80% 90% H IRAM 59889KB(45%) 131072KB 80% 90% H SIP0 H Control Processor 2.80% 100% 90% 95% H DRAM 280MB(60%) 460MB 90% 95% H #sh ip route sum IP routing table name is default (0x0) IP routing table maximum-paths is 32 Route Source Networks Subnets Replicates Overhead Memory (bytes) connected 0 763 0 55048 137340 static 0 11 0 792 1980 application 0 0 0 0 0 ospf 100 14 132 0 10512 26864 Intra-area: 0 Inter-area: 5 External-1: 0 External-2: 141 NSSA External-1: 0 NSSA External-2: 0 bgp ASN 92436 581528 0 48525408 121313520 External: 673964 Internal: 0 Local: 0 internal 9626 28106780 Total 102076 582434 0 48591760 149586484 #sh ip cef sum IPv4 CEF is enabled for distributed and running VRF Default 675432 prefixes (675431/1 fwd/non-fwd) Table id 0x0 Database epoch: 2 (675432 entries at this epoch) #sh ip bgp sum BGP table version is 132243828, main routing table version 132243828 1039328 network entries using 149663232 bytes of memory 2932006 path entries using 234560480 bytes of memory 387399/70950 BGP path/bestpath attribute entries using 61983840 bytes of memory 217564 BGP AS-PATH entries using 8571476 bytes of memory 1 BGP ATTR_SET entries using 40 bytes of memory 9261 BGP community entries using 597808 bytes of memory 433 BGP extended community entries using 21990 bytes of memory 255 BGP route-map cache entries using 9180 bytes of memory 0 BGP filter-list cache entries using 0 bytes of memory BGP using 455408006 total bytes of memory 1609096 received paths for inbound soft reconfiguration BGP activity 1611084/571754 prefixes, 7807047/4875041 paths, scan interval 60 secs Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd BGP IX 4 ASN1 272597 53122 132243722 0 0 2w2d 109846 BGP FullView-1 4 ASN2 3129045 53099 132243722 0 0 2w2d 322163 BGP IX NEW-Main 4 ASN4 142942 5735 132243722 0 0 3d14h 285958 BGP IX NEW Backup 4 ASN4 186915 3692 132243722 0 0 2d07h 285987 BGP FullView-2 4 ASN3 9447900 28418 132243722 0 0 2w3d 318945 Пока ищу варианты, чтобы убрать фильтрацию префиксов /24 и уменьшить потребление памяти DRAM в ESP. Edited April 7, 2019 by melmaxnvk Вставить ник Quote
Zerozed Posted July 30, 2019 Posted July 30, 2019 В 28.02.2019 в 10:33, Telesis сказал: совсем упустили, с ESP5 про full view стоит забыть. Если fw обрабатывается через rp, то какая разница Esp5 там или Esp10, если и там и там Rp1? Вставить ник Quote
zhenya` Posted July 30, 2019 Posted July 30, 2019 Fib лежит в dram на esp. На разных есп разный объём dram. Собственно ошибка про cef это про esp. Вставить ник Quote
Direxx Posted September 26, 2023 Posted September 26, 2023 Здравствуйте! Возникла такая же проблема с памятью ESP0 DRAM #show platform resources **State Acronym: H - Healthy, W - Warning, C - Critical Resource Usage Max Warning Critical State ---------------------------------------------------------------------------------------------------- RP0 (ok, active) H Control Processor 10.02% 100% 90% 95% H DRAM 3281MB(86%) 3783MB 90% 95% H ESP0(ok, active) C Control Processor 24.16% 100% 90% 95% H DRAM 939MB(99%) 946MB 90% 95% C QFP H TCAM 20cells(0%) 65536cells 45% 55% H DRAM 191949KB(73%) 262144KB 80% 90% H IRAM 62677KB(47%) 131072KB 80% 90% H SIP0 H Control Processor 3.30% 100% 90% 95% H DRAM 319MB(69%) 460MB 90% 95% H В связи с отвалом одного оператора, пришлось временно поднять фильтрацию до /24, обычно /23 использую, у юзеров банки отвалились После восстановления вернул обратно настройки на /23, но DRAM не освободилась Есть возможность без перезагрузки освободить её? Вставить ник Quote
