поставил 7.8.2 extremeware
но хочеться full
ни у кого нет лекарства?
спс за прошивку ash
Edited by mishasat
Есть в нете v781b1-patch1-9:
hххp://www.antillephone.com/extremeware/v781b1-patch1-9.SBxtr
hххp://www.antillephone.com/extremeware/v781b1-patch1-9.SFxtr
hххp://www.antillephone.com/extremeware/v781b1-patch1-9.Sxtr
но у Меня падает snmp...Хоте может это не поэтому ltkj?
09/26/2009 16:54:08.06 <Crit:SYST> sys-recovery: none
09/26/2009 16:54:08.06 <Warn:SYST> 00x805b5c78 ipNetToMediaEntryGet+98 : m2IpAtransTblEntryGet ( 847f03d0 , 82239840 , 0 , 35 )
09/26/2009 16:54:07.99 <Warn:SYST> 00x805d1ab0 SNMP_Process_Get_PDU+4f0: ipNetToMediaEntryGet ( 1 , 847f03d0 , 848333c0 , 35 )
09/26/2009 16:54:07.88 <Warn:SYST> 00x805d582c process_packet_two+2c8: SNMP_Process_Get_PDU ( 0 , 0 , 869ec3e0 , 19020 )
09/26/2009 16:54:07.82 <Warn:SYST> 00x805d59d0 Process_Rcvd_SNMP_Packet_Async+130: 805d5640 ( 876a7614 , 0 , 0 , 0 )
09/26/2009 16:54:07.77 <Warn:SYST> 00x805beb0c snmpdPktProcess+2c : Process_Rcvd_SNMP_Packet_Async ( 4 , 0 , 0 , &rmonInitPeriodicTimer )
09/26/2009 16:54:07.71 <Warn:SYST> 00x805c0e8c snmpIoMain +26c: snmpdPktProcess ( 847f04f0 , 3b9ac9ff , 0 , 80d7a75c )
09/26/2009 16:54:07.63 <Warn:SYST> 00x805c0ce4 snmpIoMain +c4 : 805c0cfc ( eeeeeeee , eeeeeeee , eeeeeeee , eeeeeeee )
09/26/2009 16:54:07.52 <Warn:SYST> 00x805beac8 snmpdInit +118: snmpIoMain ( eeeeeeee , eeeeeeee , eeeeeeee , eeeeeeee )
09/26/2009 16:54:07.42 <Warn:SYST> 00x80d47238 vxTaskEntry +14 : snmpdInit ( 1 , 0 , 0 , 0 )
09/26/2009 16:54:07.35 <Warn:SYST> Task: 0x847f0580 "tSnmpd"
09/26/2009 16:54:07.35 <Warn:SYST> Error address: 0x04d18200, Error ID: 0x0000
09/26/2009 16:54:07.35 <Warn:SYST> Cause Register: 0x0000001c
09/26/2009 16:54:07.35 <Warn:SYST> Status Register: 0x10008301
09/26/2009 16:54:07.35 <Warn:SYST> Exception Program Counter: 0x8042d44c
09/26/2009 16:54:07.35 <Warn:SYST> Data bus error
09/26/2009 16:54:07.35 <Crit:SYST> Task tSnmpd(847f0580) failed
09/26/2009 16:54:07.35 <Crit:SYST> Chassis temperature is 47 degrees Centigrade
09/26/2009 16:50:22.79 <Info:SYST> User admin logged out from telnet (10.198.205.254)
09/26/2009 16:50:22.76 <Info:SYST> upload config succeeded to 10.198.200.2, file extreme_146
09/26/2009 16:50:21.78 <Info:SYST> 10.198.205.254 admin: upload configuration 10.198.200.2 extreme_146
Кто подскажет - привязаны ли прошивке к апаратной реализации свича?
У Меня на extrem'ах не работает loopback detection - Я не проверял все 150+ но на первом десятке это было так...Пробывал на тех прошивках что они пришли и на других...
  • 1 month later...
нашел решение как сделать 3 full
пишем в личку
Пытался с вами связаться по данному вопросу через личку - ничего не вышло, она мне не доступна на данном форуме почему-то...
Не могли бы вы мне в аську написать? Номер моей аськи 247755118.
Буду очень признателен. Готов выразить материальную признательность за помощь в данном вопросе.
Если кто-либо ещё может мне помочь, буду также признателен.
пишем в личку
стукни еще раз
что то я не могу тебя добавить
  • 2 months later...
  • 4 weeks later...
  • 6 months later...
  • 7 months later...
Ребят, сделайте манчик по поводу прошивки этого свича, чёт не получается ничего...
Или может поможете без прошивки, такое вот в консоли пишет
ExtremeWare
Copyright (C) 1996-2006 Extreme Networks.  All rights reserved.
Protected by U.S Patent Nos 6,678,248; 6,104,700; 6,766,482; 6,618,388; 6,034,95
7; 6,859,438; 6,912,592; 6,914,905; 5,694,436
Version 7.6.3.3 [ssh] [base] by Release_Master on 01/10/07 04:15:06
System Serial Number: 02
Memory Size: 134217728 (128MB)
System was disabled by the user
Warning! System is not initialized, Limited command set supported
  • 5 months later...
обновляю ссылку:
прошивки для extreme summit 200/400/7i/48si/ и т.д.
<a href="http://depositfiles.com/files/hn6z3de90" target="_blank">firmware</a>
<a href="http://depositfiles.com/files/g1bmd4op6" target="_blank">pdf-документы</a>
По прежнему ищется последняя ветки extreme OS 7.9 для старой платформы :)
Благодарю за подборку, weldpua2008! А где вычитать про аннонс девятой подветки? В моих закромах последняя это 7.8.3b5.
http://depositfiles.com/files/bfpq6k4mz
По ссылке следующее (увы, что есть):
s400_boot51.bin This is the BootROM file version 5.1 for the Summit 400-48;
ngboot82.bin Универсальный бутлоадер для "i"-серии;
v783b5.SBxtr ExtremeWare with Secure Shell support. Summit i-series systems with at least 128 MB memory;
v783b5.SCxtr ExtremeWare with Secure Shell support. Summit 400-48t;
v783b5.Sxtr ExtremeWare with Secure Shell support. Alpine and BlackDiamond 6804/6808;
ExtremeWare_ 7.8.3b5_RelNote.pdf.
Последняя, доступная в eSupport - 7.8.4b1.
А вообще, если по-хорошему, то с этим "По прежнему ищется" вам надо обратиться сюда, и сделать как написано тут (только там про Foundry, но суть та же).
Edited by EgorFomin
  • 13 years later...
Доброго здравия всем. Некромансеры в деле _)
Вопрос не столько с новыми прошивками, столько со СТАРЫМИновыми.
т.е на серию x440-48, x460
 первой генерации
На коммутаторе залиты 15.5.2. и 16.2.4.5 ....  и bootrom 2.0.2.1
 в этом БутРоме нет команды config none  и unconfigure switch all  тоже нет
и восстановить админ дефолт пароль можно только заливом прошивки.. что жуть ... не уверен что даунгрейд прошивки поможет ... и что он возможен
Более старые XOS есть, а вот более новых нет. Ни БутРома нового  - ни ОСей-(
Есть у кого в закромах? или Бут версии повыше или ОСь для первой генерации x440-x460 (они же вроде одинаковые на любую модель)?
Edited by GREEN_Line_TAP
