Alcatel-Lucent Service Routers and Switches Обсуждение технических возможностей продукции Alcatel-Lucent
Alcate-lucent 7450ess bgp
Господа, доброго времени суток. Сломал весь мозг(((
Есть 7450ess-1 (TiMOS-L-11.0.R5), необходимо настроить BGP сессию. Настроил по аналогии 7750. Пробовал поднимать 7450ess - Mikrotik, 7450ess - Cisco 7201. Не поднимается.
В логах микротика -
01:50:52 route,bgp,error OPEN error: unsupported capability
01:50:52 route,bgp,info Connection terminated
01:50:52 route,bgp,info RemoteAddress=79.137.251.2
01:51:22 route,bgp,info Connection opened by remote host
01:51:22 route,bgp,info RemoteAddress=79.137.251.2
01:51:22 route,bgp,error Received notification
01:51:22 route,bgp,error OPEN error: unsupported capability
01:51:22 route,bgp,info Connection terminated
Состояние BGP 7450:
Peer AS : 65000 Peer Port : 179
Peer Address : 79.137.251.1
Local AS : 65000 Local Port : 49544
Local Address : 79.137.251.2
Peer Type : Internal
State : Active Last State : OpenSent
Last Event : parseError
Last Error : Unrecognized Error
Local Family : IPv4
Конфиг 7450:
echo "IP Configuration"
interface "system"
address 10.20.30.1/32
no shutdown
exit
interface "uplink"
address 79.137.251.2/30
port 1/1/20
no shutdown
exit
autonomous-system 65000
echo "BGP Configuration"
bgp
graceful-restart
enable-notification
exit
router-id 10.20.30.1
group "uplink"
family ipv4
type internal
peer-as 65000
neighbor 79.137.251.1
exit
exit
no shutdown
exit
Карта 7450ess-1
echo "Card Configuration"
card 1
card-type iom-20g-b
mda 1
mda-type m20-1gb-sfp
no shutdown
exit
no shutdown
exit
mikrotik
[admin@MikroTik] /routing bgp> peer print
Flags: X - disabled, E - established
# INSTANCE REMOTE-ADDRESS REMOTE-AS
0 default 79.137.251.2 65000
[admin@MikroTik] /routing bgp instance> print
Flags: * - default, X - disabled
0 * name="default" as=65000 router-id=79.137.251.1 redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-ospf=no redistribute-other-bgp=no out-filter="" client-to-client-reflection=yes
ignore-as-path-len=no routing-table=""
На циске то-же ошибка связанная с невозможностью установления сессии.
Предположил что эта ошибка связана с 4 byte AS. Но команда disable-4byte-asn не спасает...
PS На 7210 с этим конфигом BGP взлетает без проблем.
Прошу помощи.
Спасибо!
Изменено пользователем 7210
Поделиться сообщением
Ссылка на сообщение
Поделиться на других сайтах
Тут уже надо подключать debug bgp на 7450 и от него плясать. graceful-restart пока отключить,peer-as прописать под neighbor. Должно конечно и так работать, мало ли.
Изменено пользователем zvukovik
Ссылка на сообщение
Добрый день!
Настроил debug.
debug
router "Base"
bgp
open
update
notification
events
exit
exit
exit
Вот что в нем:
58 2000/01/01 00:22:17.67 UTC MINOR: DEBUG #2001 Base BGP
"BGP: STATE
Peer 1: 79.137.251.1 - Change State from ACTIVE to OPENSENT due to SENDOPEN
59 2000/01/01 00:22:17.69 UTC MINOR: DEBUG #2001 Base BGP
"BGP: OPEN
Peer 1: 79.137.251.1 - Received BGP OPEN: Version 4
AS Num 65500: Holdtime 180: BGP_ID 10.1.1.1: Opt Length 16
Opt Para: Type CAPABILITY: Length = 14: Data:
Cap_Code ROUTE-REFRESH: Length 0
Cap_Code 4-OCTET-ASN: Length 4
Bytes: 0x0 0x0 0xff 0xdc
Cap_Code MP-BGP: Length 4
Bytes: 0x0 0x1 0x0 0x1
60 2000/01/01 00:22:17.69 UTC MINOR: DEBUG #2001 Base Peer 1: 79.137.251.1
"Peer 1: 79.137.251.1: NOTIFICATION
Peer 1: 79.137.251.1 - Send BGP NOTIFICATION: Code = 2 (OPEN) Subcode = 7 (Unsup
ported Capability)
Data Length = 6 Data: 0x1 0x4 0x0 0x1 0x0 0x1
61 2000/01/01 00:22:17.69 UTC MINOR: DEBUG #2001 Base BGP
"BGP: STATE
Peer 1: 79.137.251.1 - Change State from OPENSENT to IDLE due to PARSE_ERROR
62 2000/01/01 00:22:29.73 UTC MINOR: DEBUG #2001 Base BGP
"BGP: OPEN
Peer 1: 79.137.251.1 - Send (Active) BGP OPEN: Version 4
AS Num 65500: Holdtime 90: BGP_ID 10.1.1.2: Opt Length 4
Opt Para: Type CAPABILITY: Length = 2: Data:
63 2000/01/01 00:22:29.73 UTC MINOR: DEBUG #2001 Base BGP
"BGP: STATE
Peer 1: 79.137.251.1 - Change State from CONNECT to OPENSENT due to SENDOPEN
64 2000/01/01 00:22:29.73 UTC MINOR: DEBUG #2001 Base BGP
"BGP: OPEN
65 2000/01/01 00:22:29.73 UTC MINOR: DEBUG #2001 Base Peer 1: 79.137.251.1
ported Capability)
66 2000/01/01 00:22:29.73 UTC MINOR: DEBUG #2001 Base BGP
"BGP: STATE
Ссылка на сообщение
Доброго времени суток. Есть вопрос по девайсу al7210 sas-m. Интересует поддержка данным коммутатором 100мбитых SFP модулей. Конкретно модулей наговских SNR-SFP100-W53(35)-20/3.
Ссылка на сообщение
Привет всем! Подскажите, может кто имел дело, что необходимо закупить для стекирования этого оборудования: OS6450-U24 и OS6860E-U28. Только кабель для стекирования или еще модуль для стекирования? Спасибо.
Ссылка на сообщение
Мы ставим гиговые, только порт в 100м переводим - решение более универсальное.
Ссылка на сообщение
Коллеги добрый день.
Не могу побороть проблему фильтров на зеркале.
debug
   mirror-source 1
       port lag-5 egress ingress
       ip-filter 10 entry 10
       no shutdown
   exit
exit
       ip-filter 10 create
          default-action drop
           description "test dump"
           entry 10 create
               match
               exit
               action drop
           exit
       exit
Для начала хотя бы просто дропать всё на зеркале, но трафик так и продолжает идти и нет совпадений по фильтру. Требуется отфильтровать сети оператора на зеркале (у него свой СОРМ). У кого нибудь работает?
Спасибо.
Всё догнал) Трафик поступает в зеркало с фильтра на источнике, если есть совпадения. Не возникнет ли проблем с такой реализацией трафика на сорм, сейчас просто снимается с сапов.
Ссылка на сообщение
Доброе утро! Возник такой нюанс. на 7750 при поднятии pim сессии взлетает IP Stack Capacity Usage до 96%, если еще одну поднимать то дальше резко поднимается PIM/L2Mcast до 20-30%
Логика настройки простая, router interface c ипишником.
Кто-то сталкивался с таким?
Софт 12.0.R8
Ссылка на сообщение
Доброго всем времени суток.
есть 7705 SAR8.
кто нибудь сталкивался с критериями переключения между SDP или spoke-sdp?
Есть два провайдера. соответственно, Алкатели подключены через них нетворк портами. и по два SDP. подключение - static-lsp. на сервисе настроено два spoke-sdp по одному на каждого провайдера.
задача - автоматически переключаться при неполной работе провайдера, то есть при потерях, задержках и превышении мту и тд. когда порты и sdp еще в up, но траффик уже не ходит.
Ссылка на сообщение
есть 7705 SAR8.
bfd
Ссылка на сообщение
BFD может быть проблематичен в некоторых топологиях. Можно попробовать включить keepalive на SDP.
Ссылка на сообщение
Товарищи, доброго всем дня!
Подскажите, сколько будет стоить 7210 SAS-M (10GigE) + плата расширения 2х10Gig, сколько такой коммутатор вам обходился? Укажите тут или в ЛС.
Ссылка на сообщение
Приветствую!
Такой вопрос, никто не пытался поставить 5620SAM на CentOS? Сейчас на редхате стоит, надоело каждый раз регистрироваться. Есть вариант что взлетит, или там жёсткие привязки к дистрибутиву?
Ссылка на сообщение
В 20.09.2017 в 11:54, gryz9 сказал:
Берите 7210 Mxp, в нем четыре порта sfp+
Насколько я помню, платы расширения больше не производятся.
А может и Эмка тоже End of Sale. Если надо - могу у Нокии узнать, пиши в ЛС.
Ссылка на сообщение
коммутатор OmniSwitch 6850e-u24x, софт 6.4.6.424.R01,  проблема с RJ45 SFP
в 23-24 порту работают все модули (ATOP,Gigaliht,Finisar),
а в портах 1-22 только FCLF8521P2BTL, да и то на 1000.
хотя согласно OS6850E AOS 6.4.6 R01 Tranceivers Guide.pdf
порты 1..22,- поддерживают SFP-GIG-T,
и там же указанно 10/100/1000 для SFP-GIG-T.
в OS6850E_AOS_6.4.4_R01_Transceivers_Guide.pdf
насчет 6850 - указанно Release 6.3.1.R02 added support for the SFP-GIG-T at
10/100/1000 Mbits on OS6850-U24X noncombo ports only
качательно 6850E - ничего не указанно.
1) х.з. может я неверно понял мануалы. что-же с 100Мб на 1..22 портах ?
2) у кого-то есть дамп этого SFP-GIG-T ?
....те что мы используем, что-то не помогают (((
Изменено пользователем carver
Ссылка на сообщение
Подскажите, возможно ли на 7750 нарезать суммарно скорость для разных vpls\sap. Т.е. к примеру, 1 вариант: vpls с несколькими sap на разных портах, нужно в сумме отрезать 100мб. 2 вариант - как первый, только с разными vpls.
Ссылка на сообщение
Можно. Ключевые слова для изучения: multiservice site, vport и т.п.
Ссылка на сообщение
В 18.03.2018 в 03:55, JoeDoe сказал:
multiservice site работает когда несколько сервисов, которые нужно объединить, висят на одном физическом порту, а мне нужно на разных...
кто-то может показать пример использования vport? документация по данной железке довольно тяжелая...
"и т.п." - а можно написать какие это варианты еще?
Ссылка на сообщение
Для multiservice site ограничение не физический порт, а слот. Т.е. ваши SAP-ы могут находиться на разных портах одной карты.
Vport используется для организации шейпинга per SVLAN (per DSLAM), когда порт подключен в кольцо из нескольких коммутаторов.
Ссылка на сообщение
В 27.03.2018 в 04:08, JoeDoe сказал:
Значит ответ - никак, для моего случая. По поводу слота - вы не совсем правы, оно привязывается или на слот или на порт, причем портом может выступать агрегация из кучки портов на разных слотах, уже проверенный рабочий вариант, и добавить к этому еще один левый сервис, который едет не через эту агрегацию, выходит, никак нельзя. Кроме запуска отдельной железки для заведения этого сервиса на агрегацию...
Ссылка на сообщение
Добрый день.
Никто не сталкивался с ограничениями на 7210 sas-x/m по количеству sap?
На sas-x 511 sap на систему и 64 sap на 1 порт
На sas-m просто 256 sap на систему.
В документации нигде не встречал такие ограничения.
Ссылка на сообщение
On 8/22/2018 at 7:58 PM, factor said:
Добрый день.
Эта информация доступна не в документации, а в Scaling Guide. К field версии имеют доступ все работники Nokia, к расширенной - только R&D, CE и NPI.
P.S. Для sas-x 511 vpls saps на систему, но 1024 e-pipe saps. 64 sap на access port, 63 на hybrid port.
Ссылка на сообщение
Добрый день.
Подскажите какая максимальная температура для плат imm5-10gb-xfp, sfm3-7(12). И шасси в целом. При какой температуре они отключаются( если отключаются)?
Temperature threshold         : 75C указан. Не могу по этому поводу ничего в доках найти.
Спасибо.
Ссылка на сообщение
On 9/12/2018 at 1:36 PM, zvukovik said:
Добрый день.
Спасибо.
По каждому типу шасси есть отдельный документ. Из
SR-1e, SR-2e, and SR-3e CHASSIS INSTALLATION GUIDE
(был под рукой):
Parameter
Values
Normal operating temperature
41 to 113°F (5 to 45°C)
Short-term operating temperature
23 to 131oF (–5 to 55oC)
Operating altitude
197 ft (60 m) below sea level and 6000 ft (1800 m) above sea level at 40°C (104°F) and between 6000 ft (1800 m) and 13 123 ft (4000 m) above sea level, at 86°F (30°C).
Normal operating relative humidity
5 to 95% (non-condensing)
Shock and vibration:
Very low levels for continuous duration disturbance (similar to modern office building, for example)
Shock: 3 g half sine 11 ms Vibration: 0.1 g from 5 to 100 Hz
Earthquake
Suitable for high-risk areas (Zone 4/California, for short-duration disturbance)
Pollution degree 1
2
Rated voltage (DC)
–48/–60 VDC, 40/30 A per source
Operating voltage range (DC)
–40 to –72 VDC
Rated voltage (AC)
100-120/220-240 VAC, 50/60 Hz 12/10 A per source
Operating voltage range (AC)
90-127/200-264 VAC
Для 7705 будут другие параметры - там есть модели для улицы (outdoor).
Изменено пользователем JoeDoe
7705
Ссылка на сообщение
Создайте аккаунт или войдите в него для комментирования
Создать аккаунт
Зарегистрируйтесь для получения аккаунта. Это просто!
Зарегистрировать аккаунт
Уже зарегистрированы? Войдите здесь.
Войти сейчас
