Появилась сетевая Intel® PRO/1000 PT Quad
разъем PCI-E 4x, вставил в PCI-E 16x
ОС
# uname -a
FreeBSD maskarad.hol.net.ua 7.0-RELEASE FreeBSD 7.0-RELEASE #0: Sun Nov  9 15:42:07 EET 2008     root@maskarad.hol.net.ua:/usr/src/sys/i386/compile/MASKARAD  i386
Сетевая не завелась
none1@pci0:4:0:0:       class=0x020000 card=0x10a08086 chip=0x10a08086 rev=0x06 hdr=0x00
    vendor     = 'Intel Corporation'
    device     = '82571EB PRO/1000 AT Quad Port Bypass Adapter'
    class      = network
    subclass   = ethernet
none2@pci0:4:0:1:       class=0x020000 card=0x10a08086 chip=0x10a08086 rev=0x06 hdr=0x00
    class      = network
    subclass   = ethernet
none3@pci0:5:0:0:       class=0x020000 card=0x10a08086 chip=0x10a08086 rev=0x06 hdr=0x00
    class      = network
    subclass   = ethernet
none4@pci0:5:0:1:       class=0x020000 card=0x10a08086 chip=0x10a08086 rev=0x06 hdr=0x00
    class      = network
    subclass   = ethernet
Явно не хватает драйверов. решил их обновить. Скачал их с офф. сайта
Прочил readme, распаковал архив , начал установку
# make
Warning: Object directory not changed from original /usr/home/xxx/EM/em-6.9.21/src
@ -> /usr/src/sys
machine -> /usr/src/sys/i386/include
cc -O2 -fno-strict-aliasing -pipe  -D_KERNEL -DKLD_MODULE -std=c99 -nostdinc   -I. -I@ -I@/contrib/altq -finline-limit=8000 --param inline-unit-growth=100 --param large-function-growth=1000 -fno-common  -mno-align-long-strings -mpreferred-stack-boundary=2  -mno-mmx -mno-3dnow -mno-sse -mno-sse2 -mno-sse3 -ffreestanding -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes  -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual  -Wundef -Wno-pointer-sign -fformat-extensions -c if_em.c
if_em.c: In function 'em_ioctl':
if_em.c:1268: error: 'IFCAP_WOL' undeclared (first use in this function)
if_em.c:1268: error: (Each undeclared identifier is reported only once
if_em.c:1268: error: for each function it appears in.)
if_em.c:1270: error: 'IFCAP_WOL_MCAST' undeclared (first use in this function)
if_em.c:1272: error: 'IFCAP_WOL_MAGIC' undeclared (first use in this function)
if_em.c: In function 'em_setup_interface':
if_em.c:3169: error: 'IFCAP_WOL' undeclared (first use in this function)
if_em.c: In function 'em_enable_wakeup':
if_em.c:5010: error: 'IFCAP_WOL_MAGIC' undeclared (first use in this function)
if_em.c:5013: error: 'IFCAP_WOL_MCAST' undeclared (first use in this function)
if_em.c:5035: error: 'IFCAP_WOL' undeclared (first use in this function)
*** Error code 1
Stop in /usr/home/hedg/EM/em-6.9.21/src.
Почему не хотят собираться драйвера?
Обновился до 7.2 Stable. После чего драйвера скомпилировались нормально.
Толку от этого мало, т.к. драйвера на сетевые так и не встали.
Погуглил очень плотно и выяснил....
Карты с chip=0x10a08086 являются инженерными образцами и не должны продоваться где либо. Была куплена "левую" карточка и разработчики Intel не включили её поддержку в свой драйвер.
Для того чтобы ее завести можно воспользоваться патчем, который добавит новый device id..
Вот содержимое патча(на всякий случай):
 Index: src/sys/dev/em/e1000_api.c
RCS file: /ncvs/src/sys/dev/em/e1000_api.c,v
retrieving revision 1.7
diff -u -b -p -r1.7 e1000_api.c
--- src/sys/dev/em/e1000_api.c    25 Apr 2008 21:19:39 -0000    1.7
+++ src/sys/dev/em/e1000_api.c    2 Jul 2008 09:31:06 -0000
@@ -200,6 +200,7 @@ s32 e1000_set_mac_type(struct e1000_hw *
    case E1000_DEV_ID_82571EB_SERDES_DUAL:
    case E1000_DEV_ID_82571EB_SERDES_QUAD:
    case E1000_DEV_ID_82571EB_QUAD_COPPER:
+    case E1000_DEV_ID_82571EB_QUAD_COPPER_A0:
    case E1000_DEV_ID_82571PT_QUAD_COPPER:
    case E1000_DEV_ID_82571EB_QUAD_FIBER:
    case E1000_DEV_ID_82571EB_QUAD_COPPER_LP:
Index: src/sys/dev/em/e1000_hw.h
RCS file: /ncvs/src/sys/dev/em/e1000_hw.h,v
diff -u -b -p -r1.7 e1000_hw.h
--- src/sys/dev/em/e1000_hw.h    25 Apr 2008 21:19:40 -0000    1.7
+++ src/sys/dev/em/e1000_hw.h    2 Jul 2008 09:31:06 -0000
@@ -85,6 +85,7 @@ struct e1000_hw;
#define E1000_DEV_ID_82571EB_SERDES_DUAL      0x10D9
#define E1000_DEV_ID_82571EB_SERDES_QUAD      0x10DA
#define E1000_DEV_ID_82571EB_QUAD_COPPER      0x10A4
+#define E1000_DEV_ID_82571EB_QUAD_COPPER_A0   0x10A0
#define E1000_DEV_ID_82571PT_QUAD_COPPER      0x10D5
#define E1000_DEV_ID_82571EB_QUAD_FIBER       0x10A5
#define E1000_DEV_ID_82571EB_QUAD_COPPER_LP   0x10BC
Index: src/sys/dev/em/if_em.c
RCS file: /ncvs/src/sys/dev/em/if_em.c,v
retrieving revision 1.194
diff -u -b -p -r1.194 if_em.c
--- src/sys/dev/em/if_em.c    21 May 2008 21:06:17 -0000    1.194
+++ src/sys/dev/em/if_em.c    2 Jul 2008 09:31:06 -0000
@@ -161,6 +161,8 @@ static em_vendor_info_t em_vendor_info_a
                        PCI_ANY_ID, PCI_ANY_ID, 0},
    { 0x8086, E1000_DEV_ID_82571EB_QUAD_COPPER,
+    { 0x8086, E1000_DEV_ID_82571EB_QUAD_COPPER_A0,
+                        PCI_ANY_ID, PCI_ANY_ID, 0},
    { 0x8086, E1000_DEV_ID_82571EB_QUAD_COPPER_LP,
    { 0x8086, E1000_DEV_ID_82571EB_QUAD_FIBER,
@@ -765,6 +767,7 @@ em_attach(device_t dev)
        break;
    case E1000_DEV_ID_82546GB_QUAD_COPPER_KSP3:
                 /* if quad port adapter, disable WoL on all but port A */
P.S. патч написал butcher, за что ему огромное спасибо!
P.P.S. ссылки по этой же теме : opennet1 и opennet2
P.P.P.S. Пропатчил новые драйвера(em-6.9.21) установил модулем на FreeBSD_7.2 - все завелось.
На другом компе с FreeBSD_7.0 пропатчил родные дрова (/usr/src/sys/dev/em) пересобрал ядро, все побежало.
Всем СПАСИБО!
Edited by HEDG
