сервер core2 2g-ram 7.2-stable mpd-5.3 авторизирует абонов по впн
в произвольные моменты времени резко падает нагрузка на сервак, при этом в логи сыпится:
Dec 13 18:46:31 vpn1 named[706]: zone 93.17.172.in-addr.arpa/IN: expired
Dec 13 18:46:31 vpn1 named[706]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Dec 13 18:46:31 vpn1 named[706]: internal_send: 172.17.7.238#1048: Cannot allocate memory
Dec 13 18:46:31 vpn1 named[706]: client 172.17.7.238#1048: error sending response: out of memory
Dec 13 18:46:33 vpn1 named[706]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Dec 13 18:46:33 vpn1 named[706]: internal_send: 172.17.25.135#2191: Cannot allocate memory
Dec 13 18:46:33 vpn1 named[706]: client 172.17.25.135#2191: error sending response: out of memory
Dec 13 18:46:33 vpn1 named[706]: internal_send: 172.17.23.90#57408: Cannot allocate memory
Dec 13 18:46:33 vpn1 named[706]: client 172.17.23.90#57408: error sending response: out of memory
Dec 13 18:46:33 vpn1 named[706]: client 172.17.7.249#2052: RFC 1918 response from Internet for 100.0.168.192.in-addr.arpa
Dec 13 18:46:34 vpn1 named[706]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Dec 13 18:46:34 vpn1 named[706]: internal_send: 172.17.41.235#58671: Cannot allocate memory
Dec 13 18:46:34 vpn1 named[706]: client 172.17.41.235#58671: error sending response: out of memory
Dec 13 18:46:34 vpn1 named[706]: internal_send: 172.17.6.65#57155: Cannot allocate memory
Dec 13 18:46:34 vpn1 named[706]: client 172.17.6.65#57155: error sending response: out of memory
Dec 13 18:46:35 vpn1 named[706]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Dec 13 18:46:35 vpn1 named[706]: internal_send: 172.17.25.118#1039: Cannot allocate memory
Dec 13 18:46:35 vpn1 named[706]: client 172.17.25.118#1039: error sending response: out of memory
Dec 13 18:46:36 vpn1 named[706]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Dec 13 18:46:36 vpn1 named[706]: internal_send: 172.17.1.79#1184: Cannot allocate memory
Dec 13 18:46:36 vpn1 named[706]: client 172.17.1.79#1184: error sending response: out of memory
Dec 13 18:46:36 vpn1 named[706]: internal_send: 172.17.7.54#1120: Cannot allocate memory
Dec 13 18:46:36 vpn1 named[706]: client 172.17.7.54#1120: error sending response: out of memory
в нагруженном состоянии на серваке порядка 1600 тунелей, нагрузка через систему:
vpn1# netstat -w1
input (Total) output
packets errs bytes packets errs bytes colls
132788 0 82429863 133843 0 82143876 0
132924 0 82853996 133610 0 82397692 0
134337 0 83504176 135056 0 82989681 0
129983 0 81360653 131326 0 81751244 0
135276 0 84584953 135347 0 83855501 0
131939 0 82680803 132919 0 82501962 0
132729 0 82407504 132578 0 81725834 0
135104 0 84102419 135941 0 84072619 0
в момент падения:
vpn1# netstat -w1
47561 0 19894349 43975 0 17316086 0
37890 0 14746444 32076 0 11387847 0
44885 0 18912972 42120 0 16540037 0
4294397324 0 4290235287 4293999575 0 3082238743 0
52641 0 22699653 48193 0 19408857 0
46632 0 19441579 43797 0 17073324 0
55104 0 25131819 51532 0 22161942 0
60101 0 27425528 56687 0 24581312 0
63389 0 29640334 62691 0 28344628 0
61336 0 28927874 58124 0 25913584 0
70338 0 35238633 68626 0 33309069 0
75735 0 39508105 74700 0 37791982 0
82399 0 43422007 81692 0 42083385 0
81473 0 42263045 78364 0 39268485 0
77293 0 39657427 75915 0 37603753 0
68060 0 33875781 64890 0 30782561 0
70272 0 35361143 67732 0 32878204 0
79683 0 42892711 77012 0 39951303 0
63205 0 31004529 58708 0 27579331 0
62244 0 30004338 58508 0 26658620 0
очень непонятны строчки 4294397324 0 4290235287 4293999575 0 3082238743 0
значение susctl
net.inet.icmp.icmplim=100
#kern.maxfilesperproc=32768
#kern.maxfiles=65536
kern.ipc.somaxconn=2048
kern.ipc.maxsockets=100000
kern.ipc.nmbclusters=100000
#net.inet.ip.intr_queue_maxlen=10000
#net.inet.ip.fw.debug=0
net.inet.ip.fw.dyn_max=20480
net.inet.ip.fw.dyn_buckets=4096
net.inet.ip.fw.one_pass=1 # for dummynet+nat !!!!
##net.inet.ip.fastforwarding=1
#net.inet.tcp.msl=7500
#net.inet.tcp.rfc1323=1
net.inet.ip.dummynet.expire=0 #delete ocheredi
net.inet.ip.dummynet.hash_size=1024
net.inet.ip.dummynet.max_chain_len=1024
net.inet.ip.dummynet.io_fast=1
net.inet.ip.portrange.first=8192
net.inet.ip.portrange.last=65535
net.inet.ip.portrange.randomized=0
net.inet.ip.intr_queue_maxlen=4096
net.inet.ip.redirect=1 #prin 0 normalno ne rabotaet
#net.inet.udp.maxdgram=57344
net.inet.udp.recvspace=65536
net.inet.tcp.sendspace=65536
net.inet.tcp.recvspace=65536
net.graph.maxdgram=128000
net.graph.recvspace=128000
net.local.stream.recvspace=65535
net.local.stream.sendspace=65535
# Intel® PRO/1000 Network Connection 6.9.6
dev.em.0.rx_int_delay=250
dev.em.0.tx_int_delay=250
dev.em.0.rx_abs_int_delay=250
dev.em.0.tx_abs_int_delay=250
dev.em.0.rx_processing_limit=400
net.inet.tcp.blackhole=2
net.inet.udp.blackhole=1
в чем может быть причина ?
Илья прав, 100% проблема в пямяти. Посмотри как греется память в момент падения и, прогони тесты memtest86
оч странно конечно, теоретически если битая память, то проблема всплывала бы постоянно
а так в моменты увеличения нагрузки
причем вначале стояла 1 линейка в 1 гиг и такие проблемы присутствовали, а сейчас я добавил еще 1 линейку в 1 гиг
Я, же написал. Посмотри какая температура. У меня была аналогичная ситуация, до бланки было не дотронутся. В моменты простоя всё работала нормально =).
И ещё одна возможная проблема. Планки памяти одинаковой частоты стоят? Из-за этого тоже может быть проблема.
  • 3 weeks later...
ок, посмотрю, спасибо за совет
заменил 2 линейки памяти, результат нулевой
Дополнительно добавил в систему сетевушку intel pro1000 ET dual, 1е с чем столкнулся, пришлось поставить дрова с интела , тк система еле работала, сейчас вроде нормально.
last pid: 70762; load averages: 3.78, 3.23, 2.90 up 7+02:54:04 14:01:02
115 processes: 10 running, 79 sleeping, 26 waiting
CPU: 2.6% user, 0.0% nice, 81.9% system, 12.6% interrupt, 3.0% idle
Mem: 272M Active, 331M Inact, 348M Wired, 199M Buf, 1001M Free
Swap: 5120M Total, 5120M Free
PID USERNAME PRI NICE SIZE RES STATE C TIME WCPU COMMAND
3 root -68 - 0K 8K RUN 1 50.7H 51.56% ng_queue1
2 root -68 - 0K 8K CPU1 1 50.7H 51.27% ng_queue0
39 root -68 - 0K 8K RUN 1 17.8H 16.89% em0 taskq
849 root 61 0 91640K 70612K RUN 1 821:54 14.26% mpd5
59 root -68 - 0K 8K - 0 36.5H 12.89% dummynet
29 root -68 - 0K 8K RUN 1 900:28 10.99% irq259: igb0
28 root -68 - 0K 8K WAIT 0 936:41 10.89% irq258: igb0
31 root -68 - 0K 8K RUN 1 393:12 6.49% igb0 taskq
11 root 171 ki31 0K 8K RUN 1 62.0H 4.30% idle: cpu1
12 root 171 ki31 0K 8K RUN 0 56.9H 4.20% idle: cpu0
26 root -68 - 0K 8K WAIT 0 120:57 0.78% irq256: igb0
14 root -32 - 0K 8K WAIT 0 178:30 0.68% swi4: clock sio
774 bind 44 0 328M 272M ucond 1 113:48 0.10% named
774 bind 44 0 328M 272M RUN 0 113:50 0.00% named
774 bind 4 0 328M 272M kqread 0 42:16 0.00% named
хотя в лог продолжают валиться ошибки named:
Jan 3 14:00:00 vpn1 newsyslog[68129]: logfile turned over due to size>100K
Jan 3 14:00:15 vpn1 named[774]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Jan 3 14:00:15 vpn1 named[774]: internal_send: 172.17.12.31#1684: Cannot allocate memory
Jan 3 14:00:15 vpn1 named[774]: client 172.17.12.31#1684: error sending response: out of memory
Jan 3 14:00:56 vpn1 named[774]: clients-per-query decreased to 10
Jan 3 14:01:36 vpn1 named[774]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Jan 3 14:01:36 vpn1 named[774]: internal_send: 172.17.23.200#5029: Cannot allocate memory
Jan 3 14:01:36 vpn1 named[774]: client 172.17.23.200#5029: error sending response: out of memory
Jan 3 14:01:36 vpn1 named[774]: client 172.17.12.56#2050: RFC 1918 response from Internet for 108.0.168.192.in-addr.arpa
Jan 3 14:01:51 vpn1 named[774]: client 172.17.19.184#1029: RFC 1918 response from Internet for 5.1.168.192.in-addr.arpa
Jan 3 14:01:52 vpn1 named[774]: client 172.17.19.184#1029: RFC 1918 response from Internet for 4.1.168.192.in-addr.arpa
Jan 3 14:01:52 vpn1 last message repeated 2 times
Jan 3 14:03:41 vpn1 named[774]: client 172.17.3.203#2050: RFC 1918 response from Internet for 100.0.168.192.in-addr.arpa
Jan 3 14:03:57 vpn1 named[774]: /usr/src/lib/bind/isc/../../../contrib/bind9/lib/isc/unix/socket.c:1567: unexpected error:
Jan 3 14:03:57 vpn1 named[774]: internal_send: 172.17.19.210#24665: Cannot allocate memory
Jan 3 14:03:57 vpn1 named[774]: client 172.17.19.210#24665: error sending response: out of memory
vpn1# limits
Resource limits (current):
cputime infinity secs
filesize infinity kB
datasize 524288 kB
stacksize 65536 kB
coredumpsize infinity kB
memoryuse infinity kB
memorylocked infinity kB
maxprocesses 7390
openfiles 112500
sbsize infinity bytes
vmemoryuse infinity kB
vpn1# vmstat -z
ITEM SIZE LIMIT USED FREE REQUESTS FAILURES
UMA Kegs: 128, 0, 89, 1, 89, 0
UMA Zones: 480, 0, 89, 7, 89, 0
UMA Slabs: 64, 0, 4144, 163, 41570683, 0
UMA RCntSlabs: 104, 0, 8287, 1, 8287, 0
UMA Hash: 128, 0, 4, 26, 7, 0
16 Bucket: 76, 0, 56, 44, 75, 0
32 Bucket: 140, 0, 73, 11, 95, 0
64 Bucket: 268, 0, 136, 4, 186, 7
128 Bucket: 524, 0, 3580, 11, 24465226, 404
VM OBJECT: 128, 0, 54070, 320, 99750930, 0
MAP: 140, 0, 7, 21, 7, 0
KMAP ENTRY: 68, 95368, 60, 1116, 98795584, 0
MAP ENTRY: 68, 0, 1468, 828, 265523131, 0
DP fakepg: 72, 0, 0, 0, 0, 0
SG fakepg: 72, 0, 0, 0, 0, 0
mt_zone: 1032, 0, 275, 127, 275, 0
16: 16, 0, 366147, 471, 1081607560, 0
32: 32, 0, 6044, 1640, 34422289837, 0
64: 64, 0, 383410, 385, 206345548, 0
128: 128, 0, 500147, 12403, 871040423, 0
256: 256, 0, 19198, 2657, 27036299164, 0
512: 512, 0, 6892, 668, 1314093, 0
1024: 1024, 0, 1766, 374, 659204, 0
2048: 2048, 0, 317, 81, 3315, 0
4096: 4096, 0, 184, 88, 11624569, 0
Files: 76, 0, 1989, 511, 43318243, 0
TURNSTILE: 76, 0, 281, 55, 281, 0
umtx pi: 52, 0, 0, 0, 0, 0
PROC: 704, 0, 109, 76, 5907740, 0
THREAD: 576, 0, 190, 90, 362997, 0
UPCALL: 44, 0, 0, 0, 0, 0
SLEEPQUEUE: 32, 0, 281, 171, 281, 0
VMSPACE: 236, 0, 44, 100, 5907675, 0
cpuset: 40, 0, 10, 174, 10, 0
audit_record: 864, 0, 0, 0, 0, 0
mbuf_packet: 256, 0, 3735, 2537, 14519802059, 0
mbuf: 256, 0, 11364, 4009, 73134050472, 0
mbuf_cluster: 2048, 100000, 13450, 3036, 14190905174, 0
mbuf_jumbo_pagesize: 4096, 16896, 0, 44, 309286, 0
mbuf_jumbo_9k: 9216, 8448, 0, 0, 0, 0
mbuf_jumbo_16k: 16384, 4224, 0, 0, 0, 0
mbuf_ext_refcnt: 4, 0, 0, 406, 6659, 0
ACL UMA zone: 388, 0, 0, 0, 0, 0
NetGraph items: 36, 4134, 215, 565, 18503588454, 0
NetGraph data items: 36, 546, 2, 544, 50051448421, 24456243
g_bio: 132, 0, 0, 5626, 3760159, 0
ata_request: 192, 0, 0, 1440, 949820, 0
ata_composite: 184, 0, 0, 0, 0, 0
VNODE: 276, 0, 78013, 149, 2296466, 0
VNODEPOLL: 64, 0, 0, 118, 2, 0
S VFS Cache: 68, 0, 87801, 3199, 2443896, 0
L VFS Cache: 291, 0, 789, 303, 28848, 0
NAMEI: 1024, 0, 0, 36, 58017570, 0
NFSMOUNT: 560, 0, 2, 19, 2, 0
NFSNODE: 456, 0, 2, 14, 2, 0
DIRHASH: 1024, 0, 1448, 24, 1479, 0
pipe: 396, 0, 25, 45, 196179, 0
ksiginfo: 80, 0, 128, 928, 128, 0
itimer: 220, 0, 0, 0, 0, 0
KNOTE: 68, 0, 28, 252, 421921914, 0
socket: 416, 100008, 3538, 557, 22064937, 0
unpcb: 168, 100004, 50, 88, 24624, 0
ipq: 32, 3164, 0, 452, 30361, 0
udp_inpcb: 180, 100012, 109, 177, 14961724, 0
udpcb: 8, 100079, 109, 500, 14961724, 0
inpcb: 180, 100012, 1761, 307, 784521, 0
tcpcb: 464, 100000, 1646, 402, 784521, 0
tcptw: 52, 8208, 115, 533, 381687, 0
syncache: 104, 15392, 0, 185, 1982303, 0
hostcache: 76, 15400, 416, 484, 40172, 0
tcpreass: 20, 6253, 0, 507, 10345, 0
sackhole: 20, 0, 0, 338, 6995, 0
sctp_ep: 816, 33795, 0, 0, 0, 0
sctp_asoc: 1436, 40000, 0, 0, 0, 0
sctp_laddr: 24, 80040, 0, 145, 4, 0
sctp_raddr: 400, 80000, 0, 0, 0, 0
sctp_chunk: 96, 400000, 0, 0, 0, 0
sctp_readq: 76, 400000, 0, 0, 0, 0
sctp_stream_msg_out: 64, 400020, 0, 0, 0, 0
sctp_asconf: 24, 400055, 0, 0, 0, 0
sctp_asconf_ack: 24, 400055, 0, 0, 0, 0
ripcb: 180, 100012, 1557, 379, 5558955, 0
rtentry: 124, 0, 1672, 250, 70097, 0
IPFW dynamic rule: 108, 0, 0, 180, 28021, 0
divcb: 180, 100012, 0, 0, 0, 0
SWAPMETA: 276, 121576, 0, 0, 0, 0
Mountpoints: 720, 0, 9, 6, 9, 0
FFS inode: 124, 0, 77971, 242, 2296347, 0
FFS1 dinode: 128, 0, 0, 0, 0, 0
FFS2 dinode: 256, 0, 77971, 179, 2296347, 0
NetFlow cache: 52, 262196, 56891, 18570, 1556182407, 0
vpn1# netstat -m
16368/5277/21645 mbufs in use (current/cache/total)
11258/5228/16486/100000 mbuf clusters in use (current/cache/total/max)
3915/2357 mbuf+clusters out of packet secondary zone in use (current/cache)
0/44/44/16896 4k (page size) jumbo clusters in use (current/cache/total/max)
0/0/0/8448 9k jumbo clusters in use (current/cache/total/max)
0/0/0/4224 16k jumbo clusters in use (current/cache/total/max)
27808K/11951K/39759K bytes allocated to network (current/cache/total)
0/0/0 requests for mbufs denied (mbufs/clusters/mbuf+clusters)
0/0/0 requests for jumbo clusters denied (4k/9k/16k)
0/11/8704 sfbufs in use (current/peak/max)
0 requests for sfbufs denied
0 requests for sfbufs delayed
20 requests for I/O initiated by sendfile
0 calls to protocol drain routines
Не знаю, нормальны ли вот тут ошибки.
Линков, стоящих "в полке" нет случайно? Или может named шейпится? ;)
линков на этой машине-нет, а линк в инет в часы пик под потолок идет,
сегодня изменил правила ipfw , вывел доступ к dns по отдельной ветке без всяких шейпов. посмотрим как работать будет
vpn1# limits
datasize 524288 kB
stacksize 65536 kB
maxprocesses 7390
openfiles 112500
Выделенное значение указывает на то, что максимальный объем выделяемой памяти для одного приложения равен 512 Мб, причем, насколько я понимаю, туда входят и ресурсы всех порожденных дочерних процессов. Данное значение установлено для GENERIC ядра 32-bit систем FreeBSD.
Изменить этот параметр можно пересобрав ядро с такими опциями:
options MAXDSIZ=(2048UL*1024*1024)
где - 2048UL - это размер памяти, выбеляемый для одного приложения (2 ГБ). Данное значение не предтендует на идеальное, я подбирал его для своей конфигурации с 4ГБ памяти. Поэксперементируйте и подберите размер для себя.
После пересборки ядра у меня исчезли грабли с mpd, когда процесс самостоятельно, без видимых причин и записей в логах, закрывался и закрывал все соединения.
поставил размер в 1гиг, на машине стоит всего 2 оперативы, посмотрим, что получится
дополнительно , подскажите:
Jan 4 19:47:31 vpn1 named[767]: client 172.17.11.66#2057: RFC 1918 response from Internet for 100.0.168.192.in-addr.arpa
Jan 4 19:47:50 vpn1 named[767]: client 91.199.115.149#2062: RFC 1918 response from Internet for 101.0.168.192.in-addr.arpa
Jan 4 19:48:36 vpn1 named[767]: client 172.17.20.109#2055: RFC 1918 response from Internet for 103.0.168.192.in-addr.arpa
Jan 4 19:48:40 vpn1 named[767]: client 172.17.20.109#2055: RFC 1918 response from Internet for 3.55.211.10.in-addr.arpa
не прописанные зоны, куда эти запросыц сливать ?
я подозреваю, что это абоненты, у которых стоят роутеры и через них идет резолв,у меня таких подсетей 192.168.х.х -нет
Edited by Mechanic
Вынесите named на отдельную машину, ну никак не место ему на брасе.
Потом уже боритесь с кривыми запросами от юзеров, как правило там кривой софт/руки, вирусы и т.п.
Может быть, вообще отказаться от named?
В качестве кэширующего dns-сервера imho оптимальны Unbound (быстро работает)
и dnsmasq (потребляет мало ресурсов, прост в настройке).
Ну если вам не нужны вкусности named'а а-ля view'ами отдавать локальные сайты на локальных IP, а нужен просто кэширующий резолвинг и есть время - вперёд :)
dnsmasq дополнительно читает локальные имена из /etc/hosts, там можно (пере)определить всё, что угодно, например, yandex.ru :)
Для Unbound локальные имена делаются сложнее, чем в dnsmasq, но не сложнее, чем в bind'e.
Вот пример рабочего /usr/local/etc/unbound/unbound.conf:
server:
        verbosity: 1
        interface: 0.0.0.0
        do-ip6: no
        access-control: 0.0.0.0/0 allow
        chroot: "/usr/local/etc/unbound"
        username: bind
        # ftp://FTP.INTERNIC.NET/domain/named.cache
        root-hints: "named.cache"
От обращений из внешнего мира закрыт файрволлом.
/usr/local/etc/dnsmasq.conf:
filterwin2k
domain=mynet.lan
user=bind
group=bind
#bind-interfaces
no-hosts
addn-hosts=/usr/local/etc/dnsmasq.hosts
resolv-file=/usr/local/etc/dnsmasq.resolv
expand-hosts
cache-size=5000
domain-needed
bogus-priv
в бинде делаются "локальные" зоны, а не имена.
Клиентам в локалке это не нужно (всё равно трансфер зоны никто из них не делает, все запросы на простое A- или PTR-преобразование), а настраивается несколько сложнее, чем /etc/hosts :)
увеличил объем памяти до 1Гб, путем опций в loader.conf, все равно валится named.
Похоже дело в самой системе- не справляется она с нагрузкой, в часы пик на не до 1700онлайна pptp коннектов и трафа порядка 120кппс, проц core2duo-бывает загружен на 100%, уже всевозможные оптимизации делал, или это максимум системы и надо 2ю ставить, или все же криво настроил :)
да работало ведь до определ момента, да и сейчас работает пока не поднимается общая нагрузка, попробую конечно избавиться от named на время- посмотрим, что получится
замечали тоже несколько раз проблемы с named при росте общей нагрузки. +1 за перенос.
