route# Posted June 23, 2009 Posted June 23, 2009 Суть проблемв такова. Попробовал поставить в качестве unnumbered интерфейса VLAN777 для вланов 77,78. Когда вставляю пачкорд в каталист в VLAN 78 и пытаюсь получить адрес по DHCP - какталист уходит в ребут. Если адрес прописать статикоц - все отлично работает. Где косяк? C3560-M uptime is 10 hours, 59 minutes System returned to ROM by bus error at PC 0x9CE8C4, address 0x0 System image file is "flash:/c3560-advipservicesk9-mz.122-46.SE.bin" Current configuration : 5951 bytes ! version 12.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname C3560-M ! boot-start-marker boot-end-marker ! enable password xxxxx ! username admin password 0 aaa new-model ! ! aaa authentication login default local aaa authorization console aaa authorization exec default local ! ! ! aaa session-id common system mtu routing 1500 ip subnet-zero ip routing ip name-server 195.xx.xx.15 no ip dhcp use vrf connected ip dhcp excluded-address 195.xx.xx.1 195.xx.xx.6 ip dhcp excluded-address 195.xx.xx.9 195.xx.xx.254 ! ip dhcp pool test network 195.xx.xx.0 255.255.255.0 domain-name test dns-server 195.xx.xx.15 default-router 195.xx.xx.1 ! ip dhcp pool 195.xx.xx.8 host 195.xx.xx.8 255.255.255.0 client-identifier xxxx.xxxx.xxxx.xx ! ! ! ! ! vlan internal allocation policy ascending ! ! ! ! interface Loopback0 no ip address no ip redirects ! interface FastEthernet0/1 switchport access vlan 777 ! interface FastEthernet0/2 switchport access vlan 777 ! interface FastEthernet0/3 switchport access vlan 777 ! interface FastEthernet0/4 switchport access vlan 777 ! interface FastEthernet0/5 switchport access vlan 777 ! interface FastEthernet0/6 switchport trunk encapsulation dot1q switchport trunk allowed vlan 25,777 switchport mode trunk ! interface FastEthernet0/7 switchport access vlan 77 ! interface FastEthernet0/8 switchport access vlan 78 ! interface FastEthernet0/9 ! interface FastEthernet0/10 ! interface FastEthernet0/11 ! interface FastEthernet0/12 ! interface FastEthernet0/13 ! interface FastEthernet0/14 ! interface FastEthernet0/15 ! interface FastEthernet0/16 ! interface FastEthernet0/17 ! interface FastEthernet0/18 ! interface FastEthernet0/19 ! interface FastEthernet0/20 ! interface FastEthernet0/21 ! interface FastEthernet0/22 switchport access vlan 571 ! interface FastEthernet0/23 switchport trunk encapsulation dot1q switchport trunk native vlan 571 switchport trunk allowed vlan 571,577 switchport mode trunk ! interface FastEthernet0/24 switchport trunk encapsulation dot1q switchport trunk allowed vlan 777 switchport mode trunk ! interface GigabitEthernet0/1 switchport trunk encapsulation dot1q switchport trunk allowed vlan 5,30,35,40,45,50,55,60,777 switchport mode trunk ! interface GigabitEthernet0/2 ! interface Vlan1 no ip address ! interface Vlan5 ip address 10.77.77.1 255.255.255.0 ! interface Vlan25 ip address 10.10.1.254 255.255.255.0 secondary ip address 10.77.78.1 255.255.255.0 ! interface Vlan30 ip address 10.77.79.1 255.255.255.0 ! interface Vlan35 ip address 10.10.0.254 255.255.255.0 secondary ip address 10.77.80.1 255.255.255.0 ! interface Vlan40 ip address 10.77.81.1 255.255.255.0 ! interface Vlan45 ip address 10.77.82.1 255.255.255.0 ! interface Vlan50 ip address 10.77.83.1 255.255.255.0 ! interface Vlan55 ip address 10.10.2.254 255.255.255.0 secondary ip address 10.77.84.1 255.255.255.0 ! interface Vlan60 ip address 10.77.85.1 255.255.255.0 ! interface Vlan77 description Test_Abon ip unnumbered Vlan777 ! interface Vlan78 description Test_abon2 ip unnumbered Vlan777 ! interface Vlan577 description Ua ip address 194.xx.xx.206 255.255.255.252 ! interface Vlan777 ip address 192.168.1.254 255.255.255.0 secondary ip address 10.254.254.1 255.255.255.0 secondary ip address 195.xx.xx.1 255.255.255.0 ! router bgp xxxx no synchronization bgp log-neighbor-changes network 195.xx.xx.0 neighbor 194.xx.xx.205 remote-as xxxx neighbor 194.xx.xx.205 transport path-mtu-discovery neighbor 194.xx.xx.205 description UA neighbor 194.xx.xx.205 shutdown neighbor 194.xx.xx.205 prefix-list 1 out no auto-summary ! ip default-gateway 195.xx.xx.254 ip classless no ip route static inter-vrf ip route 0.0.0.0 0.0.0.0 195.xx.xx.254 ip route 10.51.51.0 255.255.255.0 195.xx.xx.25 ip route 195.xx.xx.0 255.255.255.0 Null0 ip route 195.xx.xx.7 255.255.255.255 Vlan77 no ip http server no ip http secure-server ! ! ! ip prefix-list 1 seq 5 permit 195.xx.xx.0/24 snmp-server community xxxx RO ! control-plane ! ! line con 0 speed 115200 line vty 5 15 ! end Вставить ник Quote
Stak Posted June 23, 2009 Posted June 23, 2009 Через лупбэк сделайте и не мучайтесь... Вставить ник Quote
route# Posted June 23, 2009 Author Posted June 23, 2009 Через лупбэк сделайте и не мучайтесь... С удовольствием, но : C3560-M(config)#int lo0 C3560-M(config-if)#ip address 195.хх.хх.7 255.255.255.255 195.хх.хх.7 overlaps with Vlan777 Или я что-то не понимаю? :) Вставить ник Quote
Stak Posted June 23, 2009 Posted June 23, 2009 conf t int Vlan777 no ip add int lo0 ip address 195.хх.хх.7 255.255.255.255 int Vlan777 ip unn lo0 end ))) Вставить ник Quote
route# Posted June 23, 2009 Author Posted June 23, 2009 conf tint Vlan777 no ip add int lo0 ip address 195.хх.хх.7 255.255.255.255 int Vlan777 ip unn lo0 end ))) Тоже вариант. На данном интерфейсе есть абоненты у которых стоит шлюзом 195.хх.хх.1. Если я перемещю как вы говорите этот адрес на интерфейс lo0 все останется как прежде?И еще по этому интерфейсу цыска общается с маршрутизатором который смотрит в мир. Вставить ник Quote
ingress Posted June 23, 2009 Posted June 23, 2009 имхо, 122-46 кривой иос. у меня глюки выписывал. Вставить ник Quote
route# Posted June 23, 2009 Author Posted June 23, 2009 имхо, 122-46 кривой иос. у меня глюки выписывал. Какой порекомендуете ? Вставить ник Quote
route# Posted June 23, 2009 Author Posted June 23, 2009 122-44SE6 А где можно стянуть его? Вставить ник Quote
ingress Posted June 23, 2009 Posted June 23, 2009 стянуть можно на cisco.com из под гостевого аккаунта Вставить ник Quote
route# Posted June 23, 2009 Author Posted June 23, 2009 стянуть можно на cisco.com из под гостевого аккаунта Появилось вот такое уже : Cisco Catalyst 3560-24PS Switch, Release 12.2.50-SE1, IP BASE W/O CRYPTO Кто-то тестил ? И сколько он вланов сможет? Вставить ник Quote
t0ly Posted June 24, 2009 Posted June 24, 2009 conf tint Vlan777 no ip add int lo0 ip address 195.хх.хх.7 255.255.255.255 int Vlan777 ip unn lo0 end ))) Тоже вариант. На данном интерфейсе есть абоненты у которых стоит шлюзом 195.хх.хх.1. Если я перемещю как вы говорите этот адрес на интерфейс lo0 все останется как прежде?И еще по этому интерфейсу цыска общается с маршрутизатором который смотрит в мир. как вариант пересмотреть vlan/net - план Вставить ник Quote
route# Posted June 24, 2009 Author Posted June 24, 2009 conf tint Vlan777 no ip add int lo0 ip address 195.хх.хх.7 255.255.255.255 int Vlan777 ip unn lo0 end ))) Тоже вариант. На данном интерфейсе есть абоненты у которых стоит шлюзом 195.хх.хх.1. Если я перемещю как вы говорите этот адрес на интерфейс lo0 все останется как прежде?И еще по этому интерфейсу цыска общается с маршрутизатором который смотрит в мир. как вариант пересмотреть vlan/net - план Например ? Хотелось бы сделать все максимально прозрачно для пользователя. Вставить ник Quote
t0ly Posted June 24, 2009 Posted June 24, 2009 я имею ввиду подоумать над тем что бы сети и вланы магистрали не пересикались с сетями и вланами аксесса плюс вланы юриков не пересикались с вланами физиков. Вставить ник Quote
route# Posted June 24, 2009 Author Posted June 24, 2009 я имею ввиду подоумать над тем что бы сети и вланы магистрали не пересикались с сетями и вланами аксесса плюс вланы юриков не пересикались с вланами физиков.Тоже как вариант. Сейчас стоит другая задача. Нужно довести "до ума" задуманное. Вставить ник Quote
Den_LocalNet Posted July 11, 2009 Posted July 11, 2009 2route#, чем закончилась проблема с ребутом? Если решили, то подскажите пожалуйста как. Заранее спасибо. Вставить ник Quote
Den_LocalNet Posted July 14, 2009 Posted July 14, 2009 сам отвечу на свой вопрос - проблема решилась заливкой свежего ios Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(50)SE1, RELEASE SOFTWARE (fc2) Вставить ник Quote
route# Posted July 20, 2009 Author Posted July 20, 2009 сам отвечу на свой вопрос - проблема решилась заливкой свежего ios Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(50)SE1, RELEASE SOFTWARE (fc2) У нас полечилось на таком : Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(44)SE 1 Вставить ник Quote
