Народ, ооочень нужны прошивки на FastIron FWS24 и BigIron J-BxGMR4
FastIron:
 SW: Version 07.1.26T10 Copyright (c) 1996-2001 Foundry Networks, Inc.
     Compiled on May 15 2002 at 02:44:55 labeled as FWS07126
HW: FastIron Workgroup Switch, serial number 0271ea
166 MHz Power PC processor 603 (revision 7) with 8180K bytes of DRAM
  24 100BaseT interfaces with Level 1 Transceiver LXT975
   2 GIGA Fiber uplink interfaces, SX-SX
  64 KB PRAM and 1*2048 CAM entries for DMA 0, version 0807
  64 KB PRAM and 1*2048 CAM entries for DMA 1, version 0807
  64 KB PRAM and 1*2048 CAM entries for DMA 2, version 0807
256 KB PRAM and 4*1024 CAM entries for DMA 4, version 0104, SEEQ GIGA MAC 8100
256 KB PRAM and 4*1024 CAM entries for DMA 5, version 0104, SEEQ GIGA MAC 8100
128 KB boot flash memory
2048 KB code flash memory
1024 KB BRAM, BM version 10
128 KB QRAM
512 KB SRAM
Octal System, Maximum Code Image Size Supported: 982528 (0x000efe00)
The system uptime is 3 days 16 hours 38 minutes 36 seconds
The system started at 01:49:07 Eastern Mon Nov 09 2009
BigIron:
  SW: Version 08.0.01qT53 Copyright (c) 1996-2004 Foundry Networks, Inc.
      Compiled on Jun 16 2008 at 12:07:44 labeled as B2R08001q
      (3856667 bytes) from Primary B2R08001q.bin
  HW: BigIron 8000 Router, SYSIF version 21, Serial #: Non-exist
SL 1: J-BxGMR4 JetCore Management Module, SYSIF 2 (Mini GBIC), M4, ACTIVE
      Serial #:   CH23034887
4096 KB BRAM, JetCore ASIC IGC version 49, BIA version 89
32768 KB PRAM and 2M-Bit*1 CAM for IGC  0, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  1, version 0449
SL 2: J-BxGC16 JetCore Gig Copper Module, SYSIF 2
      Serial #:   SA21030583
32768 KB PRAM and 2M-Bit*1 CAM for IGC  4, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  5, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  6, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  7, version 0449
Заранее спасибо! :)
  • 1 year later...
Кто, как и я, тщетно пытался раздобыть прошивку на свои железки от Foundry / Brocade, подпишитесь на этот маил лист и вежливо попросите прошивку, скорее всего, будет вам счастье. Только что получил апдейт на свою железяку от одного добряка.
Также не стесняемся регистрироваться на my.brocade.com как Brocade Partner (это важно!), если контракта нет, они его вам и не дадут, но вот доступ к триальным версиям всех ихних текущих программных продуктов (в основном для SAN) вы получите. Пользуюсь триальной версией Brocade Network Advisor для всех ихних IP продуктов, что у меня стоят, впечатления положительные.
