Доброго всем времени суток, господа. Приобрел в недавнем времени такую вещь: Cisco 1751 VoIP E1 Bundle для конвертации трафика с E1 в VoIP. Бьюсь вторую неделю - не могу понять причин неработоспособности.. точнее намеки есть, но хотелось бы быть точно уверенным. Итак, сначала описание:
Конфиг шлюза:
VoIP_cisco#sh run
Building configuration...
Current configuration : 1285 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname VoIP_cisco
boot-start-marker
boot-end-marker
memory-size iomem 25
tdm clock E1 0/0 both export line
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
aaa new-model
aaa authentication login default local
aaa session-id common
ip subnet-zero
ip cef
isdn switch-type primary-net5
voice service voip
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
username admin secret 5 <вырезано цензурой>/
controller E1 0/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 192.168.2.50 255.255.255.0
speed auto
full-duplex
interface Serial0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip http server
voice-port 0/0:15
dial-peer voice 1 voip
destination-pattern 5941736
voice-class codec 1
session target ipv4:195.88.76.xx
line con 0
line aux 0
line vty 0 4
privilege level 15
line vty 5 15
privilege level 15
end
Модули:
VoIP_cisco#sh inv
NAME: "1751 chassis", DESCR: "1751 chassis, Hw Serial#: 2472228613, Hw Revision: 0x600"
PID: 1751              , VID: 0x600, SN: JAD064207GW (2472228613)
NAME: "Chassis Slot", DESCR: "1700 Chassis Slot"
PID: 1700 Chassis Slot , VID:    , SN:
NAME: "C1751 Mainboard", DESCR: "C1751 Mainboard"
PID: C1751 Mainboard   , VID: 0x600, SN: JAD064207GW (2472228613)
NAME: "Daughter card slot:0", DESCR: "1700 DaughterCard Slot"
PID: 1700 DaughterCard Slot, VID:    , SN:
NAME: "WIC/VIC 0", DESCR: "One port E1 voice interface daughtercard"
PID: One port E1 voice interface daughtercard, VID: 1.0, SN: 33504710
NAME: "E1 0/0", DESCR: "E1 0/0"
PID: E1 0/0            , VID:    , SN:
NAME: "FastEthernet0/0", DESCR: "PQUICC_FEC"
PID: PQUICC_FEC        , VID:    , SN:
NAME: "Daughter card slot:1", DESCR: "1700 DaughterCard Slot"
NAME: "Daughter card slot:2", DESCR: "1700 DaughterCard Slot"
NAME: "DSP Module Slot", DESCR: "Packet Voice DSP Module Slot 0"
PID: Packet Voice DSP Module Slot 0, VID:    , SN:
NAME: "DSP Module", DESCR: "Packet Voice DSP Module with 3 C549 DSPs"
PID: Packet Voice DSP Module with 3 C549 DSPs, VID: 2.2, SN: ICP044002W7
NAME: "DSP Module Slot", DESCR: "Packet Voice DSP Module Slot 1"
PID: Packet Voice DSP Module Slot 1, VID:    , SN:
Статус потока:
VoIP_cisco#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 33
    Total Allocated ISDN CCBs = 0
Статус DSP:
VoIP_cisco#sh voice dsp
DSP  DSP             DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC    VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
Active Voice Call details
Current total analog signalling channels: 0
Current max allowed digital timeslot for voice: 36
Current number of DSP group: 1
Group 0:
Current allocated analog signalling channels: 0
Current free analog signalling channels: 0
Current allocated digital signalling channels: 30
Current free digital signalling channels: 6
Port(s) served: 0/0
Current Available MIPS: 600
SPMM  DSPRM  State   Image     D-sig  D-sig     A-sig  A-sig  Mips Voice/Xcode
  Dsp   Dsp                  allocate   free  allocate   free  Free     Chan
  0/0     0      UP   FLEX6         6      0         0      0   100        0
  0/1     1      UP   FLEX6         6      0         0      0   100        0
  0/2     2      UP   FLEX6         6      0         0      0   100        0
  1/0     3      UP   FLEX6         6      0         0      0   100        0
  1/1     4      UP   FLEX6         6      0         0      0   100        0
  1/2     5      UP   FLEX6         0      6         0      0   100        0
Включаем дебаг:
VoIP_cisco#debug isdn q931
debug isdn q931 is              ON.
Смотрим:
VoIP_cisco#term mon
И видим при звонке:
VoIP_cisco#
*Mar 1 02:46:17.223: ISDN Se0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0027
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18381
Preferred, Channel 1
Calling Party Number i = 0x2181, '9**12770*1'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '9**306*2'
Plan:ISDN, Type:Unknown
*Mar 1 02:46:17.251: ASSERTION FAILED: file "../src-m860-les/if_ipm_c54x_idma.c", line 655
*Mar 1 02:46:17.251: ISDN Se0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8027
Channel ID i = 0xA98381
Exclusive, Channel 1
*Mar 1 02:46:17.251: ISDN Se0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8027
*Mar 1 02:46:17.347: ISDN Se0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0027
*Mar 1 02:46:43.723: %IPM_C54X-1-DSP_TIMEOUT: dsp 0 NOT RESPONDING.
*Mar 1 02:46:43.723: ASSERTION FAILED: file "../src-m860-les/ipm_dsprm_c1700.c", line 3310
*Mar 1 02:46:43.735: ISDN Se0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8027
Cause i = 0x8090 - Normal call clearing
*Mar 1 02:46:43.799: ISDN Se0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0027
*Mar 1 02:46:43.803: ISDN Se0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8027
*Mar 1 02:46:53.723: %IPM_C54X-1-DSP_TIMEOUT: dsp 2 NOT RESPONDING.
"Интересное" выделено жирным. Судя по похожим проблемам трабла в битых модулях PVDM (их там два). Вопрос извечный - кто виноват и что делать? В присланном вместе с бандлом протоколе тестирования значится только инвентаризация (конечно же в ней все есть). Или все-таки у меня что-то напутано в конфиге (не похоже, но все-таки..)?
Edited by sumjohn
Всё правильно - битый PVDM. У меня была та же проблема. Проверьте PVDM по одному. И вычислите битый. Обратитесь в НАГ(если там покупали). Они без проблем заменят.
Спасибо за ответ, обращусь к менеджеру по поводу замены. Не отвечают же оба модуля, судя по дебагу? Или есть вероятность, что один нормальный?.. дело в том, что физически манипуляции с роутером затрудненны ввиду отсутствия доступа к нему (находится в другом городе и мотаться туда-сюда ради вычисления не совсем целесообразно. Точнее, хотелось бы по максимуму оценить ситуацию удаленно, насколько возможно)
В эти бандлы ставят PVDM-12 вместо PVDM-256k-12, которые должны ставится согласно напутствию Cisco.
Проверяется это командой sh diag, которую предлагаю опубликовать.
Интересно. Вот инфа с магазина: Cisco 1751 E1 bundle.
Вот sh diag:
VoIP_cisco#sh diag
Slot 0:
        C1751 1FE VE DV Mainboard Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 6.0
        PCB Serial Number        : JAD064207GW
        Part Number              : 73-5128-06
        Board Revision           : B0
        Fab Version              : 04
        Product (FRU) Number     : CISCO1751
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 02 4D 41 06 00 C1 8B 4A 41 44 30 36 34
          0x10: 32 30 37 47 57 82 49 14 08 06 42 42 30 02 04 FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Packet Voice DSP Module Slot 0:
        Hardware Revision        : 2.2
        Part Number              : 73-3691-01
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 02
        PCB Serial Number        : ICP044002W7
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 02
        Number of DSP's          : 3
        DSP memory size(in kwords): 192
        Type of DSP              : TMS320C549
        Product (FRU) Number     : PVDM-12=
        0x00:   04 FF 40 01 5C 41 02 02 82 49 0E 6B 01 42 41 30
        0x10:   80 00 00 00 00 02 02 C1 8B 49 43 50 30 34 34 30
        0x20:   30 32 57 37 03 00 81 00 00 00 00 04 00 09 02 FF
        Packet Voice DSP Module Slot 1:
        Board Revision           : A0
        Fab Version              : 02
        RMA History              : 00
        Processor type           : 02
        Number of DSP's          : 3
        WIC/VIC Slot 0:
        E1 (1 port) Multi-Flex Trunk WAN daughter card
        Hardware revision 1.0   Board revision B0
        Serial number     0033504710    Part number    800-04475-03
        FRU Part Number   WIC/VIC-E1=
        Test history      0x00          RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
        0x20:   01 21 01 00 01 FF 3D C6 50 11 7B 03 00 00 00 00
        0x30:   58 00 00 00 02 12 23 00 FF FF FF FF FF FF FF FF
То есть и правда установлены PVDM-12.
Edited by sumjohn
Все нормально, производят замену. Сейчас тестируют новые (для нас, на самом деле они, конечно же, б/у) и вышлют. Собственно, спасибо всем, тему можно закрывать.
хмм.. спасибо за уточнение. Выслал информацию а расхождении инфы о модулях менеджеру, надеюсь меры приняты будут. Высланы, опять-таки надеюсь, будут PVDM-12.
У них продано более сотни таких коробок. Проблем именно PVDM-12 vs. PVDM-256k-12 не было.
Собственно на сайте cisco.com в одном месте пишут PVDM12, в другом уже PVDM-256k-12 что для NM-HDV, что для 1700.
И тот и другой тип сделан на базе одного и того же с549.
