anton-ny Posted October 25, 2009 Posted October 25, 2009 FREEBSD Как локалку по нат направить через один интерфейс (ext_all), а несколько отдельных клиентов по БИнату через другой (ext_binat)? Привожу свой pf.conf В итоге вся локалка на выход ломится через (ext_all), включая БИнат-ных клиентов. На вход естественно видно и тех и тех. ext_all="ext1" ext_binat="ext0" int="int0" gw_all="333.333.222.1" gw_binat="333.333.333.1" tcp_svc="22" table <lan> { 192.168.0.0/16 } set optimization normal scrub in all set skip on lo0 nat on $ext_all from <lan> to !<lan> -> 333.333.222.0/24 source-hash binat on $ext_binat inet from 192.168.1.5 to any -> 333.333.333.2 block in antispoof quick for $int pass in on $ext_all reply-to ($ext_all $gw_all) inet proto icmp to ($ext_all) tag EXT_IF_A icmp-type echoreq code 0 pass in on $ext_all inet proto icmp from ($ext_all:network) to ($ext_all) icmp-type echoreq code 0 pass in on $ext_binat reply-to ($ext_binat $gw_binat) inet proto icmp to ($ext_binat) tag EXT_IF_B icmp-type echoreq code 0 pass in on $ext_binat inet proto icmp from ($ext_binat:network) to ($ext_binat) icmp-type echoreq code 0 pass in on $ext_all reply-to ($ext_all $gw_all) inet proto tcp to ($ext_all) port { $tcp_svc } pass in on $ext_all inet proto tcp from ($ext_all:network) to ($ext_all) port { $tcp_svc } pass in on $ext_binat reply-to ($ext_binat $gw_binat) inet proto tcp to ($ext_binat) port { $tcp_svc } pass in on $ext_binat inet proto tcp from ($ext_binat:network) to ($ext_binat) port { $tcp_svc } pass in quick from ($ext_all:network) tagged EXT_IF_A keep state pass in quick reply-to ($ext_all $gw_all) tagged EXT_IF_A keep state pass in quick from ($ext_binat:network) tagged EXT_IF_B keep state pass in quick reply-to ($ext_binat $gw_binat) tagged EXT_IF_B keep state pass out inet from (self:network) pass in inet proto icmp to (self:network) pass quick on $int pass out route-to ($ext_all $gw_all) inet from ($ext_all) keep state pass out route-to ($ext_binat $gw_binat) inet from ($ext_binat) keep state pass out inet from { $ext_all $ext_binat } to (self:network) Вставить ник Quote
anton-ny Posted October 26, 2009 Author Posted October 26, 2009 Проблему, может и не корректно, но решил добавлением правил: pass in on $int route-to ($ext_all $gw_all) from <lan> to !<lan> keep state pass in on $int route-to ($ext_binat $gw_binat) from <lan> to !<lan> keep state Вставить ник Quote
