Скажите пожалуйста как мои параметры телефонной линии.?
Вот что показывает модем Acorp Sprinter@ADSL USB
10/05/2009 - 10:45:28 - EVENT = Ndis driver version: 13032.099.074.000
10/05/2009 - 10:45:28 - EVENT = Current MAC address: 00-14-2B-06-81-F2
10/05/2009 - 10:45:28 - EVENT = EEprom MAC address: 00-14-2B-06-81-F2
10/05/2009 - 10:45:28 - EVENT = Local Data Pump Vendor: Conexant Systems Inc.
10/05/2009 - 10:45:28 - EVENT = Local Data Pump Version: 3
10/05/2009 - 10:45:28 - EVENT = Local Data Pump Firmware Version: 3.25.0
10/05/2009 - 10:45:28 - EVENT = Remote Data Pump Vendor: Unknown Vendor
10/05/2009 - 10:45:28 - EVENT = Remote Data Pump Firmware Version: 0
10/05/2009 - 10:45:28 - EVENT = ************* Start Statistics Acquisition *************
10/05/2009 - 10:45:28 - EVENT = CALL STATUS - Connected
09/30/2009 - 12:40:20 - EVENT = PHYSICAL STATISTICS -
Upstream Output Power = -38 dBm
Upstream Noise Margin = +2.3 dB
Upstream Attenuation = 3.3 dB
Upstream Bits per Frame = 229
Upstream CRC Errors = 1
Upstream FEC Errors = 1
Upstream HEC Errors = 0
Downstream Noise Margin = +10.0 dB
Downstream Attenuation = 3.3 dB
Downstream Bits per Frame = 1110
Downstream CRC Errors = 0
Downstream FEC Errors = 3
Downstream HEC Errors = 0
Startup Attempts = 1
Вот в другой день
10/05/2009 - 19:30:08 - EVENT = PHYSICAL STATISTICS -
Upstream Noise Margin = +2.0 dB
Upstream Attenuation = 3.5 dB
Upstream Bits per Frame = 140
Upstream CRC Errors = 0
Upstream FEC Errors = 19
Downstream Noise Margin = +2.9 dB
Downstream Attenuation = 3.5 dB
Downstream Bits per Frame = 732
Startup Attempts = 7
Вот в другой день
10/07/2009 - 10:42:03 - EVENT = PHYSICAL STATISTICS -
Upstream Bits per Frame = 225
Upstream CRC Errors = 2
Upstream FEC Errors = 0
Downstream Noise Margin = +9.3 dB
Downstream Bits per Frame = 1933
Downstream FEC Errors = 0
Скорость на порту стоит 2Мб.
Больше 2 Мб линия недержит.
Спасибо всем за ответы.
Шумная линия, говорите. :)
Эх, мне бы такое Downstream Attenuation = 3.5 dB
Я так понял Это даже очень хороший параметр.? Я читал что DownStream Attenuation у Вас до 20 dB то линия у Вас отличная. А у меня колеблется от 3.3 dB до 3.5 dB. Я так понимаю у меня линия суперская? Если бы такой параметр был бы выше я думаю интерне вообще бы неработал.?
У меня
Всегда показывают одно и тоже, никогда неотличается.
А мне кажется, проблема в другом. А именно
слишком маленькое SNR... Да и +10 dB тоже не ахти. Линия шумная очень...
У меня
Всегда примерно одно и тоже
А у
Колеблется от +2.9 dB до +10.0 dB, и я так понял что от скорости подключения отдачи.
У меня всегда модем подцеплялся на скорости отдачи 768Кб, потом ближе к обеду отцеплялся и подцеплялся на 736Кб, бывает, и на 446Кб, 416Кб, 384Кб.
Редко была скорость отдачи выше.736Кб.
Вообщем я заметил, если скорость отдачи 768Кб, то Downstream Noise Margin = +2.9 dB, если 446Кб то Downstream Noise Margin = +4.9 dB, если 384Кб то Downstream Noise Margin = +10.0 dB. Но только вроде не всегда так.
Edited by webset
Дайте ка я угадаю. У вас бесплатный модем Acorp Sprint@ADSL USB ??? :)
А че угадывать если если во второй строчке написано Acorp Sprinter@ADSL USB
И никакой он не бесплатный, я его по 800 рублей покупал.
Могу тока посоветовать взять на тест ZyXEL Ethernet.
Легко сказать. Я б попробовал. Только модем взять негде. Потом конечно обновлю поменяю на другой.
Вообщем то я живу в частном доме. От столба с коробкой до моего дома 1 квартал, тоесть столб стоит в 1 конце улицы, а дом в другом конце улицы, вроде больше 100 метров провод идет по столбам. В одном месте на улице на этом проводе есть скрутка :) . Тоесть соединены 2 разных кабеля.
От станции до дома 1.5Км.
Еще у меня недавно ломался телефонная линия, пропала одна жила, сказали кабельное повреждение, потом когда сделали я выяснил что типа кабель весь сгнил и находится в хреновом состоянии. Я так думаю что этому кабелю больше 20 лет раз он уже сгнил. А кабельщиков нет, чтобы менять. Я так думаю, что возможно они пересадили 1 жилу на другую пару, сделали распаровку, возможно поэтому. Но раньше же тоже так же работал интернет, как и сейчас.
