Ситуация такая. Пользователи подключаются по pptp, туннели терминируются на cisco 7505. Вот конфиг:
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime localtime
service password-encryption
service single-slot-reload-enable
hostname pptp
boot-start-marker
boot-end-marker
no logging rate-limit
enable secret 5 xxxxxx
username admin privilege 15 password 7 xxxxx
username bill privilege 8 password 7 xxxxxx
clock timezone YEKT 6
aaa new-model
aaa authentication login default local
aaa authentication ppp default group radius
aaa authorization exec default if-authenticated
aaa authorization network default group radius
aaa accounting update periodic 10
aaa accounting network default start-stop group radius
aaa session-id common
ip subnet-zero
no ip rcmd domain-lookup
ip rcmd rsh-enable
ip rcmd remote-host bill 10.10.1.10 bill enable
ip name-server 101.10.10.53
ip cef
vpdn enable
vpdn session-limit 1
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
interface Loopback0
ip address 10.10.1.1 255.255.255.255
no ip route-cache
interface FastEthernet3/0/0
no ip address
no ip route-cache
full-duplex
interface FastEthernet3/0/0.10
description -=vlan pptp=-
encapsulation dot1Q 10
ip address 192.168.0.1 255.255.255.0
ip access-group 100 in
no ip route-cache
interface FastEthernet3/1/0
ip address 10.2.0.1 255.255.255.128 secondary
ip address 10.3.0.1 255.255.255.128 secondary
ip address 10.1.0.1 255.255.255.0
no ip route-cache
full-duplex
interface Virtual-Template1
ip unnumbered Loopback0
ip access-group 105 in
ip tcp header-compression
ip mroute-cache
timeout absolute 1440 0
no peer default ip address
ppp authentication ms-chap-v2 chap
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
no ip http server
access-list 1 permit 10.10.1.10
access-list 100 permit gre 192.168.0.0 0.0.0.255 host 192.168.0.1
access-list 100 permit tcp 192.168.0.0 0.0.0.255 host 192.168.0.1 eq 1723
access-list 100 permit icmp 192.168.0.0 0.0.0.255 host 192.168.0.1
access-list 100 deny   ip any any
access-list 105 permit ip any host 10.10.1.10 any
access-list 105 dynamic test1 permit ip any any
access-list 106 permit ip any host 10.10.1.10
access-list 106 dynamic test2 permit ip any any
radius-server host 10.10.1.10 auth-port 1812 acct-port 1813
radius-server timeout 10
radius-server key 7 xxxxxxxx
privilege exec level 8 access-enable
privilege exec level 8 access-template
privilege exec level 8 access-profile
privilege exec level 8 clear access-template
line con 0
line aux 0
line vty 0 4
access-class 1 in
transport input telnet
end
У пользователей каждые 10 минут рвется соединение. Т.е. висят пользователи:
#sh vpdn session
%No active L2TP tunnels
%No active L2F tunnels
PPTP Session Information Total tunnels 3 sessions 3
LocID RemID TunID Intf    Username      State   Last Chg Uniq ID
21    0     21    Vi4     x1          estabd  00:12:41 20
24    2355  24    Vi6     x2      estabd  00:02:05 23
25    32768 25    Vi5     x3      estabd  00:01:50 24
Так вот у x1 туннель не рвется, и 2-х других дисконнект каждые 10 минут. Если посмотреть на виртуальные интерфейсы то:
sh int Vi6
Virtual-Access6 is up, line protocol is up
  Hardware is Virtual Access interface
  Interface is unnumbered. Using address of Loopback0 (10.10.1.1)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100000 usec,
     reliability 255/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoVPDN vaccess, cloned from Virtual-Template1
  Vaccess status 0x44
  Protocol pptp, tunnel id 24, session id 24, loopback not set
  DTR is pulsed for 5 seconds on reset
  [b]Time to interface disconnect:  absolute 23:53:47[/b]
  Last input 00:00:08, output never, output hang never
  Last clearing of "show interface" counters 00:15:25
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 0 bits/sec, 0 packets/sec
  5 minute output rate 0 bits/sec, 0 packets/sec
     57 packets input, 3272 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     59 packets output, 2602 bytes, 0 underruns
     0 output errors, 0 collisions, 0 interface resets
     0 output buffer failures, 0 output buffers swapped out
     0 carrier transitions
to Konstantin Klimchev
+1
Проблема оказывается в DHCP-сервере. Т.е. клиенты получают ip через dhcp, потом создают VPN-подключение и выходят в инет. В dhcp время аренды по умолчанию стояло 600 секунд. Т.е. каждые 10 минут происходило обновление ip-адреса и из-за этого отваливался ВПН. Вот теперь думаю что с DHCP сделать, чтоб он так не борзел. Может время аренды побольше поставить?
+1
маршрут на dhcp сервер выдавать через dhcp-сервер же.
искать по:
option ms-classless-static-routes code 249 = array of unsigned integer 8;
и
option rfc3442-classless-static-routes code 121 = array of unsigned integer 8;
например здесь посмотреть:
http://www.linux.by/wiki/index.php/FAQ_DHCP_routes
